PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Help:Hard to go into reverse after 9" install
  2. LS7 clutch vs. Hendrix Clutch
  3. factory T56 shifter= crap....
  4. LS7 OEM Friction Disk Thickness.....Anyone have a new one?
  5. LT1 T56 Components for conversion questions.
  6. Ordering a monster lvl 3.. Billet or Chromoly??
  7. 700whp guys what clutch
  8. Unable to shift into gear
  9. where to buy the braided line from master to tranny?
  10. Input shaft wear
  11. help grinding noise when clutch pressed
  12. reinstalling my t56 ... need a hand on a sol question...
  13. Anyone want a Auto?
  14. Cant Shift Tranny
  15. Dumb Question?
  16. Help with textrailia twin disk
  17. MF'r Im spitting 4TH! on WOT
  18. T5 World Class Upgrade Options?
  19. How much are built t-56's going for ?
  20. Installed Monster clutch and new problems arose
  21. Fidanza aluminum fly wheel on c5 z06?
  22. quick adn easy question: need a clutch reservoir
  23. What the Hell is this..??
  24. Rebuild Kit DIY
  25. T56 is dead.
  26. Wanted 6.0 clutch suggestions.
  27. Can I damage my trans if...
  28. Think we can reuse this flywheel? (pic inside)
  29. t-56 rebuild
  30. Whats the best Clutch kit and Rearend??
  31. Car shakes and shudders -- new problem help pls
  32. Short stick compatible?
  33. Shipping Weight & Dimensions - T-56?
  34. Short Stick ?
  35. LS7 Clutch install, hydraulic questions...
  36. Will go from 4th-5th fine, but WONT go from 6th-5th? wth
  37. How much will my ram powergrip HD hold?
  38. t56 stuck in neutral
  39. Swapping a T-56 trans into an Escalade...has it been done?
  40. 26 spline
  41. spec clutch
  42. pedal wont return after master cylinder change
  43. Reverse lockout solenoid. How does it work??
  44. Textralia OZ700 Z-grip review (14,000 miles and counting)
  45. Probably a dumb question about my M6 swap.
  46. Went to replace the Slave, help IDing clutch please.
  47. Where to rebuild t56 please!!
  48. Need help asap.. Anyone please help. Slave cylinder grommet missing.
  49. Tranny Mount
  50. what clutch is this ?
  51. C6 Corvette 6speed into 97 TransAm?
  52. DIY Short throw?
  53. Ripper shifter
  54. Installing ProthaneTranny Mount
  55. Slave hydro line conversion?
  56. mc leod twin disk won't work since i parked my ta for winter
  57. McLeod or LS7?
  58. Help sort out 06 CTS-V clutch swap
  59. I kilt splines on my torque tube
  60. Switching to LS7 clutch...need part numbers...
  61. New h/c pkg tor my m6 '72ss-input please!
  62. Weird clutch problem
  63. wll it hurt anything
  64. Grind Going in 2nd
  65. what the tq specs. on the flywheel bolts????
  66. Strange intermitent clutch problem
  67. 5th & 6th gear issues
  68. 4L60E to T56 conversion on LT1?
  69. vibration in 3rd gear through shifter
  70. Aftermarket Slave???
  71. trans issue (video of problem)
  72. clutch swap?
  73. No leak possible bad slave?
  74. T56 Core?
  75. Trans problem. Advice please.
  76. 09 C6 shift issue, only on 3-4 shift
  77. what shifter to buy
  78. difference in gto t-56 and camaro t-56
  79. tick master...?
  80. Monster stg 3 vs Spec stg 3?
  81. I bought a Tick Performance master cylinder
  82. 2000 c5 vette wont shift at high rpms
  83. 4l60e to t56
  84. How long will clutch last question?
  85. new cam, more power, missing shifts
  86. Help me make a clutch replacement parts list..
  87. Carnage T56
  88. B&M Ripper Shifter Length vs. Lou's Short Stick
  89. Monster Clutch.. Short Pedal??
  90. New Clutch Advice Please!
  91. R154 on 98 LS1? Crazy? Doable?
  92. need help finding a replacement retainer for an M6
  93. clutch bleed question
  94. non hydro throwout bearing ?
  95. McLeod clutches?
  96. Recommend me an aftermarket LS7 Flywheel
  97. 2nd gear is gone.
  98. ?, I purchased my car with a built T56 w/ Strait cut gears good or bad?
  99. How do you identify a ls7 clutch
  100. confusion about what clutch to use?
  101. Best way to bleed clutch
  102. Best way to bleed clutch
  103. clutch to use
  104. Best value replacement clutch?
  105. CTSV Shifter question
  106. Six speed in list
  107. Need Help with Hydraulics
  108. slave leaking, is that the problem
  109. Monster clutch Stage 1.5 installed. do I have Chatter or a bad install?
  110. "Sloppy" shifting - Any thoughts?
  111. LT1 T56 clutch problems
  112. T56 Rebuild kits?
  113. T56 Ls1 Flywheel
  114. Identify this T56 sensor. Please.
  115. 2nd gear grind after rebuild
  116. Flywheel Help!
  117. Where the heck did I screw up my T56 swap wiring?
  118. Is this typicall for the t56s
  119. installing ls7 clutch, what adjustable master cylinder to use
  120. Help with plate holding MC
  121. 04 ctsv t56 in an fbody?
