View Full Version : Manual Transmission
- GM installed SPEC III...it's engaging at the floor! HELP
- Ram powergrip HD is a piece of *&%@, only 500 miles on it and its slipping like crazy
- [B]Spec stage 2 kit and billet steel flywheel good enuff?[/B]
- bolt type for center plate under the car where SFCs tie in?
- Clutch or Tranny
- Any reason NOT to do the Drill Mod?
- Will changing my fluid help ?
- Transmission problem or rearend?
- 03 Viper T56
- Slipping Spec stage 3, thats pretty much new
- T56 Pita... Again!!
- After Drill Mod, Does Anyone Have Problem Keeping Pedal Pressure?
- What would happen if I
- Ram Clucth...so far so good!
- my spec 3 went out today w/ only 1000 miles.
- m6 problem
- UMI short stick
- whats ur favorite shifter?
- shifter help please
- Clutch issues in here
- 3th and 4th Problem
- November T56Rebuilds.com Specials
- Drill mod for updated Z06 master??
- V6-V8 clutch master cyl different?
- Gears feel notchy?
- What does a Textralia OCZ700 come with?
- Shifter?
- Shifter Q?
- Pro 5.0 noise
- what to do for new clutch
- Clutch hydraulics problem?
- The Best Rebuild Kit For M6
- Need help
- Will I have any regrets?
- is there a proper way to set up clutch or hydrolic system on ls1 clutch?
- shortening a short stick
- help please with 3rd gear
- CAGS system breakdown for a noob
- Questions on the 05 GTO T56
- T-56 Questions
- Rebuldable T-56?
- Resurfaced stock flywheel and Spec clutch?
- What T56 gear oil to use and how much?
- How much?
- Powershifting??
- Sorry, don't know how to search for this one....
- Who, other than D&D?
- clutck sticking
- What clutch will hold 1000 rwhp?
- Do I have to get a new flywheel...
- rebuilding the t56
- help. new trans mount and now all hell breaks loose!
- trans mount giving me hell!
- Clutch Problem...
- Clutch Problem...
- How hard is a clutch install?
- Stock Replacment Clutch Gone Already???
- Bell Housing
- pro 5.0 shifter stops
- good deal on z06 clutch?
- What shifter do you like best?
- Tranny finally swapped!
- Progress on my Transmission
- 3rd gear on STOCK M6 feels a little notchy
- Please help! clutch is clicking after install
- how much HP on a M6
- Clutch Replacement from ground zero
- 9 inch OR 12 bolt
- "free play" in clutch pedal
- question about the ls7 clutch
- Found a cheap clutch...will it work?
- Random clutch story
- M6 or TH350?Better et's
- having T56 problems on a 99 Z28
- Close-ratio t56 in a 98Z?
- Tilton/QuarterMaster question.
- Drill mod necessary for '01 / '02 hydraulics?
- Squeeky Squeeky
- partial clutch shifts
- insulating clutch line
- Do i really need the mcleod adjustable master cylinder??
- can you make a ls1 have an old style cable clutch?
- Mallett Short Throw Shifter
- Popping out of first gear?
- What's the benefit's to a poly tranny mount ?
- Spec stage 3 Does and Don'ts
- Cheap T56
- Remote Clutch Bleeder for TA
- which master cylinder
- Anyone have a picture of T56 yoke?
- Correct position of the clutch pedal?
- Just a observation.
- Slp hurst vs Aftermarket shifter
- Input shaft
- gm part #'s anyone??
- SPEC 2 or SPEC 3- Help Me Pick one!
- why would the stock clutch break
- the Spec 4 is one awsome clutch
- Hurst Equiped?
- Just installed Energy Susp Trans Mount OH NO!!!!
- t56 locked up in fourth on my Daily Driver!
- Stock flywheel with a SPEC 3?
- Drag Flywheel help
- [2004 Corvette Z06] What is UP with the wheel hop?
- Clutch or Tranny?
- Need help with an ls1 6 speed clutch/actuator & throwout bearing
- Broke drive Shaft w/et streets, 12 bolt and twin disk
- Stock clutch diagnoses <pics>
- convert LS1 hydro's to LT1 style (smoother shifting)?
- do i need it
- Stock Tranny Life?
- release point on spec 3 clutch
- looking for master cylinder
- code 711
- 5 speed in my frc
- New Gm Master And Slave Question..pre Blead?
- Clutch sticking to floor (step by step troubleshooting) hope this helps
- M6 to A4 swap?
- does this kill my clutch?
- Clutch problem??
- Does the Textralia come prebalanced?
