View Full Version : Manual Transmission
- NE1 Break a 10bolt With Stock Clutch????
- Spec Stage 3 Installed!!
- Why want my clutch pedal push in...
- Best price for the 01-02 slave cyl.????
- Can you bleed a MC while on car?
- Please help me with spec 3 clutch Break in procedure.
- How much horsepower can a LS6 clutch handle?
- Flywheels. Whats the diff.?
- RAM clutch user's inside.....
- How to adjust Mcleod master?
- Yank transmount/TA mount
- spec clutch is here, as is another question
- Ending the speculation: Blocker rings, who's had them fail?
- help with bleeding the clutch
- Mcleod Slave Cylinder
- Help me please
- Anyone ever do a before and after dyno with a TH400 swap?
- LS1 382 stroker / stock T56. Will it hold?
- Throwout bearing noisey
- something to keep me busy this weekend
- Anyone using a Spec Stg 3 w/98-00 hydraulics?
- Hate Stock Friction Point
- where can i buy the lou's short stick?
- When cold, I grind into 2nd gear, when warm, no grind.
- Manual Transmission People
- differences between spec 3 clutches
- shifter noises
- shifting problems
- Other parts
- Problems. Help!
- What is the smoothest shifting shifter?
- Buy new slave or keep the one I have
- Around how much for a clutch install?
- Clutch Recommendation for 420hp NA + 175-300 N20
- Opinion on a clutch
- Clutch Pedal Spring Noise
- if u know about clutch install please help
- Differences between Viper and F-body T56?
- shifting problem...
- 4th Gear Failure when Racing
- need some help
- Tranny issues at the track.. what could the problem be?
- WTF happened ?!?!?
- a4 to t56 swap i need trans and all help me
- Pops out of third gear.......
- Shifter question
- Rebuilding t-56
- Spec Stage 3 not holding
- White Lithium Grease???
- I'm a little confused now, clutch help please.
- What's the best shifter 6 speed
- T-56 Questions...
- New aet is slipping big time under load.
- Revlock work with Mcleod flywheel and plate?
- Ram Clutch Slipping
- rubber bushing on Hurst shifter
- Who/where in PA does T-56 rebuilds that will last?
- Group Purchase for the Spec 3 Clutch with billet steel flywheel?
- power level on t-56
- Help clutch slave cylinder.
- rebuilding fried T56
- t-56 in silverado z71?
- Tranny fluid: Type, Amount
- The Truth behind Adjustable masters
- Having problems shifting into any gear
- Spec Stage 3 with stock master and slave?
- Strange problem with clutch pedal feel...please offer suggestions
- Part # for nylon bushing in trans
- just ordered the spec stg3 from TTP
- A4/M6 swap, just a couple questions
- Spec 3-I?
- Brand new OEM flywheels $50
- Do they make plugs to go into the ....
- Where to get a new/used T-56
- Who runs Redline ATF in the MN6?
- new clutch slipping
- A-4 To T-56
- Clutch sliping
- What clutch to get.....
- Denny's NR DS Weight -Inside
- New spec clutch what should i get
- anybody want to trade A4 for M6 setup?
- stock clutch ?'s.....and what to get?
- Bellhousing Pressure plate contact
- Master Cylinder Decision
- Help need with Ram install
- P/N for pilot bearing?
- Paging Ram 910 users...
- Pioneer Trans Mount
- Clutch Engagement is near full release of clutch pedal
- Bleeding: new ram master, new slave
- bent shift fork?
- Pro 5.0 install question...
- WTB: Braided slave cylinder line, where to get one?
- 11-10 second guys, what suspension tricks do you run on the street?
- HELP! on take-offs and shifts=hard thump under my car
- How will a RAM 910 disk hold up with 700+rwhp and how long?
- High RPM shifting Problem
- how to install new clutch cylinder
- Who's got the best deal on SPEC cluthces?
- who sells a mean t56 or sells solid parts?
- who makes a beefed up T-56?
- Corvette shift knob fit F-body?
- just installed!!!!
- 1st Gear Problem
- Aftermarket Shifters
- bad throwout bearing????
- 3rd gear vibration
- installing short stick
- Spec III or Spec IV??
- Question about flywheel
- Whats wrong with my t-56?
- I need a clutch for 700+hp
- Installed Hurst shifter, car wont start......
- please help!!!!!
- T-5 vs T-56
- Does T-56 have Tremec gear box stock?
- What is the best clutch kit to buy?
- how much is my tranny worth
- How Much HP Does a Slipping Clutch Rob?
