PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. alignment bolt problem
  2. runnin into some problems
  3. rear trans yoke has a little play....>?
  4. T56 install issues...
  5. 28lb. or 18lb. Flywheel?
  6. custom master cylinder
  7. need help clutch issue
  8. Delayed shifts with all new stuff!
  9. Just ordered a McLeod rxt clutch and steel flywheel, What comes with the kit?
  10. What's This Noise? (video)
  11. Installing a Rockland tailshaft bushing
  12. Tremec TKO600 5th gear chatter noise
  13. T-56 Rebuild questions
  14. Need help asap
  15. Bearing end play and preload for used bearings
  16. trans rebuild time? strange noise
  17. What gear ratios in turbo application trans
  18. New clutch, slave, master, won't go forward
  19. Hard to put into gear when cold...
  20. GM male qucik connect???
  21. McLeod Clutch Master Cylinder Leaking, Any option besides $75 rebuild kit?
  22. shifter gets hot sometimes?
  23. Im looking for a STIFF clutch.
  24. transmission fluid
  25. T56 whine in 2001 T/A
  26. What rpm's do you all run...
  27. obd2 code
  28. fourth grinds when goin in
  29. Weird Clutch Nosie
  30. wtf is wrong with my tranny
  31. Clutch diagnosement
  32. TICKMASTER PRE setting?
  33. Spec Stage 1 or LS7 clutch
  34. Quick time blow-proof bellhousing issues-T56
  35. 6spd to th-400 speedo? urgent
  36. what clutch for 500rwhp and ZERO I mean ZERO chatter
  37. Clutch suggestions
  38. LS7 & LS6 CLUTCH SALE +++ ALL CLUTCH ACCESSORIES SALE..INSTOCK ready to Ship Today!!!
  39. I am about to get raped by the tranny shop -- need answers fast!
  40. Still trouble getting into gear...
  41. T56 to a SBC?
  42. Shifter not centering itself. Please help!
  43. Question for those who have installed Tick Remote Speed Bleeder...
  44. LS7 Clutch strength?
  45. Need help diagnosing metallic noise... transmission??
  46. Need help troubleshooting noise
  47. Ls7 clutch issues
  48. mainshaft bearing & race
  49. Transmission Stuck to Engine
  50. t56 noises\vibration with clutch ingaged
  51. Mgw issues help!!!!! Vid
  52. preload/anti-shock ??
  53. Sticking clutch pedal, need recommendation for slave cylinder
  54. 97 LT1 Camaro needs clutch
  55. GTO T56 needs a shift rail --- F-body?
  56. T-56 Fluid Change
  57. Tick master interference issue with a4 firewall
  58. Need some help with countershaft extension assembly for T56
  59. 5-6 driven gear removal
  60. new flywheel thicker than old flywheel, problem?
  61. urgent tranny question
  62. Ls7 clutch grabs
  63. T-56 Reverse Lockout Solenoid...
  64. Question about shimming clutch
  65. T-56 Parts that fell out help
  66. Clutch gone/going out?
  67. For the GTO guys, JHP Pro Billet shifter review
  68. where to buy quick time bell housing?
  69. Pulling my t56 this weekend
  70. started my m6 swap
  71. anybody run a stock MC with spec clutch?
  72. Clutch Pedal Sticks Momentarily - *UPDATE- clutch fork issue
  73. Tick Speedbleeder - Drop Trans without bellhousing?
  74. Tick Speedbleeder - Drop Trans without bellhousing?
  75. Rattling that started today. Throwout bearing?
  76. CTS-V Second Gear Tug/Bump?
  77. T56 fluid pump
  78. Can't Bleed New Slave and Master Cylinder...
  79. Tick master
  80. Engagement Problem
  81. My T56 is done where is the best priced place for another!
  82. No reverse questions about rebuild price
  83. Check your clutch fluid
  84. Spec 3 problems?
  85. whining / grinding ......?
  86. What is the THICKEST, TOUGHEST oil I can put in my viper trans??
  87. Help with T56 part number
  88. Clutch recommendations
  89. Need help with a screw up
  90. Review of Product Innovations Delrin Shift Knob
  91. Monster ftmfw
  92. squeaky clutch petal
  93. RPM's 1000hp/ftlb capable T56 Magnum for you T56 murdering madmen out there!!
  94. T56 part hunt
  95. At wits end... hard shifting.
  96. Rebuild or Replace
  97. Bought a used SPEC stage 3+
  98. clutch upgrade too much ?
  99. Tick Master Slave
  100. Tick Master Slave
  101. 3-4 synchro upgraded springs... install question!
  102. Twin Disc Clutch Life
  103. In need of a T56 core for LT1 to LS1 swap.
  104. shifter install
  105. Iron clutch.
  106. T56 rebuild, 1-2 synchro is hard to slide
  107. shify knob
  108. There's a Monster inside...
  109. Gauging an interest in rebuilding stock hurst shifters
  110. Is 6th gear the weakest gear?
  111. Bad vibrations from tranny mount
  112. ARP Flywheel, PP bolts
  113. Low clutch pedal, partial engagement in nuetral?
  114. Clutch and Such list
  115. SPEC Throwout Bearing
  116. Shiming your Clutch
  117. GTO T56 - can't get in certain gears when motor is off
  118. Tick MC question
  119. where can i get the white clutch line release clip
  120. T56 Corvette rear adapter bolt to TR6060 main case?
  121. Which clutch...LS7 or Monster Stage 1
  122. Monster clutches on super sale!!!!
  123. Replacing just the clutch disk, reusing PP and flywheel?
  124. Having problems please help!!
  125. got a free alum flywheel - is it junk?
