PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. T56 Manual in a 2.2L S10? Whats needed?
  2. Drill Mod '99 hydraulics?
  3. time for a new clutch, opinions
  4. ? about flwheel material
  5. t56 weird 5th problems bugging the hell outta me
  6. royal purple m6 fluid
  7. Can I put this Hurst Stick on my Factory Hurst Shifter?
  8. Transmission running hot?
  9. clunk from 1 to 2
  10. LS7 Clutch Disk Question...
  11. clutch install problems
  12. Textralia Disc?
  13. pros vs cons of turbo trans
  14. suggestion for those replacing master, learn from my mistake
  15. which bearing
  16. Clutch grabbing really hard and fast...
  17. Need help!!!
  18. anyone successfully put a TKO600 behind an LS?
  19. ls1 t56 into a lt1 a4 car
  20. LT1 / T56 Fork & Throwout Bearing Problems!
  21. T56 Rebuild Parts...
  22. lt1/t56 prob.
  23. Glad I replaced my stock shifter!
  24. Speedway T-56 LS1 Hydraulic Clutch Kit
  25. several weird M6 minor problems
  26. Six Speed Trans
  27. Broken 3rd Gear Blocker
  28. Preferred Trans mount ?
  29. Ram, Spec, or other?
  30. Ram Release Bearings questions????
  31. LT1 t56 swap
  32. Basic T56 Questions
  33. Installing master
  34. What is a good throwout bearing brand to get?
  35. Stock clutch life
  36. newb tranny swap question
  37. T56 Rebuild Yourself?
  38. Reverse Lockout and CAGS Solenoid
  39. Transmission noise
  40. Textralia Customer Service
  41. How much weight diff in these flywheels?
  42. Ordered the Mcleod Twin have some ?s
  43. Tranny bolts
  44. Noob Shift Questions
  45. Wont go into gear
  46. grinding noise when turning
  47. Bleeding Tool
  48. slave problems
  49. 95 LT1 and T56 in 68 camaro hydraulic questions.
  50. Which part is causing my chatter?
  51. Mcleod Street Twin w. Wilwood 1"?
  52. Where to find rubber mount?
  53. Power Tower Install
  54. LT1 Adjustable Master Cylinder
  55. 1rst gear shakes the whole car
  56. bleeding system anyone have suggestions
  57. T56 Skip Shift Solenoid Delete Plug
  58. help with tranny upgrade
  59. Mcleod master cly problem
  60. LS1Tech special! FREE SHIPPING on all T-56 parts @ D&D Performance
  61. Should I replace pilot bushing?
  62. T56 in 3rd gen, what drive shaft?????
  63. LT1 t56
  64. Clutch Problems
  65. lt1 t56 in a 99 trans am will it work?
  66. New Spec 3 installed
  67. T56 Problems
  68. t 56 questions
  69. grinding isue going into 1st?
  70. Will This Work????????
  71. "DEAD pedal syndrome?" will shim fix?
  72. Question about the t56.
  73. Reverse Lockout
  74. t56 rated to ?
  75. What clutch for street/drag strip?
  76. Clutch Question
  77. Rebuilt transmission problem: Can't downshift into third.
  78. Textralia Z Grip
  79. Rattles when I shut car off?
  80. Shift Forks and Rail Assembly
  81. 6 speed manual stuck in 4th!!
  82. Help me figure it out
  83. Anyway to tell if there is a Aftermarket clutch
  84. LT1 T56 behind an LS1
  85. what did I break?
  86. clutch issue
  87. Six Speeds Inc. is no longer selling online parts
  88. any rebuilders, 3 ls1 t56 cores for sale
  89. How to tell difference between slave cylinders
  90. rebuilt transmission probem, no first or second
  91. RPM Stage IV, problem
  92. Looking for T56 input shaft a bad one
  93. Master Cylinder - Causes of Failure?
  94. Transmission Damage from running something over?
  95. Tranny installation problem!
  96. Symptoms of a bad master cylinder
  97. Rev match 2nd gear
  98. output shaft spline problems
  99. Trouble finding master cylinder line for 99 Trans AM
  100. Clutch help!
  101. Mcleod RST vs RXT clutch
  102. Transmission fluid.....can it be a cause of this problem?
  103. Clutch or Trans
  104. Spec 3 Question
  105. t56 parts in stock? and diagram for t56
  106. T56 question
  107. t56 issues please help
  108. Flushing hypro system, any cleansers i can use.
  109. Strange Clutch Problems!!!
  110. Cheap LT1 clutch
  111. Worn Clutch - Would it cause this?
  112. T56 Grinds in 4th
  113. What are these items? Look at Pics!!!
  114. Spec Flywheel Issue
  115. crash box t56?
  116. McLeod Master Help!
  117. Who makes an adj. slave cylinder for 97 lt1?
  118. Tell Me About Your Ram Twin Disk Problems
  119. Need Some Help With Hydraulic Line
  120. does anyone need t56 cores i have three of them..
  121. Help with sticky clutch.
  122. LT1 A4 to LS1 T56
  123. Thoughts on clutches?
  124. New McLeod master cylinders... a review
  125. Spec stage one.
  126. Looking for good T56 Rebuild Shop on East Coast
  127. lighter LS2/7 flywheel, any interest?
  128. exo-skel install nighmare any help...
  129. ls1 t56 slave cylinder?
