View Full Version : Forced Induction
- turbo cam needed?
- turbo tune HELP!!!
- ebay turbo kit question
- Looking for an STS install manual
- Which new turbo should I go with?
- Who makes oval silicone tubes or Stainless??
- Zombie made a boo boo and put e85 in his tank
- Retro fit 6.0 To supercharge or Turbo
- OK your thoughts on the Edelbrock E-Force (mp122)
- Made a couple of passes in the heat..sneaked in an 8.
- oil return line question
- Will the GT-67 support 15 PSi???????
- quick ? needs a Quick answer
- What fuel pressure Regulator that rises with Boost/1000rwhp/what are you guys running
- sts turbo need your input!!!!!!!
- remote turbo...pump location?
- Ebay Truck manifold hot parts
- Got the car Dyno'd, something isn't right
- ITS 274 Turbo.....X Trim?
- Exhaust gasket
- My Procharged TA is done.
- fan choice for a fmic d-1 procharger setup???
- Anyone tack welding reluctor wheels????
- LSX 427ci Turbo?
- What boost level will stock springs start to float ?
- Adding ARP rod bolts to a stock LS1 to add strength for boost.... is it worth it?
- Best place to get 3" SS blower piping?
- Air flow math question on PSI to CFMS
- Lt1 blower work on a ls1?
- 550 rwhp and +/- 10psi. What head fasteners
- Aps extreme kit anything compareable
- novi 2000
- Am I blind? Fast List?
- STS Turbo Oil Leak problem
- SDCE procharger vid contest makes the top 10
- Fast 90/90 guys
- oil pressure issue sts kit
- starting my truck manifold build.....
- What are you running for timing?
- oil feed for lt1
- Oil line kit worthwhile?
- Truck manifolds go 202.80mph
- what the hell should I look for??
- procharger video contest, our submission
- New Dyno numbers on Bob's V - 864 rwhp with 12.4 psi of boost!
- need some missing procharger parts
- trade t76gts for gt47-88???? yes or no
- Procharger Pulley Help really quick.....
- bov
- Fuel pumps and Regulators --- 8psi
- cadillac xlr v supercharger fitment
- quick question help please???
- stall for th400 (turbo setup)
- Progress numbers on TT vette
- Blow off valve on a Procharger ?
- Anybody use this tunner????
- how to upgrade the procharger
- what intake do i need to run with turbo
- Vortech T-trim can not build boost 2004 gto
- losing boost psi from some where need ideas?
- New to the turbo world, got some ?
- re-using cometic head gaskets
- killed one more APS turbo any ideas and who has a exrta one ?
- Anybody have TTP from new jersy tune for them
- considering supercharging/turboing the goat
- APS clunk
- Who's the fastest with A/C FM?
- F1 Install: 370 CI Lq4
- Cant find what turbo to use (???)
- What type oil on a 408 with an sts?
- Question an WG flange sizes
- Question on sheet metal intake manifolds
- Hotside coating/wrap
- what plug for approx. 1200 hp?
- First 1320 Track results
- Thoughts on 383 with SMALLER turbo?
- turbo cam
- Help.....
- Fuel related but more FI specific. 120 low impedence..
- t76 and pt4000.....
- Is there any way to lose/stay same boost going with a smaller pulley?
- 2007 LS6 into Camaro?
- Twin s200 borg turbos ? ?
- Ninetres 1st track day 2009; Bracket car??? lol
- About to start Build, Imput please...
- Maggie Tuning Problem Code P0341
- Need some advice.
- 35th LE APS FINALLY DONE (Not tunned)
- Favor from guys with hptuners running 2 or 3 bar
- Can't find OFI's Website
- Looking for 700RWHP
- Cheapest you can do a diy turbo?
- Which pistons are you running?
- Any one ever had this happen?
- Contacting Kentucky Turbo
- Question for all fabricators...
- MAF or SD?
- 396ci + D1-SC New #'s
- T6 v/s T4
- Any harm is running no DP at all?
- So...who's pushed a production LS2 block the furthest with FI?
- Mounting an eBoost2 in A-pillar
- Why a broken ring land @ 10psi with mahle?
- Cutting K Member Ok??
- Need some advice
- looking for more HP with F1C on ls2 going from 4.75 to 4.5 pulley
- inlet openings in compressor housing?
- More Boost
- AEM Tru boost
- ls7 turbo info
- Thread sealer on LS1 block?
- Brian(Fireball) Testing Drag radial @ Cecil
- Going TT@12psi, questions about engine build
- GT4088R Questions...
- question on whats the best place for breathers?
- 2 bar SD tune
- SDCE/ Aftermarket Waterpump ?
- vortech v1 tune
- Tight with money Tight on space
- Is stainless mandatory for turbo fab?
- Y pipe for sts
- summit direct fit radiator
- Mild Steel
- Who's running a T6 truck manifold setup
- Procharged... overheating... need a plan
- My TRUE cost of FI
- Help me decide!