- grinding gears
- Mission Complete: Clutch installed
- STG 2 or STG 3 ???
- what did i break now?
- T-56 Questions
- T56 rebuild?
- paging matt at TTP again
- master cyl and slave question
- Nitro Daves:January Install Special
- Spec III Clutch??? 700rwhp???
- hurst vs.b&m
- Beat manual shifter for firehawk
- NEED Cluth help!!??
- Slight problem with Pro 5.0, any suggestions
- Strange noise from Trans
- Problem
- Who has the best deal on Mcleod Twin Disk
- paging Matt at TTP!
- What rpms are you guys shifting at?
- installing MSD Shift Light
- spec stage 2 clutch.......
- clutch upgrade..what else do i need?
- spec stage 3
- can someone tell me if this is the right master cylinder fpr a 2000 vette?
- clutch question
- Master cylinder line Help!!!!!!
- RAM flywheel studs??
- Grinding going into 6th...
- Syncros, steel vs carbon fiber ?
- Clutch Bleeding Help
- Need Suggestions Now.
- B&M ripper sucks ass!!!!!!!!!!
- do i need to bleed?
- Ford clutch disconnect tool
- Ram VDS 402-2550N weight
- popping sound?
- How to build solid M6
- should i bleed
- T56 Awd
- Bleeding a Clutch
- Viper t56 mate w/ ls1?
- clutch help
- is there a trick to linin up the clutch, pad, flywheel and pilot bearing nice and per
- KP is da' MAN on building T56s!
- SLP shifter (woof woof)
- Transmission fluid
- When I install my Zo6 clutch next week....?
- Aftermarket clutch line????
- Got problem with clutch when launching hard.
- Stock clutch question?
- Strange noises from gearbox area...
- Free fix for 5th gear grinding problem
- Need help with McLeod MC substitution
- Going round #2 w/ Mcleod Adj. Master (info inside)
- 103k miles on the stock clutch!
- spec, mcleod, or Ram
- clutch pedal squeaking??
- clutch "drill mod" question
- what does he need?
- Slave cylinder question..
- Transmission Grinding???
- Pro 5.0 or Ripper? which one
- hydraulic throwout bearing removal-need help asap
- not sure where to post this but I gotta question
- LS6 Hydraulics Part #
- 1LE trans mount
- What parts do I need for an M6 conversion?
- My M6 is hard to get into reverse.
- Help. Shims And Bearings And Ahhhhh
- T-56 price
- Would a new clutch plus drill out mod cure rough shifting?
- found out an ailing problem
- question regarding my t56 transmission
- Bellhousing I think we have good newss!!!
- Viper t-56 tranny?
- Spec III, are they SFI approved?
- Draining and filling the T-56 help
- lowering transmition
- Whats up with crappy shifting T56?
- who has best prices on spec clutches online???
- Bellhousing blanket
- G-Force T56
- anyway to delete hydraulics
- 5th gear problem?
- How long will z06 clutch last with 440rwhp under normal street driving conditions?
- WHich gears and clutch?
- LS1 T-56 in truck
- Defect with Ram pressure plate?
- Please share your launching technique
- upgrade hydrolics with stg3 spec
- Break-in time for the Zo6 clutch?
- What splines are the T56 input shafts???
- in the middle of a clutch install and need some info
- What does a T56 weigh?
- Tremac TKO
- hurst pro billet?
- Help
- wierd crap with clutch
- Flywheel questions
- Weird problem....
- Held in my clutch too long for the burnout
- auto to manual swap
- Need Specif questions I need answered on Spec stage 3
- Zo6 Clutch-any good
- How much can this stock clutch take?
- Has anyone ever heard of a LUKE clutch?
- which clutch
- help! huge bang/thump under my car
- I CANT stop misshifting even with a pro 5.0 shifter! I NEED a rocket scientest HELP!!
- How tough is it to change....
- McLeod Problems
- Mcleod clutch ussers inside
- Which Aftermarket Clutch Works Best w/ Stock Master Cyl?
- Bellhousing Help/info?
- Clutch questions
- spec vs mcleod
- which aluminum flywheel?
- Ram 980
- T56 conversion
- Self Adjusting?
- help
- Aluminim Clutch
- Anyone having problems with a 6 speed?
- Trans stuck in 4th gear!
- Quick disconnect?
- how many bolts?
- swapping a TKO into a 98 t/a
- Driveshaft was gone!!!
- Clutch install in 2000 C5 instructions
- Hows the driving with the Spec 3 clutch?.. is this true?
