View Full Version : Forced Induction
- piston options for a "mild build" are forged a requirement?
- Anyone ever made/tried front tag mod to make it swing/let air go to IC?
- 408 s484 missing power over 15# boost
- biggest affordable twin turbo intercooler?
- build help 4.8 stuff with stroke
- On3 Billet 7675 BMF
- basic advice for a turbo'd higher reving 4.8
- 70 Nova - Turbo ls, under trunk mounted radiator opinions wanted
- 2015 camaro V6 to Ly6 swap
- Can i add a analog signal to retard the timing on E67
- S475 Exhaust Housing Options
- Huron T4 A/C Kit Install Pictures How Close to Radiator
- What intake is BEST for a LS turbo motor?
- Will a 317 exhaust manifold work with a ls3 head
- Huron Speed Black Friday - Cyber Monday Sale INFO
- Running a bypass valve AND BOV on procharger kit?
- Can someone take a peek and see if all looks good in the tune?
- Edile Brock e force supercharger
- 2 walbro 450 in tank set up. Check valve question.
- Who is the denmah package for?
- 7665 turbo with stock 5.7
- Isky triple 12 in a 383
- FI 383ci, Dual Pump, bigger lines, regulator boost referenced, PIG RICH!! Advise.
- 10psi+stock longblock track results...
- Block options for boost
- Oil coming out turbo under boost
- 93 octane in a tune that's for full time E85.......
- Pump fuel vs race fuel tune-ups
- Need advice on LS9 supercharged 6.0 build
- Hooker turbo manifold
- Cheap 4.8 turbo build
- Vs racing Billet s480 t6 or t4?
- Bell vs Garrett IC Core... yeah yeah
- thinking of changing things again. help me decide.
- 2016 Cadillac CTS-V w/ Whipple Supercharger! 748RWHP on PUMP GAS!!!!!
- Cable driven fuel pumps
- Too small turbo or too large a camshaft
- Turbo or Supercharger?
- Location for an accusump on a 4th gen
- Application
- BTR 227/244 Cam and a PT7675 in a 5.7L?
- Application
- S400 90 degree compressor outlet pipe
- 2000Hp+ LSX Twin GT50-88s
- What will this take to get 1000hp?
- On3 1st Gen Kit???
- electrical problem
- LS Gurus, Please Come In. I need Help.
- LSA Supercharger in 4th Gen
- Gearing for swap.
- BBC and turbos
- Should I change turbo turbine housing ?
- LQ4 swap, which turbo and which cam?
- Finally got the D1SC to the track...Like a walk in the park
- Dual AEM 380LPH and E85. How far have people pushed them?
- New personal best
- STS PCV on lt1
- At what point forged crank (5.3)
- From Nitrous to ProCharger F1A94
- S400 turbo on huron v1
- Custom Intercoolers build to order
- Boosted E30
- GTOv2 - Going twins this time, sizing help!
- Which heads to upgrade to....before turbo kit goes in.....?
- CXracing SBC header
- Boosted C6Z06 Texas Mile
- 1999 FRC Pro Mod Style TT Kit
- Anyone have a base tune for 98 ecm boost efi live
- What are the important Add-on gauges for a forced induction set up
- What are all the notch guys using for frame strength?
- 76mm turbo 65 Malibu wagon.
- Thoughts on the Proflow injection plate.
- Newbie questions... Vs racing GT35 turbo and turbo build.
- Just when the weather gets good.....
- Starting ANOTHER turbo build!
- New YouTube Video! My Turbo Trans Am on the dyno. Do I still have 1000 Horsepower
- 406 bbc or 496 bbc
- High compression (11.1+), Boost, 93+ Meth, Timing, stock bottom end
- DIY high mount alternator
- LS9 3 bar MAP on truck intake
- Whipple Supercharger on LS375/525
- Pump gas LS twin turbo buick
- best boost piston
- Huron Speed - Complete kit under $3k NOW AVAILABLE!
- LS6 vs Ebay Fab intake N/A and Boosted, dyno results.
- procharger chevy 2500
- Turbo car gearing for 1/8 vs 1/4
- EMUSA wastegate spring Q
- H Beam Callies Rods. How fast have they been? HP on turbo e85?
- Fuel Sys & E85
- Keep Breaking Ringlands 6.0/s475/T56. Tune/Scan Attatched
- Is my high stall (3200-3400) causing idle and stall issues? Video attached
- LS3 84mm Turbo, sluggish cold start, won't start at all when warm...
- Thoughts on what the heck my TPS is doing?
- need help random no power
- Still running hot, ProCharger 416 ci.
- Help with turbine ar sizing for rear mount
- Dyno Tuning for Twin Turbo LS6 in Southern California?
- Twin s366 or twin vs 7668 .96a/r
- Boosting the old CTS-V ... stay with LS2 cam?
- 340lph, turbo limits
- G body, El Camino turbo cars-down pipe
- T4 Turbo supporting 1200-1500 WHP???
- Intake for Procharger D1
- Boost Referenced FPR help
- Piping kits/Piping sources?
- Huron coming: what’s else should I install while in it?
- Turbo JY 5.3 Camaro 10.1 @ Mile High Bandimere
- turbo LQ4 for towing c10
- good dyno tuner for megasquirt near chicago.
- New Best 1.159 (60ft) 3.04 (330) 4.612 156.85mph
- Supercharged exhaust size
- Switch to PG or put a brake in the 80E?
- Attention huron speed
- Build Thread '02 C5Z AA Supercharger & HPA / 629whp and 516tq
- Running out of fuel
- Magnusson belt tensioner
- Almost burnt up my 255 with 10lbs
- Deep in the 8's!