  130. Finished the drill mod today. Afterthoughts inside
  131. Weird shift at dragstrip
  132. Welp broke my transmission!
  133. McLeod twin disk issues.
  134. Input shaft splines hitting the Pilot bearing...wrong bellhousing?
  135. hydraulic leak question??????
  136. Vibrations in shifter
  137. Need opinions, clutch or tranny problems?!?!
  138. dropped 7/16" socket into bell housing, how to remove?
  139. What flywheel for ls7 clutch
  140. slipping clutch
  141. Viper T56 in LT1 car?
  142. Clutch slipping
  143. pressure plate resurfacing????
  144. HELP, Lost "roll pin" while performing drill mod
  145. Vss..
  146. Need a new clutch, suggestions?
  147. Anyone "tight" with Mcleod Industries?
  148. T56 Issue... Reverse Block Plate??
  149. T56 won't bolt to bellhousing 3/8" gap.
  150. bleeding new slave resolution
  151. Textralia OZ700 Z grip on slicks with high dumps!?!?
  152. OK... help with a spec 3
  153. Grinding Noise in all gears under heavy throttle
  154. Lenco
  155. t 56 output shaft question
  156. Best brand of clutch fluid for performance
  157. Flywheel Shield?
  158. Clutch/Transmission Issues - Help Amber!
  159. Pilot Bearing Install???
  160. Rebuilding Trans
  161. Disengagement question: Ram powergrip HD needing slim on c5?
  162. 6.0 Install with T56, What is different from LS1?
  163. Torque Spec question
  164. How long to "break" it in for?
  165. 70k and having clutch replaced... master cyl required?
  166. McLeod Street Twin Spec Discs?
  167. Lost 5th 6th and reverse No noise, no anything... Ideas???
  168. Clutch Help!!!!
  169. how do you remove/install a new Slave cylinder?
  170. ls1 six speed into a lt1 auto car
  171. Some clutch master cylinder and "quick" disconnect Qs
  172. LS7 slave/throwout bearing
  173. Just completed L S7 Clutch install
  174. Clutch problem after break in?
  175. Clutch Failure -- Master Cylinder Valve?
  176. T56 Rebuild
  177. Where to buy a new FACTORY HURST shifter?
  178. Pressure Plate to Flywheel torque spec on a Textralia?
  179. Manual trans question
  180. will a master cylinder from a 00 camaro work for a 02 vette?
  181. Shifter Movement & banging noise in 1st and 2nd - already replaced trans and TQ mount
  182. need help. reverse lockout solenoid
  183. clutch woes
  184. HELP!! cant get clutch to bleed
  185. reverse lights dont come on
  186. Will this slave work?
  187. Need help asap! Problems with tranny/clutch...
  188. 3rd Gear issues....
  189. Another T 56 installation tip
  190. Bellhousing cracked??
  191. Who sells bell housings?
  192. Rockland std gear extension housing bushing
  193. 1000flywheel hp-T56?
  194. Ram Twin Clutch Questions
  195. Bleeder Valve - You wont believe this....
  196. Best Place to Buy Pro 5.0
  197. Cant go into 5th.
  198. 1st - 2nd Grinding :(
  199. New clutch and rebuilt trans
  200. Clutch fork problem?
  201. Bleeding question
  202. LS7 Flywheel Question
  203. Worth?
  204. non hydraulic tranny options?
  205. Shifting woes
  206. oz700 flywheel ?
  207. Would an adjustable master more slave travel?
  208. !$^@$%& McLeod Back order HELL #$%^%
  209. My Clutch, Stock?
  210. Am I in trouble?
  211. help with a problem
  212. hard to go in reverse
  213. Been running engine with T56 in nuetral, no fluid any damage done?
  214. 10 sec. clutch that's smooth on the street??
  215. Shifter cup part # and were to get it?
  216. Did i get the wrong Mobil 1 ATF ???
  217. quick
  218. ford t56 fit a ls1 with new bellhousing?
  219. NMCA/NMRA Event Special July 16-20th
  220. Quick clutch and PP question
  221. Rebuilt transmission, Grinding goin into 5th??
  222. Clutch Engagement Issue or Synchro? Please help!
  223. Pilot bearing depth
  224. Purchase stock keys and pads?
  225. Problem with bronze pads on 5/6 and reverse
  226. bad luck with my trannys
  227. LS7 clutch right for me?
  228. new clutch..slipping
  229. What is this hole in my slave cyl?
  230. A4 To T56 Conversion Swap
  231. Where do i get a shifter bushing for a B&M Ripper??
  232. what transmissions are my options
  233. joe from sixspeedinc
  234. missing u-bolt bracket
  235. how do i use this slide hammer?
  236. Finially Changing out the Master.
  237. need a new shift knob!!!
  238. Clutch problem
  239. Centerforce Clutch
  240. when and how to change tranny fluid on my t-56 6-speed
  241. Quicktime Bell housing
  242. Possibly air in hydraulics??
  243. Mcleod RST twin disk clutch (my review)
  244. Weird Noise-Synchro's?
  245. rounded flywheel bolt, what do i do?
  246. Snap rings
  247. $$$ Camaro Engine & Manual Transmission $$$
  248. T56 trouble shifting at high rpms + some noise
  249. reverse lockout will not work
  250. Where to Buy New Master Cylinder
