View Full Version : Manual Transmission
- Issue's! Issue's! Issue's!
- What shifter is this? Can I fix it? Missing spring/caps
- Still some problems?
- Difference between 98-00 and 01-02 slaves ?
- How much of a difference is there?
- Newish Clutch, 2k Miles ~Problem~
- Question on clutch line fittings
- what is this?
- Best fluid to use
- ls1-t56 pressure plate bolts
- T56 behind a big block?
- A4-M6 swap
- Pilot Bearing?
- How much will the T-56 take?
- slave cylinder?
- clutch opinions
- Shifter Gasket Material
- How To Install Master Cylinder Video
- Can anyone identify this piece?
- Clutch failure analysis.
- how hard its it to replace a syncrho
- will my lt1 t-56 parts fit into a ls1 t-56
- cheapest clutch replacement
- PRO 5.0 vs. MGW- Worth the money?
- Clutch Pedal goes rock hard after a few gears - checking my diagnosis..
- Tick + monster 3..1st is hard as ffckk
- Car will not go into gear while running
- t56 magnum(tr-6060) has anyone got these to fit an ls1 f-body yet
- which sponsor for T56 repair and cost?
- clutch job buttoned up now wont start
- 3-4 only? how come?
- Trouble getting through reverse gate
- clutch master cylinder removal
- Need help
- Anybody have pictures....
- What tools are needed to rebuild 6 speed?
- Reinstalling transmission. Where does the black sensor thing go?
- input shaft grease/bleeding question
- Jerrod @ Textrailia's email address
- What does it take for a t56 to bolt into a lq4 or lm7?
- Crack in Monster Puck?
- Reverse slips
- Need help asap
- Inspecting a t56 out of the car. (chasing a vibration)
- Any ideas on what broke t56
- What do I do...
- Black shift knob with red 'SS' emblem?
- clutch advice question
- where to get bearing pressed on to mainshaft?
- autozone bearing puller doesnt fit...
- MGW vs. B&M shifter
- using aold school muncie trans with a 5.3??
- T56 wont mate to LS3 engine
- gauging interest T56 and clutch for sale
- Grinding gears
- Clutch wont disengage..
- Looking to trade my new A4 for an M6
- Bleeding with MityVac is BAD NEWS!
- New Tick Master Cylinder Leaks!
- Brand new MONSTER stage 3 $700
- I have two Slave Part numbers - Which one?
- Great Experience
- Clutch?
- Follow me through my journey of the famous clutch sticking problem
- Short Shifter vs. Short Stick
- New Clutch Engagement
- M6 Price?
- What would cause a T-56 to lose 5th, 6th, and reverse?
- MC rod keeps popping off pedal...
- shifting kinda stiff
- NOW AVAILABLE: Tick Performance Level 3 EXTREME Viper F-Body T56 Rebuild Parts Kit
- Engine Break-in w/ new clutch...
- Flywheel choice on 3000lb Stock-Internal car???
- Problems with T56
- T56 torque arm bracket...
- quick pilot bushing question
- Loctite on PP bolts and flywheel...
- LUK pro gold series?
- clutch noises, is it the TO bearing?
- Please help me! (video inside)
- Oops! No Sixth Gear...
- Quick connect on slave trouble
- Anybody Daily Driving a Stage 3 or 4 Monster Clutch?
- Question About Trans Fluid...
- ARP thread sealer on Flywheel bolts
- Funny noise, possibly clutch related?
- Where did i mess up? t56 rebuild
- 6speed and Slicks how do you launch
- Lt1 t-56
- Installed Monster Stg4 last night, all night long...
- Who sells slave shims?
- converting from an auto to a 6-speed
- For those of you wondering why replace the 3-4 shift fork to steel
- i have a question about my clutch
- 2nd Gear Burnout
- Ram level 3....
- Mcleod LS1 T56 Bellhousing Install Issue, Help!
- slave quick disconnect problems!!!
- Free Remote bleeder with clutch kit, free shipping with master
- To install solid mounts before or after clutch swap
- Removing Driveshaft....help
- which Monster clutch is right for my set up
- For guys who've swapped to M6 but used a M6 donor car
- Quick HelP! Clutch Dowel Install Question
- Rebuilding t56 and i have a question.
- A reminder to keep your clutch hydro fliud clean.
- clutch fluid reservoir
- Won't disengage all the way! HELP!
- Im over it...
- Clutch Install - Three questions please
- Bad pilot bushing problem fixed. Valuable tip inside.
- Need help: Pro 5.0 shifter bolts up to mustang trans but too tight, what does it fit?
- Do you have to use mcleod's flywheel with a street twin?
- LS7 Clutch?
