View Full Version : Forced Induction
- Twin Turbo kit almost avail!
- Injectors?- QUICK RESPONCE PLEASE...
- ls1 motorsports build up
- help with 2 step install....????
- Advice/Opinion on Turbo Build-up
- LS1 Motorsports Single Turbo Update:
- Best gears to run with a blower?
- Whats the highest psi you can run on a stock bottom end with ati procharger?
- What gears are you turbo guys running?
- fuel pressure
- Any updates Harlan?
- FTRA... 1/4 Times
- ATI Fuel Questions
- ATI Procharger on my LS1
- Best low impedance injectors...
- Incon Specifics
- need help I'm having some issue.
- Paging Cablebandit
- Found 110 unleaded @ $3.50 a gallon!
- turbo or supercharger???
- is 13psi of exhaust presure as bad as it sounds?
- Coolant on a turbo
- Both headers into one turbo...
- What do I need?
- LS1 Motorsports
- Might be looking for a turbo and an intercooler soon
- Would you consider this false advertising?
- question about 8rib & cog setups?
- WTF!! belt broke off!
- what kind of switch for harlan 2 step?
- Weekend supercharger sale!
- help me build best FI C5!!
- Turbo setup to smoke single supras?
- smokinhawk...call my house
- Need help with My ATI Procharger
- ATI got my blower yesterday.
- What is the Grand Total cost of Global West Performances Stage 2 ATI kit
- I need information
- Whipple oil?
- Need some info/advice for my build
- 12psi of boost on stock crank?
- Fuel Injector Flow Rating Help Needed...
- TUNING QUESTIONS
- changing wastgate spring
- Super chargers for sale
- Researching Blowers
- ALKY INJECTION ON A VORTECH SUPERCHARGER
- Harlan.....!!!
- attention vortech owners !!!!
- Vortech Supercharger installation
- Looking for opinions....
- 6.0L heads worth it?
- T-Trim LS1 Kit
- Turbo Guys - What Cam?
- torque converter?
- Paging SmokinHawk
- Magnacharger or Eaton
- Can't believe no one wants my engine?
- paging Rob Raymer or anyone familiar with the ls1turbokit
- blowing off MAF tube on turbotech kit...?
- what might i expect adding exhaust to a blown and stroked motor
- dyno runs
- vortech supercharge?????? pleas???...
- Blower Cam
- superchargers for a 2002 ls1
- should the cats go
- LS1 Supercharger
- Boost for the poor.
- bad news....motor out AGAIN
- Monitoring Detonation
- Anybody know the weight of one GT35 turbo and one Intercooler?
- Is it smart to buy a used turbo kit?
- Finally seen my hottest temps ever with the Procharger
- harlan
- Converter for 99 Z with Vortech #9
- blown bitch w/problems
- air/fuel gauge
- Everybody with a supercharger and headers please read.
- Turbo 60fters
- Hugger Orange SS ATI BOV ?s
- Dyno numbers so far - 672.9hp/618.6 torque
- Help Installing Boost and Fuel Gauges
- T-74 Q Trim Turbo For Sale....
- raising timing with lower boost?
- For those interested in Blow off valve for S/C
- turbo kit
- Lingenfelter TT vette
- Ball Bearing LS1 Turbos
- Incon TT dyno...
- Fuel pump ?
- LS1Motorsports Turbo Kit (pics)
- Incon parts and a few questions
- FTRA Install
- innercool / radiator ???
- ATI Procharger 7psi with 112 LSA cam?
- Procharger low output probs. Black LS1 T/A can you think of anything?
- Any Turbo's For Sale?
- Best Place to Buy T76 w/o Kit?
- Paging Harlan - Timing Question
- Best Head Gasket for 10psi
- Hey Mike (black ls1) Jason (GWP)screwed my head today
- Need help with a supercharger
- Incon twin turbo sites or other
- Gas mileage amazing! what's yours?
- Whats wrong with my Procharger setup?
- Dare I say, perfect daily driver.
- How much is too much?
- Headers???????
- blower guys ...................help
- Turbo Technology kit VS LS1 Motorsport kit
- New ATI #s
- procharger crank pin kit has to be cut down to work on vortech.
- halltech tt
- Another cam question.
- ATI Front mount intercooler?
- NO Boost and no ET improvement
- I noticed some other Top Machines tuned by GWP
- WOW I love UPS
- Did somebody ask about a dyno? 697.5 710.1
- Paging Rob Raymer
- Stock Fuel System + Injectors - Support How Much HP??
- What turbos come with stage 1 incon system
- Lowering CR Question . . . Guru's Within
- can you replace the bypass valve on the G trim with a BOV?
- How much boost is too much?
- Just finished the C5 Ati 7 psi installation.
- SC Fuel question
- Need information, please.
