View Full Version : Forced Induction
- Boost question about pulley size with P-1SC
- Where to get 316 SS 3/8 " T-4 series inlet flange?
- Billet Main caps on a 408cid Iron block??
- Finally back on wooohooo
- Dimensions of PT74/PT76 ?? Also, GTQ wheel ?
- Head and cam
- Anyone running 6.0 coil/ trays with FI setup?
- Ok the MAF topic again - limits.
- 7/29.03 - Pics of Vortech YS Trim mounted on 348ci LS1
- BOOST GAUGE DOES NOT WORK...HELP
- Anyone had Ignition Delay?
- Good article on the different turbo kits for LS1 cars.......
- 8# ATI reliable on LS1 Engine?
- A book people should buy/borrow/steal and read...
- WARBIRD vs. QMP....the answers within....
- Turbo Tech Question
- Looking for a scavenging pump;from a incon TT kit or other
- OK to drive 3 hours to shop untuned?
- F.A.S.T.questions
- Uh oh, no boost. HELP!
- Has anybody seen a Maybach ??
- Dumb Question
- powerDYNE supercharger
- Time for a 10 day countdown? YS Trim 348ci getting closer!
- when is a water cooled turbo a good idea?
- Air filters on T88 turbos?
- Is the QMP turbo kit going to be fixed? This sounds bad....
- Bypass valve help
- Need more suggestions with belt/pulley setup.........
- Oil Cooler discussion forTurbo
- Help with Autometer elec. fuel pressure gauge please
- what kind of manifold/header for over 700hp turbo?
- Replacing Passenger side manifold on turbo
- Anybody have a D1sc they wanna sell me ?
- Problem after problem Help!!!
- How to tell if turbo is bad?
- Anyone looking for a FAST system? Possible GP???
- Loking to do nitrous, or a blower, or a turbo set up...
- 2-core to 3-core upgrade
- too much pressure
- D1sc questions
- Anybody using a single 88mm or 91.5mm turbo with an LTx/LSx?
- which turbo to get
- ATI PSC-1 Installed and very noisey at idle, Please Help!
- Magnuson exploded... link within
- torque!.. i mean dyno results inside
- Whats the best head to go with LQ4 or LQ(
- incon questions, Manifolrs, Turbo, info needed.
- turbo chargers
- turbo chargers
- Poll: How much Fuel press at WOT on boosted cars
- Boost Gauge Idea's??
- Intercooler dimension questions... (98-02 F-car)
- Getting closer!!! YS Trim is mounted!!!
- PICTURES OF MY CAR FROM ATLANTA
- Do you guys pin the crank pulley?
- I need advice on my new build
- Interest in a digital knock guage with memory recall?
- ATI Guys - What kind of ETs and Dynos are you guys seeing???
- Cam and Gear Questions...
- hey everyone look at all my turbo stuff
- Turbo or Supercharger
- Going with larger cubes..how much boost?
- Car is seeing 12psi now.....
- 03 Camaro V6 Supercharger
- Summer supercharger sale!
- Need help with roots blower intake for LS1.
- Another Insane Ford...
- GM High Tech shoot out!!!
- Maxium boost vs. Block integrity
- Thanks East Side Performance!
- Boost vs. RPM with centrifugal SC
- procharged bird
- Pics of my ported 6.0 heads
- FI Forged motor build
- MagnaCharger <New Applications>
- Anyone took his procharger on a race track?
- Whats a safe Fuel pressure for full throttle under boost...
- Champion spark plugs
- 711rwhp 745rwtq
- Slowly making progress on the YS Trim project car
- Which name should I use for my car? (YS Trim 348ci)
- Procharger w/7psi on otherwise stock z28???
- 9's on a budget?
- Would a D1 be to small for a 382 Ab
- 230/224 .576/.563 111LSA=2 much cylinder pressure for boost?
- driving through my convertor...
- Any word from y2khawk???
- 4 port heat extractor hood for 98-02
- you guys are making me nervous
- How can I actually Tune a Procharger D-1SC tuner kit?
- Can I make it to a shop with stock fuel pump after s/c?
- best header for D1SC
- Fuel for a 15+ psi blower car.
- Are ported heads worth it on F.I. engine
- vacuum hobb switch?
- home built turbo setups? pics needed.
- Need suggestions for building a turbo mainfold
- Boost spike or boost dropoff? Turbo Z06
- Need some advice, going max effort
- Turbo cars
- Autometer fuel/ boost gauge problem
- Extreme-G 1969 Camaro SS - Supercharger plans
- Paranoid about turning up the boost
- Help me pick a setup....
- I need advice on my next setup..
- Intercooler analyses. Some technical, but cool info.
- Help with new fan set up
- Witch ATI will suit me best?>>
- Paging: y2khawk
- Belt Slipage/Cog Setup?
- WRX @ over 5000' - need premium?
- Getting a total of 8psi out of the 8 rib pulley setup..
- Anyone else waiting on QMP/LS1M turbo kit??
- Boost Question
- Blew out the dipstick?
- dyno #'s with #4 ati
- Yella Terra rockers worth it on boosted motor?
- 44" Camaro intercooler photos - MTI
- Turbo LS1 dyno videos?
- How big of an intercooler / intercooler theory
- Help me decide on the cam
- 101mm of Fun and a prototype CHAIN DRIVEN Pro Charger!!!
- initial results from the IC sprayer.....
