PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 [164] 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. H/C ZO6....possibly going F/I ????'s
  2. Best true bolt-on FI Kit?
  3. 408/stock heads/88mm turbo at 24 psi = 920 rwhp
  4. Pukes
  5. where do you guys start to tune your boosted setup
  6. Install Vortech supercharger how long?
  7. Twin Turbo dyno results....
  8. Vac source for boost gauge
  9. ways of spooling a turbo faster
  10. Installed procharger and no boost
  11. Dyno Numbers
  12. Custom rear mount guys what oil scavange pump ?
  13. Trt Turbos
  14. Placed an order on a LME 408
  15. should i turbo an LT1 or LS1. (limited on $$$)
  16. Intercooler over Meth for STS??
  17. MTP T70 Exhaut AR ?
  18. Rear Mount, How does it affect sizing
  19. Found my boost leak
  20. Best engine parts for FI Type Engine
  21. reliability questions
  22. FI M6 guys come inside!
  23. any body tried the Evans water pump to help cool your boosted setup
  24. Max Spark Advance @ 7-8psi???
  25. ATI ProCharger Friday the 13th Sale at Exotic Performance Plus!
  26. Wanted - 2002 Pontiac Trans Am for twin turbo system development
  27. do prochargers like peak timing before,right@,or after peak TQ
  28. Found oil in charge line of STS Turbo
  29. cant find sc pistons for 3.908 bore?
  30. 8 rib belt question..
  31. Roots Type for the ls1?? Manifold base plates?
  32. Which piston? Pick one
  33. Post your dyno #/ ET/ MPH
  34. How do these bearings look?
  35. Making a custom Turbo setup, Tell me what else i might need!!
  36. Lighting supercharger????
  37. how cool is meth???
  38. STS guys (come inside)
  39. stalled a4 turbo
  40. How restrictive will stock heads be with a procharger D-1SC
  41. Max power out of T76??
  42. Looking for specs and info on use of restrictor plates for Vortech S-trim
  43. procharger timing...
  44. intercoolers
  45. Video of me breaking my car
  46. Boost Time????
  47. hummer h2 with sts turbo , need help
  48. Hope I picked right!! ordered a new blower cam today
  49. Help me get a parts list for a twin buildup
  50. Car breaking up at 5,500 RPM Please HELP
  51. Help me decide
  52. Twins completely plumbed
  53. Harlan 2 step install question
  54. TE44 get the boot hello new turbonetic turbos
  55. finding how much timing i need on a d1sc car
  56. Anyone need a 71MM??
  57. high hp turbo timing/fueling help
  58. Procharger guys with Alky injection
  59. Which is Better F2 or 88mm Turbo
  60. I got the wrong pistons in my shortblock, can i change the combo to make these work?
  61. Magnuson Supercharger's 3/36000 Powertrain Warranty Info
  62. more head gasket fun!
  63. guys with relocated alternator come in
  64. What Motor Build should i look into?
  65. Machine gun before full boost?? turbo
  66. D1SC Back from the Dyno!
  67. Is anybody running the intercooler spray bar?
  68. granatelli with turbo?
  69. oil return ???? on STS kit
  70. Head Gaskets
  71. T-rex inline pump on stock engine?
  72. Turbos and catbacks?
  73. OFI will take orders agian begining of NOV...
  74. where to buy stock 317 heads?
  75. having a hard time idling... i have a log and a bin
  76. DTE/APS Twin Turbo C6 Corvette Results- 10.89 @ 129
  77. lifters
  78. Best turbo for Corvette
  79. electronic boost controller
  80. Not forced induction but I thought you guys could help.
  81. bout to start a turbo project
  82. Fuel flow requirements
  83. Search dead/Corvette single intercooler
  84. Fast intake worth it on a turbo setup?
  85. Replacement sensor for DJ Wideband?
  86. PurEvl track times
  87. Is it easy to reach around 500rwhp with P1SC?
  88. twins and intake dyno....(long)
  89. Help!! car stumbling on dyno
  90. best cam
  91. Got some new dyno numbers
  92. pistons and rods
  93. Stock ATI 16" Camaro fan needed.
  94. LS1TA guys with OBX intercooler have ??? about front bumper
  95. test runs and some loading up questions?? Turbo guys?
  96. What is normal idle vacuum?
  97. New best and then BOOM ***videos and pics***
  98. Finally Got Her on the Dyno.....
  99. Turbo cam???????????
  100. STS Kit... YUCK!
  101. YS + YSi Lets hear what they can do!!
  102. 02 turbo ws6 34k what is it worth
  103. frustrating situation, can't make more than 14psi
  104. Tial 44mm Wastegate issue, HELP!
  105. I'm finished...
  106. New best and Broken stuff --Advice Please
  107. Prelim HI-Flo Dyno numbers ***
  108. Supercharged C6 Video
  109. Ran the car today, new best.....
  110. Problem with GM PN 12580698 2 bar MAP
  111. New Best STS (1/8)
  112. Bypass Valve Question
  113. New personal FI best, 10.63 @ 132.8
  114. TB for FI?
  115. What CFM does a 90mm FAST TB flow?
  116. Stock LS1
  117. Magnuson F-body dyno results
  118. Tom K >>> 8.08 on drag radials video
  119. Finally in the 5s in the 1/8..
  120. looking for a tune/tables from a blown 408.
  121. World Street Nationals in Orlando Oct. 27-29
  122. PCV Turbo Venting!
  123. Procharger or 408 engine build?
  124. Pully seal on Vortech leaking
  125. Picked up my new heads today!
  126. figured out why it runs like a dog
  127. sts turbo cam
  128. anyone know who owns this beast?
