PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 [224] 225 226 227 228 229 230
  1. Built FI motor vs TQ vs Boost
  2. Anyone using DFI????
  3. Are Ported Heads worthwhile for Forced Induction?
  4. Oil smells like gas?
  5. Fuel Pump Idea
  6. T3 turbo's
  7. Easy detonation question
  8. Twin Fuel Pumps and what size Injectors?
  9. Look at this ATI owners!!
  10. 7 psi (3.4") ATI pulley 4 Sale, CHEAP!!!
  11. Anybody replaced the stock ATI BOV ?
  12. How long will my stock rear hold w/ a D1SC.
  13. total cost out the door for a complete FI system.
  14. Which rear gear to go with for the tuner kit?
  15. from a blower to twin turbo
  16. 2002 LS6 cam with ATI....
  17. installing intake walbro pump on 2000 t/a
  18. What would be a better turbo/blower set up?
  19. converter with turbo question.
  20. Who runs the lowest compression ratio?
  21. LS1 Motorsports = bad customer service
  22. Powerdyne original parts list????
  23. 42lb injectors big enough?
  24. Anyone doing any big 2003 turbo buildups?
  25. Who has a cam and FI? Please take a sec and help me out...
  26. Custom H-11 Head Studs Available
  27. Timing v.s. boost...
  28. External fuel pump setups?
  29. Christmas came late this year.
  30. Small air filter on D1SC setup
  31. Question on fuel pressure gauge
  32. Going to order D-1SC tomorrow, help with the checklist...
  33. anyone turn on their power enrichment table sooner?
  34. Chamber Size
  35. Revenge of the Big Block
  36. Grenaded Tailshaft bushing, HPA Stage III 4L60E holds!
  37. need help, fuel system. Oh and started up the 408.
  38. Anyone running a 60-1 Turbo?
  39. Anyone running a 60-1 Turbo?
  40. Need help w/ elect fuel pressure gauge
  41. Where is my vacuum line?
  42. Plastic or Metal Plenum?
  43. I need info on CAS TT
  44. Well I did it!!!!!!!!
  45. Alky injection?
  46. Steel ATI idlers for sale
  47. Charged Air Systems Twin Turbo Kit
  48. Confused about adding checkvalve to PCV with ATI kit
  49. Any Merit in ATI SuperDamper Balancer to control Supercharger Bearing wear?
  50. ideal compresion?
  51. ATI's F3 blower.....
  52. anybody need 670rwtq and 525rwhp
  53. ATI Stage II Kit
  54. Vortech price increase January 15th!
  55. C5 Vortech S-Trim Video
  56. In tank Pump Options for 99s
  57. Paging Stealth
  58. anyone take out intake fuel pump from inside car?
  59. LS1 F-BODY LPE TT :)
  60. Safe to run boost and spray??
  61. If LPE makes a Blower for the F-body.
  62. Anyone run a filter off the valve cover...
  63. turbo kit made for ls1?
  64. stock postons ok with ATI 5# kit?
  65. '98 LS1 Engine rebuild recipe for MagnaCharger
  66. Vortech Aftercooler Bulletin
  67. where can i find these plugs?
  68. Need Help installing air/fuel gauge with pigtail
  69. FAST is running perfect, if you need it then read inside
  70. who has a relocated maf on the ATI kit??
  71. Turbo Camaro posts.
  72. Which cam is better for a supercharger?
  73. Where to buy madrel bent tubing??
  74. 408 ci iron motor + t76 + stock fuel system, what's going to happen?
  75. ATI tuner question
  76. Which "Cam" for ATI Supercharger and Ported Heads Combo
  77. Vortech Pulley Question
  78. Exchange ideas without harrasment
  79. relocated maf and now it doesn't idle well?
  80. TORCO fule additive??
  81. FS:V-9 Vortech Supercharger
  82. T-76 ?? on LS1 Motorsports Kit (Rob Raymer)
  83. ATI 5# kit question
  84. Attn--jam master j
  85. 600rwhp C5 vs. F-Body Fuel Pumps.... Major Differences??