- not sure what to call this
- T-56 Problems (98 Z28)
- T56 in c5, new from GM, WOT fluid out vent
- WTF? Why does my clutch get WORSE after bleeding?
- Mount Stripped
- 2 Questions....(one is opinion)
- Whining In First Gear?
- Help me make my stock master cyl adjustable
- 1LE transmission mount for 2002 M6?
- How many miles does it take to break in a new clutch?
- Bleeder Screw?
- Anyone use a spec Stage 4 on the street.
- Textralia installed. My opinion.
- zo6 clutch
- Poly Mount Installed
- Clutch engaging 2x closer to floor....Z06 clutch...HELP
- Grinding sound when shifting into 3rd and 4th?
- can u tell me whats wromg with my m 6
- quick and easy bell housing question
- Drill Mod question?
- Hopefully the master????????
- A4 to M6 swap and reverse lockout
- Spec stage 3 on the street ??
- Help Clutch Pedal Stuck To Floor.
- How much should a clutch replacement job cost?
- Difference between 98 and 99 wiring?
- T56 Sensors?
- PRO 5.0 shifter problem
- Clutch and flywheel
- Swapped in new GM master and slave...
- best rpm to shift for best 1/4
- Would a 2002 T56 have steel forks and carbon synchros?
- Help - clutch pedal pushing back at be at high rev shifts
- how do you tell the diff between LS1 LS6 clutch?
- Presure Plate torque specs?
- lengthen or shorten Adj. Master to get to engage more
- Life Of A Stock Clutch?
- Just had a U-joint blow out on me damaged yoke seal on T-56 how hard to replace this?
- Please Help! Hydralics Problem
- New Cam only Best with a T56Rebuilds.com M6.
- 2 questions. Master? flywheel? (textralia)
- making sure i am using my new toy right
- TO bearing always spinning?
- Rverse lockout?
- T56 rebuilds
- Anyone with a MBA shift knob.....
- 2000 Master cylinder?
- Clutch Masters and Fidanza
- Help with ShiftKit
- mcleod clutch users come in for a couple of ?
- what type of synthetic fluid to use in M6
- Who here can hook up their M6 car on the street?
- Clutch line removal
- rebuild price?
- Help with clutch!!!!
- hesitation probs...any guesses?
- street tires plus oz700=chirp in 4th
- Need Clutch Install Advice
- Any One Using A Pro 5.0 Shifter?
- disengaging problems
- How do I recognize an upgraded slave cylinder?
- problem with clutch engagement
- Can clutch life be prolonged?
- McLeod Twin Disc Issues...
- Clutch to Buy?
- Pro 5.0 and lss
- clutch pedal return spring
- Ram HD break in period?
- Shim for a Spec stage 2
- Anyone with a RAM clutch please look..
- M6 Issues anyone got any ideas?
- just installed pro 5.0... some questions
- Need Clutch Help... Textralia owners in here.
- how to tell if an m6 is good
- Spec Stage 3+ review
- Textralia Clutch
- thoughts on t-handle shifter
- 97+ 6 speed console Q?
- Problem with shifter
- Some Crazy Ass Noise...
- Driveshaft will not go back in?
- C5 Vette grinds when trying to go into 5th
- will this work ?
- what rpm do you take off at from a stop?
- Loud noise question
- is it a hydraulic issue?
- Just installed new clutch and...
- short shifters
- Does anyone have the instructions for their Street Twin?
- What is going on with my cltuch!
- Is the slave cylinder suppose to have a male or female end?
- installing a master cylinder hard???
- Bendix Slave
- clutch line wont plug in
- what all i need
- clutch makin noise
- Where to get a clutch installed?
- Stuck in 2nd, PLEASE HELP!!!
- Need GM Part# for 1LE Transmission Mount.
- clutch installation?
- clutch and master/slave cylinder replacement cost?
- T56Rebuilds.com October Special
- shifting problem
- Speed shifting an M6
- T-56 Help
- LS7 Clutch?
- spec 2 plus
- Master upgrade.
- Help Me With T56 Parts
- Shifter feels soft
- Vehicle Speed sensor retaining bolt??
- What is the best short throw shifter for the LS1??
- Exedy Clutch Grinding/Squealing
- McLoed master cylinder
- who builds t56's to take 900 hp?
- Question about McLeod Street Twin / Shims
- Replacing Clutch
- Flywheel torque?
- T56 Identification numbers
- clutch ruined? ideas anyone?
- Finished My First T56 Rebuild?
- Transmission gets "stiff" after racing...
- C5 Trans gear grinding Problem
- Spec 3i?
- Stock Hurst Shifter??
- Oil Leak From Bellhousing-m6
- reverse problem
- Tranny fluid help please look!
