View Full Version : Manual Transmission
- Probably been asked a million times but I can't find it. Any rebuild guides for T56?
- A little compatability help please
- Just installed Spec Stage 3!!
- Clutch/tranny problem!
- Is the torque arm bracket on the tail of the tranny the same on the m6 and a4?
- WTB: LS1 T56 parts, where to get them?
- RAM clutch or spec stage 3 ?
- Flywheel Help?
- clutch choice
- Is this ok for my t-56?
- Just installed my Mcleod Twin Disk
- Question about T56.. Fluid Lines
- i had something weird happen today shifted into rev when drivin
- 4th Gear Grind
- Shopping List Needed for Replacing '98 Stock Clutch
- spec 3 chatter disappears with mcleod master cylinder? Help!
- centerforce or spec???
- Hard to shift 1-2 at high rpms
- Rebuilding a C-5 Tranny????
- Shifiting problem??????
- Thread Size?
- Borg Warner 6 speed?
- How many have had problems with Spec III Clutches?
- 02 Hydraulics
- Spec Warranty ?
- 02 C5 Pressure plate and disc interchangable with 98 Z-28
- question about slave clyinder
- 3RD gear trauma/rebuild
- rebuild/upgrade parts for T-56?
- The Clutch Prob Post
- Will the Z06 clutch hold up too......?
- which shift knob with B&m
- shifter questions
- WHAT OIL for my M6????
- GM 3/4 shift-fork recall??
- T-56 Upgraded parts kit?
- Anyone test hp limits of McLeod single disk clutch? I'm about to myself....
- Leaky Tailshaft R&R
- Let me try LS1tech for my last plea of help
- Anyone tried the Steeda Tri-Ax Shifter?
- New Hurst shifter
- jss installed on stock hurst
- trouble making 1-2 shift
- few flywheel questions
- Need help selecting clutch....spec 3i?
- Roasted clutch with a side of 'pedal to the floor'?
- 650+rwhp- Spec 3i clutch hold???
- My Z06 clutch kit only came with three pressure plate bolts!! WTF?
- Clutch engagment point changes
- Attn: Camarohaulic- rebuilding tranny myself
- where to find a spec 3?
- 1st gear grind after clutch replace
- looking to buy shifter with shift stops???
- spec 3 breakin?
- spec 3 on near stock car
- Ran 11.6 at 118mph with stock clutch-gonna need a clutch soon help!
- Does my shifter have stops?
- Lost 5th gear, what happened?
- How to take off/put on a T56
- WTF, car still wont go into gear at high rpm's.
- throw out bearing? hydraulics?
- quick ?
- T56 Problem: 4th Gear Completely Stuck!!!!
- Leaky MC
- Do I need to lube the trans input spline?
- Lightweight Crossmember
- centerforce vs ls6 clutch
- clutch and shifter question
- Rebuild t56 myself or pay someone?
- ARP Flywheel Bolts - Loc-tite or no?
- SPEC III - Love it.
- Should I change clutch slave?
- Drill mod experience
- Spoke w/ a tech from Ram
- stock or aluminum flywheel?
- 11's on Stock Clutch and Stock Suspension?
- Cartek Clutch
- LT1 T56 behind a LS1??
- pulled a 1.64 60ft-what are you guys launching at?
- Good day of racing= SCREWED TRANSMISSION
- how hard is it to change the clutch
- Clutch sticks to the ground when driving hard?
- my A4 sucks! i want a M6
- Super Detailed T56 Rebuild Sequence Pix/Description
- B&M RIPPER REVERSE PROBLEM!!!!
- CUSTOM T56 in the works
- Transmission problem?
- is this normal
- Straight foward answer...
- T56 experts needed
- Call me crazy, but I think the factory Hurst has positive stops built into it.
- Spec Stage 3 or Stage 4 or Ram???
- Please HELP! Tranny Locked!!!
- Swappin Shifters, Pro5.0
- RAM 910 clutch installed!
- Is my T56 gone?????
- cheapest place to get a spec, and one more ???
- Anyone know the difference in these slaves
- RAM 910 or 980? what is website
- Centerforce dual friction
- 99 z28 manual transmission gears
- A few Q's about a m6
- Getting Spec Stg 3 - One ?
- Ever here of a broken tranny tail from TA?
- Stout clutch
- clutch install. Help?
- Changing Trans and rearend oil?
- 4:30 gears?? what rpms at 70mph????
- Gaskets?
- Mcleod Master
- Break in Period for T-56
- Wes Mclaughlin A.k.a. Wmsupersport
- 10-11 sec M6 1/4 guys, what are your bleeding techniques?
- Spec Stage 3 squeeks?
- McLeod street twin
- Shimms when resurfacing stock flywheel
- gauging interest in A4 to M6 swap
- Trans Maintenance.
- ZO6...two failed Spec3...what next?
