View Full Version : Manual Transmission
- T56 Shifter Vibration
- Slip Yoke for T56
- T56 Magnum 2000 camaro
- new 5 speed
- Clutch break in: total press and release? Or starting from a stop?
- Help post!!!
- Lightweight clutch dyno article I found
- Looking for Pedal covers / Clutch pedal extension
- Transmission Questions
- Dorman pilot bearing for t56?
- T56 Issue
- Not another NO CLUTCH PEDAL THREAD! SORRY!
- Cant get the tailhousing back on my c5 t56
- Reverse lockout not blocking gate
- Brand New Magnum F Leaks
- Magnum F require shorter driveshaft?
- Mobil 1 Synthetic ATF discontinued?
- Problem with T-56 Trans after new engine and clutch install
- Clutch Preload problem
- Street and Road Course Clutch Recommendation
- Tick adjustable MC installed.
- Will not go into reverse with engine on
- How tough is the braided clutch line on Tick M/C???
- Slave cylinder differences
- Tr6060 in a third gen camaro
- Changing the clutch myself for the first time, '94 TransAm
- Anyone know cost 1994 z28 auto to manual swap
- TR6060 on Gen V 6.2 LT1/LT4?
- Magnum T56 grinding while in gear
- T56 Rebuild Help
- 98 f body stock t56 issues
- Sprung Hub Clutch Options
- Auto 1998 Corvette LS1 to Manual trans
- New Tick MC pedal stroke
- Anyone regret buying Magnum F?
- Bummed - Tick MC leaking after just 2 months
- ID Transmission
- Clutch cable
- 4l60e out - Tremec TKX in - VSS and computer questions
- Slipper Clutch release Solenoid and MSD 2-step Wiring Help
- L83 t56
- Ford T5 behind a SBC?
- Gen3 LS T56 slave cylinder gap extremely large
- Grinding noises
- Components for shifter install...
- What's needed for a 2013 mustang t56 magnum xl to convert to a fbody
- Tick master Adjustment / bleed procedure
- I need a clutch asap.ready to buy... monster or mcleod?
- Tailshaft housing strength
- Clutch will not bleed, I need help - Mr Tick?
- Tunnel cut for shifter...
- 2001 Z/28 Convertible floor cross brace
- Mating LS427 to T56...
- installing TICK adjustable master cylinder.... BRAKE bleeder gun?
- Pilot bearing for T56...
- Removing factory bell housing dowel pins?
- Best budget trans for drift build
- Aftermarket street clutches without chatter?
- New clutch setup
- Media blast T56
- Clutch over hang on flywheel
- Clutch Pedal Switches 2001 WS6
- Bell housing alignment analysis...
- Bell housing alignment inconsistencies...
- Bellhousing alignment - Is it even helpful?
- How to fix a bent clutch pedal rod?
- T10 to t56
- Beefed up T56 or T56 Magnum for 427?
- clutch help
- Help! Can't seem to get 5th gear reinstalled. TR6060/Magnum
- Dex III
- Pilot bearing
- Frequent burning clutch smell 97 SS
- Summit FB Friday Noon EST. Livestream with DDNSpider!
- t56 to ls7
- MWC 9" trans hits tunnel.
- TR6060 cooler lines - which is in/cool and out/hot
- Stuck race inside T56 front cover - Removal???
- 5th&6th synchro
- Clutch not fully disengaging!
- 6 Speed Swap Clutch Issues; Need help!
- Shift knob
- Clutch slippage under load
- How hard is to replace mainshaft on T56 ?
- Sequential shifter for t56?
- Full Review- Summit Racing Twin Disc Clutch (New Release)
- 2nd leaking slave on my 06 GTO
- Directions please! What is the best route here?
- Site newbie's '00 5.3 sleeps next to a 4,a 5,&2 6-spds. W/$500. Help!
- Advice for leaking main shaft repair
- Another Reverse lockout wiring thread with pics!
- Need some help finding/making hydraulic clutch line
- Stock clutch durability.
- Tremec Magnum Plug Question
- T56 removal without bellhousing
- Help Identifying Trans
- T56 slip yoke engagement length question.
- Does anybody NOT like their Monster twin disc?
- Can anybody help identify this McLeod?
- T56 shaft and gear worn enough to be replaced?
- Strange question
- Clutch not Disengaging? Notchy 2nd & 3rd gears
- Saw noise when going in reverse
- Clutch and flywheel recommendations...
- Clutch Master Cylinder only moves pressure plate a little bit
- Performance clutch for autocross/RR recommendations
- Stiff and notchy shifting
- Magnum F Black Friday deals
- Tremec T56 Magnum Shifter
- Rebuilt T56 Popping out of 2nd
- Clutch Noise - Diagnosis?
- T56 rattle
- How to test MC?
- Pilot Bearing Question???
- TKX 5-speed
- Who’s running a Tilton ST-246 or Monster LT-1sc twin disc clutch?
- Sachs 1050 dowels?
- T56 swap
- trouble lining up tranny mount bolts
- Shim question
- Weird clutch issue
- Holley adjustable master
- McCleod Street Level Clutch (75016). Anyone use (LT1)
- Clutch pedal
- Speed sensor VSS run-around...
