View Full Version : Manual Transmission
- 68 camaro t56 crossmember
- cant get tranny to line up
- Front torque arm bracket
- Slave Cylinder Quality
- Any T5 rebuilders here, have ?s.
- Shifter Parts part numbers
- Need parts list and fact check-in 2000 1500 4.8 5 speed swap to 2003 5.3.
- T 56 shifter relocation
- Bellhousing bolts.
- 98 vs 99+ pedal assembly
- 5th gear
- Slipping Clutch advise /recommendations
- Tracking a tick - slave noise?
- McLeod RXT Street Twin install question
- New fw, clutch chatter issue w/ pedal to floor
- Longer clutch slave line
- LS3 with a TKO 600 (what clutch/flywheel)
- Stuck shifter
- clutch disconnect plastic thingy
- What would you do...m6
- Signs of a bad pilot BUSHING?
- 2000 Trans Am Clutch Pedal Sits Very High
- Driveline removed- Problem- HELP
- Key lesson learned in LT1 clutch replacement
- WTF Caused this ?
- Water in my T56?
- Ls1 flywheel question
- strange clunk in gear, clutch depressed, while rolling
- Tick Master turnbuckle questions
- Tr6060 oil cooler lines
- 02 z28 Camaro Clutch Bleed
- Should I be concerned with this?
- mgw shifter or clutch problem
- TR3650 behind LS....anyone done it?
- Rear End Whine Or Transmission Whine
- 2002 Camaro sticking clutch petal
- Tr6060 shifter linkage pin
- Centerforce LT1/2 Bolt Main conversion flywheel: Externally or Internally Balanced?
- what do I need to use a C5 transmission in LS1 swap camaro
- New clutch ???
- Tick Master Cylinder Problem
- Which way does the pilot bearing face?
- Bellhousing Whine
- New Diamond Stage II lugging when taking off in first gear
- act clutch ( T2S-G01 T1S-G01 )
- Help Identify this clutch....Video Inside
- Shifter Knob
- Tick Master Failed at the Worst Possible Time [UPDATE]
- Time for new clutch
- New clutch won't disengage
- grinding in nuetral
- Trouble bleeding clutch master
- LS to Lt similarities
- Trans/clutched pooched??
- Is anyone unhappy with their lightweight clutch/flywheel?
- Speedtech Clutch Master Cylinder Bracket question
- Killing Slave Cylinders
- Holes in bellhousing, should I fix this?
- Tr6060 electronic sensors and such
- T56 weird sounds
- Remote Clutch Bleeder Install Questions
- Tr6060 twin disk vibration
- What is it worth? 1994 t56 near perfect only 10k miles
- RK t56 built 6 speed, really hard to throw into reverse.
- Stuck in 4th
- High RPM 1st to 2nd grind
- CD009 dimensions vs. T56
- Reverse not working
- Clutch Waranty
- Throw Out Bearing advice/information
- Red or Blue Threadlock for Flywheel and PP Bolts
- Remote bleeder fitting
- Manual Conversion Wiring
- Tremec torque underrated?
- clutch pedal stopper needed?
- T56 acting funky after hard braking
- Tranny Fluid - Syncromesh - yes, ANOTHER one...
- McLeod RST Rattle at 1500RPM under load
- Manual transmission swap from 4l60e
- Intermittent whine at high speeds
- a4 to m6 swap 02 z28
- Pilot bearing install question!!
- 1998 ws6 Trans Am 6-speed
- help with wiring on a4 to m6 swap 02 z28
- Removal of Master clutch slave cylinder
- T56 Magnum v Tick Level 3
- Reputable Manual Trans. for LQ4 6.0L
- PSA: Do Not Use Pilot Bearings!
- Reverse Hard to Get into - 6th also 96 LT1 t56
- clutch pedal stop
- Gto Tick Master cylinder in F body possible?
- '01 SS Clutch Recommendations
- Hydraulic issues, I think???
- 97 6 speed Camaro 30th anniversary
- Input Shaft Retipping Repair
- MGW vs HAWKS Short Throw Shifter... Opinions?
- Corvette z06 t56 front plate?
- What countershaft should c6 corvette t56 transmissions have?
- Mating 1997 corvette LS1 to 2005 cts-v t56
- Anyone know where on Earth I can pick up a retainer ring for the shift boot to knob?
- What clutch? Turbo nova
- Tightest fitting t56 1350 slip yoke?
- Driveshaft question
- psshhh sound when pushing clutch in
- 5.3l t56 help
- 5.3l pilot bearing help
- Fbody T56 swap. GTO trans and shifter work?
- Help with T56 Rattle
- Lube or Loctite on flywheel bolts?
- Oil leak
- clutch not disengaging after rebuild
- T56 magnum where to buy
- Ram 10.5 dual disc clutch, can I use stock slave cylinder?
- Buying New Clutch within 2 weeks, Need insight on Monster LT1-S - Sponsors ???
- Write-ups or vids on racing with t-56 how-to by Pros?
- Tko 600, is it worth it.
- Tick master cylinder install\ cannot get into gear.
- Clutch
- Why does reservoir fill back up when bench bleeding Tick master
- SPEC3+ LS1/LS6 Rebuildable? Attn Spec-01!
- TR-6060 bearing preload endplay
- The problems continue - Grinding when revving, slight grinds into random gears
- BW T56 shifts fine until up to temp?
- Do I need a clutch shim if I'm using a Tick Adjustable Master Cylinder?
