View Full Version : Manual Transmission
- ls7 clutch & fidanza flywheel
- Textralia clutch after 1500 miles and 15+ dumps
- 1/2 shift fork aluminum?
- Help me pick a new clutch
- Twin disc clutch question
- t-56 shifter to a t-5
- Those who have torn down their own tranny...
- what could this be??? pressure plate or clutch
- i cant figure out what it is...
- LS7 Clutch Trouble
- T56 Advice needed.
- Is there a trick to getting the tranny to slip back in.
- What a day (clutch woes)
- is it a clutch problem, or a tranny problem?
- Fidanza short throw install
- trans temp gauge?
- Positive note for Spec 3+
- no psi after drill mod??
- Need your help....
- t56 removed. question
- Diameter pipe for 5/6 gear install?
- reverse lockout question
- What Clutch????
- Mainshaft Bearing Issues
- best place to get a fill plug for the t56?
- tranny jack need to remove t-56
- I Have a Question and Need Advise Fast
- Help. Clutch won't disengage.
- Torque arm Bushing
- transmission removal
- Spec flywheel
- Pro shifter installed w/white hurst ball
- bell housing wont come off!!!
- Slave Cylinders
- Project Crazy Power is ALIVE!!!!!!!!!!!!!!!!!!!!! 1st DYNO NUMBER IS IN
- Knocking sound near bellhousing
- Trans issues...advice needed
- napa clutch?
- Ok to drive with worn synchro?
- Ebay clutch kit? Good? Bad?
- cluch on 03 Z06
- Where can i get LS7 clutch?
- exo skel question
- Anyone using the RAM Adjustable master cylender?
- What clutch/flywheel should I get?
- LS2- LS7 clutch??
- how long did you manual trans last?
- and.......The TA breaks down.
- What shifter is this?
- Viper Tranny for GM/conversion
- Help!!
- Swapping to the t-56 today
- clutch problems
- clutch fluid question
- which side Pilot Bearing?
- Sludge in master cylinder resevior?
- What master cylinder?
- vote for which clutch i should get
- LS6 clutch disk
- Clutch pedal is losing pressure!
- t-56 shot again please help!
- what is the "normal" engagement point for pedal travel
- Project Crazy Power is ALIVE!!!!!!!!!!!!!!!!!!!!! Video Uploaded
- Is this clutch a stock LS1 clutch or better?
- weights of clutches
- Ginding under 2k RPM
- Text 0z700 owners, got a few ??
- is the Centerforce DF any good
- downshifting from 3rd to 2nd WHACK
- Car stutters in 1st from a stop?
- Anyone running McLeod Twin Disc w/ a Stock Master!?
- throwout bearing
- Close Gear Ratio T56
- M6 Throwing Torque Converter Codes!
- No pedal pressure
- t56 for BBC pricing questions
- ?? sloppy tranny ??
- Ram powergrip HD guys come on in....
- hows clutch replacemant with headers
- Transmission Problem -- No 3rd Gear
- 98 camaro t-56 slave cylinder question
- pilot bearing
- Where to buy T56 fluid??
- stuck in reverse and forward?
- Is this normal with my spec 3 plus?
- Pedal Pressure with LS7 clutch/flywheel/PP
- need help picking
- Ive about had it...Please help!!!
- clutch install Pain in the A$$
- Relocating shifter for T56?
- stiff shifting. synchro or hydralic???
- Thinking About Selling My M6
- need help!
- 4th grinds...
- Textraila billet flywheel weight vs stcok
- ls7 clutch/ls2 fly wheel, pilot bearing?
- LS7 paint marks on flywheel and P Plate WTF?????
- Pictures Of Nubs needed to grind on Tranny Mount
- PRO 5.0 Question
- Clutch or hydraulic problem??
- Washing Rocks Sound...Normal?
- Hurst Billet plus questions ----->
- Flywheel balancing?
- Clutch grinds when taking off...Whats wrong?
- transmission rattling..help please
- Lou's Short Stick on a B&M Ripper?
- FS: T56's 4A Built transmission (1 left in stock)
- Changing Out Master Cylinder Today
- Clutch Install Success Story
- No backup lights
- T56... bad throwout bearing???
- "Viper-spec" T-56?
- SPEC strikes again.......
- 2nd gear "kicks"
- Ordered Textralia today!
- clutch install, problems with lock out
- MN12 in fbody???........
- transmission problems, grinds when i hit the brakes?
- Seach isnt working, how much hp does a stock t56 hold?
- Anyone running a Centerforce dual friction clutch?
- lost 6th and most of 5th last night
- A4 --> M6 ?
- Who runs a T56 with BIG power??