- New personal best. 69 camaro ss 9.35@147
- quick tool question
- "hard coated" blower pulleys
- Turbo Cars Making 800+hp - What Plug Wires?
- Huron Speed Gen 5 single turbo kit
- "How Original".......Billet S480 Fox Body
- wiring a 5.3 in a third gen camaro
- Need Cam Recommendation for TT 416
- Do you have detroit turbo in stock
- G-Body - Ebay Headers down and forward possible?
- First turbo build, had a couple questions
- put 317s on do I need retune?
- Opinions and ideas needed please
- Winter project ideas
- Heads and Cam for LSA Blower
- Multiple fuel pumps and check valves
- Dyno Results!
- Thinking of Ebay-Turbo over HCI
- Nova going in under the knife
- new best with 5.3 micro build.
- Boost gauge not showing boost?
- Pulled the trigger guys :)
- Muffler Recommendation
- 5.3 or 6.0 Turbo Build for Foxbody Swap
- flowtech vs cam motion. custom solid roller
- Huron Fbody turbo kit who is running a restrictor or pump?
- bigger intake on 1500 novi
- a ton of questions for 65 chevelle build . hope i can get it all in one post.
- Piston options for ~600 rwhp
- Dyno didn't go so good, HELP
- Btr stage 1 turbo cam with stock stall
- Boost reference?
- Valley Cover - Add 8 bolts instead of plugging DoD Towers
- Fuel recommendation
- Valve Cover Breather Bung Location
- Anyone have the Racetronix Dual Fan Harness Install sheet?
- Lmf 2008 5.3l
- Which map sensor for meth injection (boost leash or 3 bar )
- Scavenge pump recommendations
- Jon Capizzi new 1/8 SBE record
- 216/220 .560/.560 vs LS9 camshaft - which is the best for a budget?
- 317 to 243s by milling ?
- Borg Warner s400 compressor housings
- Turbo 5.3 sits at 5700 in high gear.
- Twin turbo with two widebands. One is lean. Video attached. Help
- E85 vs E98
- 4.8 s475 rcsb
- Compressor Surge w/ BOV?
- S472 too small for rear mount LS3?
- Holley Sniper Manifold
- Turbo LQ4 Mazda/Ranger build thread
- Holley Sniper Intake
- Huron Speed V3 A/C T4 Single Turbo Kit
- Intercooler pipe size with 2 intercoolers
- 06 5.3L "Hybrid motor"
- Ls 6.0
- 87 TA single turbo 5.3 build
- turbo drains
- Too much for the street?
- Goertz1 Sheet Metal Intake Manifolds
- when is a deka 80 truly done on e85
- Fully Built LQ9 Missfiring/Stalling/Sputtering/Backfiring At Any TP when warm
- Home ported LSA Heads
- What Rocker Arms? going to Solid roller
- F1r on a 2002 fbody Help
- “No prep” drag radial guys- what tire?
- L92 heads on LQ9 block
- LS3 head gaskets and ring gaps for boost
- Brian tooley, lil john camshaft help
- Blow-by?
- Turbo failure with pics and questions.
- Procharger i-1 question
- Aem wideband 30-4110 / hptuners - erratic a/f numbers all over on scanner
- Pics of what happens to your transmission after a sudden driveline failure
- Looking at Procharger kit, how does this look?
- At What point would you "Build" a 5.3
- Boost referenced FPR
- Boost drop twin turbo
- T6 front mount swap
- Supercharger for bracket racing
- C5 corvette single turbo kit
- Going turbo ?s
- How much oil - boosted w. stock pans
- Procharger FMIC bumper cutting
- Turbo exhaust header studs or bolts
- Meth Injection
- is there any gain in headers vs manifolds in the 600-700hp range
- Low boost tvs2300 new install
- help for a newbie on a 2500HD build
- Turbocharger + road racing - How to keep temps under control??
- What's everyone using for an oil pan? Having pressure issues at the track
- Turbo and PCV?
- Whats the best bang for buck turbo these days?
- E85 vs 100+ octane.
- Inline oil filter for twin turbo setup, with new engine??
- Chassis is working good, MWC stuff FTW
- 2000 SS D1sc Map/SD question
- Can I make 600+whp on a iron 5.3 lm7 boosted
- 4.8 76mm 7675 vs 67mm
- Quench area with boosted engines.
- tire advice plz
- vic intake over holley mid ram with boost
- 7.0 .. 427 ... where are the limits ?
- Looking for good gear choices
- Twin Turbo 4.8 Results / Single 80mm Build
- Edelbrock Pro Flow XT Fuel Rail HP limit
- 5.3 tensioner relocation?
- 1000 or no????
- C6 manifold turbo build
- Turbo cam, 9ish:1 non turbo 6.2 - a dog NA?
- IAT temp with D1SC / D1X
- FITech Ultimate LS Kit
- Yank PAS 3400 stall opinions needed
- Turbo Intercooled e85 Timing
- stock 5.3 bottom turbo choice
- Turbo options
- Boosting Dorman Ls2 intake
- knocking sound around supercharger
- converter flash on twin turbo 5.3
- Boosted 454 LSX?
- Restrictor or not on YSi Billet SC
- One Bent Pushrod/Valve. Any ideas???
- 4bolt vs 6bolt lsx 1000/1100rwhp
- Well she's to get tuned
- 5.3 vs. 5.7 vs. 6.0
- Spent lots of money.. still got problems. Need some help guys
- Crown Vic, 6.0, holley dominator, twin 70s, JFR cam, denmah tuned, 9.64@141
- Blow Through vs EFI Valve events
- on3 78/75 to borg 80/83 results.
- Jet Boat Procharger bracket question
- Going for twin GT35's. Hoping to use two stock passenger side manifolds...
