PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Clutch Recommendation...
  2. stock flywheel and spec stage 3+ ?
  3. T56 shifter hole question
  4. Input shaft T56, LT1, quick question
  5. Which Short Throw?
  6. noisy shifter with high rpms
  7. rebuild: no reverse on test shifting
  8. T-56 hop up
  9. Textralia 0Z700 Z-Grip?!?
  10. Bellhousing danger?
  11. Place to buy just clutch disc
  12. Need 6spd rebuild parts! where do i get them?
  13. Need some help
  14. Does RAM still make the 910 clutch kit without the VDS PP?
  15. HELP!!! Quick need trany to bellhousing torque specs
  16. I need some T56 measurements!!!
  17. question for Spec 3 oweners ?
  18. Trans issue help Houston
  19. Surface rust on flywheel & pressure plate
  20. T-56 Shimming Specs
  21. Anyone try these shifters?
  22. Not disingaging?
  23. How much is my stock T56 and stock 10 bolt worth?
  24. How many guys are using trans blankets?
  25. competition clutch
  26. Tick performance question
  27. I can finally shift!!! My dilemma has been solved! ( yay tick!!)
  28. Slave cylinder failing?
  29. Need 2nd opinion on failed master cylinder
  30. front offset lever roll pin not budging!!!
  31. flywheel question
  32. Textrailia Twin Disc Problems!!!
  33. Vibrations above 75 MPH
  34. T-56 rebuild manuals?
  35. T56 rebuilds/ 6 Speeds INC... where did they go?
  36. G.T.O shifter
  37. 350SBC w/ T56 Clutch??
  38. Difference between these two Ram clutchs?
  39. T56 gear grind when cold. Normal?
  40. clutch or tranny?
  41. Help!!!
  42. spec 3 or mcleod single
  43. Any news on pricing of twin disc clutch/flywheel in new CTS-V and ZR1's from GM?
  44. Adjustability of clutch engagement?
  45. Southbend Clutches, anyone else running them?
  46. Do I have a worn tailshaft bushing?
  47. Clutch suddenly will not disengage, changed master and slave, didnt work.
  48. couple questions
  49. Got my Tick master cylinder installed....
  50. How bad is the stock t56?
  51. Installed driveshaft, now tranny leak
  52. Changing a M6 to a A4?
  53. Pro 5.0 Install, problems with 2nd gear..
  54. Installing ls7... Question on slave/master cylinder
  55. Figure this out?!?!
  56. New Twin From ATC...I think this may be a winner !
  57. 06 6 Speed
  58. t-56 desperate help needed. Soo close.
  59. will an ls7 clutch work here? suggestions?
  60. LTx clutch recommendations
  61. Pilot Bearing removal issues
  62. How hard can I launch my 94 without breaking? obviously its opinions
  63. Buy a used clutch?
  64. Whats the min thickness for an LT1 flywheel?
  65. Clutch Recommendations
  66. What fits?T-56 yoke
  67. Spec Twin vs Tex Exo-Skel-If you have had both, please comment
  68. t56 noises
  69. Help:Where is the Clutch Bleeder?
  70. Spec 3 clutch stupid question
  71. Where do I get an LT4 PP?
  72. Short stick questions
  73. Clutch acting up
  74. Spec will not fully disengage
  75. compare between two GM and RAM
  76. few questions
  77. Drill mod question: not the usual
  78. G.T.O t-56 swap
  79. Question, need your help..
  80. HEEEELP!!!!! no 5th or 6th gear
  81. HELP-installing tranny today!
  82. lt1 to ls1 conversion
  83. LS6 Vs. LS7 Clutch
  84. reverse wont go in..
  85. 5th gear grind/vibration?
  86. need a part number or name for driveshaft balancer
  87. Trans noise...any ideas?
  88. Need help asap on shift knob removal
  89. How to make T56 hold up in high HP cars.
  90. t-56 swap questions
  91. New T5 clutch, makin more noise?
  92. Centerforce Dual Friction or LS7?
  93. Best remote bleeder and where to buy?
  94. Rebuilt Jasper Transmission???
  95. Replacing clutch - Should I replace t/o bearing too??
  96. Trans. fluid rec. by 6 spd trans. builders?
  97. 2 Cars, M6 and MN12-Which to use?
  98. Noise in transmission.....help please.
  99. Bronze Pilot Bushing
  100. LS7 clutch smell !! why ?
  101. T56 Not shifting properly after rebuild
  102. Recommend me a clutch!
  103. Actual power/performance loss with LS7 clutch?
  104. LS2 clutch ?'s
  105. Southbend Stage 2 clutch
  106. t56 Transmission to bellhousing bolts
  107. MGW + Pro 5.0 Review
  108. Shifter question
  109. Cheapest place to buy new billet flywheel.
  110. need some help
  111. looking for great shop
  112. clutch????? come on help me out pls
  113. clutch???
