View Full Version : Manual Transmission
- t-56 gone!
- T56 question
- High clamp LT1 clutch pressure plates. True or BS?
- how much can the LS7 clutch take???
- hard shifting
- A4 to M6 swap parts for 04 GTO
- 9 sec T56
- Weird problem. Vibrating with RPMs and clutch wont disengage with horrible sound
- Just did the 6 speed swap, now ses light
- has anyone broke the slave after doing the drilll mod
- its grrrrrrreat!
- Clutch problems??
- LS6 clutch
- centerforce question
- bleeding clutch questions
- mcleod clutch hose
- T56 do-it-yourself question
- SixSpeedInc
- t56 grinds
- How to identify a Hurst shifter?
- Clutch Hydraulic Fluid!
- Tired of this setup.
- Remote Bleeder
- dust collectors for t56??
- 1500 miles on Textralia
- 6 Speed Amber???????????talk To Me !!!!
- How much torque should I apply to tighten the tranny mount?
- weich clutch??
- Is this the tool i need to pull the pilot bearing?
- pro 5.0 problems
- Scatter Sheild
- Problems maybe motor mounts
- Sintered iron disk clutch
- T-56 behavior when putting in gear
- LS7 or Ram HD?
- Help me, trans problems?
- New GM Clutch
- Clutch/ Trans Problems..Someone Help!!
- ls7 clutch swap?
- Missed 3rd, ruined 5th, couple ??
- Aftermarket Shifter??
- UMI shortshift for 5.0 pro?
- Need to replace clutch soon
- HORRIBLE Grinding Noise!! Help!
- Shifters
- Proper slave cylinder spacing questions
- Pro 5.0 shifter question
- It won't go...
- will this clutch bolt right up to my car
- six speeds inc, i have a ?
- adjustablemaster/t56rebuilds ?
- T56 sticky clutch question
- What happens if tranny is only filled 60% full?
- I bought a RAM Powergrip HD, use it or not?
- Replacing rear output seal
- Tailhousing seal
- Clutch diagram manual?
- Where can i buy a stock ls1 clutch
- need some advise
- alignment screw problems
- Anything besides the t56 that fits LS motors?
- Problems with LG motorsports rebuilding my trans.
- how to get pilot bearing off?
- Clutch squeels when taking off....Cartek
- Remote Bleeder- Teach me
- problem going into 2nd gear
- Clutch Woes: Replace with aftermarket or stock stuff
- Shifter stuck in neutral
- Where to find stock clutch or simlar..
- Need help choosing my next clutch.
- Ram PG HD issue
- What do you think about this Pressure plate?
- 6 speed inc got ? for ya!
- Wow hardest t56 I ever removed
- where can i find a conversion for from a4 to m6
- can a mcleod master be rebuilt while on the car?
- sqeaking slave cylinder??
- 3rd Gear Grind!! Help!!
- clutch problems!
- Clutch Question for T56 and Vortec 350
- Got my Textralia Triple Disc Clutch
- I broke my slave...WHY??? *pics*
- Which parts to order for new clutch?
- 2000 gt transmission
- The worst day of my life... so far :lol:
- which sponsors??
- Clutch life?
- Power shifting..
- Spec super twin fitment issues?
- T-56 Centering Question
- Transmission whine. What is it?
- Blew out my Z07 clutch
- where can a buy a mn12
- hardcore t56 guys.... whats wrong with this?
- clutch feels soft, help.
- Some one had to know????
- Best Clutch For Under $400
- what is face platting?
- Roadracing clutch?
- Centerforce clutch?
- a few swap questions a4 to m6
- 4 th gears sometimes and not others
- Strange reverse grind...
- is it time for an ajustable slave?
- c6 transmission
- Auto Conversion To Standard Trans.
- big t-56 question
- loud vibration after LS6, slave, master install
- Low and hard pedal
- New rebuilt T56 Grinds New 4th Gear
- Manual vs Auto. Reliability, Maintenance Costs...
- anybody ever machine a slave down?
- What's a good clutch for just normal driving?
- no reverse after total rebuild
- Best short shifter?
- ls7 clutch
- Problem Pulling Tranny
- light weight flywheel install
- need help with ram adjust. master cylinder
- Textralia Exo Skel
- Installing a Clutch fork bolt in car???? T-56
- T56 in 1990 ZR1???
- what HP to replace LS6 clutch?
- Mistakenly used antiseize instead of threadlocker
- Shifter Grease?
- pops out of reverse.
- Pro 5.0 vs Hurst...Dumb question
- What Shifter do I have stock?
- TNA or WS6 store?
- Clutch swap/trans removal sticky!!!
