PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Anyone done the so-called Anti-Venom Mod?
  2. 1,2 Shift Fork Billet Keys
  3. ram hd questions
  4. Extremely Notchy Tranny in the cold
  5. reverse question
  6. needa clutch, please help
  7. local autoparts store slave cylinder?
  8. Post Some Pics Of Shifters & Knobs
  9. anyone ever seen a yellow spec clutch?
  10. clutch job rough to get into gear
  11. Clutch Power Losses?
  12. Needing my transmission rebuilt
  13. adj. a master cylinder....
  14. Need socket to bleed clutch can't find the socket?
  15. lost my pedal pressure after new clutch install????
  16. t56 swap
  17. Could it be my clutch making this noise?
  18. Nasty vibes at the shifter
  19. Help with Clutch problem
  20. Best Clutch for me?? Need Opinions
  21. T56 Swap Cruise Shut Off
  22. how to make a street twin SLIP
  23. Shifter Knob/ with line lock mount??
  24. Wich part number for McLeod BH?
  25. Flywheel/clutch installation snag..
  26. clutch slipping?
  27. Wasn't Thinking, slave cylinder
  28. T56 woes and pains
  29. Clutch pedal return spring
  30. clutch rebuild?
  31. Reverse Lockout assembly help
  32. Need some help
  33. vibration in first
  34. Cant Down Shift To 2nd
  35. Help me identify what year is this M6
  36. Stock power, stock clutch, record life?
  37. What tool for slave bleeding?
  38. Mainshaft Bearing
  39. Hurst Billet Plus Question???
  40. Would Heat tape and Dot 4 brake fluid help shifting high rpms
  41. 2 questions
  42. Dealership "powerbleed" clutch?
  43. Pro5.0 w/ short stick problem...
  44. A4 to m6 swap, now clutch chatter?
  45. Cruse control?
  46. Quicktime bellhousing question...
  47. tremec 6060
  48. How do you tell if you have the factory Hurst shifter?
  49. Getting new clutch and flywheel
  50. Got a real simple question about our Hydraulic pressure
  51. Is my pilot bearing in all the way?
  52. T56 Problem
  53. Another 3rd problem but different.
  54. t56
  55. LS7 drill mod question
  56. 3rd Gear grinds... what do I need?
  57. bad clutch??
  58. LS7 Clutch Kit
  59. new mount
  60. trans, clutch, rearend gurus ...in here
  61. Confused..a4 to m6
  62. help! big problem
  63. What bearing is this? How do you get the darned thing out?!?
  64. trying to reinstall my trans
  65. Use this PP or Send it back?
  66. Spec stage 5?
  67. Why does my clutch howl when im going up hill?
  68. T56 Sensors
  69. Bell HOusing
  70. Sticking clutch at high RPM's
  71. Car creeping after clutch install
  72. GM Part Number Needed
  73. ws6 store short stick + umi handle? no workie
  74. Bronze fork pads for road racing?
  75. .............Will T5 hold LS1 bolt ons...........?????????
  76. 6th gear pops out
  77. internal parts
  78. clutch problems
  79. 2001 Camaro clutch pedal return spring PLASTIC BUSHING
  80. Going to settle this shifter debate.....
  81. Looking for a shift knob.
  82. So Six Speeds Inc, How far behind are you guys?
  83. F&*(&^g transmission wont go
  84. C6 Z06 T-56 Questions
  85. Transmission fixes itself?
  86. Found part of my trans/shifting problems...
  87. doing a clutch in gto
  88. Stock flywheel or Ram flywheel with Powergrip HD?
  89. What is the Best Clutch for LS1 manual transmission
  90. Problems with 5/6 gear.. grind
  91. LS1/A4 to truck M5
  92. RPS clutch after 2yrs and 110+ launches
  93. please help
  94. Which adjustable master to go with?
  95. Clutch bleeding
  96. two questions/problems
  97. Lower Shifter Boot Question
  98. spec 3+
  99. NEW ls7 clutch slipping at high rpm?
  100. New LS7/LS2 combo VIBRATION???
  101. master cylinder, throwout bearing or something else wrong?
  102. TEX OZ700 X Grip is parts for sale
  103. Cheapest ls7 cluth kit??
  104. HELP: Camaro LT1 M6 to LS1 A4 Trans Crossmember Question
  105. Synchro problems?
  106. Whats Wrong with my M6
  107. you ls1 guys have it easy!!!!
  108. Spec clutch shim install
  109. Weird pedal @ WOT
  110. What kit to get?
  111. Heat tape
  112. clutch ?'s
  113. Shift knob threads
  114. im startin 2 hate this ws6
  115. How can I quite down a PRO 5.0 shifter?
  116. Anyone else having centerforce problems?
  117. Any Shops Sell A complete T56 Conversion?
  118. 3rd gen 454 6speed
  119. Ebay slaves/throwout bearing?
  120. can anyone tell me if the skip shift sensor has to be plug in
  121. T56 gear change
  122. Mabye I'm Just Retarded
  123. zf 6 speed with bbc slipping
  124. Changed my trans fluid today... not happy... D&D inside please...
  125. Spec problems WTF
  126. Swap T56 for 5 speed??
  127. clutch trouble
  128. Which clutch?
  129. Shifter knob and shifter feel... C6 knob installed.
  130. Will this dodge viper tranny mount work?
  131. any body have a textralia pressure plate?
