PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. How the hell do I get this pilot bushing out?
  2. Hard to bang gears at higher RPM's???
  3. Lower shifter boot
  4. SPEC clutch is in
  5. school me on t56s
  6. T56 Clunking. Help!!
  7. Clutch not disengaging
  8. clutch anticipation switch
  9. Textralia Rebuild
  10. What trans to use for ls1 swap?
  11. Quick question
  12. LT1 t56 clutch stroke/throw help?
  13. Clutch for bolt-on LS1 Camaro
  14. c5 non zo6 internals in 99 f-body case?
  15. Best bang for the buck t56 and clutch for 500rwhp at 2800lbs?
  16. 11.03@124.93 with 404rwhp and Level 2 Monster
  17. Textralia disc came apart, pics inside
  18. t56 swap
  19. Questions Adjusting Clutch Pedal?
  20. clutch wont engage
  21. Clutch won't disengage
  22. Transmissoin cooler used as oil cooler
  23. noob clutch/hydraulics question
  24. t56 ls1 input shaft dimensions
  25. 3rd gear grinding
  26. Whining!
  27. Is it normal to get more vibration with.....
  28. anyone ever heard of this?
  29. SLP Skip Shift Eliminator
  30. Clutch pedal not returning problem solution for Corvette & Camaro
  31. Getting to reverse
  32. grinding noise
  33. Bad Synchros?
  34. quick question....
  35. ls7 clutch kit
  36. Clutch Preference
  37. Broke mainshaft going to viper internals
  38. Quick question on flywheels....?
  39. did the drill mod, still sticking at high rpm
  40. stange slutch pedal
  41. M6 Shifters for T/A
  42. LS4 w/ WC T-5 set-up questions...
  43. Strange problem (upgraded hydraulics ls7 style clutch)
  44. T56 Question
  45. testing the waters, t56?
  46. Salvageable 05 GTO M12 Input shaft??(Pics)
  47. Damaged T56?
  48. Bleeding clutch. Noob question
  49. Replacing a seal. Need help.
  50. A little concern on possible hydraulics
  51. ACT GM9-HDSS street clutch , what vendor sells it .
  52. doing clutch check my parts list please.
  53. Can you use a 2001 Fbody T56 with 2009 LS3 Crank/Pilot Bearing
  54. Slave Cylinder Popped While Adjusting M/C...
  55. Need help with programming for ecu (converssion)
  56. Rebuild T56 or buy a new one?
  57. Diamond Clutch Stage 3 Just installed, Review.(pics)
  58. 98 t56 with a LS7 clutch and throwout?
  59. Another whine
  60. what mods to do? nos and two step
  61. pilot bearing
  62. Reverse problems
  63. Buying a t56
  64. Stupid question but.....Anyone short people find the M-6 car uncomfortable?
  65. banging into R
  66. Clutch goes to the floor and stays there.
  67. a4 to m6 flexplate bolts
  68. M6 Swap help...
  69. slave cyl. and ruuber o-ring?
  70. viper t56
  71. Clutch installation
  72. New clutch, and what a clutch!
  73. Transmission purchase input
  74. T5 problems
  75. i need some input on a transmission
  76. help please no reverse
  77. Soft/Sticking Clutch
  78. MN12 service parts Where to buy???
  79. Removing Trans with Solid motor mounts??!!
  80. B&M short throw trade for stock! Needed for rx7!
  81. Reverse issue-need to double pump clutch
  82. Trouble with McLoed Street Twin
  83. Texas drivetrain performance******
  84. Rear mainshaft bearing t56
  85. Clutch sticking to the floor after hard acceleration problem solved!
  86. 99 V6 m5 speedo inop wont rev over 3500
  87. dont have 5th gear at all?
  88. UMI Short Stick Review and Pics.
  89. LS6 clutch question, Newbie needs opinion.
  90. for those Canadians buying MGW shifters..
  91. Clutch recommendation for a near stock LT1
  92. 99 camaro ss Clutch Master Cylinder
  93. T5 on a 5.3 help
  94. Anyone know anything bout monster clutches?
  95. What clutch should i get
  96. Buzzing/vibration noise when clutch engaged
  97. Can't get into 4th at high rpms. Help Please!!!!
  98. smoothest aftermarket shifter
  99. 94 Z t56 trans problems
  100. act clutch best price.
  101. t56 output shaft wtb
  102. T-56 stuck to bellhousing/motor
  103. Help! New Clutch Checklist and ??'s
  104. Pedal Vibration after New Clutch and Hydraulics
  105. HELP!! LT1 T56 Clutch MC issues
  106. nv3500?
  107. Rebuild t56? or buy tko/tr6060?
  108. SLP Skip-Shift Eliminator?
  109. Now that I know I need shim...
  110. Umi VS WS6 Store short sticks?
  111. Tick MC Installed, Pedal Still Sticks
  112. new clutch problems
  113. T5 input shaft length?
  114. cruise control help
  115. New clutch problems
  116. Need a new clutch to replace a Cartek clutch.
  117. replace clutch but its really hard to put the gears in
  118. M6 gears sometimes lock out?
  119. My clutch needs a negative shim. What to do?
  120. Where to find a rear output boot
  121. T56 Timkin transmission tail shaft bearing install
  122. t56 rebuild opinions needed
  123. Knocking sound when clutch depressed
  124. 02 WS6 Clutch/Trans issue?
