View Full Version : Forced Induction
- 10.19 @152.93 video Speed Inc. TT Z06
- I don't get it?!
- need help going TT
- Procharger Air Filter?
- Cam choice
- IE 6-71 blower value???
- Oil restrictor for BB turbo?
- Epp blower cam & 1.85's
- G5x3 on a 114..
- Finally Finished The Z06----Dyno results inside
- D1SC procharger kit?
- 2 step
- Will Higher octane fuel help with engine detantion
- Forced induction
- Rear mount oil return locations??
- looking for a shortblock for turbo "383"?
- D1SC Pricing
- Remote/rear or front mounted turbo for road racing
- single GT35R?
- about truck manifold please
- FYI Edelbrock Vic Jr. L92 vs LS1
- gauge question
- Need some ideas
- dd 370 or 408
- Abaco DBX digital MAF sensors with boost ?
- NGK Iridium Spark Plugs with boost???
- Been Thinking bout DIY Procharger??!!
- are 11.0 air/fuel ratio enough to spit gasoline by exhaust
- cam question
- It started!!! But issues...
- Front Mount Turbo Manifolds
- Just bought a homemade rear mount kit, is the Turbo big enough???
- those who moved there battery
- Which intake for boost?
- APS boost control issuse
- bs3 boost control ?'s
- We need something like this for the GM crowd...
- Lingenfelter launch controller
- STS turbo no oil pressure
- Popping and backfing under boost
- somebody with ethanol
- ASP underdrive pulley?, meziere?
- lm1 wideband
- Low voltage
- easiest way to turn off STS oil pump?
- Changing to smaller pulley, high RPM at idle
- Passing the sniffer test: What does it take?
- Cam Question
- OHIO BOYS-Spy pics
- twiny twin twins
- 2 step lounch controler
- Why is it recommended that you !PCV when going FI?
- interchangeable parts,V-9 supercharger?
- APS Install time
- ??? wideband 02 no cats????
- help me find a belt!
- What psi Hobbs switch?
- Meth. Inj.
- anyone running turbo with no intercooler?
- digital fuel pressure
- Fan hook up
- Back pressure vs cam, anyone tested?
- Another dead aps turbo
- APS TT question
- Intake/throttle body
- C5 single front mount? (build my motor)
- Is this bad?
- LMR Warhawk 440 TT W/ 4L80 Build!!
- TVS 2300 blower
- Highest rwhp put thru a 6.0 iron block with no fill or special girdle?
- LS3 vs. L92 for turbo setup
- Vortech Supercharger kit
- What do yall think of this turbo cam?
- HP question...
- ATI Procharger Cam selection
- Procharger install TBSS.....
- Turbo v6 camaro?
- Just got my car back with rear mount??
- bypass valve location
- what size fitting for sts stainless oil line
- Turbo plugs
- Those of you with pusher fans step in
- Help Me Please! STS Turbo kit?
- meth kit ?
- turbo for a daily driver and cold temps
- aps twin turbo questions....
- Anyone install a muffler on their STS turbo?
- STS PPL Only! Turbo upgrade advice
- Where to buy...
- NGK Iridium IX Spark Plugs, for boost? TR6IX or TR7-IX???
- Check Valve needed? Valley to blower??
- those with a fenix999 alt. relocation, IN HERE!
- trick flow heads vs afr/edlebrocks by west coast cylinder
- anyone using a flow meter on there meth???
- gathering parts for new motor, any suggestions
- what torque conveter is good
- any one with 800rwhp truck 317 kit
- purge valve hose hookup
- My new Z numbers with ECS Novi SL1500
- aem truboost?
- S/c
- need help,, procharger
- The science geek in me...theres more than one way to clean a turbine housing
- How much boost should I be seeing?
- turbo manifolds.
- Those with aftermarket radiators.....
- Does STS sell just the hot/cold pipes for there rear mount Fbody kits?
- O2 sensor placement
- alt bracket question
- clueless on FI build
- Car wont start, need your help
- looking into turbo set up. need your input!
- fleabay intercooler piping-fmic
- Who sells Whipple superchargers for SBC's
- How many of you guys
- magna charger
- Some intercooler questions (with pics!)
- Fitting the new hood
- PRC 237cc CNC Ported LS Cylinder Heads VS trickflows 235
- 2-step and M6 fun
- 2008 C6 with EPP blower cam and ProCharger D-1SC - 671 rwhp on our Mustang Dyno!
- 5.3 turbo questions
- Turbo guys....
- Procharger bracket
- Thinking about finishing my project.
- new to forced induction and starting on a summer project.
- STS turbo melted number 3 =(
- Cam for APS Car
- PCV system complete, i think...
- New #s; P-1 on stock bottom end LS1
- How much boost with your 2 Step?