- Ls7 Clutch Kit
- Clutch help
- LT1 T56 swap behind 89 TPI350 - which year master cylinder should I use?
- B&M shifter owners come in, need help .....
- Driveshaft loop install
- Pedal sticks to floor. (new m/cyl & slave)
- shifter prob.
- GM Ext Warranty cover Slave & Flywheel?
- help monster broke down braddahs!!
- LS6, or, LS7 with LS2 fw clutch???
- rpm drops how much between shifts?
- Tex total weight with billet or alum?
- Textralia OZ700, Is it overkill?
- Do the 01-02 come with LS6 clutches?
- Slave replacement coming up
- Ram slave cylinder and through out bearing.
- Does the GM upgraded Slave come with Throwout?
- Stock LS7 Clutch- How much power.
- master or slave? pleeease help
- Clutch?
- Tranny issues!
- after 1 1/2 hour cant get clutch to bleed????
- difference between 99/00 01/01 master cylinder
- Textralia torque specs?
- Blew my freakin' pilot bearing
- Doing Drill Mod! Can I use my original line???
- Are these the same pro shifters?
- Please Help Me!!!!
- Shift knob....
- hard to get into gear
- Slave cylinder ????
- RAM BS Flywheel with SPEC 3+ Clutch
- T56 Stuck in 4th gear? Help
- where to buy RAM adjustable master cylinder?
- Can anyone give me better details to the Pro 5.0 spring mod?
- 03/04 cobra shifter knob users....what size thread to I tap it?
- LS7 clutch with aluminum flywheel?
- Need a Clutch Master Cylinder
- T56 installation assistance requested
- axle shakes in reverse
- ebay slave prices compared to sponsor slave prices??
- clutch install in an 02
- POP goes the T56
- T56 Rebuilds Review...
- Stock hurst shifter with what short stick?
- How much pedal play on LS7 Clutch?
- Clutch write up for a lt1 ?
- Difference between Hurst white knob and Speed inc white knob
- anyone have the part # for stock 2002 ls1 flywheel bolts?
- Big A$$ Crack
- Water in clutch bell housing possible damage
- Crossmember?
- Spec shim
- Synthetic okay in my '99 T56
- will my lt1 t56 bolt up to my new ls1??
- Tranny wont go in gear...Master Cylinder??
- Clutch Noise Problem
- Tranny mount?
- Stock shifter worth replacing?
- well, i ordered my t56 rebuild!
- Spec gone wrong...
- Help...
- well if this doesn't work it is time to dial it back! lol!!!
- Any 6 spd cars over 3300 lbs going mid 10's or faster? if so, in here please.
- are these the cheapest for clutch install parts?
- t56 rebuild
- Slave cylinder broke
- Shift Light
- What are the TQ spec's for the bellhousing?
- CLutch ?
- Torque Arm
- Problems...
- Valvoline Maxlife Dexron III/Mercon dino oil
- which clutch for H/C/I street/strip ride?
- Gears are hard whats going on...
- Should I throw in the towel (expert help needed)
- Torque specs?
- what brand of steel billet flywheel works for street/ strip?
- What is the best stick for a Pro 5.0 Shifter?
- Z06/gto M6?
- T-56 woes but time for upgrades?
- Textralia with a gen1 SBC?
- Clutch advice
- Broken Tranny Mount??
- Drill Mod now Clutch is Flat HELP!
- LS7 Clutch Done!
- Should I reinstall this clutch?
- LS7 clutch fit LS1?
- Rear trans seals not the same?
- clutch replacement question
- does this list look good to install the McLeod twin?
- 3rd gear
- Hydraulic line (drill mod) Question
- How to remove/install the front seal T56
- Installing your own gears
- I Am Bleading To Death!!!
- Disconnection MC line from t56
- what happened with my T56??
- Clutch Pedal Play
- need advice fast, mcleod twin or tex oz700
- corvette short shifter question
- Dead Pedal
- Speedo moves when I rev
- I need a slave dont I?
- B&M Shifter install help.
- Pilot bearing help
- full T-56 rebuild?
- Balancing Clutch + Flywheel
- Hard to get into first gear and reverse
- What bellhousing for T-5 and LS1
- Clutch feels weird now...
- Ls6 clutch close pic or info?
- Clutch info
- help in the flywheel
- thinkin of doing a transmission swap
- T56 rebuild questions... gurus get in here for big hp application!
- slave cylinder bleeder leaking
- trans shot?
- Any negatives for Spec stage 3 w/aluminum
- T56 Rebuild time
- Aftermarked Shiftboot that fits?
- C5,6 Z06 Master Cylinder...in GTO
- Tranny oils
- 500rwhp LS7 clutch???
- The Only Clutch You Should Buy!!
- finger is on the buy button, thoughts before i click?
