View Full Version : Manual Transmission
- Tick M/C squeaks like a rabid mouse
- Flywheel install??
- No clutch engagement?
- LT1 Monster clutchs
- Dropping Transmission
- monster clutch ?
- Need a clutch....Recommendations?
- Fidanza flywheel help
- Tick Performance Customers - How Quick Can YOU Shift? Video Contest - Post them here!
- Finally recieved My McLeod Twin disc set up. Have a Question before Install.
- Transmission Rebuild
- Does anyone have a photo of the hurst shifter that came in the 4th gens?
- Is this normal driveshaft play?
- T-56 grinds in 5th and 6th
- LQ4/T56 flywheel bolt question
- light weight flywheel
- quicktime bellhousing and monster stage 3 - does it fit?
- Light feeling clutch?
- derlin shifter knobs?
- 2nd gear oddities
- Help, problems installing new clutch
- Losing reverse in my t56
- Stubborn Shifting
- Clutch bleeding problem....
- Clutch pedal wont release at wot? T56 LS1
- reverse light/reverse lockout/vss pigtails, Pep Boys?
- Can I mate a T-56 to a 5.3 LMG?
- t56 stuck in gear after tow
- Tick Adj. Master Cylinder, stripped rod?
- tremec 3650 to lsx 5.3
- Stuck driveshaft in T56
- hard to shift
- 2010 Chevrolet Corvette ZO6 clutch kit
- New build....small issues
- manual transmissoon that came in 1998-02 f-body
- LT1 mcleod scattershield - have to align it?
- L92 Starter on a T-56?
- New Gen III Mcleod Master Cylinder
- McLeod RST
- T5 5 Speed
- Notchy Shifting unless I rev higher (like hitting a wall for a second)
- tremec 3550
- ANyone else have a MGW SHort Shifter???
- What the hell is up with my B&M Ripper?
- Trans making whining noise, what could it be?
- Removing CAGS from my 95 Z...pleez help w.how to?
- t-56 fluid qustion
- Tick Performance Adjustable Master Cylinder Kit in GM High Tech Performance Magazine
- Sensor on left side of the trans (M6)?
- Big thanks to Steve @ Monster Clutches
- Draining Stock T-56 tomorrow, Which Fluid Should I Refill it With?
- time for a new clutch?
- Clutch Issue
- Need a new clutch, I want a STIFF SOB
- What is the bolt size for the transmission mount to T56?
- MGW shifter question
- flywheel locating pins
- Clutch????
- Which clutch??? HELP FAST!
- Presolite/Mr. Gasket Aquires Quicktime Inc.
- M6 guys, you NEED a shiftlight; check out our $55 6-LED light!
- LS6 Clutch VS LS1 Clutch
- Monster Clutch Sale ends Saturday!
- tick master cylinder = teh sh!t
- 2 Gear Grinds Bad At Almost Every RPM and i have to slam it
- RAM Master Slave Problem/
- Remote Bleeder
- Questions about stock z28 shift knob,hurst option,and aftermarket sts for 98 Camaro Z
- problem!?
- can you rebuild a shifter?
- need some help/advice. "UPDATE"
- Reverse Gone!
- replacing CTS-v slave, can I use fbody slave?
- HELP! Installed Tick MC, where is bleeder??
- t5 questions
- MGW shifter rattle fix?
- Assembly lube substitute
- I Just Rebuilt My T56
- Clutch Disc/Flywheel "Welded" Together... Maybe?
- Pilot bearing- how far into crank does it go?
- Buying a T-56..which to order help!
- Researching remote bleeders, need opinions
- Monster Break in?
- lt1 slave help.
- how to's on bleeding master
- Expensive Clutch M/C alternative
- Rpm level-v m12
- Hurst Shifter question
- I cant get my slave cylinder to properly bleed
- Which clutch should I get? Poll
- T56 reverse light conector?
- Looking at used T56 tips
- T-56 Fresh Rebuild Hard To Get In Gear
- What clutch???
- D & D Performance
- New Shift Knob ... Gauging interest
- I think theres a leak in my hydraulics?
- 03 cobra short throw into 98 z28?
- Tranny/Rear end Noise
- Turbo camaro needs a clutch!
- Save the Manuals...
- Temporary lockout of 5th and 6th and temporary lock in 3rd
- What is going on!?
- T56 Drive Shaft Will Not Go IN
- Stumped on swap wiring?
- Fresh rebuilt T56, break in ?
- What fluid do you use in your Tick MC?
- 5th gear problem
- Can 5/6 gear ratio from M6 be put in a M12?
- how to trim poly trans mount
- LS1 4L60E to T56 complete conversion kits?
- 6 speed for Gen 1 sbc
- clutch master cylinder question
- lt1 flywheel
- reduce T56 gear noise?
- shim or adjustable master?
- My clutch finally feels right
- 3 and 4th gear grinding
- What year started CF Blocker Rings?
- Tick master cylinder mounting?
- New Monster stage 3/tick mc
- Tick or RPM ?