- ? f1c procharger kit for f-body
- My Procharged 451 LSX build
- Should I use turbo blankets using the APS kit? What are the pros and cons with them?
- Cam experts in here.
- flipped 94 lt1 exhaust manifolds leaking, where to get donuts?
- Ebooost2 help?
- Who runs stock radiator?
- how do these cam specs look?
- Patriot LQ9 vs. TFS 235 with FI?
- How much lag? Lsx cobra...
- Turbo Gurus -- Smoke on Accel
- turbo selection
- The STS Camaro we built has been sold and we just installed a rollcage for the owner
- who (vendors) sells GT35R's?
- Belt slip on 8 rib D1-SC
- Hidden supercharger
- First passes with the new D1SC/347 firehwk
- lt1 .... spark problem?
- what would u do
- A2W intercooler? any gain over A2A? anyone ran a ebay one?
- Vortec V-1 Self Contained(?)
- fan-setup
- To run an intake tube off the turbo or to just clamp on a filter?
- Scavenge Oil Pump...
- Rotrex Supercharger kit (W2W)
- Compatibility of my H/C setup with FI?
- Got Launch Control and Flat Shifting Working
- any guys from ohio? turbo?
- LT1/LS1 STS piping????
- Going turbo
- A&A Corvette blower cams?
- Turbo almost done...
- Intake Upgrade with Forced Induction
- Oil Drain??
- so of the f/i engines/projects we've been working on
- Crankcase problems, blowing out dipstick
- Hood Stack
- putting together a turbo kit
- how much power with a 347 forged & 317 heads
- kentucky turbo kit out there
- Which one?? Edelbrock E-force or Vortec v-1 t rim on a SBC?
- opinion please spray or boost
- what do you think guys t78 or t88 street car
- Just some import....
- In case anyone is looking for a Turbo Car....
- Borla or Custom Single?
- Who is using the oil restrictor in their systems
- Oil in charge side
- Best way for me to go a little bit quicker?
- Twins or a Big Single?
- racetronix hotwire kit???
- twin turbo with vette manifolds
- anyone had bmr turbo k-member issues?
- Check this MAP
- still tuning!
- Help with 5.3 turbo project
- Fuel Regulators
- Ls1 Sts kit on LT1 with intercooler?
- Twin Turbo Intercooler
- 681rwhp stock long block, vid inside
- Alt relocation problems!!!
- New LS1 9ltr High Performance alloy cast sump
- Where are you guys buying your Turbos/ Accessories?
- F1C stock shortblock results
- Wastegate referenced before or after TB?
- Show me your intercoolers!
- Just bought a FI car, new to the scene and have some ?'s
- Fuel fouled spark plugs issue
- HELP LOCATING MAGGIE UPGRADER 112 to 122
- Looking for a turbo system for my 01 2500 HD truck
- D1SC with 3.2 pulley, what boost at 3000 rpm and 4000 rpm?
- another e85 thread
- turbo/size/make?
- lil help?
- About what would an F1A cost?
- differences in blow off valves
- boost creep or no?
- DIY turbo?
- Dune Buggy Dyno
- Made the cover of the May GMHTP!
- C6 T-trim supercharger results
- Exhaust Pipe Size...
- Rear mount setup with FMIC, how much in piping?
- need set up input
- Wtb aps tt?
- will this work ok for a catch can set up?
- What rpm do you spray meth at?
- need your thoughts....
- One Way check valve
- STS TT Problems
- -8cc pistons v's -25cc pistons...
- Who say building a turbo kit is hard?
- Things to do before going to dyno?
- Impeller moves!!!!!!
- Turn up the boost or upgrade the turbo ?
- ls1 CR with -23cc pistons and 72cc heads
- Help me decide, Nitrous or FI.
- Procharger Piping
- FFI Exhaust systems
- Kenne bell ((big bore))
- Turbo LS1 GTO 517whp & 53X trq on 8psi
- ugh collent issues rad hose collapsing from turbo heat
- Procharger On GTO Is Pi##ing Me Off!!!
- 4" DP possible with truck manifolds
- is this a complete p1sc (pics)
- turbo help
- 600rwhp FI: Building fuel system from scratch, lots of questions!!
- Pics of Rob's TT Formula!
- Exhaust Shop Hot-Side
- How do you cut the front of your bumper for your intercooler
- L92 carb intake and elbow...check it out
- Building a truck manifold for my buddy -
- APS install Ron Davis Burkhart Bumper Support
- cant decide eather a 78 or 88??
- DIY Meth injection kit
- Picked up my new Va Speed Turbo-Ready LS2 motor...
- Will I notice a difference between 3" and 4" intercooler piping?
- is this a realistic goal with a p-1 procharger?
- ebay turbo kits for 800 bucks bad or good?
