View Full Version : Manual Transmission
- LS7 Clutch
- Destroyed my shift fork!
- Problems with Spec Clutch?
- Bellhousing ? 4 a 00 z28
- Wanted!! 94 v6 5-speed bellhousing
- 5th Gear Syncro?
- Is it possible
- Recently bought car = ?????? milage on trans oil
- Did the drill mod.
- Fluid questions, dumb Q
- Clutch Bleeding..??? HELP???
- slave stud size?
- Introducing the Katech LS9X twin disk clutch for LS2/LS3/LS7
- New clutch
- What is the best gear oil?
- New Clutch...
- Dirty clutch fluid
- Bad noise when in neutral, clutch out.
- Which Clutch to Go With
- ls7/ ls2 or alum flywheel?
- I need a new slave/master assembly for my 94 T56
- Is my master cylinder working properly??
- who had a shop do your a4/m6 swap?
- clutch not dissengaging?
- won't shift after 5k
- where to but 6 speed parts
- what does this rubber gasket do ?
- Do you have to run a Mcleod adj MC with Street twin?
- Need help no pedal
- Removal of broken driveshaft yoke
- What did i break?
- sound about right?
- Anyone know where to get blocker rings only for T56?
- ws6store short shifter
- Well?
- Shifting problems with my t56 when going harder on throttle.
- New Problem after rebuilding T56 (IDEAS?)
- TKO 600 what oil???
- shit, clutch help please?
- Clutch won't go down, HELP
- Stuck in gear now no reverse? WTF
- Putting together a clutch setup
- T-56's and Moroso oil pans?
- Vibrations - Clutch or not?
- clutch or tranny issue?
- chromoly or billet steel fywheel?
- Brand: Clutch master/ clutchs
- Clutch wont Bleed - Need Help...
- Clutch line and fitting HELP!!!
- weight of Street twin vs single disc???
- Slave problems
- New @ TICKshift: Monster Clutches ON SALE, New Offerings from SPEC, Lightweight LS7..
- Tick or 01-02 GM MC
- Vibration under engine braking...
- Max HP / TQ on '97 LT1 T56?
- How much is a stock clutch, master cylinder, slave cylinder, 17K miles worth
- clutch pedal not comming all the way up.
- Aluminum Flywheel & Clutch Q's
- T56 jack
- Trans downshifting/misc issue
- Ls7 clutch setup, now i have clatter
- Reverse lockout soloniod or sensor
- ls7 clutch
- What should the clutch pedal feel like while disconnected
- Monster Clutch Sale Going on?
- what is my setup worth?
- pullin tranny
- 2 complete cars:swapping tranny m6-a4 and a4-m6. Swap interior harness???
- Which mityvac model to get
- Packaging and shipping a T56
- 01+ master with drill mod vs tick master
- I Need T56 Parts HELP!
- Clutch
- trouble shifting under wot
- Pilot bushing for LS1
- Do I need to take the starter off to pull the bellhousing?
- Big confusion, have a question about SPEC
- What clutch setup for 900HP?
- ls7 clutch question
- Pro 5.0 install
- Can I make a t56 from a c5 fit into an 82 f-body?
- any tips on removing tailshaft seal/bushing?
- Locking clip for clutch pedal/piston
- A quick question
- spec2+ or spec3+
- Monster clutch break in
- Another Tick/monster setup
- spec1 and spec 3
- New clutch installed... problem with pedal stiffness
- Monster and tic rock!
- Help!
- any strip tips?
- Newb shifting questions.. dont laugh
- Exedy Clutch poor customer service
- ls7
- Dextron VI?!
- LSX Super-Single Clutch Kitch Now Available
- Monster & Tick Performance = Awesome
- Is there Any Worth To These Parts?
- T56 Coversion
- Shifter Rattling
- Centerforce DFX failure after 2.5K and 11 months.
- Reverse Inhibit Soleniod
- What is a T56 worth???
- Old SBC and T56
- Helpe needed ASAP shifting problems CTS-V
- clutch problems
- Rebuilt T56 or go 4L80E? good T56 rebuilders for high HP
- hurst billet plus centering springs
- Speedometer Problem after Conversion
- tremec tko 600
- Tick Performance Adj. Master???
- Drill mod Review: What not to do & End resluts
- uhh 4gear grind, and wouldent go into 2nd.
- Clutch Problems with 7k+rpm shifts. story inside!
- T-56 & v6
- Clutch sliping because of Oil?
- clutch
- T-56 Rebuild
- ram twin disc question?
- Clutch suggestions
- Trouble with clutch slave cylinder install
- What do I need to mate a 5.3 LH6 to a t56?
- Textralia After 6K Miles What Happened
- CTS-V supercharged LSA clutch 6 or 8-bolt?
