View Full Version : Manual Transmission
- Spec stage 3 or 3+ ???
- New Options Available at TICKshift.com: REM, Cryo, Faceplating and More!
- shim slave for ls7 clutch?
- T56
- first gear not engaging sometimes
- C4 transmission?
- lt1 six speed
- Six Speeds Inc
- Mcleod adjustable question
- Is strong clutch light peddle possible?
- clutch install question
- LT1 4L60E to LS1 T56?
- Need help finding Scatterproof Bellhousing
- Stick removal
- Someone please HELP!
- Clutch hydro issues...about to give up
- can a SPEC clutch disc be installed backwards?
- T56 manual, mistakes found~
- Introducing; Monster Clutch Co.
- Looking for a mock up T56
- t56 problems (probably rebuild time)
- How many fork pads, keys, shifter forks....do i need?
- T56 replacement options
- Clutch Shopping
- What clutch to replace faulty ls7?
- clutch options
- pictures of hurst shifter next to stock PLEASE
- cutting B&M ripper
- replaced a slave cylinder in my gf's 04 gto
- shortest stick
- Anyone else having problems with Six Speed Inc??
- trans making noise
- My Faceplated T56 experience
- Transmission Rattling/Shaking, Help Please
- high hp trany
- Can't figure it out.. (clutch problem)
- South Bend Clutches
- pro 5.0 shifter bolts size??
- Want to get a LS7 clutch Kit for C5. Yeah?
- fidanza 4.3 clutch question
- PP bolt length???
- website help
- faceplated T56 guys- which trans fluid to use?
- Does your clutch grab off the floor?
- Shifting problem persists; unable to shift quickly.. HELP!!
- Crankshaft expansion Plug Leak - with fun pictures!
- If I have a bad slave cyl, can it damage a new master cyl?
- normal? clutch engages higher
- Clutch won't bleed, almost no pedal resistance
- clutch or hydraulic problem?
- please help!!!!!!!!!!
- Clutch, what clutch?
- T56 Premium Master Overhaul Kit
- m6 swap problem with pics
- Textralia OZ700 done in 5000 miles
- clutch still wont disengage. help
- pressure plate bolts question
- Checking fluid level?
- noise in shifter
- Need help fast please...! tranny
- Need opioins?
- textralia EXO-SKel TQ rating?
- m6 pedals question
- Quick Disconnect on Slave Cylinder Problem
- Question for you guys
- How strong is the manual transmission in the G8 GXP's?
- Who has more chatter?
- LS7 Clutch swapping tomorrow
- Help with pilot bearing install/M6 install
- Is the fenco 13207 slave the bendix 13207 slave
- Picked this clutch/PP up on the cheap!!
- DON'T waste your time on the Drill Mod OR Wrapping your Line...
- More Textralia problems--- OZ700
- !!!Is this brand new Slave Defective??
- Need help with which pilot bearing to use (2 Q's)
- Leak from tail shaft (I think)
- Energy Suspension Trans Mount
- where to get good pilot bushing
- What Clutch for 700RWHP
- Hard to get into the gears..
- ls1 and lt1 t-56 questions
- Flywheel Bolts
- Needing a new master cylinder.. Go aftermarket?
- LQ motors and 6 Speeds??? help
- Anyone know when sixspeeds will be available?
- Clutch problems...maybe?
- t56 overhaul kit?
- Go big or go small for the time being
- need a clutch set that can hold 450 RWHP
- How much HP or torque will a M6 handle.
- LMR's Sixspeed special
- BBC 454 and LT1 T56 Setup
- who should i have rebuild my t56 ?
- How do I convert a LT1 T56 to a LS1 type T56?
- is my eco skel shot ?
- Should I replace the slave?
- clutch slipping after 1000 miles?
- 4th gear grind question???
- Cant take it. Cars been apart for 8 months.
- power handling on a t56
- Tex Exo-Scel!!!
- which clutch for 550rwhp?
- ACT clutch
- zoom Stage 5
- SPEC 3+ gone after 2500 miles
- 74K, replacing clutch, anything else?
- Textralia Question
- transmission took a crap???
- Please Help Braided Clutch Line!!!!!
- Very odd breakage
- Well, I bought a fidanza, now for the clutch.
- Six Speeds Inc
- Clutch Engaging Right Off Floor
- Trans/Clutch Questions Need everyone's Opinions*************
- B&M locating washers
- Pilot bearing-2 part question??
- spec clutch vibrations
- 6 Speed 60ft Record?? 1.30 9.95@137.69
- Way to good at trans removal
- HELP! Broke something in T56
- Clutch Hydraulic Issues
- FYI on Adjustment for the Tick Perf. MC
- HELP! Major Clutch Problem
- Another LT1 T56 behind LSx thread
- Trouble getting into first and reverse.