  86. which is better
  87. Best Sparkplug For Forced Induction?
  88. New TT Kits????
  89. Few questions about an ATI
  90. throwing lean codes.
  91. What would make me run lean
  92. Intercooler/Aftercooler tweaking , Improving Ambients & Efficiency?
  93. Big Turbo Pics (56k users, beware)
  94. Do Turbos Always Have Higher Peak Torque #'s over SC?
  95. Detuning?
  96. Turbotech kit Q's
  97. Weinand Intake?????
  98. help a girl out......easy question :)
  99. Dyno results with ATI 7# kit
  100. How much oil leakage out of a turbo is normal?
  101. help w/ turbo???
  102. '02 ZO-6 Supercharger question?
  103. Home video - my ATI blown Formula
  104. Do LS1's still have head lifting problems under boost?
  105. Powerdyne Cooling
  106. C/H vs. Charger opinions..all mixed up
  107. T-Trim pics
  108. car dies after wot!
  109. How much will my cam hurt me ???
  110. ATI with Cam?
  111. ATI complete setup?
  112. Where to find these gauges?
  113. what parameters
  114. question regarding ATI D-1SC
  115. Foaming oil
  116. Turbo oiling?
  117. H/C with supercharger...benefits?
  118. QUESTION
  119. paging ATI users w/ a relocated MAF
  120. Spare parts? ATI or Vortech
  121. Fuel Pressure Issue
  122. FI MAF Solutions above 58 lb/min What are people using??
  123. Spal fans with ATI?
  124. Turbo manifold?
  125. Bottom End Questions....Experts Step inside please....
  126. How much can stock head gaskets take?
  127. @$%! Drats! Belt Slippage, fan quits at track!
  128. Best Supercharger Cam?
  129. Marine Superchargers
  130. Boost gauge rising after car is shut off???
  131. Best Supercharger Belts... Goodyear Gatorback vs. Gates
  132. Vortech V9 setup Ques?
  133. attn. Ed Potter or LPE staff
  134. Gauging interest on Custom Large Hi. Imp. Injectors
  135. Streetable 500-550 rwhp possible?
  136. "Supercharged" emblems and Boost gauge
  137. ATI Supercharger vs. Vortech Supercharger
  138. anybody know weight of lsm turbo kit?
  139. ATI Procharger - hooking up boost gauge
  140. Big hp cars or 10 second cars with dyno figures in here!
  141. What's Your Opinion
  142. Brand New ATI D1 SC for sale,,,,,cheap
  143. Tuning Issues please help!!!
  144. GWP-How much are their D-1SC Procharger Kits??(No Answer)
  145. Pro Charged Lingenfelter SS Dyno
  146. Record for FI Dyno #'s?
  147. What is the Safest A/F On A Turbo Car??
  148. If you had the opportunity to build your ideal engine..
  149. Twins vs. Single on a V8
  150. Took my GWP422 to dyno for first tune with 42# injectors
  151. 8lb's want more!!!
  152. Lingenfelter Blower
  153. Good Turbo Question's
  154. Anyone have 60-1 Turbo Dyno Results?? 68-1 Phyiscal Size?
  155. Your probably sick of it..but please
  156. Varied SC Boost levels seen at diff RPM's?
  157. How much fuel pressure drop is acceptable?
  158. what causes parts to break under boost?
  159. engine reliability @ 5# (ATI intercooled)?
  160. Need opinions of my twin turbo 68 Camaro engine setup
  161. Are the first wave of LS1MS turbos installed yet?
  162. Incon scavenge pump veterans, I need help!
  163. Dyno results for FLP heads, FLP blower cam, Vortech supercharged 2000 WS6 T/A...
  164. Where do I find out about certain info on my car?
  165. Intercooler Installation Problems
  166. tt setup what do you think?