- Spec Stage 3:Kevlar?Ceramic?Carbon?
- Are the Lou's SS and Stock Lou SS handle interchangeable?
- Rebuilt tranny question
- Clutch
- shift knob problem?
- Installed B&M Ripper...Awesome!
- HELP!!! Need Slave bleeder valve wrench size!
- Clutch brake in
- Some clutch and fly wheel questions
- Need good all around clutch?
- Ok damnit, T56, internal positive stops negate use of them on aftermarket shifter?
- Those with RAM 910 VDS what gears do you have and do you have chatter?
- Which clutch for a NA high 10 second Z LT1
- Clutch bleeding/bleeder valve
- Confused on hydrolics and clutch ..
- scatter sheild or trans blanket - what is out now
- Does the Shifter have to be removed to pull the tranny?
- gripforce clutch?
- Clutch and Hydraulic Choices?
- Burnout dilemma
- New LS1 owner , need tranny/throwoutbearing removal help
- i need a good price on a spec 3, and some other help
- clutch help needed.....
- Need Beefed UP T-56
- Mcleod street twin?
- How durable is the stock T56?
- vibration = lost horespower?
- Anyone try the SPEC stage 5 yet???
- Is my clutch causing this problem?
- PLEASE HELP (no pressure in clutch drill mod)
- Are Spec clutches balanced?
- What 60 ft are you guys getting on nittos's
- 2nd to 1st
- 12 bolt breakers!!!
- Anyone gotten their trans "slick shifted"...not proshifted.
- cartek clutch (help)
- Can anyone tell me how they pedal
- Clutch
- Power Shifting???
- Clutch Differencees...and what they mean
- fixed my broken trans mount today but have a part # question?
- Are the flywheel bolts
- help w/ new clutch
- do they MAKE a clutch...
- did a high speed run and...
- Mcleod bellhousing installed
- Will Tranny Rebuild Work?
- SPEC 3 or 3I
- T56 from 95 camaro work with a 94 vette?
- To cut or not to cut pro 5.0 shifter
- Clutch pedal stuck to floor
- Tranny Mount causing y-pipe to bang?
- not the same but similar
- Clutch-What do you think????
- Banging/rattling coming from under pedals...
- Just an FYI on the Ram clutch...mine wore out....info inside
- should a new clutch.....
- burning clutch???
- winding sound
- eastside performance hydrolics
- Squeaky clutch!
- Do I REALLY need a Mcleaud twin disc?
- clutch quick disconnect?
- Clutch slow to engage but not slipping, any ideas?
- mind boggling
- ??Reuilt Trans
- What do you guys think of the Mcleod street twins?
- Pro-shifted T56 @ the track
- updated hydrolics for 98?What part #?
- Problems with Pro 5.0
- Aluminum or steel flywheel?
- Clutch Question
- a little chatter - stock clutch
- Clutch bleeding????????
- Transmission Noise
- Does the 2001 M6 vette have a LS6 clutch?
- HELP!!! T56 Popping out of fifth...
- Spec 3 flywheel options???
- drill mod question
- car wont start after clutch install.. help!!!!
- Help Please
- POS pilot &.....
- Spec stage 4???
- Newbie M6? Trick to getting into reverse?
- Spec stage 3 is in.
- Clutch problem. I think!
- Swapped out my factory Hurst w/ JSS for the B&M Ripper w/ JSS
- Clutch for cammed 00' Z28?
- Will it be ok to re-use Pressure Plate and McLeod Master Cylinder with a LS6 Clutch
- RAM 2550 flywheel, shim starter?
- Cost of tranny rebuild
- What is it that fails?
- Everyone's Opinion
- Having problems installing T-56
- Z06 clutch help. Please read!
- Whats best?
- clutch problems
- Stock Clutch??
- Smoked Clutch
- speaking of shift lights
- T56 Parts?
- need advice on shift light?
- Weird noise when I push the clutch in when the car is cold?
- Updated slave help!
- t56 noise (help)
- drill mod and bleeding the system, can i do it easy?
- Reuse Clutch Pressure Plate?
- T56 Gear Ratios
- Ram 910 or Mcloud Twin Disk
- Reverse lockout?
- Hmmmmmmm
- am i screwed
- Pro 5.0.
- gettin a new clutch what do i need?
- Where to get T-56 upgrade parts?
- Spec 3 update break in complete
- Spec 3 vs. McLeod Twin Disc
- Transbrake
- cartek clutch
- Bled system, no pedal feel,HELP-asap
- what's a normal cruise rpm?
- clutch question
- Need new syncros? 1st slides right out.
- Help With Mcleod Adj. Master
- What Clutch?
- beefed up t 56?
- Spec I
- Pro-shifted T56 is in...
- Question about Ram or MCleod
- mounting our m6 to old school small block chevy?
- Getting ready for first clutch install
