PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. how much is this T56 swap setup worth??
  2. Need a new clutch
  3. Pro's and Cons's of Aluminum Flywheels
  4. Silly clutch bleeding question
  5. Clutchmasters or Textralia?
  6. How long did your stock clutch last?
  7. No gears at higher RPMs- car isnt as fun.
  8. Spec 3 + alum fly= chatter?
  9. Tranny Rebuilt, now problems
  10. Odd sound When engaging
  11. Is my car light enough for aluminum FW
  12. Trans Fluid
  13. Slow shifting-tips?
  14. Clutch Noise
  15. synchros
  16. Why did I miss 2nd gear at the strip?
  17. Rebuild my tranny or buy a built one ?????
  18. broken seal inside of master cylinder
  19. 4 speed ?'s
  20. shifter locks up on me???
  21. Hooking up the clutch line???
  22. liberty or g-force t56?
  23. Clutch problem
  24. help me.. different sound from clutch
  25. C5 Torque Tube Extension
  26. I just changed to Synchromax
  27. Is too much a bad thing?
  28. Clutch pedal all the way down is this normal?
  29. slave cylinder bolts...
  30. 2nd gear doesn't like me!
  31. Textralia's (Pete) phone # ?
  32. Clutch not disengaging after a 1/4 pass
  33. rebuilding an Mcloed ADJ master
  34. help please , SPEC stage 3 came without shim , do i need one ?
  35. Clutch slipping...
  36. Spec 4F disk locked to flywheel for the 2ND TIME IN 2 MONTHS
  37. bleeding slave cylinder
  38. m6 3rd &4th gears awol
  39. Install Problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  40. Clutch Writeups
  41. Bad clutch slip......Ongoing prob. and I'm very pissed
  42. What transmission??
  43. ? about flywheel
  44. who makes a t56 to hold alot of power
  45. Now what!!!??? 2nd to 3rd prob.
  46. Fucked My Tranny Up
  47. pilot bearing...
  48. B&M short throw install help
  49. can you replace the disk?
  50. Broke a spring?
  51. clutch poll!!
  52. clutch poll!!
  53. Clutch has a grinding noise...
  54. B&M or HURST or Breathless Performance
  55. tailshaft bushing
  56. Help-I think my clutch is gone
  57. spec III clutch question
  58. Silverado clutch options?
  59. A4 - M6 Swap?
  60. Will 93-97 tranny mount fit a 98?
  61. getting a new clutch
  62. Adj Master
  63. how to measure clutch disc
  64. Why is this Z06 clutch/flywheel so cheap?
  65. problem trying to bleed clutch
  66. I need Help Please
  67. Clutch not disengaging
  68. Going with a Jericho
  69. Issue With Shifter Movement In To Reverse?
  70. Is my clutch going out?
  71. Anyone?!?!?
  72. ram---------BAM
  73. I cant think of a name for this thread, but you should read it
  74. quick question about reverse
  75. stronger internals?
  76. Drill mod Question?
  77. T56 rebuild...How Hard???
  78. Pedal Pressure?
  79. Brake Torquing an M6
  80. Starting tranny removal 2nite... advice?
  81. Calling all T-56 experts
  82. Changed Fluid - Bloody diarrhea?!
  83. t56 problems help
  84. Z06 Clutch without New Flywheel?
  85. One Hose On My Slave Cylinder
  86. One Hose On My Slave Cylinder
  87. flywheel/input/output etc for my proshifted t56
  88. Grinding letting out clutch in 6th
  89. Pro 5.0
  90. Tranny Fluid?
  91. Auto or Manual
  92. Q for experienced "shim" guys..
  93. Stock M6 Trans rating
  94. Anyone use other then DexronIII in their T56?
  95. Shifting problems on the N20 @ the track
  96. Problem Shifting To 2nd
  97. Rear Main Seal Replacement Instruction
  98. Textralia installed!
  99. need help with trans roar!!!!
  100. clutch doesnt seem to be fully engaging
  101. Centerforce Clutch
  102. Just installed Pro 5.0 w/LSS
  103. Hurt My 6 Sped At The Track Last Night, Suggestions?
  104. Heres a thinker!! Calling all experts
  105. Vibrations at 1800 RPM's
  106. Well I bought a RAM Powergrip...
  107. what does it take to get just the counter shaft out t56?
  108. What clutch to get
  109. clutch/flywheel setup for LS1 to Super T-10
  110. can't downshift 6th to 5th
  111. Knocking in the Hurst
  112. Textralia is in and working good
  113. T5 Transmission Troubleshooter
  114. lenco, jefco, jerico, liberty?
  115. Interest in hardened steel slider keys?
  116. In Houston...Need to have my T56 race built
  117. tranny mount?
  118. Clutch problems
  119. Difficult 2-3 shift under hard acceleration
  120. Yet another Spec 3 Install...
  121. Bushing or Needle Bearing?
  122. T56 Transmission
  123. Throwout bearing, tapered side goes towards front or rear of car?
  124. Tremec experts please help! Come in!
  125. Weird noise in my Tranny
  126. Does a new 288 slave come pre bled?
  127. Bolting LS1 to truck 5 speed
  128. LS1 / T-56 Clutch Options
  129. change the pilot bearing???
