View Full Version : Manual Transmission
- Anyone with a Textralia please respond
- Can a Textralia aluminum FW be used wtih a RAM HD clutch?
- Further diagnosing the Textralia problem......
- t56 third gear issue
- 435rwhp - LS7 ,Spec 2+, Ram PG, or Cartek
- clutch feels like it isn't there anymore.....
- greatness
- ---New hydraulic problem---
- ordered a stage 3
- Stuck In 4th Gear
- pilot bearing
- Throwout bearing replacement
- slave cylinder replacement.
- Reverse grind and newly acquired 3rd grind
- F-Body Motorsports
- Ram HD clutch
- LS7 clutch ?
- clutch purchasing question
- Packaging of Transmissions
- T56 problems HELP
- Which of these two clutche setups?
- Need Help!! Tranny Is Sometimes Hard To Get Into Gear !!
- SLP LW flywheel after 30k
- Best clutch for 750+ RWHP
- LS7 Clutch and LS1 flywheel ?
- Broke My Spec!!
- t56 rebuild suggestions?
- what clutch to get ?
- OEM Clutch disk thickness???
- How do you shift on the strip?
- Ls7 Cluth Question
- transmission specs???
- Drill mod/Bleeding method
- FlyWheel HELP!!!!
- Quick Help...Is this a factory hurst or stock shifter?
- Need something better, quick.
- Transmission Problems
- 30 Spline Viper Yolk
- Break in Clutch? (Searched)
- clutch problems !help!
- Finishing in 3rd
- Skipping gears?
- where can I find a ls7 clutch?
- Strange noise on down shifts!?
- Vibration through shifter and seats at about 4k? (Corvette)
- Tranny shifting problems...need help
- F&$* master cylinder
- cluth fluid?
- No straight answer yet! Spec 3 is pissing me off!!!
- damn it to hell top bolt t56
- 3rd gen T5 vs 4th gen
- Aluminum Flywheel or Billet Flywheel
- Tranny Mount Help...
- Noise
- push or pull style for Ls1
- Possible clutch problems.....need insight
- thinkin about doin a 6spd swap
- T56 Gear Speeds
- Good Daily Drivin Clutch that can Hold
- ??ANYBODY HEARD OF "BRUTE FORCE"??
- what is a good price to pay for slave cylinder and master cylinder install?
- pilot bearings, who all has had them fail?
- Clutch drops to floor when car is parked.
- What clutch for high hp?
- LT1 T56 behind LS1 motor?
- need a rebuild
- issue with m6
- turque spec's
- When to change T56 fluid?
- Pullin the tranny
- Autozone or Murray's clutch?
- Reverse Lockout wont disengage
- Leaking Tranny Fluid
- spacer with spec 5
- Clutch having trouble holding at high rpms?
- shifter rod???
- Completley flushing the fluid out of your hydraulic system...
- Quick clutch question
- need help clutch falls to the floor
- Clutch & Slave, help please ???????
- Any way to tell if I have Drill Mod?
- lt1 manual tranny..
- clutch sugestions for power???
- Another Spec takes a dump
- m6 tranny weight
- Whats the best clutch for 500-600rwhp?
- Help - Dealership cannot find transmission problem
- Throwout Bearing Question...HELP!
- Good clutch, dont mind the chatter
- Fidanza Alum. LS2 Flywheel In Stock?
- Shift Boot for M6 Question??
- Spec stage 2+ vs stage 3 vs stage 3+
- how much for clutch install?
- 94 T56 hydraulic problem
- Rolled out my car after T56 rebuild +, project has burnt me out.
- Another thread on Clutches
- SPEC 3+ problems
- Pics of clutch bleeder valve?
- Quality Clutch Replacement In Naples/ft Myers,fl?
- Does this Shop want too much?
- LS2 flywheel in Aluminum?
- Question on how to bleed the LS7
- WTT: my A4 (w/ Yank 3500 Stall) for your M6
- Textralia Installed, my opinion.
- What vendor carries Textralia?
- Weird stalling and surging...?
- Clutch or Tranny problem?
- Changed shifter out - E-brake messed up now (spring?)
- Can you pull the tailshaft housing off w/o dropping the tranny?
- ANOTHER Clutch Slippage/Problem
- is my tranny f-ed
- Remote Bleader Line for SLave? - AE fitting's?
- Clutch problem help!!
- Question about hurst aftermarket shifter.
- T56 vs. Richmond 6sp?
- clutch hydraulic problems!!! need help!!!
- transmission problems!!!!!!
- LS6 Clutch + 5.3L Truck + 18 Months + ...
- Transmission Specialty
- Cheapest LS7 Clutch Dealer??
- Need Help putting tranny back in.
- Part Numbers Needed!
- new clutch and tranny wont slide back in???
- T56 rebuild kits off ebay?
- Car will NOT go into gear, inside please to help!!
- ??Ram HD or Z06 Clutch??
- I dont know how to feel...
- Q. on adj master. Already searched a bit.
- clutch/trannsmission problem?
