View Full Version : Manual Transmission
- New clutch hard to get in gear
- Ok need help with clutch problem
- What am I missing?
- T5 Speedo Help
- two enguagements with the street twin??
- 5th gear grinding, only 30K
- buying a new t-56
- mity vac'd and pulled up black globs?
- Clutch replacement questions
- RXT vs Text
- Time for a Tranny Rebuild...
- Not Mentioned in Any Clutch Replacement Treads
- best mg fluid
- Eneos Fluids ?
- Short stick
- Clutch Problems
- Cheapo ebay shifters.
- High RPM shifting issues! HElp!
- How do I test my clutch?
- LS2 clutch into LS1 car NOT WORKING?!
- LS7 clutch checklist. Did I forget anything?
- Short Stick B&M Shifter
- T56, LT1, Hard to get in gear/pop out.
- Clutch Slipping
- cammed ls7 clutch
- Couple of questions
- Intorducing Diamond Clutch, our all-new adj. master cylinder! & T56 Rebuilds
- Need help identifying this clutch!
- Clutch Break in a Myth?
- Is a used FBody T56 tailshaft housing worth anything?
- LS7 clutch fylweel options.
- Short throw shifters for Corvettes???
- ~~Clutch pedal engages at different places?!?~~
- LS7 clutch w/ LS3?
- Clutch master cylinder reservoir
- Third gear grind
- 3rd gear problem
- Clutch break-in for non street car
- rebuild problems.....
- 1-2 T56 billet key springs
- What clutch and PP is this?
- t56 extension shaft
- stock t56 questions.
- Sticking Pedal Read sticky
- Will Tail Housing Break?
- T56 shops in dfw
- Need a quick answer, how hard should the 3-4 synchro move?
- T56 Whine
- Rebuilt my t56 but theres a small problem...
- pilot bearing question
- Replacement clutch advice.
- LS7 Clutch Question - hopefully quick
- Advanced Clutch Technology: INFO PLEASE
- something broke please look inside if you can help.
- Does a new pilot bearing go in with the bearings toward the tranny or the block?
- Gear ratio's in stock 01 M6 ?
- LS7 clutch won't release?
- Pros and Cons of Lightweight flywheel
- Zoom street/strip (stage 2) clutch kit
- SPEC CLUTCH GUYS...throwout bearing question????
- Pilot bearing question????
- Tail shaft seal / gasket questions.
- Blown trans horror story and help needed!!
- Anyone using RPS clutches?
- help on clutch
- Rear seal question
- clutch help
- skip shift help
- clutch not releasing
- master cylinder problem
- Can a C5 Corvette T56 be converted to a Camaro?
- two engaugements with the street twin??
- Mcleod Street Twin longevity?
- need help with a pilot bushing puller
- Couple T-56 questions...
- Recent 4l60e to t56 conversion, problems with clutch
- Replacement Springs for Pro 5.0 shifter??
- master cylinder hyd line help!!
- clutch is sticking to floor
- Whats the best LT1 T56 I can buy?
- Shop where I can send my fbody tail housing to be machined for a viper output shaft?
- Spec + GM Hydraulics = No Fourth Gear?
- Monster clutch quick install question
- ls7 clutch
- Help pick a transmission
- I Might have a big problem sponsers welcome.
- Problems with new clutch and tranny, need help
- Stuck in fourth!!!
- Hurst shifter vs Hurst Billet????
- T-56 5th - Can I change the ratio?
- Slipping clutch
- Best T56 shifter?
- Clutch slipping now what
- Mushy pedal
- HELP!! Broken Pieces=SUCK!!!
- Wtf happen!
- Car wont drive.
- replacing clutch which mc?
- What gear should my tranny be in....
- I need a new t56
- Clutch install price
- New clutch - balance question
- FREE shipping on all clutches from SDPC
- Clutch acting funny?
- Viper T56 with Fbody front plate, tail, and bell housing - Output shaft seal question
- Anti-Venom mod?? Anybody done it?
- What clutch?
- Throw out bearing
- Monster Dual Disc Clutch?
- bellhousing problems
- Monster Level 3 Disk Size??? Need answer quick
- Is this normal?
- upper clutch switch
- 93-97 pedals vs 98-02 pedals?
- LS1 T56 with LT1 Adapterplate/InputShaft on LT1 Trans Am
- Trans help (going back together with it now)
- need some help with clutch disc choice.
- help after t56 swap issues
- 01 6.0 and ls2 flywheel starting problem
- which clutch?
- Questions on Wilwood and Tilton master cylinder for LS1 T-56
- A few questions about my shifter.
- Corvette B&M Ripper + T-56 Trans Am
- 97 LT1 t56 w/SSR shaft?
- Pilot bushing woes
- T56 problem please help!!!