- How to check wideband O2? I think mine is incorrect
- TTI guys Upgrading 67 trim over 60
- Magna Fuel boost ref reg (sales section)
- hight temp RTV for head to manifold gaskets
- intake and cam?
- Still bleeding boost, need help.
- Selling my single 4" exhaust if anyones interested
- gt45r vs turbonetics vs precision??
- problem solving at 1100 rwhp (help )
- procharger question
- Procharger Pulley Removal.
- Fuel Pressure Drop Going Into Boost
- What spring?
- Ebay 4" vs brand name intercoolers (what are the 1000hp guys using?)
- Went for a ride in a procharged vehicle today...
- Will my cam work with a supercharger
- Switching turbo turbine
- Boost problems
- New aps system 99 02
- Ms3 cam work with boost
- Eboost solenoids where did you mount them aps guys especially.
- Some advices on front-mount arrangement, please
- STS CARB EO sticker help!!!
- Meth and AFR question
- Procharger inlet hat
- STS Convertible Piping
- delete cruise control.
- Finally getting tuned
- dont know much about sts turbo
- Do i have to lube my Procharger idler pulley or stock idler pullyey
- Do certain turbos make more sound then others!
- Problems with Alky system causing hydrolock?
- GTO Procharger - dual valve springs?
- Possible build
- popping under boost
- ORTC Boost vs No Boost DR race in Georgia!
- new to turbos have a few questions
- Skid Plates Anyone?
- for all you high hp guys
- Turbosmart BOV...super or mega sonic
- S400 Borg Warner, T4 .90 A/R Hot side
- is it possible to by a ls9 block
- Oil return line IDEA for STS
- ls1 timing tuner nitrous controller
- I need help on cam selection.
- Procharger tensioner system
- going FIA need advise!
- Where to get a 3.1" 8 Rib Pulley?
- Next mod,Meth or e85?? Turbo car.
- truck manifolds
- Proper way to clock the turbo?
- my new 76 mm build and new car
- turbo choices for e bay kit???
- C5 Procharger stage 1 kit questions?
- My Procharged 451 LSX build with Procharger F1C
- Anybody making big boost power on L92 heads
- Another Piece to the puzzle (Engine Porn!)
- SPONSER: sell me a turbo kit
- 7-SYi supercharger help!!!!!
- low compression no FI ???
- STS install instructions
- Supercharger install problem. HELP!
- Truck manifolds... Gaskets between manifold and crossover pipe..
- aps guys running eboost where did you mount your solenoids?
- Help, Compressor housing leaking.
- Spring with boost questions..
- Ais stage 2 trunk mount kit anyone put it on drivers side at back corner?
- Where did you put your Eboost2?
- Check out the difference in numbers between our Mustang Chassis Dyno and a Dynojet
- Help with my procharger build
- Tune Required
- Need help with Vaccum lines... Please
- Tubular manifolds what size are u running
- Help with prochager pulley
- Texas Mile Setup...opinions
- Vortech YSI Question
- What intake gaskets with LS6 and boost?
- Decent wastegated turbo??
- Picture thread of my EZ 94mm KYTP Build!!
- Truck manifolds have very different size openings (40%) - isn't it a problem?
- Getting 500-550rwhp safely?
- 2010 Camaro Kenne Bell SC
- stock turbo set up
- head gaskets???
- FAST 90/90 or carb style with a elbow for a TT set up?
- New turbo setup mock up PICS!!
- Questions for APS and Procharger guys
- boosting stock lt1
- Need wastegate actuators for Incon TT kit w / 2871 turbos
- Kytp a/c kit w/tc78, 620whp,705ftlbs!!
- STS Oiling System Issues - Please Assist!
- air to water intercooler
- Should i install it myself?
- *** Some press for my Cartek beast on LsxTV ***
- S88 Dimensions
- Broke a piston on 17 lbs WHY!!!
- What does the adjustable stop on a BPV do?
- how to install studs????
- clean out the turbos?
- STS boost control oddball issue
- Got the Firehawk to the track
- Street Warrior Intake!
- 72mm or 75mm S400 to big for 5.3?
- Procharger Tune
- Vertical Radiator... Turbo Size? Window Washer?
- What psi to start tuning at?...
- Turbo inlet screened or no screen?
- piston ring gap for turbo
- Turbo headers
- Turbo pricing
- Intercooler questions about quality?
- Lingenfelter 2 step issue
- Difference Vortech and Procharger
- YSI RWHP ? can it be done ?
- Guess on piston specs (picture)
- Best Flowing and Quietest Muff?
- TTI 60 trim track results
- Meth Question
- Having boost bleed issues,need some help.
- vacum line
- A Few Pics Of The Twins
- Procharger question
- 3 bar map and 60 pound injector questions
