PDA
View Full Version : Forced Induction
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Lets talk Wastegate size for non priority Single Turbo
  2. Bearings for L33 rebuild
  3. Pseudo 4-port EBC (with a 3-port)
  4. New to the forum, turbo questions.
  5. What would you upgrade in this setup?
  6. Summit Pistons
  7. Truck turbo kit opinions wanted: Huron vs KB vs Trick
  8. More Boost on Pump Gas!!! 1999 Turbo Camaro SS Alky Controls Methanol Kit Install
  9. Turbo sizing and horsepower differences
  10. 5.3 turbo burning oil during boost
  11. Downpipe options for GMT800 99-07 truck turbo kit
  12. Procharger Bracket w/HD Tensioner
  13. Been a while, new best with 1.09 60ft
  14. Vortech V3Sci Belt Slip
  15. C6 Z06 new PB
  16. 1998 Camaro Rear Mount Turbo Failure - vid short removing before sourcing new turbo
  17. What's a good t6 turbo for a 5.3
  18. How much boost/power should my combo be able to handle?
  19. Aster bracket parts needed
  20. Methanol Injection Users Come In
  21. V-band vs Vanjen clamps for intercooler piping??
  22. Post divorce looking for more power
  23. Valve springs
  24. Bad night at the track
  25. Torqstorm New Gen 2 75MM Compressor Cover.
  26. Magnuson TVS Heartbeat 2300 on LS3 questions
  27. S369 on a mild 5.3
  28. Turbo Exhaust Options
  29. IAT sensor not fitting into charge pipe “On3 Performance kit”
  30. LSA blower build
  31. LS3 lowram question?
  32. Good intake for Procharger D1X?
  33. Turbo in swap suggestions
  34. Vs7875 is there a s400 equivalents FIS S478/82 ???
  35. Alternator relocation with turbo steup?
  36. Nova Upgrades and new PB
  37. 98mm 403ci
  38. Is this possible?
  39. Building a turbo Suburban
  40. Non-Resistor vs Resistor plugs
  41. GM 3.5 - 4 Bar MAP sensors?
  42. High lift cams and boost?
  43. Leaky V band conn.
  44. Turbo 388 Cam Thoughts
  45. Manual trans users, how is your boost control set up?
  46. What camshaft are you using in your boosted application?
  47. Puller Fans on Huron T6 V3 possible?
  48. Oil burning on hard braking, any easy fixes?
  49. Fuel pump - now and later
  50. F1a-94 vs F1x
  51. Turbo air inlet hose?
  52. Vacuum leak
  53. Catch can advice needed
  54. Are these pistons suitable for boost?
  55. Silverado Holley Terminator X mounting location?
  56. VSR 62/62 size
  57. Headstuds 1/2 Inch vs 625 for a 5.3
  58. Anyone used a diesel resonator for a muffler?
  59. Anyone do a "roll your own" CO2 setup?
  60. 2000 Trans Am build advice
  61. Best Fuel Rail For LSA SC Fbody
  62. Street 5.3 turbo, the BEST setup
  63. SNOW vs ALKY Control vs AEM - water injection systems
  64. I know every cam is a turbo cam but....
  65. Is Cut-ring the best HG for Boost? 1khp+ Iron 6.0
  66. Boost/Terminator X
  67. Help me figure out my boost issue
  68. Boost rated vacuum caps?
  69. 417c.i./D1X rwhp/tq projections
  70. rich AFR when crusing
  71. Fuel Pump limitations 2009 Corvette base
  72. Dual fuel pump control
  73. Whipple 2.3 Bypass orings/sealing
  74. STS GT67 Turbo - rebuild kit?
  75. 20 psi 402ci - TFS 225 or 235 Heads – Head Gasket Implication
  76. Strategies for minimizing Turbo LAG
  77. Huron Speed...APS style TT kit..anyone have one on their 98-02 Fbody
  78. P1SC Procharger only making 5psi on 5.3?
  79. Who wants a turbo…
  80. Turbo lq4 rings?
  81. 6L and S467 turbo?
