View Full Version : Manual Transmission
- 5.3 vortec + T5
- Thought I had Seen it All
- Suggestion on the junk T56 I just bought ?
- What flywheel to get
- Info needed about T56 Magnum / TR 6060 input shaft
- Monster+quicktime=shim question!!
- Anyone broke a Viper shaft T56?
- Short Shifters
- Diff or Transmission Whine
- GS Creations C6 shift knob review
- 2000 M6 clutch pedal question
- Why so many PRO 5.0 shifters for sale?
- 98 z28 shifting problem at high rpms
- 2000 T56 fill
- Which McLeod Twin Disc for my TR6060
- LS7/RAM LFW or Monster Stage 2/LWF for ~400rwhp LS2 in 2800 lbs?
- Pilot bearing major issue
- 4 month old RST slipping
- normal clutch brake in?
- T56 clutch woes!
- Are all Green Slaves the same?
- AWD 5 speed manual on ls motor?
- Transmission oil pump. Will this work?
- what is the current solution for 500rwhp?
- Diamond Clutch??
- Monster Holiday Sale!!!
- Can you tell if this is an Ls1 or Lt1 T56?
- Tick MC adjustment after someone else messed with it
- T56 Magnum Gear Set
- LS7 clutch wearing behavior after 1 year
- Those with rpm T56 rebuilds?
- T56 Reverse Lock out
- T56 wont go into gear
- Clutch and flywheel condition
- Clutch break in
- Transmission Help
- Growling noise while in gear
- Well just rebuilt my GTO t56
- cross threaded hole from crossmember into th body
- Shift pattern on console
- Monster stage 5 (big ups)
- 99 camaro z28 clutch not wanting to go into gear.
- Need help identifying a clutch
- Clutch replacement cost and shop recommendations
- T56 GTO bellhousing/6.0 truck starter??
- Clutch Pedal Won't Firm Up
- Spec 3 shimming
- Questions on Clutch Swap
- Monster Clutch Co Holiday Sale!!!!!
- Clutch recommendation
- Reverse lockout issue. Please help!
- Routing of Tick Speed Bleeder
- Its time to upgrade the clutch!
- MGW shifter install and feedback C5 Z06
- T56 swap
- Clutch pedal assembly
- Who builds the strongest t56, tr6060?
- Hydraulic Clutch Fluid
- Loud whine, 1st gear decel?
- New Best with the Monster LT1-S Triple
- T56 1-2 synchro sleeve
- T56 Reverse Lockout Wiring
- 14 spline T5 to LSX?
- What flywheel is this
- Hybrid t56 mount
- Ls7 clutch problems
- Clutch slipping
- T56 Reverse Rail differences?
- Gaving issues with measurement
- Mcleod twin slipping
- A question for those with Tick MC (Tick techs welcome)
- Why is spring removal needed for measurement B?
- Pro 5.0 install question
- What Shifter is this?
- Monster clutch with out flywheel
- T56 Input Shaft Play - Is this normal?
- Mcleod twin disk issue
- T56 98 ss slp
- Clutch shatter when hot
- Missing parts from B&M short throw.
- Reverse lockout - how to connect in swap
- ls1 mc to tr6060 trans
- Any deals from vendors on tko600s?
- LSX454 to t56 magnum
- Is this the correct slave?
- LM7 and NV3500 thought?
- New clutch - car won't go into gear. ideas?
- Pilot Bearing Self Destructed.. Carnage, Need Advice
- 6 speed shift knobs
- -3 AN won't fit clutch slave? CHECK THIS OUT!
- New clutch needed
- LS2 Slave Cylinder Out, What else to change?
- C5 T56 to LT1 F-Body
- T56 Magnum fbody spec dust covers?
- T56 scheduled fluid change?
- T56 rebuild guides
- Mgw knob
- LS1/T56 Nissan S14 trans clunk? Video attached
- Anyone spraying on a monster stage 2?
- F-Body T56 What Clutch with F-Body Case TR6060 Conversion?
- T56 Help!!
- Nodular ironFlywheel? Good?
- Looking for help picking a clutch,Monster,Diamond,McLeod.. EDIT:SLIGHT BUILD CHANGE
- Need help diagnosing, believe it's the clutch
- Clutch pedal lock when hit hard!
- Tailshaft conversion flat flange possible? t56
- broken tick master?
- T56 with drive by wire?
- LS7 Clutch will not fully disengage (another one i know)
- C5 Transmission Upgrade Options
- Help-Sensor position locations T56 mag
- Clutch Problems [T56]
- McLeod Street Twin Stripped Splines and Messed up Input Shaft
- Install rail socket in forward hole of T56
- Mystery sound when coasting in gear
- Mcleod original street twin
- Please help, Another Clutch Master Adjustment Issue
- Pilot Bearing Input Shaft Damage (pic)
- T56 - No Reverse
- Cant get Clutch???
- tr6060 swap?
- Slave cylinder replacement
- Tick Performance great service
- T56 getting hot!
- Failing master cylinder?