- Process of building engine
- Calling Harlan...Turbo Question
- Does anyone have any idea if the magnuson will fit on an f-body?
- 9.5's with only 10PSI of boost (GN)
- 671.8 RWHP / 597 RWTQ 383 and still tuning!
- 1991 tpi camaro z28
- Vortech crank pulley removal?
- my new boosted engine set up
- Count down to fire it up
- SC reliability which is best?
- Weird thing happening to FP
- Ported T/B with a supercharger?
- Incon TT kit Picture's ?
- Incon Stage II computer software
- Dyno Queen Rides again, new numbers
- Need Inline pump
- Custom ARP Head Studs- Who's interested
- ATI guys need some advice/mike (black ls1 t/a) and others
- ATI Supercharger Install Questions?
- Help with ATI #s
- blower cam?
- People who run Prochargers on their LS1......
- Shes BAAAACK
- 422 blown or turbo possible?
- ? on Electronic Fuel Pressure Gauge
- Newbie question on compressor maps...
- How much rwhp do you think I have now??
- Ordered a new scavenge pump...
- Turbo Oil System?
- Compressor Map for ATI Procharger?
- Fuel Pressure Regulator
- 420 RWHP on a A4 '00 T/A with all the bolt ons?
- EGR and boosted cars
- CAS rising rate regulator. NEED HELP!
- Thinking of Supercharger, Which is the best in ur OP??
- Compression Issue--LS1
- over heating after WOT??
- FP ?
- Magnuson owners, come inside?????
- anyone need my 42lb injectors
- Need some help.
- 6.0 L truck heads worth it on a FI application?
- New C5 Kits.. ATI D1-SC vs. Vortech V-2 SQ??
- mti ported throttle body ok with charger?
- vacuum/boost gauge install
- Look what I found!
- Stupid question about TurboChargers....
- I emptied the rest of my wallet today.
- Incon number - Disconnected?
- when do you o-ring
- help me choose a cam
- Ati/C5/Damper help.
- If you pay full retail, what is the cheapest Supercharger system for an LS1 Camaro?
- need help, will 28x 10 fit ?
- excessive crank pressure fix
- Can you run a procharger with nitrous?
- Turbos go back on tomorrow ;)
- Who owns....
- anybody running nos with turbos
- who all is running a turbo?:
- I just recently installed a ATI 4psi kit. Need help.
- went to the track with new motor ......results....
- build a blower motor
- ATI 5psi kit on a 98 Z
- racetronix pump is in
- I want a turbo! Who can hook me up...
- Ideal sized turbo for a single turbo application
- So would a 50 shot on top of the Magnuson work?
- Fuel systems
- is there a supercharger for me?
- TURBOS
- LS1MS STAGE I TURBO
- What are your MAP and MAF readings?
- Looking for twin turbo manifolds....
- 100 octane aviation fuel
- smallest pulley for the P-1sc-h?
- Any whipplecharger users out there?
- interesting article on supercharging
- Is this the fastest stock bottom end force induction car in the country!???
- max boost 15psi but at what compression?
- It has been 4 years for the LS1.. Who has a reliable FI setup?
- Anyone talked to Tom Porter lately?
- D1-SC & Stock SB @ 700rwhp, 11-12psi
- what's the most boost i can run
- BBK 80mm.. worth it?
- White smoke out of my intake? But none out of my exhaust?
- ATI & Fresh Air Valvecover Intake
- Getting closer
- Need a FPR guys
- Roots vs. Centrifugal
- Considering forced Induction with a 422
- Finding a Vacuum leak under Boost?
- Gas Mileage with FI?
- Force Induction Tuning
- ATI guys I need some help, please!!!!!
- Port match LS6 Intake
- Blowing hoses
- Who's still out of their Incon kit??
- anybody with vortech have problems with crank pulley bolts
- Qustion for those runnig FI.
- mr. raymer, im ready for that kit!
- ATI kit on lowered car???
- Another interesting product(timing controller)
- PLZ POST PICS OF VORTECHS, SPECIFICALLY WITH ON AFTERCOOLER! THANK U
- Questions on Rob Raymer's Turbo kit???
- Downside of running high octane gas?
- how to control boost spike
- One more twin turbo on the street.
- magnacharger?
- Quick connect to -6AN adapters LOOK!
- How much compression can you drop from porting heads?
- boost controllers and programming the pcm
- In-Line Walbro 340 vs. Aeromotive 1000
- Is there such a thing as too big of an intercooler
- Is 2 Garret T3's enough for an LS1?
- Where is the best Forum for LT1 Turbos/SC's?
- Whats safer??
- 73 cc chamber ls1 heads -pics
- Underdrive Pullies with a S/C
- how cold and what type of plugs?
- Have SC, What Will It Run?
- Lets make a streetable 346ci forced induction setup.