  82. Is my pcv routing good for 700hp?
  83. intake air temp
  84. Leaking vortech?
  85. S&B velocity stack plus Filterwears
  86. Lnc 2000 and no lift shifting?
  87. Hood Exposed Turbo C5 LS1
  88. Hood Exposed Turbo For C5 LS1
  89. Pusher fans
  90. Zo6 cam worth it? I know I know...again
  91. Where should wastegate dump enter downpipe/dump?
  92. Turbo output VS Manifold pressure difference in RPM range
  93. Feels like misfires under boost, some popping. No codes.
  94. quick shout out to all the wizards
  95. Amazon cheap borg s488 turbo
  96. Slimline radiator fans, what are you using and how many?
  97. Slp tvs1900
  98. Turbocharger recommendations for my C5 Corvette
  99. Maintenance any different than NA
  100. PVC and Turbo help
  101. Catch Can: 2 Port sealed vs 3 Port- vented
  102. Huronspeed 4" bumper exit for v3 AC F-Body kit questions
  103. How much water can you inject?
  104. Crankase venting vs PCV "valve" vs BOOST
  105. Trouble building boost
  106. Blowey to no blowey
  107. I said I wouldn't, so....
  108. AirMass vs Manifold Pressure : Expertise welcome
  109. Big injectors and idle quality
  110. LSA won't make more boost
  111. Anyone run the Borg EFR turbo/s?
  112. More knock
  113. Speedmax innovations?
  114. Turbo: Blanket or run NAKED ?
  115. Forced Inductions turbos turbine options??
  116. BOV for dummies ?
  117. Vacuum block source on engine?
  118. Wiseco Boost Piston Issue
  119. Is this normal for high boost E85?
  120. Looks like I have some retuning to do
  121. Proform brushless cooling fans?
  122. Dart 402 block, 10.5 compression, Tooley Trick Flow cnc heads, F1a blower..
  123. Thoughts on this turbo?
  124. Have to build custom downpipe/dump. Thoughts?
  125. Boost reference "Manifold" question.
  126. CAS Twin turbo kit owners
  127. turbo 4.8 ET guess
  128. 120lb vs 80lb injectors
  129. How would I got about boosting an L33?
  130. Turbo manifold for 2nd gen. LS swap
  131. Newbie needs answers on Turbo selection
  132. Rolling 2-Step Stops Working Over 25mph?
  133. Titanium for hotside piping?
  134. ls6 intake vs 102 fast.
  135. Meth Tanks?
  136. Pro Charger F Body low horsepower boost leak?
  137. My '98 Formula Turbo Build Thread
  138. Anyone Run a Huron Speed 4th gen f-body APS extreme with 408
  139. AC 4th Gen condenser Placement
  140. Procharger Race Valve and FPR questions
  141. GM or Delphi IAT sensor # ?
  142. Huronspeed top mount alternator users, in here
  143. Powerstroke 6.0 turbo
  144. belt grip spray
  145. PWM a fuel pump
  146. stock 5.3 boosted 5psi injector ??
  147. 6.0 LQ4-Boost Build Swap
  148. Near fresh lq4 losing oil pressure with rpm/boost
  149. High torque low RPM rods question
  150. 10.8 afr safe ? Stock 5.3 on 5psi
  151. Turbo Pressure Gauge MAP/EMAP
  152. Turbo 4.8
  153. Help me choose a turbo 6l truck
  154. VSR 68/62 DBB Gen3
  155. 1998 LS1, unleashing the whip of god
  156. 3.97@185 with a hydraulic roller 388 LS. First to the 3's!!
  157. ok guys what should it make
  158. Radiator fan for turbo
  159. Supercharger "kit" for 2016 5.3 silverado 1500
  160. Head selection for a 402 with LSA
  161. 4.8 turbo setup for beach/show jeep
  162. stock 5.3 turbo set up
  163. What gear ratio are you running with your M6 turbo combo?
  164. do you run heavier oil when running a turbo?
  165. Turbo/Supercharged Engine Rod Legnth
  166. Turbo drain, I tried searching I promise!
  167. pipe sizing for a twin rear mount?