- True tale of the Sachs NFW1050 swap flywheel
- 99 T/A reverse lockout problem
- T56 6spd Manual Transmisson install into a Gbody
- T56 problems, hopefully clutch.
- Stock T56 and slicks?
- Help me double check install
- help with mounting lm7/ls1 to muncie in non gm car
- 1971 LT-1 with 2003 G35 transmission??
- 2.29 close ratio Gearset, Anyone? Help please?
- Lq4 swap w/t56..proper pilot bearing part#?
- T56 Ever heard of this?
- Fresh RPM lvl V Trans w/LS7 clutch
- Bolts for T56 Magnum to bellhousing?
- Clutch Hose O ring leaking
- t56 High RPM Lockout
- T56 will sometimes grind in between shifts But NOT all the time
- t56 magnum with no cags solenoid failed nys inspection
- Cheaper alternative
- Are LUK LSC265B same as GM 24264182 slave cylinder?
- vibration problem
- Tick Performance Master Clylinder
- Mantic Twin Disk
- T56 Jumping out of 1st and no reverse
- Clutch help
- How many cycles to bleed this stupid clutch?
- Mcleod twin disc rebuild
- Just opened my LT1-SC Tick & Monster Complete Clutch package..
- t56 grinding when going into gear
- able to build NV3500 to take more power?
- Issues with Dealer work
- Hydraulic Clutch Line
- Can you help me identify this part ! ?
- Low-Profile Clutch Master
- Reservoir??
- Disc disengagement spec
- Shifter rattling?
- Fluid leaking from bleeder screw
- t56 flywheel/pressure plate bolts
- Mcleod RST/RXT pressure plate the same?
- Whine in first and second gear at low rpms.
- T56 experts
- Mcleod Street Twin Slipping on Dyno
- T56 stock speedometer gear?
- 2000 Trans Am has clutch doesn't fully disengage unless you push it down HARD
- Tremec T56 Shift Rail ??
- Built T56 break-in process?
- Need Help Picking A Clutch
- Damn, Think My Clutch Is Done
- McLeod RXT Clutch with Fidanza Aluminum Flywheel?
- t56 noises (videos)
- Not your typical Throw out bearing shim question.
- LS7 w/ Liberty's Faceplated TKO600 - Which clutch and slave?
- Monster clutch
- Help!!! Weird problem after rebuilding t-56
- How to adjust hurst short shifter
- T56, Tick master cylinder, OE slave, LS7 clutch, SUCCESS!
- Jumps outof 6th gear
- I screwed up. (Tick Speed bleeder)
- Which Mantic 9000??
- Crankshaft movement BAD***
- measurement B bigger then A slave cylinder issue?
- T56 noise
- T56 pedal action
- 1st gear issue
- T56 shift rail
- (Pics) Transmission Fluid Leak??
- GTO Transmission compared to Camaro T56
- T56 Size
- t56 noise??
- Thinking about a manual Swap?
- VSS reluctor tooth count
- T56 slave cylinder replacement
- Monster LT1-S triple review
- TR6060 forward shifter location
- # of teeth on T56 tone wheel?
- T56 locked output shaft
- Stripped flywheel bolt
- Odd inconsistent clutch pressure issue....
- Spec Stage 1 w/ 426hp/397tq ?
- RCSB - Auto to T56?
- Monster Clutch 4th of July sale!!!
- Clutch line
- Vibration in the clutch pedal, and clutch doesn't fully disengage. What's wrong?
- Input shaft Max wear
- Tranny rebuild question
- Thanks m6 forum
- T56 countershaft endplay ODD shim size?
- Quicktime Bellhousing - Yay or nay?
- Quick one, how much should auto to manua conversionl run at a shop?
- 5th/6th drive gear stuck
- You wouldn’t believe what happened when I installed a Mamo RPS Clutch
- T56 second gear engangement issue...
- -4 vs -3 Clutch Line
- T56 gear ratio change
- 4th gear issue. Grind/vibration.
- Opinions on clutch issue - just worn out?
- Grinding when clutch is being released
- Get a Tick MC or Replace the Slave?
- How can I make shifting feel better?
- Lost clutch after trans install
- Difference in T56 feel in Camaro vs Trans Am ?
- Undriveable smell
- Ls7 clutch,pp,flywheel to lm7
- Clutch not handling power?
- Can't find Clutch Master that fits
- T56 swap wiring need help
- mgw shifter
- Almost destroyed new clutch
- Can't shift into 3rd and yes have a tick master
- Why the need for the drill mod?
- Dropping my transmission
- Cags
- Shifting problems
- Shifting issues
- Ls1 clutch replacement
- glazed clutch?
- M-PACT clutch / any reviews?
- Snapped T56 Output Shaft
- T-56 six speed
- Help Identifying this crossmember?
- Jason@TDP
- T56 crossmember will it hold up?
- Fixed my 4th gear issues, Tremec input shaft issue.
- Brand new broken "billet" 3-4 keys. NEVER USED
- Mcleod Super Street Pro