- Centerforce 12 inch
- Spec 3+ slipping!!!!
- Third Gear Grinding
- Must i use an Adj. MC with Street Twin?
- Does Valeo PPs come stock on the LT1s??
- Spec 3+ = Crap!
- I think I have a clutch problem? pics
- Shifting problems at or near WOT
- Do I need new clutch soon...?
- Central Illinois: I Need A Reverse Gear By Saturday!
- u bolt doing the drill mod
- okay, going to order a clutch/flywheel from a sponsor, LS2 clutch is correct, right?
- Stock vs. Hypersingle weights
- Clutch disc still good?
- Sixspeedsinc website
- A4- M6 Gurus inside!
- problem shifting 3rd
- I dont understand?
- stock GM part numbers for ls7 clutch and ls2 PP?
- MN12 GTO 6 speed Trans
- Six speed INC?
- what's a broken pressure p feel?
- NOT just another Tick clutch mater install
- Need Help Clutch Install issue
- cant decide if I should replace clutch
- kurbon shifter
- Replacing Clutch
- lt1 t56 wire harness?
- clutch pedal catches, not hangs
- 04 gto 6spd problem. sponsers feel free to step in
- Ram Powergrip Clutch Help
- Slippy Clutch Syndrome
- need help asap..
- clutch questions & pressureplate
- rotating clunking noise - driveshaft or clutch?
- Bellhousing bolt questions
- how to diagnose master or slave problem?
- Thinking about a TEXTRALIA, LS7 not working good
- LT1 1.1/16" clutch disc vs. 1.1/8" ???
- Notchy Grinding T56 after 9" & Driveshaft installation
- I seem to have fixed my latest shifting issue - now shifts better than before
- Will 6Cyl 6 speed work in a V8..question from a unregistered friend
- Tranny bolts
- my problem wasn't hydraulics...
- transmission making grinding/whirring noise in gear
- Need to remove slave cyl spring - help
- STUCK In 4th...
- Where to get jam nut
- Pilot Bushing Question
- t56 oil?
- Output shaft play
- Do I need a twin disc clutch?
- 4th Gear Grinds Help
- does my car have CAGS?
- When changing the master and slave cylinder do I have to...?
- cracked tailhousing
- Shifting issue
- GM clutch master cylinder
- Help, Clutch won't disengage
- Flywheel balance?
- "Sachs" clutch kits??
- My Tick Perfromance Adjustable Master Install
- LS7 Clutch and Pressure Plate in a C5
- Sponsers for T-56 parts
- What size gears did you guys go with after 6 speed swap
- ATTN Vendors: Need a Spec III+ by 10/17!!
- m21 muncie
- LS1 F-Body slave/master cylinder question..
- Hissing noise question
- I need clutch opinions
- Input shaft play?
- '93 A4 to M6 question
- The Ultimate Clutch period: The tilton triple carbon
- 3rd gear issue
- anyone use advanced auto slave?
- Clutch Fluid
- ZR1 slave
- t56 rebuild or donor?
- What the hell is the hang up?
- Weird Tranny Issue...
- Which clutch?
- Pilot Bearing Swap With Clutch Still On?
- Oz700 disk thickness
- Textralia Clutch Disc
- T-56 help
- Shifter messed/bending push rods.
- newer spec 3 slipping after 5k?
- grinding sometimes.........and sticking
- twin disc installed, clutch wont dissengage at all
- so confused on which clutch to get...
- time for a new clutch?
- Z06 Clutch?
- Clutches to use with LS2 flywheel
- grease or no grease?
- rattle sound
- Better pilot bushing..part number..
- Ray Bestos slave/TOB
- drill mod??? aftermarket clutch
- What size line & bore for upgraded clutch?
- ssr 6sp in a tbss
- What aftermarket clutch can i run with..
- Where to buy synchros, forks, pads, etc?
- shifting a manual without the clutch
- strange noise
- would you spray on an ls7 clutch???
- Is this the right pilot bearing?
- Where to get a metal clutch alignment tool?
- Clutch?
- gear sometime
- WTB WTT ls1 t56 conversion
- LT1 Corvette clutch in Camaro??
- Ls6 vs. Ls7?
- clutch question?
- Ram Billet Aluminum 2554 Flywheel - Anybody??
- What do I grease?
- something blew
- Anyone use this clutch?
- Master Cyl. How to remove?
- Centerforce DFX first 200 miles wow!
- clutch issues!
- vibration
- oil cooler?
- 01 m6 transmission mount ?
- Tick Perf. Adjustible Master Cyl. Review
- function of blocker rings?
