View Full Version : Manual Transmission
- m22 muncie carnage (pics)
- t56 input shaft play?
- Mater Cylinder Hydralic Line Question
- 12" centerforce installed
- Spec Stage 3+
- what do I need?
- witch clutch???
- GM High Tech Mag. LS7 Clutch in a ZO6
- do I, or do I not get clutch/Flywheel balanced?
- Grindes going into 4th
- Ram HD installed: 5-31-06....GREAT!!!
- clutch is acting funny, whats goin on??
- problem with ram clutch install, HELP!
- CRASHING clutch pedal??? wtf
- LS7 Clutch adj.???
- Pressure plate bolts or Master??
- T56 Tranny Cooler??
- Pro 5.0 "Power Tower" shifter for sale *new*
- Road race trans? sequential?
- Tell me what happened???
- LS7 clutch and stick tires, who's done it?
- Crazy vibrations and noise. HELP!!
- revs up when i push in the clutch?
- Just ordered Ls7 clutch kit from t-56 Rebuilds...
- Differences between ls6 and ls7 clutch?
- drill mod for c5 zo6
- Couple master cylinder questions
- UPDATE...my clutch has issues..
- Centerforce 12" DF clutch slipping or chattering on slow take-off from a stop
- can we reuse our stock pressure plate?
- Supra Turbo R154 trans to LS1/Gen III V8- Custom Clutch Disk?
- Need Advise on New Clutch/Flywheel Setup!
- Problem with Short Throw Shifter (If you Have one Come In)
- What can I get out of it?
- Done with new clutch Install
- HELP!! LS7 Clutch Install Problem
- slave cylinder
- LS7 clutch kit installed....
- Bad Master Cylinder?
- Pete at Textralia?
- MN12 Grinding third gear?
- Textralia 0Z700sb
- T-10
- t56 and spray?
- Skip Shift Solenoid
- another a4 to m6 conversion
- t56 Help
- A4 to M6
- Another LS7 Installed
- burning smell coming from under car and engine bay, just had new clutch installed?
- SFI approved bellhousings?
- 11,000 miles and still ok.
- adjustable clutch master clyinder question?
- T56 dependability
- Shifter ?
- Tranny Issue?
- Tranny whines (T56)
- which clutch?
- 6th gear issues
- M6 tranny mount
- Help My Tranny Is Stuck In Fourth
- m6 feelin shaky
- shift skip on my ta buckin and shakin? help please
- Car rolls in gear
- M6 Transmission problems
- Fluid Leak
- LT1 Clutch Owners
- cupholder question
- Wierd clutch question.....
- Anyone use a Brakebest or Bendix slave cylinder?
- Weird Clutch Feeling
- Hit 3rd and something gave out - help!
- Trans will not go into 3rd @ track.
- HELP!! Clutch wont go into gear!
- My LS7 clutch kit finally came...
- what clutch?
- LUK progold clutch?!
- Why cant we use regular chevy clutchs?
- Anybody sell the z06 clutch disk by itself?
- ram powergrip hd part numbers?
- Clutch noise when released?
- SPEC 3+ problems
- Master and Slave Cylinder
- T56 Swap question???
- Do you guys have this problem?
- Is it normal that the car rolls backwards in gear when parked??
- clutch Master cylinder
- clutch master cylinder mounting hardware?
- Drill mod or new cylinder time
- center force pedal pressure ?
- viper T56
- spec billet flywheel weight??
- Strange Clutch problems, need help...
- What should I do?
- How far should pedal travel to disengage?
- help
- Need Help Asap
- Clutch bolts
- Need help with Reliease/relief bearing spring!!!
- Tranny mount causing problems?
- clutch problem. please help.
- What clutch is good for my application
- Reverse problem!
- Clutch Scared!
- clutch stickin?
- Trying to drop my engine, can't get nipples lined up
- UMI short throw shifter handle
- Check this out fellas
- Spline count for '00 Camaro t56 driveshaft side
- Hard to get into gear HELP!!
- LS7 clutch owners chime in........
- Drill Mod huge improvement with slippage!!!
- Looking for a new shifter for my WS6
- New LS7 Clutch: What do I need???
- Flywheel dow pin
- Drill Mode Any Good 4 Lt1
- slave valve
- trans problem
- Just having some fun with a hacksaw, vice, and a gas welder lol
- Why is my clucth still on the floor
- Clutch Masters Stg-3 700RWHP.... OPINIONS? Yea or Nea??
