View Full Version : Manual Transmission
- Installing Adjustable Master (Mcleod) - Help
- Tranny Rebuild
- Clutch Questions...
- 3rd GEAR GRIND!!!!
- pro 5.0
- slave/master question
- how many of you guys had to use spacer on your clutch?
- M6 Fill plug and drain plug torque spec
- Textrailia clutch install questoion
- leaky rear seal on T-56, common problem?
- Anyone ever use one of these?
- Recieved new clutch...
- notchy chunky shifts????
- I call it the clutch-safe
- Clutch pedal stuck to floor-drill mod done why?
- Imput shaft question???
- Did drill mod
- Broke my T-56 tailhousing....Need lots of help!
- Ram Vds?
- Transmission rebuild question
- anybody got any tips on puttin in a clutch spring...
- BAD transmission noises
- Is there a Code for HURST
- textralia clutch arrived
- pressure plate to flywheel bolts???
- SkipShift Diagrams/Photos
- Shifter Sticky in gears!
- Aluminum Flywheel People
- Clutch pedal ?
- t56 - Bellhousing bolts
- Car nearly stalling, clutch problem.
- Weird problem with tranny ... or clutch...can't tell.
- just got my car back with spec st3. clutch feels light as air,is this normal?
- Slave Cylinders
- A4 to M6 Swap, easy question here please
- Bell housing
- Spec stage 3 write up
- $$ Throw out bearing
- ls2 clutch
- Skip-shift light
- Wrong flywheel?
- Don't know where to check next
- new clutch time!!
- which knob?
- Hard shifts
- Throw out bearing??
- UMI Short Stick
- Pictures* Finally broke my Spec 3
- shifter neutral return spring mod
- Question(s) about clutch installation
- my spec3 journey begins
- OEM vs Replacement rear seal, no boot <pics>
- new tranny and clutch
- How many miles are on your stock clutch?
- TNA Short stick install
- Spec II or III?
- About to change tranny fluid, one question.
- upgrading to spec s5
- Best Clutch For the $$$??
- HELP!! Is my tranny about to take a dump?
- New flywheel + new motor
- Need to bleed?
- Shift pattern
- Clutch Play?
- M6 help
- stock clutch life expectancy+ questions
- Any flywheel pro's? (mcleod billet)
- quiet down a Pro 5.0?
- Clutch Fork
- Balancing PP&fly spec3
- Would a PRO 5.0 stick bolt up to a factory Hurst?
- Textralia clutch is in. Impressions
- Clutch release point all over that place after Mcloed.
- whats better with a pro 5.0 the power tower or short stick.
- Just bought a Ram
- Why is my clutch so hard to push in?
- Whats involved in replacing the rear seal?
- Ok, did GM change something... slave, pics!!
- Mcloed clutch question
- Inside diameter of clutchmaster on a LS1 Camaro or Vette
- Powergrip HD Install ??????????need help
- Spec3
- Signs of bad Master or bad slave?
- clutch engaging 2X?
- Shifter Install
- Lightened Flywheels
- McLeod bellhousing, Will it fit with SLP longtubes?
- 2 Tranny's in One car??? Street/Track
- built tranny
- Methods for flushing/bleeding the clutch??? Please help!
- converting A4 to M6, do I need computer harness?
- Spec stage 3????
- Mcleod twin disc rebuild?
- Torque Specs For Clutch And Flywheel??
- loud knocking noise???
- Mcleod masters still having problems..?
- What Torque Spec?
- Auto transmission dipstick tube...
- clutch
- McLeod Master Install Question
- Ram PowerGrip clutch seems to have died tonight
- Quick answers - Clutch Master Cylinder Install
- Clutch engages extremely close to floorboard
- Balancing Question!
- What make a clutch SFI approved?
- $900 + 400 miles break-in = shi-t
- Can an F-body shifter be modified to fit a vette?
- replacing friction disc on fidanza flywheel
- Clutch Slipping or Normal
- 99 Hydo questions
- Overfilled Tranny?...how did this happen?
- Used stock flywheel ok with spec?
- Exactly how to break in Spec Stage 3
- Shim?
- need slave cylinder parts asap
- Short stick 4 my Hurst?
- high power and transmissions
- question ablout clutch & flywheel balancing
- clutch alignment tool?
- B&M Ripper, installed.
- which way is the pro 5.0 mounted.
- Weird Problem...
- Stuck between 3 & 5
- transmission problem
- slipping clutch
- Centerforce Dual Friction Question!