  168. Custom built A2A ICs
  169. Timing and AF on spool M6 5.7 LS1
  170. Twin turbo cam
  171. Anyone wanna talk twin turbo sizing...?
  172. Help with Re-Pinning a MAF connector
  173. Reality check - VSR 67/62 single for LS1
  174. 416 SC Piston To Wall Clearance
  175. 4.8 with aps extream kit boost questions/advice.
  176. 2 wastegates 1 Mac valve hose routing
  177. D585 coils and dwell time
  178. Max rpm built 5.3?
  179. Corsa sport cfm rating?
  180. Critique my exhaust idea
  181. 1998 Camaro LS2 Rear Mount 75mm 6MT - launching, BOV and acceleration clip - 27 secs
  182. Aeromotive Eliminator Pump - Boost Referenced
  183. Finally back together, but someone stole my BOOST???
  184. Where to place wastegates?
  185. Chat GPT says it can spec my LS camshaft no problem!
  186. Oh great minds of LS1 Tech critique my build / advice / etc.
  187. Should I swap the cam? PDS with a turbo cam currently
  188. First Timer Building a Forged LQ4 for E85 turbo build
  189. Blast from the past Ofi turbo
  190. Plug read
  191. Noob to turbo setup
  192. Head gasket for twin turbos
  193. .68 AR too small?
  194. need help with build
  195. Huronspeed T4 truck manifold users - What exhaust do you run?
  196. Comparing Wastegates: quality vs PRICE
  197. Magnuson Heartbeat in LS3 powered F-Body?
  198. ****og aps/ huron speed tt peeps***
  199. Been turbo for a couple years now and....
  200. Terminator x max multiple boost targets
  201. No brakes after WOT, turbo car
  202. I've got a really good bad idea - Oil Less Turbo!
  203. 1968 Twin Turbo Camaro Build
  204. EBC duty cycle.
  205. Anybody running TFS225 heads?
  206. Convert -12 to -10 AN
  207. vs racing g45 (76/89) too big for my set up
  208. Turbo M6 guys - Does your T-56 live with big power?
  209. Swapping Twin T3 6265s for T4 6266/6466 on LS3
  210. Milling 317 heads - Worth the compression or waste of time?
  211. David Vizards take on "turbo cams" (90% are BS)
  212. Water meth injection diy setup questions
  213. EBoost 2 Ramp by Time help
  214. Torq storm supercharger
  215. Best turbo on market ?
  216. Turbo kit
  217. Which procharger = ysi??
  218. cam choice
  219. Wanting to build 416 for boost
  220. Any easy/inexpensive coatings for turbo truck manifolds?
  221. Single turbo 402 Landcruiser build
  222. New Turbo build 04 RCSB Silverado
  223. Best turbo size for power/efficiency for 4.8l
  224. FPR and BOV shared boost/vacuum reference line
  225. Vortech LS Swap alternative brackets for belt slip
  226. Turbo LS tuner in Texas
  227. Should I go catless on a pd blower car?
  228. 1998 Camaroi LS2 75mm Rear Mount Turbo Donuts/drifting on grass video
  229. Basic Turbo Question?
  230. Huron Speed turbo oiling
  231. Ideal turbo?
  232. ls2 402 going boost
  233. Boost cutout vs vacuum cutout
  234. 3 inch collector to 2.5 inch crossover
  235. Twin scroll questions
  236. 2006 silverdo supercharged stock head bolts boost
  237. LS2 single turbo newbie
  238. ScottStaypuff's quest for more power everywhere...
  239. Done 4.8L boosted to 26 psi and 1203 hp
  240. Going Procharger...
  241. Little help with a little verfication
  242. New project, Freemont.
  243. 2007 ls 6.0 questions
  244. LQ4 Build for 3L Whipple
  245. Most compression you’d run on boost
  246. Analyze my spark plugs
  247. Looking for a ls3 turbo tuner/tec near Eugene/Portland
  248. Ls2 396 Stroker... Boost?
  249. Help With CR on my gen4 6.0 with LSA
  250. Turbo Firebird IAT's/heatsoak and license plate cover