- Can't Shift into gear running or not.
- Tick stage 2 rebuild t-56 with monster lt1-s clutch
- t56 outright spoonsors ?
- QuickTime bellhousing alignment needed?
- Diamond clutch
- What does the reverse lockout press on inside the transmission?
- Tick master cylinder with speedbleeder
- T56 grinds 2nd to 3rd
- C5 t56 in c3 corvette
- Just rebuilt T56 - Stuck in neutral
- Manual transmission noise? Stumped
- T-56 input shaft play/noise (with video)
- clutch fluid flush
- T56 rebuild question.
- LSA mated to T56? in 69 Firebird need advice plz
- Reverse Lockout Not Grounding?
- Which transmission fluid to use in T-56?
- Clutch pedal in 02 ss
- Should I replace this blocker ring that I dropped?
- Need specific gearing question answered.
- Driveshaft to rear t56 seal part number?
- Metallic rattling sound from trans area
- Noisy MN12 T56 when backing off acell see my youtube video
- low budget question
- T56 magnum/tr6060 drop in for 98-02 fbody
- Monster stage 4 help
- Tick vs RPM Transmission
- Tick Master Cylinder Help
- T-5 speedo problem
- 385hp and the clutch is smoking on 1-2 shift
- Tick level 2 and nitrous. Will it live?
- t56 magnum 6- speed
- Strange Noise
- Light Weight Clutches - Who's Ditched Them?
- Trans rebuilt, PST driveshaft, 9" vibration
- T56 Clutch Fork Replacement
- 4L60e to t56 need advice
- Gto t56?
- Stock Clutch Master Cylinder Size
- LS3 install in 68 Camaro with TKO600
- Slave, master, bleeding
- LS7 clutch and flywheel wear question
- Help! Can't shift T56 to reverse after replacing reverse fork pads
- Tick master quick disconnect? Leaking..
- Sequential Shifter and/or Dog Box for a C5Z?
- Tick master question
- Desperate for Advice - Pilot Bearing Lasted 5,000 miles
- Need Help W/ T56 Rebuild (Pics) - Which Gears/Parts To Replace
- Stuck clutch
- LS7 clutch measurement, pls help !!!
- T-56: Is having no oil in the shifter turret normal? [pic inside]
- Is This Normal Countershaft Wear (Pics) - Added a Few More
- Short throw shifter question?
- Clutch Help/Experience recommendations
- Anyone pulling their trans right now?
- Best Place to get rebuilt T56 Transmission
- MGW shifter...Can I use factory bolts?
- Luk Slave cylinder
- Bleed the Clutch and Change Tranny Fluid
- Master Cylinder and Synchros?
- Let's talk safety: Are my concerns justified?
- LS1 GTO Mcleod clutch throwout bearing
- GM T56 retrofit trans
- Clutch master cylinder going out?
- I was told to use this fluid for my t56, what say you?
- Clutch pedal travel sensor for Gen 4 F-body
- High pitched whine in sixth
- using monster stage 3 clutch for a daily driver
- why do people bash ls7 clutch/fly in an ls1 t56. enlighten me!
- T56 noise/vibration issue - help identify possible causes
- main shaft races spin in place
- Mgw angled shifter handle?
- T56 to TKO swap
- LS3 and T56 with LS1 clutch?
- Shifter bolt size?
- Go to place for t-56 rebuild parts...???
- Shifter problem
- Shifting question
- Clutch issue
- 98-02 T56 deal, lend me some input
- Anybody install hurst line lock kit ?
- Anyone use royal purple synchromax?
- Ls7 clutch horsepower?
- Short shifter suggestions ?
- T-56 Grinds when revving
- Strange plug/slug in T56
- T56 Hard to go into 1st 2nd or reverse
- Pitting on input shaft?
- ls7 flywheel question?
- LS1 T56 slave cylinder bolt size??
- Questions on LS7 clutch install for an LS1 and T-56
- Rebuilt "stage 2" T56, yoke interferes with tailshaft bushing
- loose 5-6 vibrations
- Whats the issue
- Re-Occurring Clutch Disengagement Problems
- What flywheel is this?
- Corvette T56 Identification using Tag
- Clutch Master Cylinder Question
- Is My First Gear Shot?
- Anyone Use this Mobil Trans Fluid for your T56?
- Race inside input shaft
- Slave cylinder
- LT1-S vs RXT
- Able to access reverse gate at any speed
- Driveline Vibration After T56 Install?
- 2005 CTSV T56 + Gen III LM7 + Mustang Notchback
- Clutch falls to the floor while driving then suddenly works again for a while, rinse
- T56 Magnum Install, couple questions
- LS1 Stock Hurst shifter
- Problems after new LS7 clutch install
- 2000 LS1 / 93-02 Camaro T56 LS7 Clutch & Fidanza part number confirmation please !
- mgw with hurst stick?
- Shifting issues
- first 3/4 of an inch of clutch pedal dead
- TR6060 backup light switch wiring
- C5 auto to manual worth it?
- T-56 one time issue. Grind in 4th 5th and 6th
- What's the thinnest hydraulic throwout assembly?
- Where to get a 700hp+ t56
- Closed pilot bearing?
- T56 skip shift lever
- T56 Tail Housing Help (Repair or Replace)
- Skip shift problem?
- t56 3/4 synchro
- T56 Aftermarket Mainshaft
- Slave Cylinder Question