  129. Managed to get the Formy out...
  130. F1 or F1-R on 8.5:1 383 LT1??
  131. turbo ls1??
  132. Found some boost leaks, how much could I be losing?
  133. Just got back from the track..... (yay!)
  134. sts intercooler question
  135. High Octane
  136. with stock motor and setup,..What would the differnce be going from d1sc to a p1sc
  137. which best cam ??
  138. anyone ever tried this?
  139. LS6 Bottomend Safe Limit
  140. Hey Kyle, is this your car?
  141. Speed Inc Eliminator Turbo Systems Kit
  142. Twin Turbo or Single?????
  143. How to get a pair of 3" pipes over the K ?
  144. some issues- need some help fast-
  145. Superman has parts on the way!
  146. sts turbo setup w/ my mods?
  147. Where to get FMIC Piping for Procharger???
  148. Little Twins action
  149. Considering Custom Mid-Mount - Need Turbo Suggestions Please.
  150. Boost Controller Hook Up????
  151. Installed a bigger housing on my T76
  152. Pinning Crank...ATI guys
  153. my custom procharger inlet with thick Be-cool rad
  154. T67 and methanol: predictions? Jose?
  155. What thread is oil feed on a ITS turbo ?
  156. ..turbo charger/super charger..what do i get
  157. Incon 9.93 at 141mph vid plus blowing off the 325MT DR's vid.
  158. KB on a f body if new hood and cutting is done???
  159. Dyno Queen #s, Final 3bar SD @18#s
  160. V band inlet exhaust housings???
  161. Does this sound right?
  162. Procharger guy's inside
  163. Questions for the turbo dudes!
  164. ic mounting location?
  165. LT1 Procharger on a LS1
  166. Tracking down exhaust leaks
  167. Power gain going from 93 to 100 octane
  168. i need help with this setup? (wastegate)
  169. i need a bov!
  170. line connected to passenger side of TB...?
  171. How restrictive is it to run stock manifolds?
  172. strength...
  173. How loud are open downpipes
  174. Looking for advice on Stall...
  175. can anyone explain these Z06 dyno numbers....
  176. What causes some turbos to be loud and others to be quiet?
  177. Boost.
  178. LT1 2nd Gen RX7 Looking For Boost :)!
  179. faster @ 1/2 to 3/4 throttle than @ full need help
  180. Cometic .120's
  181. best palce to buy fi forged shortblock
  182. T76 front mount
  183. Supplies?
  184. Compund og BI Turbocharging
  185. 1/2 inch head studs fo boost 900+
  186. ATI SC users with Larger Filter setups in here
  187. Looking for the magic 500RWHP w/Vortech.
  188. How to:
  189. Need some fans.... Twin Pushers, questions!
  190. Trt Fmic
  191. Difference in units
  192. Anyone running a KB twin screw on a LS1? (Vette guys I guess)
  193. Belt Slippage?
  194. When it comes to a front mount turbo, what is the best way to go with headers?
  195. poll on stock ls1, sc or sts setup
  196. 8:1 or 9:1 comp
  197. How loud can P1SC be????
  198. gonna get BLOWN
  199. twin gt28rs...what do you think?
  200. Qyestions about methanol injection(boost cooler)
  201. crank
  202. quick pcv question
  203. Turbo Blazer Pics And Vid :d
  204. Ran the TT Chevelle on Tuesday.
  205. magnacharger
  206. New 1/8 mile best Friday night
  207. OFI Single f-body kit with a 80mm T6
  208. Anyone own GMR twin kit
  209. PCV/crankcase Evac with Drawings, need Help
  210. Getting ATI crank pulley off balancer?
  211. Streetable long term turbo setup?
  212. Forged LS2 Bottom/L92 Top w/ D1sc?
  213. worth it to reduce exhaust to 2.5"?
  214. New Dyno Numbers!
  215. So I am installing my PTK
  216. Help me with what Im not getting?
  217. Formula? Boost vs HP gain??
  218. Critique my FI rotating assembly
  219. Could the AC be used to cool the water in a air/water IC?
  220. not sure what this sts part is???
  221. Rear mount turbo goes 10's :)
  222. Zombie ss finally went 10's...
  223. Does anyone make a crossover for truck manifolds?
  224. well, im getting blown!
  225. ATI shroud/Spal 9" 30100452
  226. Lowest psi springs for Racegates? Anyone have any laying around??
  227. Finally!!!!! in the 10's!!!!!
  228. Turbo Car Restrictive Exhaust
  229. t74 build ???
  230. How finicky are wastegates?
  231. Hp ?
  232. Define "useable boost"
  233. need to buy Pulley and Belt, need info
  234. Need help - Boost or H/C paclage
  235. Where's Parish?
  236. what crank pulley are you FI guys using??
  237. Pics/Built Specs Of LT1s Stroker with Superchargers
  238. Hmm...Help me decide...Blown/Turbo guys..Come on in!!
  239. prelim dyno numbers for twins
  240. Well I decided to just sell the turbo kit for now
  241. Fi ?
  242. can i put my oil return bung here
  243. What belt do I need????
  244. limit of twin ati intercoolers
  245. ATI procharger with dual intercoolers...
  246. Turbo timing...
  247. OFI GTO times and more pics
  248. lowering compression for a turbo
  249. Procharger intercooler questions
  250. Where can I get this spark plug?