- t56 zf6 swap 1997 ws6
- monster triple initial review
- Clutch help
- need help
- Best Launching Methods!
- Changed Lockout Solenoid, Still hard to get into Reverse
- Clutch help
- T56 on an LT vs LS
- Clunk/knocking when releasing clutch
- Many questions about 6-speed manual swap in my 68 Camaro
- Need need help LOL
- 01 z28 slave bleeder valve Question
- Help Needed - Is the shifter adjustable in a manual 6 speed in WS6 TA's?
- Can you use an LT1 master cylinder with an LS1 slave?
- Has anyone tried Summit Pro Twin Clutch Kits
- Clutch engagement noise, 1st gear
- T56 clutch drag/ wont disengage on swap setup
- Bogus noise MGW
- T56 confusion
- Tr6060 too good to be true?!?!
- T56 Good Buy?
- NV3500 direct replacement?
- Tick M/C pros needed
- T56 mid shift relocation revert?
- How to build an all wheel drive t56 - AWD t56
- Tremec T56 5 speed?
- Identify 4 speed shifter
- LS7 Clutch with TR6060
- Where is all the Dextron III?
- t56 slip yoke
- McLeod / Wilwood Clutch Master Cylinder
- Clutch master cylinder and pedal height
- Tremec Magnum F install.
- Clutch M/C Bolt
- Help with M6 identification
- 00-02 ASR traction module - ditching module and keeping TC
- T56 help
- Help, Clutch won’t disengage with swap setup.
- Anti venom mod
- Flywheel question
- Stage 2 TDP T56
- New Clutch and Slave and Fluids very hard/notchy to shift
- Help Identifying F-Body Tremec T56
- Used T56 Shopping
- Is this much space in between the slip yoke ok? - LT1 Trans Am
- Anyone have experience with Tilton clutch release flow control valve
- Stock clutch info and recommendations on aftermarket
- shortest throw shifter for t56
- Help identifying clutch part number.
- Forgot to install pilot bearing
- T56 Clutch Pedal Issues
- F-body shifters
- Cannot get into 1st, 3rd or 5th gear
- T56 question
- RPS twin carbon or tilton ST-246?
- C5 to 2006 GTO t56
- Adjusting tick master cylinder
- Rear main seal & ARP bellhousing bolt torque
- Lq4 into 4th gen fbody
- T56 Stuck in gear, will nit shift
- Oversized LS6 Pilot Bearing? 1.705"?
- my 2002 Trans Am clutch stuck to the floor after 2 min???
- Shimming question
- Magnum F
- MGW broke.. Am I the only one????
- T56 MidPlate differences?
- Clutch not disengaging
- 2012 Camaro TR6060 with 2002 LQ4
- Clutch sticking and whiny trans
- Stripped Bellhousing Bolt Holes
- Uneven release fingers! Frustrating
- Cannot bleed the T56 clutch for the life of me...am I not very smart?!??
- T56 whining/noise..diagnosis help needed
- T56 Reverse Help
- What happened to my drivetrain
- Ls1 t56 measurement.
- Another clutch question
- 93 T56 grinds trying to into 1st &.....
- Need a new speed sensor or reverse light switch for your T56 Magnum?
- Tick Short Throw Shifter
- C5 Corvette clutch recommendations
- Aftermarket input shafts any good. LS t56
- T56 2nd gear grind
- Am I forgetting something?
- Looking for a T56 bushing, need help.
- Switch on the passenger side of my t56
- Clutch pedal stuck
- I Keep Missing 3rd, MGW or Something Better
- 2nd gear pop out issue following slave/master replacement
- Rebuild t56 or new t56 magnum F? Does it shift better?
- LS1 T56 Clatter / Chatter When Releasing Clutch
- Adjustable master clutch cylinder
- First Gen crossmember for a t-56
- LH6 TR6060 Clutch Slave Interference
- T56 issues
- Starter Issue After M6 Swap
- McLeod SFT (street fighter twin) 2000hp
- Transmission fluid
- Weird grinding/rattle/scratch noise
- Clutch removal, inspection, replacement - any recommendations/suggestions?
- ACT clutch (lt1)
- What is this stuff I just pulled out of my bellhousing...? (Pics inside!)
- t56 loud clicking under load in 3rd
- Master cylinder hose o ring
- T-mod custom lower shift box mgw+ shims
- Do I need a new clutch
- having issues with my hurst shifter
- Have I been using the wrong trans mount??
- How to tell for sure if clutch is fully disengaging?
- New LS build - What manual trans exist?
- Hard to get into R and pops out
- T56 not being easy to shift into 1st or R
- Clutch pedal. Adjustment?
- T-56 won't go into reverse with engine on or off
- Sbc Lt1 T56 Borg-Warner
- Sbc 350 Lt1 Borg-Warner T56
- 1993 S10- needs manual advice
- T56
- T56 upgrades
- T56 clutch slave shipped with fluid in it?
- MN12 Rebuild/swap
- T56 identification
- TR6060 front shifter location conversion
- Adapting T56 clutch line to master cylinder.
- Gto T56 first gear replacement