- 99 TA clutch bleeder valve?
- Clutch Issues. Again. (Deleted previous thread.)
- grind, and popping out of reverse.
- Tranny mount and crossmember torque spec(quick please)
- cartek vs LS7
- Spec Stage 2 Problems....NO SPEC Haters Please!
- LS7 clutch dealer?
- new clutch wont work
- clutch pedal gets stuck
- Qeustions regarding mityvac
- Do I need new bolts for doing a LS1->LS7 clutch swap?
- Hurst Pro Billet Plus w/ WS6 Store Short Stick Impressions
- ripper shifter for my Z?
- New flywheel needed... suggestions please!
- 3rd Gear grind????
- What power bleeder for clutch?
- Slave cylinder removal?
- Checking tranny fluid, can someone show me pics of where the fill plug is?
- Re-Use Old Flywheel Bolts OK?
- Spec 3+ Flywheel/PP question.
- New Spec 2+ installed... Now hard to shift gears.
- Sorry, another question about trans. mount
- what broke off? (pic inside)
- Engine need support after trans removal?
- my friends tranny needs help
- trouble putting in 1st and reverse from stop
- Noobie: Clutch Change Question?
- 3rd Gear Bog
- ws6store short stick install question
- Happy Birthday to Joe (LS1Joe)
- Centerforce stg 2?`
- Pro 5.0 question
- shift knob.
- Anyone using Fidanza flywheel with McLeod single disc?
- Eating clutch fluid, clutch going to floor, slave or master?
- LS7 CLutch INstall...tranny bolt problem?
- Clutch
- Time to replace clutch...again?
- Are you happy with our rebuilds
- Customer Satisfaction
- LS7 clutch/alum fw installed, might need adj master cyl.
- I need shims for a specII! please help if you can.
- Proshifted t-56 for sale + full conversion!
- 2nd gear grind when speed shifting, rebuild options?
- Can I get a Timken seal part # please
- Better short stick, Lou's or WS6 Store
- Possible bad U joint, or????
- T56Rebuilds.com NMCA Special For Joliet Illinois
- Is my clutch going?
- What shifter to go with????
- Pro 5.0 with lss installed today.
- Help Haveing Clutch Problems
- ??Centerforce Clutch?? Good or Bad??
- HELP!!!Bleeding Clutch....!!!?
- Skip shift and short throw q's
- Pilot bearing not there???
- hydraulic line
- LS7 Clutch arrived today
- exo-skel heads up
- buddies car wont move, clutch wont disengauge????
- Transmission ??????
- Did I just lose alot of horsepower by installing LS7?
- LS7 Clutch Problems
- BellHousing stuck to the block
- Swapping a 98 T56 into a 95 Formula
- T56 install?
- Puzzler- Missing 1,3, Reverse after rebuild
- After shifter install, 2-3-4 shift it grinds BADLY??
- Textralia Exo-Skel Clutch
- 3rd Gear Grind?
- LS7 clutch
- Soo many choices
- My Tranny Is Broken N I Need Help (daily Driver)!!!
- Why cant i get the slave cylinder hose back in
- hotspots and grooves in flywheel...
- How important is this spring?
- Tranny Problem
- Bad Ohm in a JET skip shift eliminator
- did the drill mod
- McLeod Adjustable Clutch Master Cylinder
- T56Rebuilds now offering for rent a 2 jaw puller for the do it yourself guys
- Is my clutch slipping?
- clutch fluid, which brand?? mine is evaporating
- m6 fluid
- Another clutch question
- 500rwhp C5 Z06 and roadracing-Which clutch?
- car wont go in 6th!
- 1st...2nd....then went into reverse, instead of third ? OUCH
- car will not shift in 2nd 4th or 6th
- !!clutch Problems Help!!
- How much horsepower can a stock tranny hold?
- Factory Hurst: VERY notchy on shifts or somethng wrong?
- Impressions of Textralia clutch after first track trip...
- Wierd 3rd Gear Problem???
- spec5
- Ive had it with my clutch!!!!! TIME TO REPLACE, HELP
- lt1 Super t-10 Modular bellhousing help
- LS7 clutch / drill mod / bleeding question.
- transmission wont go in
- Question about what clutch to get and Centerforce Clutch
- Part number help please!
- Help diagnose weird tranny behavior.
- Another "What's the best Clutch" for 800+RWHP!!
- What is the difference between '98-'99 slave and '01-'02?
- New master cylinder?
- master cylinder lenght?
- help - can't seem to get clutch to disengage?
- mn12
- T56 Reverse Problem?
- Stock Flywheel Questions (specs/turning)?
- how much fluid
- Problem after LS7 clucth install**Did Search*
- LT1 T56 Grinding Reverse
- New Spec 3 clutch sound good
- c6 shift to reverse?
- What am I missing here? Master cylinder removal wtf
- Question about Clutch choices
- LS7 clutch has finally been finished.
- Swappin trannies
- I AINT getting an Automatic
- Ques.Auto to 5 speed LT1l/COMPLICATED