  167. Anyone using 50# Injectors? Tune easy?
  168. Max boost with 10.5:1 and BUILT engine???
  169. TurboTech ??? on Alternator relocation....
  170. best place to get tuning...?
  171. More Boost + Less Timing = More HP??
  172. Turbo TA in HPP/Calling all 98 TAs with stock dyno
  173. 6 psi, do I need an aftermarket pump?
  174. LS1MS Single Turbo Power Distribution
  175. H/C with procharger?
  176. Vortech Crank Pulley...please help get it off
  177. 10psi ATI DS1 Procharger...how much power?
  178. Turbo technology single turbo kit $4500
  179. LSM single turbo kit on top of a H/C???
  180. 1970 Chevelle TT427. General help needed for planning this.
  181. anyone try this fuel pump aproach?
  182. Hypertuetetic (sp?) vs. Forged, better for FI??
  183. Fuel Supply ?'s
  184. Gauge Questions, Please help.
  185. Got Dyno Tuned, but NEED help from Incon TT Owners!!
  186. FAST almost done, How much HP will I make
  187. TURBO INFO PLEASE?
  188. Supercharger or not?
  189. ATI Guys interested in a good priced cog set up?
  190. Turbo block opinions..LS6 v.s. LS1
  191. I really need some help!
  192. help with fuel setup...
  193. ? about 3.8 turbo f-body
  194. tuning worth it on ATI p-1sc?
  195. has anyone made there own tt kit??
  196. Twin Turbo
  197. C5 Turbo kit ?
  198. Paging Matt Harlan and Eric Connelle
  199. intercoolers
  200. Dyno'ed today not too great....
  201. Fi guys howed you fix your PVC system?
  202. Denso lead proof o2's
  203. ATI P-1 4-sale
  204. LSM single turbo kit ????
  205. Inline v. Intank Fuel delivery systems
  206. Ideal Compression ratio
  207. upgraded radiator
  208. Opinions for this specific Comparison...
  209. PSI level?
  210. Is the LS1 REALLY a 347.88??
  211. Surge valve
  212. Single Intercooler Piping touching Sway Bar Ok??
  213. Best wastegate for my turbotech T-76 kit
  214. LPE 8.95 @153.6 427TT Vette - video inside
  215. Where would I get a water cooled turbo ?
  216. Stock block and forced induction
  217. Formula LS1 (stock engine) with ATI's D-1SC makes 462RWHP
  218. LS1 Motorsport turbo kit's O2 sensors
  219. Stock Motor Questions?
  220. ATI Procharger D-1SC Setup vs. Singe Turbo Setup
  221. maf draw or blow through
  222. A Question About Turbo Log Primarys sizeing?
  223. Paging Rob Raymer
  224. Any Other Turbo Cars In AZ?
  225. Experienced ATI users answer here
  226. FI Forum Newbie
  227. Buying 42lb Injectors - Are These The Right Ones??
  228. New LS1/LS6 Crank Damper with TWO keyways & Pin Kit
  229. Hesitation on top of 3rd gear
  230. The ulitmate blower setup?
  231. Dual Blowers?
  232. ok experts how much boost can she take
  233. Belt Slipping? Check it out. Gatorback belt info within
  234. ATTENTION!!!! ANOTHER POSSIBLE EBAY TURBO SCAM
  235. what just happened?
  236. ATI 3 Piece Cog System $550.95
  237. Procharger Question ??
  238. Now I am really confused!!!
  239. Compressor maps for Prochargers
  240. PROS/CONS
  241. Anyone have a Vortech SQ sound clip??
  242. Throttle Body with SC?
  243. please help in finding turbo kits.......
  244. I have a t-60
  245. Head Flexing under boost? > Get them "Pinned"
  246. Paging Mike from MMS
  247. LS1 Motorsports Single Turbo
  248. Waiting for my new mota in my Z, took the 1LE out for some action
  249. P1SC-1 or D1SC and why
  250. D1-SC Noise Levels... anyone request a quiet blower?
