View Full Version : Forced Induction
- The Forum Wars - My350z vs. Stangnet
- Camaro Front mount intercooler
- Personal turbo design?
- hows this merge pipe and wastegate location look?
- PT88 turbo Z71 street truck Goes 9.65, 143MPH on boost only! Vid!!
- Help me move my rear mount up front.
- Glide or TH400?
- SLP MAF for 600hp plus
- Wierd AFR, bad respons, fresh turbo build
- battery relocation help
- LMR/Kelly Bise TT Camaro
- Only 6in of vaccuum at idle...?
- BW S400 picture thread request.
- Procharger oil change
- Modular Turbo TWIN TURBO KIT!
- Anyone installed a LMS Ls1 Magna Charger kit?
- What's the most boost u can run on pump gas?
- 2007 5.3L Silverado...how much boost will she hold? Engine management?
- STS dealers?
- d1 procharger
- Does anyone know if Manley makes a good piston?
- Idler pulley, alternator bracket
- New Best on 17s
- water meth spray
- Where can i buy PAC springs?
- Procharger help
- 2.6 kenne bell on a 2002 camaro?
- Vortech YSI AfterCooler vs. Front Mount Intercooler?
- Looking for Pics!!!
- Finally feeling the power
- Looking into forced induction!!
- What vacuum pump do you guys run?
- Silicon Hose/Tubing
- APS discharge pipe
- lm7 vs l33 for boost
- Jay's Turbo Build Thread
- Header close to valve cover question
- Really thinking about a procharger
- Stock Converter
- What's the power limit for LS6 Heads?
- Heat insulation for engine wires
- 02 Sensor placement....
- Only 9psi from 404 w/D1sc...NEED MOAR BOOST!
- New best over the weekend.
- Ebay\ptk kit and spoolin performance alternator bracket
- aps upgraded turbo's what size short block for best performance
- Should I keep my t56 for FI?
- i have two turbo cams,which do i run?
- Yet another turbo build, but keepinq a/c !
- Intercooler type?
- V-Band Assemblies, where do you buy them?
- speed inc alternator relocation
- 370 or 402 w/PT-88
- Oil Return / Drain Advice
- Corvette procharger on f-body
- sts newbie
- T6 76mm Turbo Failure
- HP gain with LS6 cam on an STS T/A?
- zo6 cam or ????
- cam choice for procharged 408
- pt-88 measurement please
- TEA 220cc 'Turbo Heads'
- 3 bar MAP on 98 PCM
- 2 step help please.
- Newbie Qs
- Anyone have any opinions on Monster 4l60e's
- Can i get 10sssss
- UPDATE: LS9 ZR1 camshaft & Maggie 122 W/Videos
- Adkins performance (jonathan adkins)
- Turbo Questions
- my radix ls1 build?
- Benefits of Headers?
- Still having issues after Procharger install
- Idler pulley
- What gaskets go on the truck manifold flanges??
- Turbo noise?
- Help me pick a Blow-Through Carb, please!
- Figured I'd post this here - - turbo parts
- Catch Can setup
- EPP Front Mount Intercooler, they still make this?
- F2 prochager ? Can I spin it with a rib belt/drive it on the street/ f1 pulleys fit
- Turbo lq4 Nova finaly running!
- magnacharger squealing issue
- Procharger crank pulley help!
- Dyno'd today, have some knock issues
- LQ from the start or build the stock motor?
- Ceramic Coating... mask vbands and inside turbine housings?
- Minor Updates on the 106MM SS
- Supercharger or 80 mm turbo
- need info
- Eboost2/ Bleeding boost question
- Which exhaust manifolds???
- Some new dyno and race Videos and Pics
- people with manual racks inside
- Is boost a good idea?
- Our NEW C6 Build.....
- Way too much lag! What can I do to get rid of it?
- What tranny should I buy?
- TSP 408 with rear mount T4 turbine
- No factory traction control can I use trans torque management as poor mans traction c
- List of complete Turbo Kits
- Whats wrong with my car? Lack of boost.
- Loud banging noise...
- Truck manifold hits steering knuckle?
- Factory fit slimline higher airflow fans with aluminum shroud anyone make this??
- What oil pump are you running?
- 402 compression before blower?
- KY turbo forward facing manifold kit with A/C and power steering
- LS1 twin turbo setup questions
- LImit of un-touched 317s?
- Looking for some info
- Turbo and motor ready for round two
- pt88 build
- front mount turbo question
- 5.3 headbolts, rings, headgasket questions
- Cts v ls6 rear mount turbo..Boost issues!
- how much boost
- compression with what gas/power/cubes
- Turbo lq4 79 Mercury Capri Build
- Issues with surging, stumbling, and p0300 after Procharger install
- Crank Pinning--Newb Needs Help
- oppinions on 6.0 boost friendly rebuild
- what et?