- Centerforce DF 12" shifting issues
- LS7/LS2 combo results
- instructions: how to rebuild pro 5.0
- Aftermarket Ls7 Flywheel?!?!?!?!?
- proper method for install/bleed of hydraulics
- centerforce clutch is it any good?
- Couple of problems.
- T56 Safety Housing
- updated slave part#
- Still Having Problems With Clutch
- Spec 3+ Clutch, Need Help!!
- Help!
- Another successful install “Pro 5.0”
- Grinding Into 6th?
- trannys gone bad
- Ordering new clutch. suggestions please.
- Got my clutch...Questions
- Strange thing happend... problem?
- shit! bent shift rod
- a ticking noise
- Anyone running the McLeod twin disk?
- T56 Stuck in 6th gear???
- Speedometer way off! Why?
- Should I get a short shifter in my position
- Any one use a speed inc built t-56 street trans?
- Textralia clutch
- adjustable master cylinder?
- t56 to 4.3
- LS7 clutch and alum FW installed. Any questions?
- Another Ram bites the dust...
- Spec Pp
- Bellhousing help.....
- Figured out the noise from new clutch and flywheel.
- Manual Transmission FAQ - Look Here First!
- my clutch has issues..
- What do think caused this?? (56k beware)
- Noisy Drivetrain
- z06 slave for fbody?
- Need instructions on Master Cyclinder and Slave Cylinder install?
- z06 clutch for sale
- My clutch just gave up....
- Is it rebuild time?
- TEXtralia OZ700 x or z grip? New Slave?
- Can't get the clutch release line off tranny!!
- rockauto parts?
- how much you think ls1 t56 weighs
- Do I Have To Get An Adjustable Master Cylinder?
- Stupid Question
- Earl's Solo Bleeders???
- Clutch Bleeding Problem!!!!
- New clutch, Tranny grinds when clutch is at floor help me out.
- what is the drill mod
- F1 x-lite flywheel
- Clutch vibration
- New Clutch!!! now problems...
- Quick Ploy Mount Question
- Installing ws6 short stick
- How hard to replace clutch?
- Hurst ??'s
- best shifter for 2/3 shift... pro 5.0???
- what is wrong with my cutch
- ARP Part # for clutch bolts...
- In need of a part number
- Clutch master O-Ring
- New clutch install, now car won't go into gear, PLEASE HELP!!!!
- Clutch install prices??
- will ford tremec fit lq4?
- which snap ring pliers for T56?
- just wondering?
- I have bench bled the master, but is it ok to put the slave in dry?
- removing clutch slave from tranny...?
- Car grinds into 5th gear and reverse when still warming up?
- Need a good trans mount
- O F&*K!! Need Help with clutch install
- ls7 clutch
- What year is this T-56?
- question...
- Slave Cylinder
- Spec S3 in LT1 vibrating!!!!!!!
- clutch sticking and noise
- aftermarket bellhousing?
- Help me diagnose my M6
- Centerforce dual friction w/drill mod??
- New GM Hydra-Matic 6 speed RWD Planetary Manual transmission
- new clutch, does not release fully
- Clutch is starting to slip bad....... :(
- Breaking in new clutch questions...
- Clutch Issue
- Which clutch for very high power
- crushed magnets??
- Master cylinder question
- Creaky clutch
- pro 5.0 shifter?
- A real problem with SPEC clutches.
- Can a corvette clutch/flywheel be used in a f-bod?
- m22 to ls1?
- Master Clutch Cylinder, Auto Zone?
- bleeder on the t56
- Out of Ideas, Help !!!!!
- Ram Clutch
- T-56 and Big Block
- whats the best clutch for t56.
- Anyone Using a 2-Step?
- LS7 clutch kit ordered...
- pro 5.0 springs
- big thanks to TDP
- Everybody is an idiot at least once
- WOT 2nd gear grind
- out with old in with brand new
- Shifter Install questions
- PLEASE READ!WHAT went wrong ?
- Loose Pressure Plate Symptoms
- T56 feels knotchy after driving hard (more after fluid change)
- t-56 question?
- clutch chatter?
- What trans is in a new z06?
- Tranny removal with longtubes
- hurst to pro 5.0?
- Auto Meter Quick-Lite Shift Lite???
- Factory "H" leather shifter knob
- Will LS1 work with LT1 T56??????????
- mcleod problems...where to start
- What did I break? Fluid leaking like crazy.
- New Clutch Fried?
- What can the LS7 clutch handle
- Clutch engages different at WOT
- New B&M "Precision" Short Throw Shifter opinions
- URGENT NEED HELP NOW. i broke the car
- Clutch issues.....