- Damn this clutch
- Jersey Transmission Shop
- Tick Master, What brake fluid ?
- t56 hard to get in gear
- 00 Bellhousing doesn't fit over Z06 clutch?
- 5 speed manual tran best fits 502 RamJet
- Shifter Boot
- shifter shake
- A4 to 6speed swap ?
- t56 problems
- Will an Ls7 hold up
- Clunky/notchy shifting after s60, DS, Adj TQ arm.
- Clutch will not disengage at all
- Shakey 6th gear?!?
- Transmission Fluid
- Signs of a bad Throw out bearing
- Where to get bellousing to tranny bolts? t56
- Mustang Cobra Pro 5.0 shifter in Camaro?
- T-56 swap
- sooooooo question
- please help cars apart...
- Master cylinder
- starter troubles
- What style T56 is this??
- biggest needle bearing in a t56 is where??
- Transmission Noise
- Suggestions for where to buy parts for Viper T-56 Conversion?
- t-56 rebuild kits
- I pulled the trans and HOLY SHIT (pics)
- ********VIDEO******** Clutch Sqeal
- replaced slave cylinder and still have no pedal @ high RPMs
- installed motor/trans, now clutch is slipping... HELP!
- T-56 swap, need advice
- master to slave braided line question
- Will a 99 6spd bolt up to 93 Chevy 350?
- monster and tick....strange issue
- Powershifting w/ Spec 3
- t-56 tear down
- Speedo Gear Teeth?
- I have searched with no LUCK!
- Can anyone reccomend some good shops?
- Need a clutch expert on this one!
- Annoying squeal noise coming from tranny
- mobil 1 ATF
- C5 Clutch Problems w/ Spec Stage 2
- Bleeding Help
- Help me pick a clutch
- Flywheel Torque Specs
- Which flywheel 28 or 18lb?
- Alright tick helped but didn't fix. I think I found the problem.
- Time for rebuild?
- Monster clutch guys.. how are you taking off?
- Skip Shift Solenoid Removal
- Street twin break in procedure?
- Good replacement clutch
- Bye Bye T-56 Hello 4spd
- Probably going to need a rebuild.
- is a m12 the same as m6?
- Cookie cutter abrasive????
- T56 Problems
- Hurst Shifter
- M5 tranny question
- possible clutch problem
- need help asap
- t56 tear down (revised w/ pics)
- Clutch question HELP!!!
- sticky pedal(tick fixed it)
- Stupid quick question
- torque arm mount bolt specs
- T 56 bearings
- T56 Issues Not Sure whats broke..........
- clutch is slipping
- New clutch break in
- New Clutch and Hydros, 2nd Gear Grind?!?!
- gto bellhousing??
- Good replacement for stock clutch
- Clutch for 400+whp and Trans Rebuild questions. Thinking Tick lvl 2
- Car pops out of 1st gear?
- looking for 6 speed
- Ls1 t56 to SBC bellhousing question
- Bleeding the clutch
- Need a new clutch
- Ok getting close with this shift light.
- 5 speed man and about moving to 6 speed
- popping out of 6th
- ls7 clutch and salve
- Help, oil behind pilot bearing
- Which make/model/year had triple carbon syncros?
- Transmission trouble
- Vengeance Racing introduces Magnum T56 DIRECT Bolt in for F Body!!!
- Throw out bearing help
- Is there a way to distinguish between a Clutch Master cyl failure vs Slave cyl?
- Truck - TKO 600
- 93 Camaro Z28 Auto to Manual Swap
- question about a clutch
- lost 5th gear . rebuild asap ?
- Whining from shifter from 1-4 , HELP !!!
- tick m/c questions
- How to take off shifter boot properly?
- Does anyone make a short stick with a 12x1.5 thread?
- Raptor Shift Light question
- Best clutch for my application ???
- Monster install - Pressure plate and dowel issue. *PICS*
- Stock lenght shaft with MGW shifter?
- Clutch going out what all do i need....
- People seem to blame the shifter a lot.
- Did you guys lose the positive feedback feel from your MGW ?
- Car pops out of 3rd?
- LT1 T56 Behind an LSx
- Clutch recommendations.
- T56 98-02
- Anyone know where I can buy a y-pipe bracket for the T56?
- LT1 Flywheel Problems "Shaking with Clutch Use"
- How many have broken the plastic rectangle for the shift boot
- Monster Twin Disk release day??
- master cylinder went through firewall?
- Reverse light switch broken
- High RPM shifting problems, SPEC Clutch?
- t56 rebuild ??
- 1 leg amputee driving a 6 speed WS6, having an issue, please HELP!!
- McLeod Dealer of Race-Tick Performance
- Lost 1st, 3rd, 5th & reverse!!! HELP
- tick master cylinder problem
- does pro 5.0. make a shifter for a c5?