- anybody have an opinion on these flywheels?
- McLeod or Spec?
- Flywheel question? quick help!
- Shift problems Help?
- first clutch
- Clutch and Tranny Trouble!
- High rpm 6,2 and up, wont shift into next gear
- spec sent me a new clutch but not a flywheel
- Won't shift into gears!!???
- CAGS in DFW
- What Are Signs of a Slipping Clutch
- Problems with Hydrolics
- trans shakes off idle
- 2002 M6 parts for sale
- Help with transmission
- Drill mod without removing tranny?
- Ripper shifts really rough
- Z06 Clutch Ready to Fail?
- Pics of an insulated clutch hyd line
- price for a4 to m6?
- help with Nissan 350Z
- Variation on soft clutch petal...
- Whats a Good Clutch For Fidanza Aluminum Flywheel?
- Driving a Manual Tranny.
- Seal leak and a question
- Possible worn clutch?
- do you need a adj master with....
- Beginner at launching
- spec clutches junk? pix of mine inside.....
- flywheel auto/manual same?
- Shifter impressions...??
- anyone have a jerico in a LS1?
- Stock hydrolics with Spec S3?
- New clutch master cylinder
- bleeding
- Shifts into 1st instead of 3rd!
- Is this normal after the "drill mod"?
- Great T-56 rebuild!
- How many sponsers sell the Textralia Clutch?
- pics?
- how's my clutch and flywheel look??
- T-56 Rebuild - Questions
- LSS on a non hurst
- clutch question?
- If my clutch slips
- broke the slave cylinder while removeing my transmision!!!!
- Slave Cylinders
- drill mod
- Mcload lt-1 bell housing
- What fluid?
- Energy Suspension tranny mount: Yes or No?
- complete t56 conversion how much?
- Clutch Safety Switch
- Installed new clutch
- Talked to spec about the stage 4F welding to the flywheel issue
- Texas Motorsports transmissions
- the daily driver is down!
- clutch install
- Oi. Clutch Pedal Stuck to the Floor.
- downshifting
- Help!! RAM stage 3 install problems
- t56
- clunking in tran when shifting and-
- Master & Slave Cylinders
- Trans dipstick
- I wanna kill spec, 2nd stage 4 is toast!
- Which clutch to get
- McLeod SFI Bellhousings still Back ordered?
- Need Help (98 Camaro SS)
- Where can I find info on
- break in peroid
- Clutch petal sticking to the floor after new clutch install
- Shifting bad after shortstick/!CAGS
- lt1 t56 problem
- Spinning grinding sound...
- pedal got stiffer
- need a clutch stock or spec stage 1 or 2?
- **Stock Adjustable Master Cylinder Writeup**
- A4-M6 swap done ?'s
- pilot bearing
- spec stage 4
- Bought New Zo6 Clutch, FW, & PP-Are They Pre Balanced?
- What shifter?
- need help getting my tranny back in
- what size thread is hurst billet plus?
- A4 to M6 swap questions...
- Planning on Trans Swap-which is better?
- 3rd POPING OUT
- Need help bad...won't go in gear.
- grind when w.o.t. only
- Damaged Z06 clutch
- Think I grinded third, might have a problem
- Best T56 Service Manual?
- .62 sixth gear in 2001 T/A
- Anyone installed a BW Super T10 behind an LS1?
- stuck in 4th gear
- spec stage 2 vibration
- who has had a clutch in their 11-10 sec street car for more then a year?
- Sbc To T-56
- Vibrating shifter when letting off clutch from a stop after spec s3 and alum flywheel
- Spec Clutches are a SCAM!!!
- Clutch, Slave, or Syncros?
- Installing clutch
- Which GM Slave Is the best??
- Which shifter shifts the smoothest and fastest
- Bad clutch allready! Shit
- t56 install and remove
- t56 rebuild help w/ some options. allready found the problems
- stock clutch life?
- Who's M6's HAVEN'T crapped out on them?
- Need Help Right Now!!!
- Clutch pedal return spring???
- Rattling; Is it clutch related?
- Is the Clutch gone?
- is $630 in parts cost for clutch assembly too much?
- Grinding into 3rd after a hard launch!!!
- smell after clutch break in
- Clutch problem??
- Bleed the Slave cylinder or not?? (and a few other ?'s)
- flywheel
- clutch upgrade info/tips
- Textralia clutch or something else?
- soft clutch pedal after revving??????