  132. LT1 trans fit an LS1
  133. Shifting without the clutch.
  134. Possible Clutch/Tranny Issue?
  135. Just Need Some Quick Help
  136. Tex 0Z700 or Spec Stage 4
  137. input shaft bearing
  138. to be spacific
  139. 01-02 Updated Master?
  140. Textralia Clutch Question
  141. clutch noise
  142. Gas Mileage
  143. Clutch Cable to replace hydrolics on LS vehicles?
  144. Forced to granny shift! Suggestions??
  145. took out my trans today
  146. Spec Clutch Question
  147. spec3+stock flywheel?
  148. What is this thud
  149. new shifter
  150. hhhhhheeellllllppppp!!!!!!!!!!!
  151. Clutch Swap
  152. quick clutch weight and RPS clutch ?
  153. question on a throw out bearing
  154. Whats the best shifter.
  155. Unable to grab 4th at WOT - M6
  156. Please vote members and sponsors
  157. short stick is too short
  158. Slip yoke sticking LT1 T56
  159. What to do...
  160. c6 Z06 trans swap?
  161. clutch pedal problem!!!
  162. '03 LQ4 w/LT1 T56 (Weir Hot Rod setup)
  163. Grease for bronze bushing?
  164. Drill mod help!!!!
  165. Fidanza Shifter?
  166. automatic guy converting to a t56. Tell me whats good for my application guys!
  167. t56 hard to shift...
  168. what do you guys do with your old clutch assemblies?
  169. tremec info
  170. m6 to a4
  171. How many times can you resurface stock flywheel?
  172. Textralia Arrived!
  173. WTB t56 conversion
  174. Which bolts? 13mm/15mm
  175. I think I figured out the problem. What do you guys think?
  176. How long until?...
  177. High RPM Problems...
  178. Textralia Customer Service
  179. 3" Of pedal Freeplay.
  180. Attn: All Customers
  181. Please help with M6!!! LOOK INSIDE PLEASE
  182. Master Cylinder
  183. BOP All I can say is WOW!!!
  184. Fbody T56 to Vett T56 swap
  185. ls1 clutch on lt1
  186. ls7 + aps
  187. T-56 Question
  188. Clutch Fluid.
  189. Xtd
  190. Need drawing for inside of a T56
  191. what t56 clutch 4 a 500hp ls6??
  192. Pilot bearing removal
  193. Shaking.
  194. Spec 5 clutch
  195. Problem finding correct pilot BUSHING
  196. How much will a spec 2+ take?
  197. Fustrated Bleeder
  198. What clutch to buy with close to stock feel
  199. LS7 Clutch
  200. tranny problems
  201. Anyone Know?
  202. Working on a project, Corvette T56, f-body rear housing?
  203. clutch jumpy, need advice
  204. Exo-Skel install instructions
  205. C6 Z06 trans & diff swap into a C5?
  206. 5-6 driven gear chipped
  207. what is a good new transmission i can put in my 2001 z28
  208. Hurst Shifter
  209. hard shifting
  210. new spec clutch install ?s
  211. Still grinding
  212. Clutch Bleeding Problems...
  213. Anyone running a Richmond R.O.D. 6-Speed?
  214. Something is weird with my clutch
  215. Do I need ARP bolts for clutch/flywheel???
  216. New clutch and more and now issues
  217. Rant!
  218. Wiring Harness
  219. Pulling the trans for service...
  220. T-56 left me stuck at a gas station today!
  221. stock flywheel weight?
  222. HELP!!! How do you remove the....
  223. anyone with a TR-6060? and some questions.
  224. stcok driveshaft lenght ?
  225. Clutch woes, and opening day at the track is Sunday!
  226. How much work to change 3-4 fork and blocker rings?
  227. LS1 T56 not as strong as LT1 T56?
  228. Clutch for a 402 making 500whp give or take a few
  229. driveshaft
  230. New Competition clutch, standard ?
  231. impact for dropping out the 6 speed
  232. Where to buy Lou's Short Stick
  233. T56 problems popping out of reverse?
  234. Have a question about clutch slipping?
  235. so i pulled out my "blown" spec 3+....
  236. Hydraulic Fluid... What do I do???? Help!
  237. "Diamond Clutch" has anybody heard of it?????
  238. Brake Master Fluid Emergency!!!
  239. Pilot Bearing Tool???
  240. I think my clutch is fried
  241. launching on DR's
  242. Textralia Z Grip Review
  243. Ok please help 4th time
  244. Clutch reservoir PART NUMBER
  245. Weird noise
  246. Flywheel and Pressure Plate?
  247. Clutch problem or synchro problem?
  248. whining noise help
  249. just got my textralia Z grip...
  250. help on bleed the clutch