  125. simple step by step instrustions please Tick Master
  126. reccomendations on tranny/clutch
  127. Scatter shield
  128. mainshaft endplay question
  129. T56 Grinding noise in first gear.
  130. ls1 t56 diagram needed
  131. Shifting to 3rd like hit a wall..
  132. Ls6 crate and magnum 6 speed
  133. a4 to t 56 swap drive shaft question
  134. RP Synchromesh change interval?
  135. ignition cut shifter
  136. HELP PLEASE - Loud whining noise under 2000 SS
  137. Just got Monster stage 2 installed, have couple questions
  138. Lt1 t56/ls1 t56 question????
  139. tick bleeder?
  140. Found my monster clutch disengagement problem...shit
  141. 3rd gear?
  142. Spec aluminum PP torque specs?
  143. New LS7 Clutch, Hard to shift 1st and reverse.
  144. T56 gear ratio question
  145. LUK Clutches reliability?
  146. How far in the air must you get your car to remove the transmission?
  147. need help with my 2001 trans am ws6 ram air
  148. LQ4/T56 Question
  149. i need t56
  150. Conversion U-joints Strength?
  151. Best T-56/Clutch Combo for 600 rwhp Smooth Street Setup
  152. Textralia Clutch after 5 years (OZ700)
  153. gm clutch master or tick?
  154. New spec clutch won't disengage. HELP
  155. Stock or Ram master cylinder?
  156. help on assembly of T56
  157. conversion question
  158. Tick M/C install question and problem. ***Update 4/10***
  159. Centerforce ?
  160. C5 Clutch swap "how-to"
  161. Still having clutch issues......
  162. Bad trans mount causing horrid wheel hop?
  163. To anyone ordering an MGW shifter...
  164. clutch slipping or something else?
  165. T56 master cyl. / line question
  166. Throwout bearing heights
  167. Master cylinder cap??
  168. Bronze or nylon fork pads?
  169. Tranny is finally on the workbench & Partially tore down *picts*
  170. Clutches
  171. FLT or Tick?
  172. Monster Level 3 install/review
  173. Testing the Master Cylinder
  174. how to remove the clutch pedal by it self.
  175. ARP and Monster torque?
  176. Need help with Tick speed bleeder / bleeding clutch...
  177. odd noise
  178. Shift Knob Suggestions
  179. Correlation between Tick master adjustments and clutch slipping?
  180. t56 main shaft question
  181. need imput!!!
  182. tomorrow is the big day!!!
  183. stock t56 worth?
  184. Bang when coming off the clutch quick??
  185. Having the t56 rebuilt and have some questions.
  186. garage clutch swap
  187. Can 12" Clutch and PP be used on resurfaced stock 99 FW?
  188. Help with my problem
  189. How to service my 6 speed?
  190. Best Shifter?
  191. Quick question????
  192. T-56 AfterMarket Or Modded Slave Cylinder???
  193. Trans Issues
  194. T5 5th gear set interchangability?
  195. Yet another 4l60E to T56 thread!
  196. Just in: Tick/Monster. Can't get into gear at idle, but can while driving and off..
  197. M6 MSD 2step
  198. transmission vibes
  199. Flywheel differences?
  200. LS3 Flywheel Dowel?
  201. Textralia customer service sucks!
  202. Strange noise coming from a built T56
  203. Reverse not working
  204. Textrilla Torque Specs
  205. C5 Shifter Questions and Pic Request
  206. Heard from MGW??
  207. Anybody ever broke a stg. 2 built t56?
  208. wierd shifting problem
  209. Bleeding Clutch NOT working!
  210. Skip Shift Solenoid ?
  211. RIddle me This
  212. Short throw installation
  213. Hurst shift stick - will it fit?
  214. Clutch suggestion
  215. Where to buy a Quicktime bellhousing
  216. clutch swap parts ?'s
  217. Clutch problems. Pls help!!
  218. need bleeding help, no peddle
  219. Best place for buying LS7 clutch kit w/ flywheel
  220. What is this hole in my tranny?
  221. Clutch problems.?
  222. Which flywheel?? Help!
  223. Little shifting problem
  224. Need rebuild kit info
  225. Atlanta area machine work
  226. clutch steel braided hydralic line
  227. 97 t56 behind lq9
  228. soft monster...
  229. T-56 upgrades?
  230. Another "Clutch Won't Disengage" Thread
  231. Torque cut module for face plated and dog engagement gear sets
  232. T56 rebuild kits?
  233. mid plate torque spec
  234. Bleeding the clutch
  235. MGW Shifter, adjustable handle height?
  236. ?
  237. Need help with tranny install
  238. Please i want the bolts torque specs for McLeod Clutch ASAP necessary
  239. Lsx and Viper t56
  240. 2001 Z28 Camaro Clutch problems! This girl is clueless!
  241. Quick question
  242. Noise, vibrations and other fun issues. FIXED
  243. Clutch Master cylinder options
  244. t56, lost 2nd, 3rd/4th and 6th
  245. What clutch???
  246. new flywheel?
  247. What clutch for me?
  248. Tranny Predicament
  249. clutch not fully engaging..help
  250. Ram Hydraulic Slave or Stock Upgraded
