View Full Version : Manual Transmission
- Tick Master *%$^!!! How to get in place???
- How can i tell if i have a factory Hurst shifter?
- Slave
- transmission question
- T-10 direct replacement?
- Will not shift over 5,000 rpm - LS1-T-56
- Reuse self adjusting Pressure plate w/new disc?
- New PP with 6 Puck clutch disk?
- new pilot bearing loose in crank ?!
- T56 Tranny Fluid Spraying Rings - Help Diagnose
- LS7 clutch require stepped flywheel?
- 6speed question
- stroker nitrous 6-speed guys... gears
- 1st to reverse clunk?
- Grinding going into 2nd
- 96 camaro clutch chatter please help!!!
- Hurst shifter for m20.
- Ram C4 Coversion System
- Tick Speed Bleeder Installation
- Clutch weight comparison OZ700 vs RST
- source for t56 quick disconnect fitting?
- cant figure it out. please help
- 5-6 Shift Grinds
- crank galley plug *pics*
- monster vs twin
- clutch question for ls1 z28
- Will a new master cylinder fix this engagement issue?
- Centerforce Clutch Issues
- Tick Slave Cylinder Shims Help
- ls6 flywheel
- Performance after m6 swap??
- C5 shifter wont center itself calling JMD MIKETPI etc
- best bang-buck clutches (~700lbft flywheel or less)
- HELP! disassembled T56, can't find problem
- Gear gurus. right ratios for all around performance.
- Crappy customer service from Pro5.0
- Clutch squeeling periodically
- Factory hurst pulled out of the rubber
- Noob clutch lifespan question Monstwr stage 3
- New part and New problem... any help?
- which throw out bearing
- Does anyone know what a Lakewood bellhousing weighs?
- new clutch choosing
- Tick master install
- Changing clutch, release bearing question.
- Weird Noise at Hi-rpm when I push the Clutch in.
- t56 lubricant
- What upgraded T56 part causes notchy shifting?
- T-56 locks up in first gear
- First T56 rebuild
- ~800whp turbo capable clutch
- Grinding noise t56 PLEASE HELP
- Mcleod Twin clutch light grinding noise
- Monster Clutch Holiday Sale!!!
- T56 troubles
- Details about swapping 03/04 Cobra .79 and .63 gears into our T56?
- LAst resort.. Clutch help?
- Return spring
- T56 Rattling under load in 3rd and 4th
- Shimming a DYAD twin disk, slave problems
- mgw to hurst stick
- monster clutch
- Clutch going out?
- Is this supposed to be like that?
- T56 engagement at the floor
- drain transmission?
- Leaking problems!!
- New clutch advice!
- T56 swap observations...
- T56 technical help
- mainshaft/countershaft shimming
- t56 core
- LT1 M6 swap. unique problem/question
- monster clutch not disengaging
- m12 mainshaft and countershaft part pics
- Which is The better replacement stock clutch. A gmpp LS7 or a Centerforce LS1 ?
- McLeod RXT - My Experience
- Drop tranny help?
- T-56 Poping out of 6th?
- T56 Slider Question
- stock T-56
- Tick Performance YEAR-END T56 & TR-6060 Transmission Rebuild SALE: SAVE $100 EXTRA!
- Wont go in Gear in the Morning
- Remote shifter for T56 magnum (Viper)
- MGW Shifter Installed
- input shaft bearing race
- No pilot bearing??
- Adjustable master cylinders
- Not your normal 2nd gear grind
- Suggested T56 Rebuild Kit
- RPM Transmissions Cyber Monday SALE!!!!!
- 7.25" dual clutch questions
- Clutch pedal gets stiff with oem clutch
- 900rwhp roll/mile/occational strip trans
- who rebuilds a T56
- Did I kill my clutch?
- LS6 vs LS7 clutch for bolt on (eventually cam only) car?
- Help!!!!
- T56 Steel 3-4 shift fork install problem
- Can anyone identify this shifter?
- Will the Mantic clutch in my 02 camaro fit my 04 Z06?
- What is the difference between LS6 and LS1 clutch master cylinders
- transmission issues
- Wondering if anybody knows the difference between LS1 and LS6 clutch master cylinders
- LS1Tech Group Purchase '13: Tick Performance Adjustable Master Cylinder Kit for LS1!
- Can't Hit Reverse or 5th Gear
- help me with what is wrong with my t56!
- T56 hard to get in gear...
- Where can I get this daiphragm???
- Anybody running a SPEC stage 1 clutch
- clutch bleeding
- No resistance, when pushed in slow
- T56 issue help...
- clutch line release
- Did Monster change their stage 2 12" frictions? Mine looks different.
- 4th gear grinding
- T-56 Making Noise in 5th & 6th ony
- lightweight flywheel/clutch for LS7
- Where is my clutch oil going?
- Clutch pedal vibration
- Skip shift eliminator???