- Stuck in 4th please help
- New Clutch Needed... Suggestions? - '97 Formula
- What bellhousing do I need?
- Any last minute advice - QM 7.25" 3-disc going in Friday
- Pressure Plate Bolts
- New master, line, and slave still wont shift at WOT
- Need advice. Possibly the clutch.
- A4 crossmember for T56?
- Opinions please! M6 Trans problem
- Is this a factory Hurst shifter?
- What connector did I just break on my T56?
- clutch issues any ideas?
- Used Pressure Plates?
- trans grind new clutch and higher rpms
- 0z700 Installed, Not disengaging.
- New to the 6 Speed world 99TA
- Ls7 Clutch breakin period?
- Car wants to roll when trying to put into gear??
- Had a drivetrain mishap, need some help
- No Reverse!
- Help Heard/Felt Loud Clunk after Hard Shifting
- T-56 clutch swap is a PITA
- Best deal on monster clutch
- Do i shim a slave for ls7 clutch?
- Trans question
- M12 shiftiing a reverse issues! PLEASE HELP
- Clutch and flywheel help_
- annoyed with my Tick adjustable
- Help me out!!! Clutch problems (after my dad borrowed car)
- torque spec?
- need adjustable master cyl for lt1
- M6 won't shift into reverse every time
- Throw out bearing???
- Another Tick Master Cylinder thread
- Stupid Question........
- Gouged Throwout Bearing
- 5th gear grind
- Changing clutch fluid
- 781rwhp
- Clutch hose question..
- T56 cost?
- HELP!!! hydraulic line disconnect tool needed!!!
- Cant Quick Shift........ i tried searching
- Textralia triple disc help - why is the slave different?
- ANYONE know how I can send Harlan a PM?
- grind going into 2nd and 4th....
- 9 in. driveshaft measurements
- ls6 clutch or ls7
- McLeod RXT/RST Users: Did you need the 1373 bearing?
- ls3 clutch flywheel fit ls1?
- Keep the Motor From Turning?
- rockland gear no walk bushing
- How to bypass the clutch switch??
- does a clutch have to break in/ and bumpy feeling why?
- anyone try an act ls1 clutch?
- drill mod Q
- Will this work?
- So...if you mishift a t56, what breaks in the tranny?
- dumb question on tq arm mount
- What is holding me back???
- weird noise coming from clutch..*Videos*
- Detailed MGW shifter pictures
- how do you use the mity vac on clutches? NEED HELP ASAP
- need a slave cylinder..
- LS7 Questions.
- need how-to for t56
- how to adjust McLeod street twin pedal
- Flushing the tranny fluid gives smoother shifting?
- clunking trans??
- Local shop rebuilding T56, which parts to upgrade?
- clutch master cylinder removal
- reverse synchro?'s
- Clutch Sticking Issues: Help Me Out
- 750+rwhp Cars
- New Drivetrain????
- i need a complete clutch kit by thursday
- anyone with an F1 cromoly and a tex come in
- Tranny out? Or just a hydraulic/cylinder issue?
- thought it was fixed, but its not, noise when turning,,, grinding, howling
- IS ther a difference i9n slave cylinders between 97-02?
- Clutch Pedal Spring
- Ever just change the clutch disk and not the press plate/flywheel?
- How Do I Test the Speed Sensor?
- Where can I find this shift knob?
- 06 vette ls1...what tranny?
- Slave Cyl Fluid Level Question
- Hurst Shifter Install...Two Issues
- Help please, cant shift at high rpms
- Will NOT go in reverse
- Stuck in 4th!!!
- Monster Level 3 break in impressions
- hard clutch pedal
- ?'s for pro 5.0 users
- Sticking Clutch Pedal
- spec 3+ to ls7 review
- T56 swap into a 69 Camaro.. NEEDING HELP
- Getting best mileage m6, cam
- Aftermarket Clutch Pedal Assembly
- Manual Transmission Fluid
- While I Have my Tranny Out - Pilot Bearing and Grinding Question
- Clutch fork or throwout problem?? (95 T56)
- Problems with clutch assembly
- Using a A4 harness on a 6 speed
- Houston Area: Good place to install a clutch
- mgw shifter!!!
- T-56 ?sss
- bellhousing questions! measurements needed!
- Hard to Put in Gear
- Monster/Tick guys.....
- Monster Clutch/Transmission issues?
- should my new clutch kick in right away
- How to align shift forks and rails to inset guide pin for t56
- Hurst shifter install tips for newbe?
- T5 question
- New GM slave already leaking!!!
- T56 bolt question
- LS7 clutch with billet flywheel: will it work?
- Need Torque Specs For Shifter Assembly!
- no idea if this is the right section, or if its been posted....
- B&M Ripper shifter
- Harlan 2 step problems
- slave bleeder thread
- broken bolt in BAD spot!!!!!!
- ls7 or oz700
