View Full Version : Forced Induction
- I'm having boost issues
- what converter stall speed for a turbo 4.8?
- anyone running fans on the front AND rear of theyre radiator???
- spark plugs turbo drag race on E85
- Procharger bypass valve removal
- supercharger
- ls9 valvesprings and turbo?
- Need some help with fuel system (fuel cell)
- Anyone have a TT manifold kit like this??
- anyone turbo'd a 6.0 with a HX35w?
- My engine doesn't like NGK TR7's
- Compressor wheel rubs inside of housing
- Anyone have dyno / times at 10 PSI
- procharged ls1 running slow
- holset hx52/hx55
- Need suggestion for down pipe clamp or vband for percision 6265?
- c5 vette alternator bracket
- My 1969 Camaro Prostreet Twin Turbo Build!
- Supercharger..
- L92 vs. 317
- Turbo too small?
- Turbo Advice. Looking to upgrade from PT88 *COMP TURBO RESULTS*
- BruteSpeed / EPP blower cam - users!
- Supercharer or turbo
- LSA head for under $200
- Any 5.3's out there with Prochargers?
- Found an old video of my Camaro back when it had 120,000 miles on original engine
- which intake to go with? vic style or the pro flo?
- Thoughts on this Futral Cam 5.3 tt
- !Help me pick between 2 blower cams!
- My forged LS3 is a go.
- Heads L92 vs LSA
- Catch can idea with ls9 cam?
- Daily driving 60 lbs injectors with a TSP tune?
- cam swap advice
- New to FI...Critique my combo
- ? Re: rear end gear ratios and rear mount turbos
- why is everyone choosing a 5.3 over a 6.0 lq?
- Brute Speed cam or Hold out
- My tt "budget" 6 speed build Now with BA 2-step vid (pics back up)
- Any Procharger guys have main belt problems?
- Recommendations what's the best cat back for big boost application on a F-body
- 60lb + injectors for LS1 plug and play?
- procharger friendly cams?
- What is the difference between a .81 AR and .96 AR turbine housing?
- Well, DKT did it. C6 Twin kit. well sort of.
- d1 procharger kit for sale
- My 5.3/F1 GTO
- Fuel Injectors......20psi boost.....but will run NA for a little while. What to get?
- LSA heads 2 differnet part numbers???
- Methanol nozzle placement in relation to bov and iat sensor
- how much boost can you build off the foot brake? VID inside
- LS9 cam not good with turbos???
- what heads for a boosted setup. Poll inside
- Turbo Comp Cam LSR 277, will the valves hit the pistons?
- Big Red Bov with turbo
- '95 TA LQ9 intake questions
- MAF, METH and IAT with Twin intercoolers
- Rear Mount Tubro, why and why not? Gurus on the subject appreciated
- Holley Hp Efi VS HPT/EFI Live??
- LQ-9 370ci with LS-3 Heads and Intake Swap
- Procharger and stock 5.3?
- 4.8L Turbo Tahoe Sputtering? Q/A
- Turbobocharger Gurus Needed.
- Not an LS... Hellion Twin Turbo Results 941 Rwhp 915 Rwtq
- 76mm and 408ci too small?
- piston slap problems
- 8 second stock 5.3 THE GRENADE
- Question boosted 5.3
- Am I wrong for going with a 3.90 pulley for my F1A?
- Rear Mount Oiling Help
- Someone to tune?
- '95 TA A2W intercooler
- High idle and backfire after sc install
- Turbo Silverado | Turbo Camaro | Turbo Fox | Turbo bike
- Horizontal Radiator
- Holley fuel pump
- swapping from nitrous to a blower
- FM Turbo and emission testing?
- Meth and twin 4.5" intercoolers?
- Rear Mount Turbo
- Another STS Turbo Question before I jump on it
- Maggie 112, valve float or out of blower ?
- Mondo, Big red etc differences ?
- diamond pistons? can these be used
- 370 forged motor on 15psi breaking up high rpms
- Accessory bracket for LQ9 408 w/ F1??
- UMI K-member Turbo Clearance
- procharger guys, who long does it take you to "spool" your centri?
- High CR question
- How to modify PTK kit to install bigger turbo
- Just pulled the trigger on an F1A
- Who said turbo cars don't 60'
- Help with STS Rear Mount Turbo Build:
- need some advice and help!
- Project Red Headed Screamer: Destroked 6.0, 333ci 12.5:1, twin 6468s, faceplated T56
- My 67 RS twin turbo lsx e85 build!
- s478
- Used supercharger?
- supercharger questions need insight
- ProCharged Trans Am Drag Pass
- Is a 212/218 Low Lift cam to big for a E85 turbo 4.8L?
- 228R cam with turbo?
- 6.0 turbo build help and ?
- Breaking in FI motor
- LQ4 turbo motor build HELP!
- Help overheating since last engine rebuild
- Need some input...thinking about adding procharger
- vette manifolds
- What is the strongest year GEN III 4.8 , 5.3 ?
- Aster Bracket Group Purchase- SALE ENDED!
- E-Fan Setup for 411 PCM
- Vengeance Built 06 C6 Vette-Supercharger/Headers-Automatic 553RWHP Dyno/Rev Vids/Pics
- Are these decent turbo headers?
- Lq4 turbo question
- what other upgrades should be made to aps tt kit?
- ...and she's alive...I had my doubts..
- 2006 gto size intercooler?
- turbo 4.8 truck
- Thoughts on a 6.0 Turbo?
- my pt88 5.3 truck
- Any difference?
- Getting a strange "dieseling" effect when I shut off my car.
- problems with engine start
- Best twins for a LSX 427?
