PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 [187] 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. SCE Titan head gaskets are in stock again
  2. New Boost Controller Question?
  3. Wormboy pix from Clash
  4. D-1SC guys
  5. Air-to-Water Coolers
  6. STS Turbo on stock Silverado 5.3L
  7. will my TR230/236 bleed too much boost?
  8. My STS track times
  9. Procharger model change?
  10. FMS F-7 vs. LPE GT2-3
  11. Think It Will Work
  12. 5.3l Sts
  13. 8's bitches
  14. Turbo exhaust
  15. Question's about Vortech?
  16. What Wide Open AFR ratio are you 800 hp turbo guys running??
  17. is it do-able
  18. People running the Mondo
  19. this is probably beat to death... maxed fuel system
  20. Victor JR Pics and specs..
  21. where would i find a complete D-1 kit.
  22. Procharger @ 10 PSI on stock bottom end unreasonable with my mods?
  23. vortech
  24. Intercooler ????
  25. Intercooler ????
  26. V-9 Rated for 575hp? Is this too small?
  27. Wheel2Wheel powertrain
  28. Turbo Camaro
  29. Guys running GM MLS ENTER HERE
  30. Compression/Leakdown test??
  31. wastegate
  32. Inspector 12 or any other Vortech experts
  33. Vortech or Procharger?????
  34. someone who can tune a turbo truck
  35. Vid's from Milan
  36. boost on stock block
  37. Sts Turbo Questions!
  38. Marko (aka white supra) car for sale!?!
  39. What is maintenence on a turbo setup like?
  40. anti-lag, an explanation.
  41. Crank bolt for ATI Damper?
  42. Supercharging A4 vs. M6: any difference?
  43. exhaust pressure ratio?
  44. Fellow FI guys check this out
  45. what do you think about this cam
  46. Pro Charger vs. STS or stay NO2?
  47. making 800rwhp need help with 2 issues
  48. Some pics of Milan last night
  49. C16 for FI cars at the track?
  50. First time in boosted F-body
  51. TPI Oval TB coupler?
  52. STS Turbo set up vs CAM
  53. So what's the deal with F/I and race gas??
  54. 6.0 heads 8#s of boost race gas, What cam stock bottom
  55. FI guys with daily driver and cam
  56. Anyone know where i can get my car tuned
  57. ESC Methanol mount and EBoost2 mount C5 Corvette
  58. Turbo charged engine set ups..
  59. Supercharger flex duct ripped, where to get replacement ASAP
  60. turbo cam question.
  61. CARTEK/STS turbo C5 breaks into the 9s on drag radials!
  62. Pulley size on D1SC??
  63. Apexi safc
  64. AFR 72cc 225 heads - good choice for FI?
  65. rear mount buildup
  66. Futral F11 and D1SC ??
  67. The Sts Turbo
  68. STS car melts
  69. information on you STS guys
  70. Stenod Performance Twin Formula new best.
  71. Pressurizing the **COOLANT SYSTEM?**
  72. Which spark plugs for supercharge
  73. Done fabbing the turbo headers
  74. SPAL fans install... Questions.
  75. Best Supercharger
  76. I cant decide Turbo or SC
  77. Engine block choice of FI
  78. Question again
  79. Curious about stroke vs turbo efficiency vs piston velocity vs power band
  80. Ground Zero's new turbo kit in the works
  81. photos of the PTK LS1 install
  82. need help with a turbo install
  83. Screwed up torque curve?
  84. Fs....tea Afr Heads...
  85. what 8 rib setup to go with?
  86. What happend to RR's turbo cars?
  87. looking for .96 on center exhaust housing for percision t-67
  88. what internals are the 850rwhp+ guys using?
  89. dual exhaust
  90. Best Gearing
  91. Forced Ind. Cam
  92. How much power will this handle?
  93. more pics of evil
  94. TT LSx or Aluminum 572
  95. How much boost are you guys running?
  96. big inches or small inches for a turbo setup?
  97. Something differenr Sir? - An electric supercharger!!!!!
  98. Hey TTI Owners, O2 Sensor & LTrim Questions
  99. Brackets for F1R
  100. Phamspeed turbo leak
  101. Cartek or A&A Corvette
  102. headers for future turbo setup?
  103. surging
  104. went to hi-flo's site....
  105. what MAP do I need for new setup?
  106. Log header vs truck manifolds
  107. Can you boost 98 heads w/ MLS gaskets??
  108. Newbie- I bought a Blow off Valve for my SC
  109. Vortech ID Help
  110. Auto or manual?
  111. Couple vids from Bristol the other day...
  112. o2 sensors in same down pipe
  113. Bling Bling.... Update Pics
  114. Progress on PT101 Buildup
  115. turbo installed now running rich at idle and bov ?
  116. Best Brand - 8-Rib Belt
  117. Where to get all parts for a Procharger set up?
  118. Vortech GTO??
  119. GT47 compressor map
  120. can a 98 vette stock maf support 500rwhp?
  121. C5 STS Twin Turbo Introductory Pricing!
  122. d-1sc question
  123. Rigid mounting a turbo?
  124. Tricks for pressure testing all my piping and such
  125. Improved my personal best to 8.76 @ 153
  126. Surge valve/ Bypass
  127. How much safer is 5psi compared to 8psi
  128. D-1SC with an F14 cam?
  129. 304 ss compared to 321 ss ??
