- Need help with a dilema
- Clutch Install gone bad
- Leaking McLeod Master Cylinder
- My clutch?
- NEED ANSWER QUICK!! Which way does Spec Stage 4 disc go?
- is there anything different between LS6 and Luk clutches?
- clutch pedal sits in the floor-slave cylinder?
- Where to buy Lou short stick besides>>>
- is DOWNSHIFTING bad?
- Spec 3i
- Who wants to diagnose my problem?!
- SPEC Stage 2 gave out at 12k miles
- tranny question.....
- noise problem help
- Chopping the stock shifter?
- Pilot Bushing replacement
- Weird Slave Problems
- Manual options
- Is the Pro 5.0 worth it.....
- Rubber Cup in Clutch Reservoir?
- High performance clutch?
- anyone know where I can find t-56 sensors
- Which Throwout Bearing?
- T56 vendors
- My T-56 doesnt like cold weather
- which trans mount to buy
- Questions about an adjustable M/C
- Clutch install for 2001 Trans Am
- anyone have nice wheel hops with a spec st.3?
- nasty vibration
- Burnt Out Clutch
- how much power can a t56 hold?
- Z06 gearsets in fbody T56
- dhaving trouble getting in reverse
- Is there a downside to using the billit steel flywheel w spec 3?
- New Master or not??
- Any Thoughts Or Opinions On A Centerforce Clutch??
- Mcleod Twin Disk Blown To Pieces
- noisy clutch pedal
- Is Loctite Really Needed?
- 2nd gear problems
- Rear-end is knocking.
- Anyone use a solid clutch disc?
- Tranny and rear end slack
- Clutch and Tranny experts please
- Won't stay in 1st or 3rd.
- Formula 5 speed making noise
- M6 Issue
- Transmission problem???
- Lou's short stick
- Got my 12k mile factory clutch out,found defective part
- shifters
- Clunking noise in rear end
- Noise in 4th gear
- went to the track and broke the rear...
- Good Vette Mechanic needed in Tacoma!!
- Vette and Camaro Clutch master cylinder
- Help with what clutch to get...
- Broken Shift Fork question
- Spec Stage 5 not holding power.
- Flywheel/flexplate bolt size, thread, etc...
- McLeod Twin Disc Install Question (shims)
- slipping stage 3
- Upgrading to 01-02 MC/Slave
- looking for a clutch
- Anyone Have Inertia of T-56?
- C5 clutches same as Fbody clutches?
- Spec clutch sucks!
- Which Clutch to Buy
- rebuild spec sheets for t-56
- Is it normal for ALL of the clutch springs to break at only 25k miles?
- real ls6 clutch part number ??
- WTB: used 5-6 gear cluster
- new flywheel.
- Did search(Need updated master or not for ls6 clutch kit)
- does a clutch have to be slipping to go bad?
- Twin disk setups
- lou's short stick???
- Stock clutch blown with 12k miles??have ?'s
- Z06 clutch users come in please
- Clutch problems under WOT
- Throwout Bearing
- Conversion 87 Corvette Transmission
- Opinions on best t56 setup
- clutch install parts...
- Unbalanced driveshaft?
- Best Clutch?
- Clutch install checklist
- Break in for Spec Stage III/Aluminum Fly?
- Anyone else run a RAM Stage 4 on the street?
- What stick to go with on pro 50?
- Anyone know slave cylinder compressed size?
- Clutch Bleeding Procedure?
- Clutch slip at high RPM
- searched and im still confused about updated hydros..
- Hope this doesn't hurt...
- problem with myspec 3
- throwout bearing noise?
- Clutch master cyl travel
- Where can i get Lou short stick??
- regular 5-speed to T-56 tranny
- Has anyone ever seen this?
- Spec clutch shimming poll!
- Pro 50 question.
- Drill mod help
- More clutch problems!!!
- Ram VDS Clutch Adjustment??
- Problem with M6, 1994 Trans Am.
- When ordering a new clutch, should i get a new fly?
- Where can I buy a tailshaft housing?
- Steel Braid line for Clutch Master Cyl.
- Warranty & Synchro's Question
- height clearance
- T-56 question
- Is it bad if your Ram 910 VDS sparks :)
- Need opions on Shifters
- SPEC stage 4/4i
- Clutch pedal feel dissapeared!
- Pulled the threads on the Tranny
- T56 problems
- F body shifter fitting a corvette Trans????
- Clutch Swap soon, which clutch??
- Tranny probs
- Where do you put the Shim for a Spec 3?
