PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 [202] 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Turbo with Borla question
  2. Opinions on Intercooler Sprayers
  3. My 66's are forsale
  4. 703 RWHP 4x4 6.0L
  5. Max Power On Stainless Valves??
  6. Gauging cost on QMP kit- Will I even like it?
  7. Head Gasket Selection?
  8. Afr 11.1
  9. STS ground clearance
  10. Braking Under Boost???
  11. How are the Fast LT1's
  12. Low CR + Boost+ pump gas
  13. Almost got the motor in.
  14. Question for people with Griffen FMIC on a Camaro
  15. Would a T91 work on a Speed Inc T88 kit?
  16. my 9 sec 787rw 346" for sale
  17. incon car on ebay
  18. Alternator bracket
  19. magnacharger
  20. twins and plug wires=not good
  21. Boost And NOS???
  22. Strange problem here....
  23. Turbo whine?
  24. MMS Pulley Problems
  25. Oppinions on the LS6 cam for blown car?
  26. How much is 1psi equal to in terms of power?
  27. 11lbs of STS Boost + New OPTI = COil Over system I guess?
  28. Diamond pistons
  29. Olsd School D3 procharger project
  30. Here is broken piece in my tranny
  31. Please Help me Select an LT1 Blower Cam!!!
  32. Boost Question
  33. electric smog pump subbing for a vaccuum pump?
  34. Compressor map for Super T-76 turbonetics
  35. S/C or Turbo?
  36. Hell fire rings
  37. Magnacharger with LG Motorsports G5X-B hits 512 RWHP!!!
  38. Eaton M90 Supercharger on a 3.8L 99 firebird!
  39. GP deep discount has been met!
  40. New Ls1 Record 8.11@169
  41. STS Sponsors
  42. TTI T-66 kit and fans...
  43. Only getting 2 to 3 PSI from Stock STS lit?
  44. Turbine housing size vs RPM
  45. Pipe shape between turbo and IC
  46. STS Meth system is screwing up? HELP please!
  47. Need you SC savvy guys to help me out
  48. Who is making good power while passing emissions?
  49. STS on a 2004 GTO almost done
  50. Effective Compression Question
  51. Questions about Supercharging
  52. Need help picking wastegate!
  53. Harmonic Blaancer Problem
  54. LT1 FI Supercharger guys/gals
  55. What kind of cam for forced induction?
  56. ifr for 60# at 54psi base fp??
  57. What would you do?
  58. ? For Those W/ Around 500 rwhp Stock Block 346's
  59. STS turbo questions.
  60. took the car for a drive today...SDCE people in here please
  61. LS1 Fuel Rail GP inside!!
  62. Any FI guys care to show me your Spark Advance table?
  63. sdce spring tensioner orders
  64. Procharger oil?
  65. One more time -- Cam Motion cam FS
  66. Where can I find some good turbo kits?
  67. Opinions on a good blower stall
  68. STS featured in CHP!
  69. Bigger ATI air filter guys in here
  70. Efficiency of the OBX FMIC?
  71. who has the best meth injection.
  72. Kissing the Blower Goodbye
  73. GTQ76 Turbo
  74. Customized STS Twins
  75. Pondering the Future
  76. How much power from these Turbos?
  77. exhaust on sts
  78. Were do I get a smaller pully for my Vortech?
  79. CAS Regulator Owners...
  80. all those with forced induction
  81. Larger Turbo Question
  82. Supercharger or Turbo
  83. STS and hotcam?
  84. Pics of amacgt 2000 C5 rear mount turbo
  85. CAS guys inside
  86. What Size Intercooler to use for a Front Mount?
  87. 04 GTO- options for obtaining around 500rwhp..
  88. How Much low Boost with STS set up and 8.5 to 1 Comp?
  89. Update on my car,(major diet)
  90. ATI Balancer users... belt length?
  91. Crank Pinning
  92. Pics of the new turbo car
  93. Turbo EGT
  94. Willing to trade 3.3, or 3.4 ATI pulley for bigger than 4
  95. Blitz SBC i-D III (need help fast,,please)
  96. Turbo Question.........
  97. Next Level Perf Installed Intercooled Vortech Base Package $6995 thru 12/15
  98. turbo oiling question..??
  99. Question for the STS peoples.
  100. can anyone help out an N/A guy???
  101. Oil all over
  102. what do u think?
  103. 2000silverbullet is dead.
  104. what after market damper , with STS turbo system.
  105. Yella Terra rockers With STS Turbo kit
  106. ATI Guys, what pcv setup you running?
  107. What happened to all the turbo'd C5's?
  108. STS turbos and ATI superchargers on sale!
  109. twin turbo 350
  110. Extending O2 wired on the AEM UEGO gauge?
  111. Turbo + pcv sys = ???
  112. Anyone know anything about the New GT55 turbo?
  113. To much boost?
  114. Got a FMU on a STS system question?
  115. Fawk I think I hurt my motor...:(
  116. Qmp Owners... Inside
  117. sic viper
  118. Need to find a boost only source no vacuum..
  119. New toys!!
  120. what i think about you forced induction guys.....