- Electric Supercharger? Do they realy work?
- anyone make a good bolt-on turbo for 4gen cars
- Dyno'd Again - Got Problems, Help Me
- 409 iron block
- 99+ FI F-bods, what's your fuel setup?
- Budget 6.0l boosted build up Questions
- check my turbo setup list ..am i missing anything?
- Cooling Fans - Hot hot hot
- Pics of Walbro in 99+ tank and intake blow bye. *DUW*
- Anybody got a 3.60" or 3.80" pulley for sale?
- New Best! Video inside
- 427 and Boost
- Why can't I get a consistant A/F ratio at all RPM
- Forced Induction Ranked List 2003!
- Boost question
- Powerdyne....Am I the ass
- Need info on dyno tunning
- Leak down, verifies, blown head gasket!
- Inital dyno #'s.......
- Leak down or compression test?
- Blow Bye or Blown Head Gasket?
- Kit For Battery Relocation?
- Project Blownzilla Update (Vortech YS trim)
- turbo cam and lope
- Blow through MAF
- need opinion on shift points
- turbo 1/4 mile times?
- THANKS, for the help larry,sikora and PSJ and Jay
- advertised boost/actual boost
- Twin Turbo
- LS1Edit warning about maxing the maf
- Anyone else out there with 6.0l iron block and turbos? help
- Has anyone tried FI on a G5X-2
- belt driven sump pump....
- Been busy lately pics within :)
- Drove Blownzilla a bit and it was nice
- ideal sc motor (kinda long)
- A surge valve problem
- I think this should work...... Right?
- Powerdyne Finally Dialed in, and Now I Have a New Problem...
- Need a 2 steep!!!
- I want to run 12psi what do I need to do?
- MMS crank pulley install
- EVERYONE HELP!
- Powerdyne SC vs. the other guys
- Please list your FI setup!!!
- ScottWS6 goes 10.30@133.85 at GLD!!! Congrats!
- Gains prior to FI with my 6.0 heads?
- Reliable Forced Induction, cost?
- Car is running.....
- 4000# Pig: My Black Gal is PHAT! Let's talk weight reduction
- any autos running a turbo?
- Chassis work is done, time to put on the YS Trim!!!!!!!!
- turbo w/8psi vs supercharger w/8psi ???
- will buick turbo work with turbo kit?
- What intercoolers are the 700-1000 hp folks running?
- 224/224 .561 114 or 218/222 .562 114 LSA ???
- Pictures of my 372c.i. 6.0L iron block, and other goodies...
- MMS F1 427 here I come!!!
- Powerdyne 2.9" pulley track result
- I'm about to join the SC ranks and have some questions..
- Intercooler sprayer idea...
- Not a FI car but HOLLY SH$T!!!
- ATI tesioner bearings
- 10.42 132.85 mph at long island dragway
- More trouble
- How does a Procharger sound?
- Any good single/twin corvette turbos?
- TURBO IN BACK OF THE CAR????????
- MUST SELL 98 TwinturboZ28
- Nice Forced Induction Fuel System for sale!
- what computer mods w/turbo???
- are companys making heads specifically for FI?
- Revised Powerdyne dyno numbers
- Who's Running SMC and What Jet Do You Have?
- Good place for silicone hose and couplers
- POWERDYNE 6PSI BLOWER
- What to do to get a tune
- 15lbs of boost on pump gas?
- Turbo vs. Nitrous
- 8 rib drive system for procharger
- anybody wanna sponsor me a turbo kit?
- What supercharger?
- Small delay (chassis)
- NE-Body Know How To Contact SMC?
- Want to build a new engine ... (long)
- Time to go FI...got some questions...
- Pro's & Cons with G trim vortech vs D1-SC Procharger
- is this normal
- Car went in for surgery today.......
- *** 2003: NEW! Boosted List (SC'd / Turbo'd) ***
- Few Questions about the Procharger, Emissions? Fuel?and Cam?
- for 15psi of boost ... D1SC or F1
- New best for TT SS!!
- 8# procharger even worth considering???
- Which heads/cam combo for forced induction?
- 10.55 at 131.84 with F1...
- Updated LT1 single turbo dyno numbers
- Is having to take fuel out at WOT normal?
- HELP! Short-Shifting out the hole - any ideas?
- Walk through???
- Let's discussing tuning options for 700 - 1000 HP
- 427 big bore forced induction????
- Pagging ultimate ATI buyer (TOM)
- Whipple is on, no boost, 10lbs vac. Help!!!
- This Turbo mustang is SICK!
- Good Video to hear what my BOV sounds like w/in
- Possible to have a real ruff idling blower cam????
- HOW WOULD YOU PAY FOR A TURBO KIT?
- 2 Step??????
- Forced Induction Question - anybody???
- which one should I use
- Anyone running OVER 15 PSI? (strokers etc.)
- 7.85" ASP crank pulley and gates belt arrived..
- Kinda new to FI. Can someone help me?
- overspun powerdyne hits the dyno today
- WHAT WOULD MY CAR NEED?
- Newbie with Q's on 5.3 w/5-spd
- FI Data Logging Solution
- fuel trim # with ATI
- Why would anyone go with a super over a turbo?
- reverse manifolds?
- Not using HKS SSQV BOV, ordered a ATI RACE READY..
- How much are turbo kits?
- will this 98-00 vortech v-9 sq g trim work for me?
- Spark blowout?