- 04 Pontiac GTO Clutch
- New 02 Slave Cylinder & 02 Master Cylinder, Pedal Still Sticks at Full Throttle
- Question about the 6spd 2010 Camaro SS
- T56 Rebuild find
- Best grease for a pilot bushing that goes the distance
- Odd "click" noise LS7 clutch setup! HELP!
- Can anybody help?
- ACT Street Clutch
- Going to fix the leak this weekend....
- ls1 bell housing
- 5 inch tach or raptor shift light
- Grinding in Reverse in the SS
- Short Shifters
- Question about bleeding...
- XTD clutches
- Is it a must to replace flywheels bolts?
- noise/wont go in gear after full throtte pass
- A must read about clutches
- Trany noise and some grinding
- Clutch switch?
- What Stage Clutch
- Swapping shifters
- cnc pedals?
- t56 problems
- Whine/Humm upon clutch disengagement?
- Quicktime Bellhousing alignment...
- sachs clutch
- fluid?
- replacement parts help
- Saw a trick on here but forgot HELP!!!
- Dot 3? Dot 4? synthetic?
- LS7 clutch
- short throw shifter T56
- Noisy spec stg 3
- Will pay to help!
- T56 Trans.... What Are The Weak Points?
- puck or twin disk clutch?
- shifter handle vibration
- Clutch slipping, looking for a oem replacement disc
- some t56 rebuild questions
- Just bought an M6, newb questions
- T56 Won't go into certain gears?
- Can you use stock rod on Tick's Master Cylinder?
- Im stumped..
- slave cylinder
- stock t56 shifter now has Play..sticking to when I slide it to the left
- LS7 Clutch burning up after I went to strip
- when to replace the master cyl
- Locked out of 2nd at WOT only Help!
- Clutch sounds like a turkey!
- Reverse Problems
- Safe trans temperature numbers...
- Clutch Issues!!! Please help!
- How much power will a McLeod single hold?
- Should I go with a alum or billet steel flywheel???
- spec 3 or monster
- Spec 3+...Trouble getting into gear at high RPMss
- i think wheel hopping has killed my t56. HELP!
- Double shim on slave??
- 1k + HP T56 Who builds them?
- 1997 or 1996?
- 2nd gear issue.
- M6 Drag Racers, clutch
- Dug the C5 out, went for a drive and busted the clutch - Wonders of a new vette owner
- t56 and hurst don't fit! NOW WITH PIX
- 2 diff types of Tick Adj MC ??
- Best place to buy QT bellhousing
- what slave cylinder do I get for my ls7 clutch setup in my ls1?
- Grinding 3rd After Rebuild
- Tranny prob no 2nd gear....Help
- leather boot off?
- Need Help By 5pm.. Slave, or master!?!?
- Taking trans out, do you support back of motor
- clutch remote bleeder
- Can I just resurface OE flywheel???
- autometer shift light/digital tach
- bad ticking noise
- Help! slight grinding shifting into 2nd gear when warm only.
- Is Tick going to have a Tax Sale?
- car creeps forward when going into gear?
- Master cylinder HELP
- 01 Z06 clutch problem
- Best clutch for 400rwhp
- release bearing/slave cylinder
- Transmission or Clutch?
- T56 failing me...grinding and slipping
- stick pulled out of shifter on fourth gear pull
- What would cause this???
- Fluid level question
- Do built transmissions whine?
- Clutch company customer service who's the best/worst
- Installed new OE clutch and cant get in any gear
- c5 transmission
- Car goes into gear fine, buzzes or grinds while accelerating, need help
- My New Tranny Plan!
- c5 trans in z28?
- What ever happened to Joe and Amber Honeycutt?
- Just installed B and M Hard to get into reverse now
- Replacing clutch fluid?
- Spec 3 help
- Stock o-ring for clutch master cylinder...HELP
- LT1 T56 - Output shaft bushing replacement - having trouble!
- transmission question
- Tdp clutch
- Not your usual 2nd gear grind..
- Will the Tick M/C solve my problem?
- Slipping Monster CLutch III?
- Need Help
- clutch wont depress
- Tick remote bleeder & MityVac
- mityvac
- Im ready to swap! But...
- Shift point...
- Clutch master and slave..where to buy?
- Vibration in clutch and locked out of 2 and 3
- Monster Clutch Stage 3 Installed
- Throw Out Bearing
- grinding 1st
- Clutch safety switch??
- LT1 clutch-McLeod/Centerforce ?
- t-56 question
- ~Tick Performance Adjustable Master Cylinder Upgrades Come In~
- bench bleed or pressure bleed?
- T56 Floor Cut
- spec clutches
- how long will a stock ls6 clutch last with....
- what clutch for me???
- Broken Clutch Quick Disconnect
- Anyone have Monster clutch level 3.5 ?
- what clutch shouldi got with??
- Console Swap?
- Need help diagnosing a shifting issue
- need help!!!
- best short throw shifter kit?
- HELP! Grinding noise...