  114. Need some help, kinda bad.....
  115. Great Customer Service!
  116. Found my clutch problem
  117. New clutch!
  118. Textralia OZ 700
  119. Where to buy parts or rebuild kits?
  120. T56 bellhousing
  121. What clutch for 600+hp and 600+tq
  122. t56 swap using m6 tranny/engine harness (wiring questions)
  123. G.T.O.trans question
  124. Can this be done?? Tailhousing swap T56
  125. Clutch problems? Time for a new one?
  126. Help me pick a clutch for my setup (LT1 T56)
  127. Shimming questions
  128. regular 6 speed with big power
  129. Ram Powergrip HD
  130. Tick Master Cylinder Review/ Install Tips
  131. Hurst Billet vs. MGW
  132. Where can i buy a ls7 clutch cant find anyhwere
  133. which is the best for my application ?
  134. What do I do with used up clutches and pressure plates.
  135. Master cylinder problem?
  136. My tranny is NOT happy
  137. Possible to order a new throwout bearing?
  138. Six Speeds Inc?
  139. New T56
  140. Who makes GM clutches?
  141. Anyone know the physical dimensions of the T56?
  142. Missing gears, trans cold?
  143. Should i rebuild?
  144. wtf??? another clutch problem
  145. Help with connectors not connected to anything on tranny..
  146. people that have changed they`re clutch please look
  147. 5th gear grind
  148. HELP! Won't go into reverse!
  149. Converting a4 to m6... Whats the $$$?
  150. LS7 clutch or Centerforce Dual Friction?
  151. trans leak
  152. Time for a rebuild??
  153. Baddest of the bad T56 replacement!
  154. Tailshaft seal and loctite?
  155. Go pick up a copy of Camaro Performers mag
  156. depth of muncie 4 speed manual bellhousing ?
  157. I need a shifter bushing, where to purchase?
  158. Textraila Exo-Skell Slipping Help!
  159. Z grip texatraila!
  160. Some quick clutch questions 4 a newB
  161. Clutch/Flywheel combo LS7/LS2???
  162. Any Monster clutch updates or feedback?
  163. Hydraulics took a dump, clutch q
  164. 6.0 flywheel ?s
  165. Why cant i bleed my clutch
  166. Slipping clutch???
  167. Pops out of reverse but everything else is fine...
  168. Shifter with a shorter throw
  169. Slave Cylinder
  170. Spec Lightweight flywheel
  171. Rebuild T56 or Not
  172. clutch disc questions..
  173. clutch problems need help asap
  174. having problem with my 2006 GTO tranny, please help
  175. hp and torque rating on Spec 2
  176. Where to buy a tranny
  177. T56 problems with 3-4 shift
  178. Slave cylinder
  179. transmission fluid
  180. Reusing flywheel?
  181. 2002 6 speed problems
  182. any luck?
  183. T56 will not downshift from 6th to 5th gear.
  184. TKO 5 Speed conversion
  185. Where to get ls6 clutch?
  186. shifting problem
  187. Has anyone used the RAM release bearing???
  188. need some opinions!!
  189. LS2 Remote Bleeder
  190. Strange happenings with 1st gear
  191. Ls7 clutch issues
  192. Master Cylinders
  193. Help
  194. M6 Question?!
  195. Problem with 6th gear
  196. SNEAK PEEK: The New CNC Billet Aluminum Master Cylinder Bracket from Tick Performance
  197. Motor Oil In Transmission?
  198. clutch fluid
  199. mcleod rxt gto
  200. 03 cobra t56 swap
  201. Does YOUR Clutch Setup need a Shim?
  202. Uh oh. Can I swap out shift rails?
  203. Good idea, or no?
  204. Opinion on Fidanza Clutch kit?
  205. hydraulic line help needed ASAP please
  206. Help, odd tranny problem, making a grinding/rubbing noise
  207. Cold Tranny Issues
  208. Cold shifting problem...
  209. MGW Fbody shifter!!
  210. Where to get LS7 Clutch?
  211. MGW shifter position question
  212. Reuse PP?
  213. Post up how much 6 speeds inc owes you today !!!
  214. Christmas transmission sale
  215. Clutch Advice
  216. Diamond Clutch Stage 3 SALE! $670 shipped
  217. Info on Centerforce Dual Friction
  218. how much power can stock clutch handle
  219. noob question
  220. Tick MasterCylinder - Spec 3
  221. Picking a new clutch
  222. ls7 clutch problem??
  223. t56 to 6.0l question?
  224. Clutch Help
  225. DIY- indash shiftlite
  226. Which manual trans. in turbo high h.p.street strip car
  227. 1st gear popping out after rear main seal was replaced
  228. a minute of your time please....clutch issues!
  229. adding trans fluid
  230. Another 1LE tranny mount thread...
  231. T56 synchro replacement
  232. Need some Twin Disk advise.
  233. clutch problems
  234. Difference between LT1 and LS1 T56???
  235. Aluminum Flywheel + 100 shot?
  236. Centerforce Holiday Sale
  237. finally took it apart
  238. 3rd popping out
  239. What cause a T56 to grind when cold?
  240. '93 T56 rebuild and ratio change
  241. 5/6 gear cluster splines
  242. Six Speed Inc 2B build
  243. spigot bearing part number ??
  244. LT1 T56 Dust Cover Bolts
  245. twin disk gto
  246. Input shaft questions
  247. T56/drivetrain Help Please!
  248. T56 viper upgrade
  249. Eclipse nightmare
  250. Looking for a clutch recommendation.