- T56 problems
- Anyone use a trans adapter cradle on your reg floor jack when changing the clutch?
- Major clutch/slave woes, come in please! Long kinda funny story.
- LS-1 Clutch Adjustment, 2001 Z-28
- T56 says no overdrive
- LS1 Throttle Body Spacers? Worth It?
- clutch probs,please help
- shim question: Mcleod bellhousing w/ Ram twin
- Question about LT1 flywheel.
- flywheel/pressure plate question
- Has anyone ever tried this/
- Help me brainstorm this clutch problem
- SixSpeedsINC above and beyond....
- Transmission identification
- Bad luck!!
- Need a clutch that is easy to push in
- When a clutch begins to go out...
- MN12 in a 98 Firebird
- flywheel
- Stubborn quick connector...
- 93-97 pedal assembly in an ls1?
- LS1 T56 transmission breaking point
- LS7 install.....
- need advise on a clutch change out 95 Vette.
- whats causing my slave cylinder to break hers a pic
- T56 slipping
- Need recommondation for new clutch
- pro 5.0 or b&m ripper?
- Skip Shift ? 93 Trans in 97 Car
- Textralia OZ700 Z Grip- My review after 3,000 miles
- vette T56 into Fbody?
- gto and fbody t56 the same?
- Centerforce dual friction - heatspots?
- mcleod twin disk???
- gto m6 on 2000 ls1 trans am
- vette with spec 3+ shim slave?
- Lightest M6 flywheel???
- Time to rebuild the t56
- GM Clutch Master Cylinder part number?
- M6 Problem..
- 93-97 t56 will it work on a ls1 ?
- Problem with LS7 clutch
- My clutch is talking crap to me....
- diff between ls1 and ls2 flywheels?
- Wierd sqeuaking noise after Clutch install
- installed tex z grip, but no pedal
- to soft of clutch
- ????steal braided line????
- Drill Mod Poll
- Comparison of f-body to GTO t-56
- All new parts.... Need somebodys help.
- Operating temperature for T56... (Cooling system?)
- Heel-toeing?
- Is it possible to break-in clutch quickly?
- Tips for installing LS7 clutch?
- ??? again. bellhousing and trans torque specs.
- Ram Twin Disc users step inside, I have a question
- Master Cylinder Problem?
- Can starter be mounted to bellhousing ?
- Write up on changing clutch?
- After 150,000 miles and track visits every weekend my clutch slipped...WTF?
- T-56 help!!!!
- Trans Mount Nut
- trans removal from bell housing HELP!!
- reverse(t-56rebuilds.com 4a)
- Clutch/hyd/starting problems
- Problems bleeding McLoud adj. master cylinder.
- diagnose my problem please....
- Is it my clutch, hydraulics or trans?
- tranny help!!
- clutches clutches and more clutches
- still having problems, someone PLEASE help!!!
- t56 GT &WS6
- Will a C5/Z06 shift knob fit?
- welding a broken T56 housing
- 2 different problems, sound and stalling at a light... new T56 install
- Need advice/help please
- Advantage of a pro 5.0
- Help with Slave Cylinder Removal
- Who else has hella noise with poly mount
- LTX Vs. LSX GM bell housing differences
- Just finished Ram PG HD install, reverse trouble
- Clutch experts come on inside!! Anyone still use ram 6130 disk?
- Stock alloy driveshaft
- spec 3 or spec 3+
- trade a4 4 m6, all parts
- ls7 clutch and t-56
- 6 speed 1st to 4th auto shift question.
- Clutchmasters Clutch
- T56 where to buy it? HELP!
- yet another..............
- T56 trans problems
- Lt1 dual friction disk
- Crossmember A4-m6
- Spec and Ram shims for slave...same thickness?
- Help with LS7 part numbers ? What are these ?
- t56 feels like playdo/ no shift gate ?@!$@^&*
- Symptoms of a bad MC?
- Trans Removal Tips?
- ls7 clutch
- netrual safty switch problem
- Clutch install writeups?
- Shifting problems.. Replaced everything.
- Gear ?'s help asap
- Clutch pedal return spring bushing?
- Partnumber for VSS sensor
- Installing SPEC clutch - need some advice
- Viper Tranny
- Ram Twin Disk ... Problems Inside!!!!
- So a flywheel out a 2006 GTO will not work on a new LS7 clutch
- Spec?
- Spec 3+ vs LS7
- so im looking to get a new shifter, a little help
- Swishing metal sound
- Proform shifter
- How much should the D/S Move Around In Trans?
- Is this noise/vibration normal
- Slipping clutch. Worse that could happen?
- trouble with slave cylinder
- Stupid question, can i remove hose from slave w/o removing trans?