- Turbonetics T76 or T78 underhood pictures.
- anybody got a spare all pro 6 bolt head?
- pushrods for ls3 force induction ?
- Fs:garrett gt5533r new
- rear mount question
- Blow off valve question
- throttle body size
- Real Street at LSx Race
- tuning a 1998 corvette turbo
- Wastegate spring question???
- Procharger P1sc Question
- boost gauge
- Garrett A2W Cores Any Good?
- BBC suppling oil to turbo??
- need help with build ideas
- Top mount throttle body with boost?
- Piston-Wall Clearance for boost, is .006" ok?
- Turbo Blanket(s)
- '63 Nova Turbo Build - Input Wanted
- ls6 intake or victor jr
- Anyone use a Edelbrock Pro-Flo XT with boost?
- mpT70 67 impala
- what comes out of your catch can?
- domed pistons for future S/C power adder
- GARRET TURBO ????s worth using?
- Anyone tried the LS9 ZR1 camshaft
- New Intake & Fuel System?
- gm 12615136 2bar sensor
- My flipped manifold mustang build
- Machine shop says a 408 isnt good for boost...
- keep twin high flow i/c's or upgrade to fmic
- F body Intercooler mounting idea's
- RR-Stage 5 LS3 A6 570rwhp
- What intake manifold? PT88+22psi
- Need a little guidance
- Procharger 408 ported 317's. ?????
- procharger
- machine shop in northen ca ?
- Legit 8 sec street car
- what is this help please.
- spark plug wires for coil relocation
- Stock bottom T76 guys come in
- which sponsors sell turbo cams
- Reducer Coupling HELP!!
- FMIC build
- What is a basic bolt on s/c kit?
- Tell me what you think???
- Budget 347 forged bottom end. build or buy?
- Finished my Setup (truck manifold kit)
- alternator relocation bracket
- 71 chevelle LS3 turbo build
- Lt1 turbo setup...
- What pushrods to use in my turbo 5.3?
- Probe FPS pistons?
- Where to mount a FPR for return style system?
- Largest Procharger to fit...
- map sensor wiring help
- Loss of traction AFTER launch... weird pulsing vibration on decel...
- Need help guys
- To achieve 500-550rwhp
- World's fastest Ebay Kit!
- A/W IC water lines
- Need some type of guard or shield for my ATI race valve
- Procharger piping replacement
- What belt for SDCE with 4.25" pulley
- AES Racing Engines FI Shortblock, longblock sale
- FMIC Build Help Needed
- need help turbo header
- Thinking about Procharging
- Need Gaskets
- TTI upgrade
- Turbo Woes
- got the kit coated
- boosted fuel pressure regulator
- Supercharged M6 guys (and girls?)...
- LMR Twin Turbo C6Z makes 1153rwhp through Auto!!!
- Finally Got Dyno #'s With Maxed Out D1SC
- need some suggestions on a 408 FI build
- Procharger and MS4
- LQ4 or LQ9 heads on my LS2
- High Flow LSx Injectors All Flow Matched
- quad turbo lsx powered sand car video
- A few Procharged L92/LS3 questions...
- SBC turbo needs help
- Running 20 psi around 4300+
- sts kit failure?
- KY-Turbo Inc. T4 A/C Header Setup
- Boost/ Power limits of ls7 and l92 heads
- Procharger Oil?
- oil drain return front mount ptk clone
- Himni Racing
- 3 bar MAP - install Qs
- procharger and cam choice?
- STS on Convertible? Please come in!
- Supercharged LT1 ???? need help
- anyone running a turbo on an lt1 please come in..
- where to tap into for water lines for TT incon kit?
- Will an atmospheric wastegate dump make more power?
- Procharger Setup LS1
- C5 hot section
- magna charger or slp supercharger???
- What size injectors
- supercharged ls1 t/a
- bettor or worse vacume source's?
- GM Boost solenoid
- Where to buy 2 bar map>!??!?!
- 427 Twin Turbo LSX Dyno Video
- remote radiator fill setup
- Holset HX55(72mm) single setups out there????
- Would running way rich cause the motor to idle high after boosting
- WTF 92mm TB wont bolt to Edelbrock Elbow
- Holset turbo sizes?
- Those with stainless works tube headers.... Plug wires?????
- How much boost can I run with a 402 and twin 58's?
- Procharger belt part number??
- my home built gt-88 setup
- Choosing a cam... 365 or 403, daily driven
- Re-Re-Re-Re-did my turbo kit
- whats what for turbo kits?
- powerdyne supercharger
- 918853 ATI pulley; does it have A/C?
- New Procharger and the fuel is running rich HELP!
- Intercoolers
- Help - Alternator Relocation
- 01 Camaro SS APS - track results
- found some procharger inlet goodies
- what's the max boost I can run on a STS 60mm turbo