  122. LS7 Flywheel???
  123. dumb question...autozone only has automatic trans oil?
  124. Bleeding the clutch????????
  125. 4th gear grinds, but force will make it engage
  126. Monster lvl 3 & Tick lvl 2
  127. RPM Transmissions Sales at EPP - Deep Discounts!
  128. Clutch Questions?
  129. where to get another 2step
  130. Having problems with my t-56
  131. what all to fix?
  132. How to tell visually its an LS T56 and not LT or other?
  133. Reverse Lockout Switch?????
  134. T56 shifter relocate
  135. Clutch problems....
  136. Need help with a clutch install nightmare1!
  137. Any of you LS7 clutch guys using a non oem ls2 flywheel?
  138. Clutch sticks to the floor
  139. Synchro Rings
  140. Part
  141. How much can I get for my broke t56?
  142. Question on F-body clutch master cylinder
  143. Noisy trans...
  144. input shaft
  145. NEED HELP clutch stuck on the floor and car is stuck in gear
  146. Concern about clutch.....
  147. does anyone know
  148. Videos Of Before/After Tickperf. Master Cylinder
  149. Can u run an aftermarket dist with stock PP?
  150. I keep getting more air when I try to bleed my clutch.
  151. Ram Clutch Disk Measurements??
  152. Last day for the sale....
  153. Third has trouble engaging but doesnt pop out once in
  154. 2009 G8 GXP T6060 6spd vs T-56 Question for shifter location
  155. T56 Differences?
  156. weird bleeding issue...need help?
  157. Pedal is low. about 1.5" lower then brake pedal??
  158. t56 vs tr6060
  159. Monster clutches Level 3 Vs. 3.5?
  160. Help buying clutch
  161. pro 5.0 problem
  162. LS7 question...
  163. Will a LT1 pressure plate bolt to a LS flywheel?
  164. trans making funny noise
  165. Need a new shifter what to Get???
  166. Opinions on the condition of this Textralia OZ700
  167. Changing Manual Transmission & Rear Differential fluid question
  168. T56 mid-plates
  169. m6 hard shifting in every gear
  170. sintered iron vs. cera-metallics, if you have experience w/ both step inside please
  171. monster stage 6
  172. monster 3.5 questions
  173. bad tranny or bad clutch
  174. car stuck in 4th
  175. Fluid Questions
  176. textraila twin is slipping
  177. Whos running a Monster level 4 or above?
  178. speed bleeder
  179. Decent affordable clutch for my mods? and is it my clutch going out?
  180. Does Exo-skel Work With ARP Flywheel Bolts?
  181. Spec?
  182. Mighty Vac Question
  183. T-56 is done for, need suggestions for self overhaul.
  184. Tick master and the cruise switch
  185. Need Help w/trans
  186. Pushing my luck...?
  187. sticky clutch.....read so much, im confused
  188. Tick Performance adjustable master cylinder
  189. Manual trans options?
  190. Dfx
  191. Tex Box
  192. What's wrong?? Clutch still spongy after Mcleod rebuild and wrap?
  193. Clutch problems, rear end????
  194. M/C or Slave problem
  195. factory 01-02 shifter m6
  196. broke t56 ???
  197. Please help!!!!!!
  198. Clutch issue!
  199. Does anybody float the gears?
  200. Just installed TICK master cyl, almost have to stand on pedal
  201. Goign Green! Got the Mosnter in.
  202. Tick Master Issues
  203. spec clutch flaken
  204. monster stg 2 guys come in
  205. Car won't shift into third @ high RPM
  206. Diagnosis help?
  207. Needing tranny
  208. new to ls1 tech need help or info
  209. New to LS1tech help please!
  210. did i wait to long, 3rd and 4th gone
  211. hopefully an easy question to answer (clutch and flywheel).
  212. Shuddering when letting clutch out...
  213. New clutch problem?
  214. Good News & Bad News!!!
  215. Clutch sticks to floor in heat
  216. Any Advice? LS7 with Fidanza - Tomorrow
  217. Balls. UPS Damaged T56. Repair or Replace?
  218. Clutch problem?
  219. how long do they last?
  220. Do i have a hydraulic problem?
  221. Trans member mounting hardware
  222. Reluctor Ring, and possibly Output shaft.
  223. Clutch Bleeding Walkthrough
  224. what could be wrong?
  225. Clutch or syncro problem?
  226. 3rd adn 4th gear are gone! help
  227. Please help me figure this out !!!
  228. Smart to get a clutch now?
  229. transmission fluid
  230. 3.4 tranny fit up to a 3.8 engine???
  231. 5.3 LS engine to T-5
  232. Monster clucth + TICK Master+track bite+ nittos=
  233. Questions about Using an AT Wiring Harness with a Manual
  234. Clutch problem?
  235. Im F*CKING stupid!
  236. My car wont shift at 6000-6500 Help Please
  237. Anyone have ls7 kit in stock if not what are my options?
  238. point me in the right direction
  239. 2nd Gear "dissapeared"
  240. Textralia clutch ??
  241. Wiggly Clutch Slave
  242. Brand new Spec Stage 3 clutch slipping a little bit?
  243. High hp T56 guys
  244. High hp T56 guys
  245. Dowel size
  246. broken input shaft..any direct upgrades i can do?
  247. Broken 3-4 Keys
  248. recently installed clutch question
  249. what clutch to get
  250. stock pressure plate bolts