- bone stock 5.3 s472, when should i stop
- Vortech v9 Gtrim rebuild
- Valve Shrouding with boost
- Stupid vacuum question
- Camshaft Recommendations
- Back to Mexico-5.3/PT88 Z28 vs 3.4 whipple/nitrous Cobra
- car running lean idle and WOT..
- whipple on a 01 trans am
- twins with short down pipes. WB02 setups?
- I'm wondering how much i would really pick up swapping to 1 7/8 LTs(Procharged car)
- Help with E85 & FI - Supercharger
- Over-Boost problem
- -06 feed for 700rwhp turbo
- What Garrett Turbo exhaust housing is this?
- Procharger & BR7EF Gap
- 1st pass with 5.3 = 2 broken, 1 torched piston ???
- Twin turbo with upside down truck manifolds!
- Can you heat wrap coated headers?
- Maggie MP112,
- BW S480 on a 5.3 opinions please
- E-boost Street hookup problem
- ***3/11/13 UPDATE*** Project Xtreme Boost! '02 Xtreme Blazer, Single Turbo 5.3
- NA cam on boost.
- 5.3l turbo build
- UPDATED!!*DYNO NUMBERS* Comparison of Comp Turbo Billet 88mm CT6X-88 & GT91 Garrett!!
- F1 procharged F-bodies, I have some questions..
- Does anyone DD with a procharger?
- Critique my f1a build please
- Best intercooler builder
- 5.3L PT7875 RX7 Numbers Inside!
- Vengeance builds 2011 GS Corvette 702RWHP Details/Idle Clip/Dyno Graph INSIDE!!
- 76mm/pump gas tuning help
- Tig welding a bead around the throttle body?
- Need a T4 housing for GT91?
- Recommend supercharger 500 rwhp no hood / cowl
- Turbo Guys that went from MAF to SD, What Wires?!?
- Twin Turbo Cooling Issues
- Pump gas with meth injection RWHP limitation?
- LQ9 whipple build
- E85 guys come in...
- Any FI guys use a Knock Sensor Gauge like the GN guys?
- Let's compare driveshaft rpm data.
- What turbo for 410ci stroker?
- ? about superchargers
- LS1 w/S480 on straight methanol
- d1sc conversion belt prob
- Anyone Using A Comp Cams 54-481-11 Turbo Cam?
- My 5.3 E36 Turbo Build
- Can I achieve 800 RWHP with front mount & D-1?
- Turbo w/ powerglide, what rear gear?
- BURST KNOCK settings - what do you have as 'safe'?
- On 3 76MM turbo on a stock 4.8L... Needs "Great" advise....
- how much boost with no tune ?
- how can you tell if the map went bad on a sd tune without a scanner. urgent help...
- maf question
- Corvette FI guys lovin on Tech FI section
- Budget heads for turbo 5.3L?
- Exhaust advice needed.
- What size meth jet
- ***Twin Turbo Lamborghini Gallardo VIDEOS INSIDE***
- **ZL700HP package from LMR**
- ***Edelbrock Supercharger VIDEO INSIDE***
- 2001 Z28 383 Turbo Pro Mod 88 Dyno 17 psi
- What would it take for 650rwhp?
- Turbo 4.8
- need build idea 5.3 turbo
- oil pan less than 1" off ground
- alternator relocation help needed
- supercharger 2005 ls2 vette
- So Close! 9.047 @ 153.74 (Video Inside)
- YET another 5.3L junker
- mp112 383 600 rwhp?
- vortech v1 t-trim that needs rebuilt, is it worth anything?
- questions about aps tt extreme
- sandwich adapter question?? need help
- on3 44mm waste gate
- Car shuts off after burn out
- Wide band questions
- lq9 rebuild- needs some tips for building for boost
- Lets talking launching with boosted cars
- no start turbo ls1
- Aps TT running hot any fix for this?
- Boost is Not Just Boost
- Went to the track for the first time! 383ci + D-1SC
- 04 gto, remote turbo
- quick question....-3 or -4 feed line for Garrett GT47-88?
- help setting boost.
- Should I run a meth kit??
- Trying to figure out what size pulley
- A.R.H./Farks Supercars Facebook Page
- TSP 454ci LSX / DP kit Twin GT35R C6 ZO6 dyno numbers inside
- RedRocket's 01 Z28 build - S480, Tick Cam, SBE LQ4, 4L80E, E85
- Alternator relocation question
- Kuwaiti 370ci TC76 l92 max safe power
- Need pics of gbodies and your gt4788 setup
- spec some turbos
- Any sponsors on here a Treadstone dealer?
- help with my next car? turbo or procharge?
- Questions on heads and cam
- Highest iats you have seen.
- Going to 317 heads with ls6 springs
- Valve Spring for Boost?
- PT 91.5 370LSX F Body
- 4L60E vs 4L80E higher rpm 800hp?
- $8000 for 4 hp???
- Procharger, TT, or Single Turbo
- Which A/R on S480Sx3 T4 for forged 6.0
- Boosted Big Cube on Pump Gas Ideas?
- picked up a spare 6.0 shortblock... need some things...
- No Low End Power With Boost - Time Slip Pic...
- Truck manifolds for ac in a chevelle?
- procharger LSx fitment in LT1 b-body
- Turbo 5.3 Blow Through Boat
- pics of freshly detailed 85 gn with turbo ls swap...
- Precision Turbo THIEVES!
- Congrats to Eric G (Wins a Wally!!!)
- LSA exhaust manifolds vs. Truck exhaust manifolds
- First turbo build with goals... (LQ4)
- Dissapointing Dyno Numbers. Any Ideas?
- When do they push water?
- will i meet my goal
- oil cooler with turbo motor
- Engine sits high after BMR turbo k-member Install
- Which heads for turbo ls1?
- PCV system with roots/twin screw