- T56 rebuild tips
- changing the 5th gear ????
- T56 swap complete now it revs with clutch in
- LS7 Clutch, Tick MC adjuster and Bleeder, new slave
- Engine / bellhousing / trans compatability
- Emergency need help
- Hurst T handle
- T56 Magnum shif quality
- Diamond clutches
- T56 won't fully mate with block...
- First C7 clutch in a C6!
- what transmission do i need?
- $300 t56
- LS7 Clutch, Centerforce, or Spec Stage 1?
- loose 5/6 driven gear
- Monster Stage II noise
- New OEM Master Cylinder leaks
- Clutch help asap!
- new clutch just work for 3 days
- Viper input shaft and Mcleod Street twin issue
- Stuck in 2nd Gear only
- clutch pedal vibration when fully depressed
- What is it worth, 202 zo6 6 speed package
- New Clutch,Slave,Master not working!
- trans question t5 tilted bell to ls1 5.3
- reverse wooooeeeessss
- having a lot of clutch issues...
- 08 LY6 6.0 mated to T56??
- clutch master bleeding with power bleeder
- WTF clutch???
- grinding going into first?
- gear speeds
- Dragging clutch?
- T-56 transmission question
- Mityvac problem?
- 6 speed grind question
- Bad clutch or something else with transmission
- LS7 or Monster??
- Stage 2 Tick rebuild T-56 issues
- Does anyone here have this shift knob?
- shifter question
- M29 with different 5-6 possible?
- NV3500 with external slave cylinder
- Launch recommendations?
- T56 $$
- What are the chances?
- Viper T56 shifter base options
- Auto PCM w/ 6 speed harness??
- PPG sequential gear box conversion for T56!
- First to Second grinding
- Second gear not engaging. Do i have to Rebuild?
- Do I need a T56 Rebuild? Or new TP Master cyl
- What's Going On Here? Thoughts?
- Shifting/down shifting and clutch sticking problem
- Randomly stuck in 4th
- Gto t56 gear noise... Help!
- T56 pro 5.0 issues
- reverse retainer install
- Bellhousing ls3-t5wc what works?
- mods to use a LT1 trans in a LS1
- Documenting my conversion, c6 zo6 to rwd.
- Clutch Recommendations
- Heavy duty transmission ls6
- probably a stupid question but need a quick answer please
- 12 bolt Moser 4:10 on 6 speed
- Debating 4L60E to T56 swap
- McLeod rxt break in
- TR6060 Behind an LS1?
- Who Sells Upgraded T-56's?!?
- mighty vac bleeding
- What clutch should I get
- t56 MAGNUM. tranny mount?
- Monster 11" Ceramic Race clutch?
- Help!!
- 2002 trans am willn't shift
- Need a little direction on what to use.
- Slip Yoke Stuck
- Help with picking flywheel
- Shifter only moves forward and back, no side to side. Car wont move!
- Pittsburgh, Pa shop to install-bleed clutch master
- problem removing main to input shaft bearing
- What does this piece do?
- First time out with new McLeod RXT
- T56 shift problems from 1 into 2.
- Staying with the GM clutch
- Shifter help
- t56 lockout solenoid not working
- I still need help with clutch fork :(
- Chirping sound coming from bellhousing area
- Anyone know the actual height difference of the MGW shifter?
- VSS Teeth on T56 from 2005 GTO
- GTO vs Fbody Shifter positions
- ARP flywheel bolts a good idea?
- First time at the track 2-step/3-step
- Strange Tranny Rattling Sound
- M12 Z06 trans options
- 3th Gear, high rpm shifting issues
- Clutch recommendations (see post)
- GTO T56 Slip Yolk Coupler onto F-body T56?
- Tickperformance built T56 or TR6060
- Trying to pull the Transmission out!
- extra part from c5z to gto t56 conversion
- Which Master Cylinder
- C5 Tailhousing To Diff Large O-ring
- Ls1 with ls7 clutch
- Well 2nd gear no longer exists....
- Shimming?
- monster stage 2 clutch got soaked
- WS6 Clutch / Shifting issues
- New LT1 clutch balance?
- Does anyone know if Tick keeps any clutch kits in house?
- over tightened drain plug leaking
- t56 fluid with metallic shean
- Squeak and rattling sound
- Tick master monster stage 2 review
- T-56 rebuild kit
- Sticking clutch pedal
- T56 tough shift issue....
- More master cylinder problems
- T56 Rebuild!
- Installing LS7 clutch on an LS1. Do I need the LS7 master slave?
- Shifter noise.....already searched
- Clutch setup for my swap
- six speed trans shifting problems
- T 56 won't dwn shift 6th to 5th
- Is Ram's aluminum flywheel right for me?
- why is my clutch fluid dark
- C5 t56 assembly: need help.
- A4 to T56 swap: Pedal wiring Help