  121. Exhaust leakfound
  122. just put a rear mount on a 2000 c5
  123. Belt Size
  124. STS turbo system Part sub fram connector?
  125. Project Turb Hoe
  126. Another Magnacharger in the 10s tonight!
  127. Few boost accessories FS
  128. FS LM-1 Wide band
  129. Which wastegates
  130. Need help with gates belt part number
  131. Anyone know where I can buy a 4 inch cutout?
  132. STS Turbo with wideband O2
  133. Pro Turbo Kits > Christmas Sale!
  134. need some input
  135. TR224 114..... decent SC cam or should I swap?
  136. How much boosted RWHP can a stock bottom end handle?
  137. Choosing the proper turbo
  138. Finally got on the dyno, what do ya think?
  139. Need help figuring out how to mount a 10 rib crank pulley
  140. AMW catch can in FI setup.
  141. custom turbo kit parts???
  142. Who said D-1SC can't make crazy power?
  143. FS: Reichard Racing ultra grip pulley
  144. Joining the boosted family- buying nasty's kit
  145. check this out
  146. what size CI motor are yall running?
  147. Digital Boost gauges...
  148. Installing STS mon.
  149. Hey SDCE anything on the FMIC
  150. Does anyone sell just a bracket for Centrifiguls
  151. Anyone compare 50/50 Water/Alky vs. 100% Alky?
  152. Alcohol - Methanol injection nozzle
  153. What kind of guy am I????
  154. What one of these cams should i run
  155. For those that have purchased the OBX FMIC.
  156. Post your Boost Gauges and Controller Pics Here!!
  157. how much oil for turbos?
  158. turbo exhaust setup
  159. STS qusetion
  160. T-trim installed on 382ab
  161. Racing vids. 2004 Yamaha YZF-R6
  162. Turbocharger or supercharger
  163. The QMP Kit Rules!
  164. New Numbers
  165. Will this PCV setup work on turbo car?
  166. Intercooler Testing??
  167. Effects of Primary Size on Turbo Motors
  168. Rear mount right after headers
  169. STS Kit
  170. Will a 60-1Turbo be too much for...?
  171. please post if interested in sdce gp
  172. Interesting source for tubing and some related stuff
  173. Anyone sell the tubing and OBX Intercooler complete for STS turbos
  174. Need some advice on my Intercooler plumbing
  175. STS Turbo kits are they good?
  176. benefits of FMIC over Vortech's aftercooler on big blower?
  177. High flowing heads - benefits with FI
  178. Man I hope this TT kit will be worth it!!!
  179. I need a tune anytuners............
  180. Icon Twin Turbo set up
  181. Turbosmart controller vs. Innovative
  182. incon y-pipe question
  183. h/c forged shortblock
  184. who makes the best turbo kit for the ls1
  185. ANOTHER SPEED INC CAR IN THE 140'S mph
  186. Question about my cam for a blower?
  187. No STS dealers need some sort of sponsor?
  188. STS Turbo kit questions
  189. 214-224 115+3 deg blower cam with Turbo?
  190. Chime in on this theory...
  191. Need advice on BOV selection.
  192. what rpm are my stock valvesprings good to with my vortech?
  193. It's alive! after over a year!
  194. reverse pattern cams??
  195. Procharger D1SC vs Vortech V9SQ pro's and cons?
  196. twin turbo montecarlo (pics)
  197. 500rwhp with a lowly stock 4.8
  198. Turbo Cam??? Recomended!
  199. Perplexed - Fouled plugs + three melted/missing tip ends....
  200. TT Fuel Systems
  201. Help! Need some input/advice....
  202. HPE "S" Cam w/turbo
  203. FS: ATI D1SC Procharger kit, very low price, must sell asap!!!
  204. Gains/losses with the FAST 90 with forced induction?
  205. TT v6 capabilities
  206. Blower cam...what do ya think? (specs inside)
  207. FS: ATI D1-SC, SDCE Spring Tensioned 8 rib, FMIC
  208. forgotten track vid found!
  209. Vortech guys please come in
  210. LS1 PTK turbo kit???
  211. Where to get TTi kits?
  212. Whats the maximum boost you can run on pump gas?
  213. Cheap Insurance or Waste of Money
  214. any LS1 guys local to us looking for mods?
  215. SDCE tensioner with ATI 8 rib
  216. NEW GP's
  217. Couple D-1 ??
  218. A little bit about us...
  219. Anyone Want to sell their car??? got money! :)
  220. whats the trim
  221. who sells a larger dia crank pulley?
  222. WOT tuning help
  223. SDCE now a sponsor????
  224. Stock Bore + O-ringed 6l heads = what gaskets?
  225. STS questions for NE1 with a Turbo
  226. AFR 205 66cc with 224 XER: thinking of a little boost later.
  227. Wastegate question
  228. whats the max timing i wanna have?
  229. Fmic ?????
  230. SDCE Group purchase
  231. no more maf limit for me
  232. aeromotive A1000 pump anyone using?
  233. Need some advice on fuel system
  234. Multiple misfire at idle only
  235. F.A.S.T Controler with MAP sensor
  236. vortech cold start in UK - 240 volt engine block heaters?
  237. Compression ratio ?
  238. Vortech Super Sale - beat the price increase!
  239. Methanal Injection
  240. FI cam FS cheap
  241. Which gear to run with my new Twin Turbo setup??
  242. i think ive finalized my turbo setup
  243. No more spray for me;mod list
  244. pics
  245. How much will 4lbs raise my compression?
  246. CAS owners chime in
  247. advise on gears???
  248. Where to go from here?
  249. Turbo or Supercharger
  250. What size injectors with blower?