  130. those with large turbos got a question
  131. best boost controller
  132. How much boost?
  133. Intercooler Plumbing 3 Inch Or 3.5 Inch
  134. PTK info
  135. about to install Powerdyne..few questions??
  136. How tight should the 8-rib belt be?
  137. Did i find a great deal, or a ripoff waiting to happen?
  138. Injector help needed in Fueling section
  139. Low boost?
  140. GT67 guys...
  141. Methanol Kit Parts
  142. Has anyone ever broken the head off of their tensioner bolt? If, so how'd u fix it?
  143. I am finally boosted!
  144. Which catch cans besides AMW work?
  145. Cooling with the F1 (did a search)
  146. TR230 with blower
  147. opportunity to get a procharger
  148. Rebuild LS1 for boost
  149. where to buy turbos
  150. what size fmic?
  151. ATI/Diablosport sucking not blowing
  152. Anyone with 3 bar? Looking for AFR & TIMING MAPS?
  153. Part # for GM Truck Wires the 9.24" ones
  154. Just dyno tuned my LT1+SQ trim tonight
  155. Strange Problem...
  156. hp numbers with low compresion 408 and D1SC
  157. turbo timer?
  158. Horsepower capacity of Vortech Aftercooler?
  159. wastegate hook up
  160. C5 C5R 427tt coming along..pics inside
  161. Contact for Vortech
  162. what cam are u guys running??
  163. What Intercooler and How much for install?
  164. sorry, but...
  165. Stock vs Tubular K-Member for PTK or Hi-Flo???
  166. My SS is finally finished.
  167. started my Install
  168. Time for a chute
  169. My twin turbo Z06 ran 8.83 on Saturday
  170. PurEvl updates pics
  171. how much boost
  172. Intake boot for STS
  173. PCV questions, new to FI
  174. dynojet tuning a turbo car
  175. Would this be a good kit to get for my 2002 Z28?
  176. Here are some pics of my boosted "demon" turbo LS1 setup
  177. phamspeed kit
  178. Z06 Procharged Vette pics
  179. turbo help for my 408
  180. 383 ci & TTI Street Kit, good combo or not?
  181. tee of the oil pressure sender
  182. Those with Twin High Flow ATI IC
  183. My bank account hurts so good
  184. ATI SC intake hat/elbow
  185. turbo and nitrous
  186. Searching for the right size turbo
  187. Jz 97 Ss 1500
  188. Hi-Flo Turbo Systems to Donate 2 Sets of hot side components of upcoming kit
  189. turbo or supercharger kits for a 5.3L
  190. THE reason why you should plan on doubling or tripling the cost of your setup
  191. turbo selection
  192. intercooler fit?
  193. Who to talk too??
  194. Too much boost in the crank case???
  195. Need HELP - good mods, less power ???
  196. where to buy race gas online?
  197. Turbo all bought!
  198. E85 w/ forced induction?
  199. RMS/HP turbo kits
  200. PT91 Solid roller 348ci Vic JR. intake 6 speed.. Cam??
  201. Having problem locating tps, iac, and gm 3 bar map help please
  202. is there a way to calculate when detonation or preignition will occur?
  203. Jose, hows that PTK Cast Manifold TT coming??
  204. Any luck hearing from Hi Flo on progress...
  205. Which is more expensive
  206. Company question
  207. Procharger Headunit Rotation Question
  208. Adding Vortech SC to my stock 2000 SS?
  209. Lurker needs a little help
  210. boost gauge. ..
  211. FAST 90/90 & a turbo?
  212. Procharger: Surge vs. BOV?
  213. 790 rwhp with stock crankshaft. Check out the video!
  214. So what about the Powerdyne kit???
  215. Question??
  216. curious about d1/p1
  217. Bought everything Q's?
  218. Katrina took my car so bye bye FI ;-( - Arkangel's Farewell
  219. Not another belt thread......
  220. vortech water pump...
  221. Help !!!
  222. Track Times Today / T-76
  223. BOV purging?
  224. Turbo
  225. Intercooler
  226. procharger bearing sound
  227. Outlaw 10.5 Dyno Run
  228. PTK street/race setup
  229. building my own turbo kit...
  230. Question for a friend...
  231. I want to build my own turbo setup.
  232. Will my SyTy turbo work with LS1?
  233. Post pics of your Twin Turbo setup!
  234. turbo controller
  235. Highest Dyno for Turbo Tech Street Kit?
  236. Which Wastegate / BOV ?
  237. Why does Vortech get such a bad rap??
  238. Whats up with Magnacharger?
  239. Anyone Boosted with 2.73's?
  240. Twins for a LS1, on a budget
  241. boost question and twin turbo!!!
  242. Custom Aeromotive Fuel System for STS Pics
  243. Turbo and auto
  244. aluminum vs iron block
  245. 500 to 600 RWHP WTF
  246. Any STS users experience misfires after install??
  247. 408 Turbo Headers??
  248. This guy must be kidding
  249. Powerdyne XB-1A Upgrade
  250. Wormboy's car (Video)
