PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137]
  1. Nice hearty tire bark replaced by...grinding?
  2. A little T56 FYI
  3. Need a new T-56.....
  4. M6 people how do you like your 4:10's:
  5. SPEC clutches. anyone else heard of....
  6. Does anyone know where I could sell my t-56, 6-speed tranny??
  7. Which clutch to buy? Star, Cartek, or Ram?
  8. Last minute suggestions on clutch install?
  9. Clutch hydraulics. Need experienced help!!
  10. My M6 Synchronizers
  11. Strange clutch behavior
  12. M6 question
  13. tranny wont go in different gears after new clutch
  14. Tranny synchros for mn6 - are they under warranty?
  15. Where can you get a flywheel resurfaced ?
  16. Clutch master cylinder question? Please help!!!
  17. Ram Clutch Problems...NEED help....
  18. Cartek adjustment?
  19. Gear engagement on a cold T56
  20. Who has the best clutch setup these days?
  21. Impressions of Mcleod adjustable master cylinder
  22. Can a 98-up LS1 T-56 be rebuilt.....
  23. Girdle's.. Good with M6?
  24. Will stock clutch handle a short Road Race?
  25. Pulling M6 trans was easy... Bellhousing? Yikes!
  26. Clutch Pedal sticking Please Help!
  27. CLUTCH PROBLEM???
  28. Can i use a Z06 clutch and pressure plate with my otherwise stock setup?
  29. Aluminum Flywheel; is it worth it?
  30. T56 problems
  31. Any Spec Clutch Guys in here???
  32. CARTEK OR RAM
  33. Car is sticking in gear after speedshifting!(M6)
  34. Grinding on 1-2 shift
  35. WTF-extremely sporactic 2nd gear GRINDING...any ideas?!
  36. How I solved my clutch chatter issues
  37. Just how much does an LS1/T56 swap into a non F-body cost ......plenty!
  38. My T56 is GONE!!???
  39. Installing new clutch would like some help with hydraulics.
  40. Great website for those interested in how a clutch functions.
  41. Clutch pedal return spring broke... TWICE!
  42. Who makes the 2002 Z06 clutch ? Valeo ?
  43. Clutch pedal sticks to floor?
  44. Special tools NEEDED for a clutch install ?
  45. Cartek chatters BAD! Please inquire within.....
  46. How do you "snick off clutchless up-shifts"?
  47. Just ordered the 2002 ls6 clutch
  48. Do I need to get an adjustable master cylinder with the 2002 Z06 clutch ?
  49. Do our cars have a T-56 tranny?
  50. ***HELP***CARTEK clutch starts engaging from the floor after a hard pass! :(
  51. Need a clutch,validate my research PLZ
  52. Help me bleed my clutch..... Pleeeeeaaaasssseee!
  53. Clutch reports please!
  54. CarTek Clutch
  55. Weight of a T56
  56. How do you change clutch fluid.
  57. M6 to M4
  58. How much effort/money would it take to put a C5 gearbox in my F-Body T56?
  59. What clutch to get?
  60. My CARTEK is slipping after 5k miles!!!
  61. Please don't shoot me. Clutch question. Long
  62. What clutch and shifter would you reccomend???
  63. Bleeding clutch, have question..
  64. clutch question
  65. Pro 5.0 Shifter is the ****!
  66. How much can you cut off of the PRO 5.0
  67. Difference between the 01 clutch and the Z06 cluch?
  68. Excessive clutch play when cold
  69. 02 Clutch - pedal feel
  70. Hays LS1 Clutch... anyone tried it yet???
  71. T-56 problems, did I break something internally??
  72. Best clutch for the LS1?
  73. Owners of McLeod dual disk - please comment
  74. Ok I need M6 help asap
  75. Viper T56 parts.....
  76. Can I put the gear ratios from the Z06 in my T-56?
  77. Pro 5.0 shifter
  78. 350 miles after the install my Cartek clutch is doing GREAT!