- Aluminum Flywheel Good Idea or Bad Idea??
- Place to buy LS6 clutch kit?
- drivetrain vibration
- Ford 9" gear ratio questions.
- Aftermarket Hurst question
- My Z is making a weird grinding noise i think it is a syncrode but im not sure
- Clutch going...how much noise?
- Trans Rebuild
- Stock clutch for 95 TA
- B&M Short throw VS Pro 5.0(already searched...
- Do you think you could put stop in stock Hurst
- M6 Clutch Issue NEED HELP and ADVICE
- Cruising speed with t56 and 3.73s and 4.10s
- the little keys that make my shifter pop out
- Which clutch for 800rwtq?
- Part Number For Upgraded Slave Cyl???
- Z06 Clutch part#........
- Can anyone confirm or deny...
- Need help with weird spec clutch problem!
- Clutch question...already searched.
- Spec 2 or Luk Gold...Alum fly wheel ?
- clutch hydraulic fluid is fried
- Are Stock Lt1 flywheels/bellhousing SFI approved?
- Clutch install... Not my Day!!!
- Is An Adjustable Master Cylinder A Must??
- t-56 magnets
- Just learned how to drive manual today
- has anyone ever come across this? (long)
- Tranny issue
- SPEC Star clutches????
- P0736 - Reverse Incorrect Ratio
- Flywheel and hydraulics upgrade????
- I have a question
- Clutch help needed
- New Clutch installation
- no 6th to 5th??
- Clutch Question from a newbie
- T56 Woes
- T-56
- More clutch problems, possibly the tranny?
- What kinda price..... Help ASAP!!
- Built up T56
- Shifting problems
- Replace clutch disc only?
- How does your Spec clutch drive?
- spec 3 problem??
- Part #'s for new slave and LS6 clutch kit?
- ? about LS6 clutch and flywheel package from GM
- Vibration after SPEC stage 4 install
- Anybody every break 2nd gear on a T-56?
- G/F Got Me B&M Ripper Shifter For 1-Year Anniv.!!
- got the quick disconnect off ... cant get it oN!!
- want to kno how to go about the track
- Muscling Into Reverse
- Reverse lock out solenoid
- Tranny ?'s
- funny smell
- which clutch is better
- rebiulding t-56
- Something went wrong at the track!!
- EVERYONE with Pro 5.0 please help....
- Gripforce Clutch or just get the LS6 Clutch Kit
- clutch grinding in first help!
- tranny slipping
- Need pressure plate bolts or part number and stock shifter
- How Difficult is it to Install a Clutch W/O a Lift?
- Clutch Chatter
- Tranny parts needed.
- question for the pro 5.0 fellas
- T56 Wont Go into 5th gear "HELP"
- Safety
- shifter jumps
- need phone number please
- Driveshaft shortening
- Clutch Problems
- what first?
- Where to find clutch line???
- After clutch install...
- LS6 Z06 clutch
- Clutch problem?
- Bleeding master
- Shortening a B&M Ripper
- Expert Tranny advice needed please
- Poly trans mount.....
- Spec flywheels Steel or aluminum???
- trouble getting in to 6th gear??
- 1LE transmission mount?
- UMI Short Stick
- Ram adjustable master cylinder? Yes or No
- Increasing spring pressure on a Pro 5.0 - Cheap and Easy!
- who sells gm 01up slave cylinders?
- Quick disconnect wont come apart
- 99 clutch upgrade
- first one to figure out my problem I paypal $10!!!
- slick 2nd to 3rd tranny up grade
- What homemade tool did you use to rebuild your T-56?
- looking for t56
- Question about transmission ratios
- Tail Housing bushing
- Cannot get the bellhousing off...
- what fluid to use for T56
- What clutch is better in my now/future case?
- thinking of going to the spec st3. what do u think?
- good idea to change the mount and bearing?
- Sloppy Clutch feeling
- Clutch Opinions
- Centerforce clutch problem?? Heres the fix.
- How much POWER?
- master or slave problems
- how bad did i f up?
- Tranny or Clutch problem?
- b&m thread size for p/n#45052
- Did the drill mod..........
- shifter stop screws or not
- What pilot bearing with a RAM 6130?
- Pro 5.0 03-04 cobra box????
- Life of a clutch?
- RAM Power Grip arrived!
- spec stage 3 clutch....new flywheel or not???
- Problems with 4th
- FLP T-56 which one?!?!
- Clutch for my setup...Exedy really worth it?
- Have you rebuilt T56?
- Spec1,2, or 3
- short throw shifters
- Can anybody help?