  130. Attn T56 builders
  131. Gotta Choose AUTO or MANUAL
  132. umi stick wont go into 2nd
  133. Spec clutches, how many miles and launches do you have on yours??
  134. 1st gear lockout???
  135. Spec III installed (results)
  136. tranny help lease
  137. finnaly need to replace clutch
  138. took apart clutch *pics* what do you think?
  139. how much can stock t56 gears handle
  140. 1-2 billet slider keys?
  141. what kind of synchros
  142. Z06 Disengagement Issues
  143. clutch install vib
  144. Clutch smell when slipping at lowspeed
  145. Tranny fluid...
  146. Those running the Aussie clutch
  147. Help, car won't go in any gear!!
  148. best t-56 output shaft?
  149. What would cause no reverse?
  150. tranny temp question..LOOK!
  151. Who knows what this is?
  152. T56 Transmission
  153. Trial by fire, RAM Powergrip HD
  154. Tranny Install problems
  155. A4 to MN6...How To Wire Clutch Neutral Safety Switch
  156. Anyone with a Yank Cross member?
  157. tranny removal w/o Jack?
  158. What's a T56 rebuildable core worth?
  159. clutch ?
  160. Input Shaft Movement
  161. please read, I'm about to smash my head through the wall...
  162. Popping out of 3rd - rebuild time?
  163. Basic T56 Rebuild, What parts should I get?
  164. Does'nt go into gear.
  165. Out of Balance Clutch?
  166. will a leaking slave cylinder cause double clutching to shift?
  167. stock t56 horsepower
  168. VETT pedals in trans am??
  169. Anyone Run an Aluminum Flywheel With a LS6 Clutch?
  170. time for a little work on the m6, where and what are the best parts to get?
  171. Throwout bearing bolts..
  172. installed new clutch
  173. Pilot bearing removal???
  174. manual transmission pedals...
  175. SLP shift knob...
  176. hard shifting?
  177. which clutch to get
  178. Pilot beang removal
  179. GM flywheel
  180. Wait for 2006 Z06 clutch to come out??
  181. Info for Rebuilding a T56?
  182. Clutch not disengageing
  183. How many miles?
  184. Bad tranny noise, i think.
  185. Stiff clutch after road trip
  186. Please help determine the problem???
  187. Bleeding clutch (MityVac)
  188. Stock clutch gets grabbier as it warms up
  189. 7-speed trans ?????
  190. Incredible customer service from SPEC...check this out...
  191. Mcleod Scattershield
  192. Looking for a new clutch, need suggestions
  193. Review of my Mcleod Single Disc clutch
  194. Guys with Textrila in Here
  195. clutch pedal stays inside :(
  196. underbody rumble/rattle
  197. Whats my problem??
  198. New owner! NEED HELP!!!
  199. changing synthetic to regular
  200. compatibility of pro5.0 shifters
  201. flywheel help with my gen 1 small block
  202. B&M ripper help
  203. Reset Harlan Shift Light?
  204. Hurst vs. Aftermarket?
  205. Any Pro shifted T56s here?
  206. M6 pops out of third
  207. Stock Hurst
  208. Z06 Clutch
  209. T56 Help!
  210. Launching
  211. Is there any way to use my Camaro 6 speed in my vette?
  212. shifter knob....any that are aluminum with a Firebied on them?
  213. All T56 shifters the same?
  214. m6 question
  215. what else to get when gettin clutch
  216. Clunking Tranny after Dyno... Gear Slack?
  217. Clutch issues
  218. where is the ground wire for the clutch pedal position switch at?
  219. clutch pedal MECHANICAL problem?
  220. crossmembers the same on swap?
  221. clutch engagement too high!!! makeing clutch slip!!! help!!!
  222. Poping out of third...
  223. Best Clutch for 550-600rwhp street and strip
  224. problems lauching the spec stage 3
  225. &*%#ing Ram clutches
  226. CarTek
  227. 5th and 6th won't engage, advice?
  228. M6 Hot Rod Wiring
  229. Slipping Clutch or in need of Drill Mod
  230. Drill Mod w/ 01-02 hydraulics?
  231. whats wrong with my tranny?
  232. Can you OVERthrow??
  233. pics of my spec stage 2 help where's the problem?
  234. 2000 TransAm Manual Gear box leak problem.
  235. m6 ?
  236. help with textralia install
  237. A4-M6 swap Wiring Problems
  238. Tranny and rear end cooler?
  239. Reverse dead on a T56!?
  240. Is T56 the best manual transmission for F-bodies?
  241. UMI Short Stick
  242. Flywheel/flex plate bolts
  243. Drill Mod only be enough?
  244. 5.0 or B&M
  245. 2001+ drill mod question
  246. short shifters
  247. what is this noise
  248. 1st and 3rd
  249. Master cylinder U bolt...
  250. Shifter moves durring acceleration..