- Clutch master issue?
- Dex 3 seem not do to well at high temperture, switch time
- 3rd gear grind question
- Help: Transmission/bellhousing stuck on block.
- Clutch noise??
- Adjusting McLeod Master LT1
- Monster Clutch Co. Twin Discs!!!!!!
- clutch help anyone
- Phoenix Friction Clutch Audition
- NAPA/Perfection Slave Cylinder, new style fitting?
- clutch engage at hight rpm even with pedal down
- TDP and Diamond Clutches
- RAM Clutch
- Centerforce clutch and spec flywheel
- Rear vent plug?
- T56 can't go in gear HELP
- Smells Bad
- need a new tranny, suggestions?
- I think I killed my clutch
- T-56 rebuild ?
- Clutch pedal sticking. Yes I read. Unique problem.
- Question about Pro 5.0 shifter install
- M6 Swap guys - cutting a hole for the shifter?
- 02 camaro ss m6 clutch noise
- best place to build t56?
- new tick master cylinder ?
- Selling our remaining Monster Clutches from the sale...come inside!
- Shift fork conversion possible?
- PITA T56 somebody help me please
- What connects the shifter to the rear transaxle on a C5 Vette?
- Clutch "squeak" when engaging in 1st gear... normal?
- Problem with 3/4 shift. New slave, tick MC
- Monster Clutch Co.'s New 11" Race Clutches!
- GMM Ripshifts @ Speed Inc
- New clutch won't engage Please Help!
- park in gear ?
- Wilwood master cylinder with 1.12" of travel
- Noob syncro question.
- not sure if i need a new clutch????
- Which clutch kit?
- Trans is out. Lateral play on input. Busted slave. Need some advice!!
- ANother Transmission oil question
- Car bucks when shifting
- More props for the Tick Master
- stage 2 tranny rebuild
- 2004 GTO Aftermarket Shifter
- what clutch should I buy?
- Stock SUCKS!!
- Adjustable master worth the extra money?
- Need some help with some bolts
- M12 T56 Rebuild Question
- Grinding at high rpms and sometimes when shifting
- centerforce dual friction clutch question
- Line-Lock Question?
- Torque specifications for spec super twin st trim
- some help on what else i need to conect the clutch to my 70 chevelle?
- Transmission wont let gear out?
- Help! T56 wen't "boom"
- CRAZY loud squeal
- RAM Aluminum LS2 Flywheel
- Will my CTS-V t56 fit on my ls1 with ls1 Pilot bearing?
- AC Delco Master Cyl any good?
- p0704?
- Highly recommend Jeremy from SPEC!!!
- Vibration in "top" gears
- In depth monster clutch review
- What do you guys recomend for trans fluid?
- GMM Ripshifter grease
- Question from someone new to these cars.
- I keep hitting 2nd, instead of 4th! wtf...??
- Can a RAM billet steel flywheel be resurfaced??
- Fast guys running a T56 come in!!! - Sub 11 second
- Reverse lockout seems stuck on
- 3rd gear grind
- Clunk / bang when shifting or disengaging clutch
- Clutch Slip?
- Not Again
- So a T56 takes 4 quarts?
- quick clutch question
- lt1 to ls1 clutch conversion question
- cant get into 1st gear from a complete stop
- wheres the best place to buy a pro 5.0 shifter?
- 1st Gear Grind
- Best way to go for my M6
- McLeod RXT?????
- Liberty Transmision?
- tranny howl
- revert grind, what I need to check ?
- Transmission Input Shaft question
- adjust the clutch ?
- Clutch engages 1/2" off the floor???
- Can you convert a corvette trans into a camaro trans?
- Want to get some opinions on my diagnosis - blown clutch slave
- Hard Shifts
- Any body here note smooth shift with regular dex 3 ?
- Why is my clutch doing this?
- New Ram powergrip clutch bad? or shop full of retards?
- Clutch not Disengaging.....master cylinder pulsating
- anything better then the spec 3+ in same price range?
- T56 acting up
- Transmission toast...again
- What Fluid for 6-speed trans?
- Severe clutch chatter....need advice
- LQ4 and six speed setup
- 2000 ss clutch sticking on floor
- 98Z T56 swap reverse lockout not working.
- Where can i get a gear puller for the t56?
- Which side of the clutch disc faces the transmission?
- Clutch problems/Hydralics maybe...
- Clutch pedal only returns back 90% of the way?
- T56 work in SE Michigan
- a few t-56 questions
- built t-56
- Clutch pedal question?
- who makes the best t56 internals??
- Help! Leak coming from transmission area
- What is this? T-56 Help please...
- Slave Cylinder Fluid?
- LS7 failure! No warning!!
- Just finished M6 swap (shifting problmes)
- Question about recent M6 swap.
- LS7 Clutch&Flywheel-Expected Changes?
- T-56 strength.
- ANOTHER noob question... extension housing binding?
- cultch or master?
- Braided line question!
- Spec Stage 1
- C5 auto to Manual