  126. Tail Housing Bushing
  127. LS7 clutch install in Sacramento?
  128. Low Clutch Pedal
  129. problem grabbing 4th
  130. McLeod master value?
  131. Clutch or Hydraulics?
  132. problems with change gears in high rpmīs
  133. Something definitely broke, but what?
  134. Meet our newest employee: Chris-Tick!
  135. T56 removal from bellhousing
  136. How the hell does this happen lol
  137. shifter question
  138. Trans rebuilders in NE Pa
  139. Redline heavy shock fluid
  140. Driveshaft Length Question
  141. CTS V Trans question
  142. where can i buy a new or reman t56 for a lt1 in az
  143. Going to check out a craigslist T56, what should I look for?
  144. stock 2000 ram air
  145. Need a parts list of things needed to do a C6Z trans and diff swap on a 03 Z
  146. Any T56 Shifter suggestions??
  147. T56 vs AY6?
  148. so did monster ever resolve the chattering/squeal
  149. Going to rebuild trans, should I upgrade the output shaft or not?
  150. McLeod bell housing owners come inside!!!
  151. T56 making noise in 4th 5th and 6th. any ideas?
  152. spec stage 1 for daily driver?s
  153. T-56 04 gto
  154. T56 questions!!!help
  155. Confused about fittings for remote clutch bleed, with pics
  156. new clutch slipping??
  157. Well this sucks.
  158. '06 GTO - T56 shifter will barely move or go into gear
  159. Spec stage 5?
  160. Anyone running a centerforce dual friction disc with another mfg's pressure plate?
  161. ls2 slave cyl vs fbody
  162. T56 wont go into reverse
  163. BAM!!!! no Pedal wth
  164. Gradually lost my clutch today - now I just get minimal pedal and a clicking...
  165. Tick Performance TR-6060 Direct Bolt in for Fbody -- OVER 900rwtq
  166. lightweight flywheel benefits?
  167. Blown new wilwood master???
  168. Replacing Clutch, Slave, Master, pulled motor out the bottom Pics!
  169. drill mod question
  170. Clutch & Q/T 8020 issue
  171. Help MSD 2 step issue, clutch switch wiring shorted out!!!
  172. Helppp
  173. 98-02 Throwout Bearing Question
  174. What clutch will truely function properly with stock hyd????
  175. Clunky Shifting
  176. New shifter issues
  177. Need help with trans bolts
  178. Tranny Help!!!
  179. 11 or 12'' clutch/flywheel
  180. Shifter bushing.
  181. Clutch
  182. Hard to get into gear from a stop, New clutch and hydralics
  183. Shaking???
  184. Average expected cost t56 ring replacement
  185. Need a couple bearings/races for a T56, PN?
  186. Any drag results for ACT twins (orgainc)
  187. many questions on clutches. 11 or 12 inch how to shim and which clutch
  188. JUST NEED TO VENT(clutch)
  189. Removing pedals, replacing clutch return spring?
  190. Which pilot bearing in my 2005 GTO M6?
  191. Cost??
  192. Clutch pedal engages but quickly bleeds off.
  193. Stock Replacement Trans Mount
  194. Help please fluid leak on line that connects into the slave cylinder
  195. "F" the GM Slave Cylinder!
  196. Post Clutch Install Question
  197. Opinion Spec stage 2 or 3
  198. New master cylinder or not?!?
  199. Need help with fitment
  200. What clutch to run?
  201. Are SPEC clutches zero-balanced?
  202. what tranny and clutch???
  203. Vette t56 in an F-body ?
  204. Spec Clutches
  205. RPM Transmissions is now official sponsor of Chevrolet Performance LSX series!!!
  206. Does the clutch hydraulic line need a restriction?
  207. Manual and 900rwtq? TR6060? Who has one?
  208. Found the problem, the fix?
  209. Benefits of billet flywheel vs. stock?
  210. need help with the monster clutch install
  211. clutch issues
  212. transmission swap
  213. What would you buy?
  214. Anyone been in touch with TDP?
  215. Sure would like to see a group purchase on Tick/Monster. ;)
  216. Pilot Bearing Questions.
  217. lightweight steel flywheels for Mcleod RXT
  218. Need New Transmission & clutch what should i do?!?
  219. Transmission cross brace question
  220. Callies crank shaft + F body T56 ???
  221. shorty Pro 5.0 shifter.
  222. Stock main shaft
  223. questions about magnum t56 in ls1 camaro
  224. Assembly Lube
  225. clutch flywheel help
  226. tick master cylinder questions on a fbod
  227. 98 z28 grind
  228. New Spec stg 2 clutch, new slave , still not going into gear??? Help
  229. Need a new clutch when?
  230. Built t56 help. Sponsors come in!!
  231. tdp vs rkt56
  232. How to make an ls1 t56 work on an lt1
  233. problems with getting into 4th
  234. Thread pitch and bolt size on Tremec shifter stub
  235. 2nd gear is like nuetral
  236. Looking for shop
  237. cheapest place to buy a monster clutch
  238. wire plug removal for clutch pedal sensor
  239. T-56 help
  240. output shaft seal
  241. ACT Clutch, F1 Racing Chromoly Flywheel **Thoughts**
  242. tick perfomance
  243. Will stock clutch hold for a few pulls?
  244. t56 reverse lockout solenoid leaking
  245. Mcleod slave cylinders
  246. RAM Powergrip HD clutch - Anyone using this?
  247. t56 where to buy
  248. T56 is apart, what to replace... with some pics
  249. Adjustable clutch pedal stop - question.
  250. Clutch disc?
