View Full Version : Manual Transmission
- Proper bleeding technique?
- Anyone know the bolt size for M6 shifter bolts?
- THROW OUT BEARING
- Aluminum Flywheels Worth the Money??
- Hope somone can help!!
- What clutch to run ? Mcleod twin, cartek, spec?
- Aluminum fly wheel question?
- Synthetic Clutch Fluid?
- Clutch pedal gets stuck to the floor @ WOT
- Throwout Bearing
- whats the deal with lightweight flywheels?
- i'm installing my RAM CLUTCH please help!
- M6 GUYS WAT RPM U LAUNCH @ W/ BFG DR?
- M6 guys with 4.10's? Did they really wake up your car?
- T56 pops out of 5TH and no 6th gear = (
- Clutch problems!!! Help quick
- What is wrong with my clutch
- Bolt in Tranny suggestions for a 3rd Gen
- which clutch to buy??
- Tranny leak :(
- Reverse poppping out under load, What could cause this?
- 4th gear grinding - syncros bad?
- Need help Trans stuck in 4th gear (M6)
- drain and fill plugs on a t-56
- SPEC Clutch Stage 2 OR 3 ?
- confusing clutch
- Rear seal in M6 blown help inside
- 'Racing' pedals... do they help?
- Which part of my clutch hydraulics is bad?
- mc leod clutch sqweels??????
- Need help diagnosing T56 troubles...
- Connverting to an M6??>>
- Ripper or 5.0
- Part Number for T56 Vent Tube???
- Clutch wont unengage at high rpms?
- Centerforce DF and clutch master cyl. question
- Light weight Flywheel?
- Ram 6130 Installed I..
- Pro 5.0 Shifter
- Can a throw out bearing leak tranny fluid?
- Re-balance Flywheel?
- Hydraulic clutch tip.
- Clutch pedal and warranty woes.....
- 1999 Z28 Clutch Install..Your opinions needed
- Weird noise coming from clutch (I think) need help
- T-56 Experts (rebuilders) Inside Please!
- Ok... Here's a controversy for you m6 drivers...
- Installed new Zo6 clutch, car won't go into gear..
- CARTEK ---> not fully engaging?
- clutches
- Which Clutch for Nitrous and Cam???
- '01 Clutch Replacement?
- Metal bits in my T56
- Replacing Clutch. What bolts to replace?
- Borg/Warner t-56 into a LS1???
- Reverse Lights Out:
- New clutch......maybe RAM?
- Keep spec stage 4 or get mcleod street twin
- Are GM and Mcleod slaves different??????
- I quit babying the new clutch and.....WOW!!
- Time for new clutch, is ZO6 good enough for me?
- CHEAPEST PLACE TO GET PRO 5.0?
- ??need clutch alignment plug??Where??
- Clutch peddle sticks, when under hard acceleration
- B&M Ripper shifter Question
- need clutch advice
- how do i make the lockup clutch engage faster
- Mcleod ADJ master makes noises?
- Tips on a good clutch
- B&M or PRO 5.0???
- Can I put my old clutch back in?
- Synchro's or clutch ???
- New Forum Sponsor - RAM Clutches!
- Another clutch question
- Mcleod street twin vs Spec stage 4
- Clutch making a wierd noise
- Please help with my clutch problems
- Mcleod sfi scattershield for ls1 T56
- Stock throwout bearing shim missing?
- M6 WITH 410
- anyone try Redline MT-90 in a M6?
- Why is my clutch pedel so soft?
- Stock Clutch Sticking
- Clutch engages too high. How can I fix it?
- broken clutch spring?
- Damn clutch pedal sticking to the floor.
- Finished A3->M6 Swap. Drill Mod needed? *DELETED*
- ? about slave and throw out
- Which clutch do you all use? Need help picking one
- M6 to Th350 swap, what all is involved??
- Possible Torque Converter Clutch issues need help!
- m6 4.10 or 4.30's?
- Is it common to smell clutch after a run?
- 6 Speed Tips
- M-6 T-56 TRANS 5TH GEAR
- need to buy clutch asap
- Clutch return spring
- are any m6 cars in the 11's with 3.42 or 3.73's?
- Z06 Clutch Question
- Needing advice on clutch setup in gf's T/A...
- help with new clutch
- where to get right flexplate for th350 swap (m6).
- My forged T56 is trashed after 1 month!?
- How do I bleed the entire clutch hyraulic system?
- Clutch install is done!! Now b/u lights dont work?
- Whats the best shifter and clutch for a 6speed?
- Clutch install a pain?
- Yet ANOTHER clutch recommendation thread...
- Did i pout my clutch in rigth or what??
- How much did you pay for your clutch?
- McLeod twin disk ,Help!!!
- M6 drain / fill plug size
- ?help with clutch selection?
- Thoughts on Pro 5.0
- Grinding 3rd...
- New clutch and break -in process
- Spec clutch & Mcleod Master. . . weird pedal feel
- M6 is putting 12bolt should he go 3.73s or 4.10s??
- spec clutch
- What fluid to use in a ZO6 clutch?
- Z06 Clutch or a SPEC Stage 1 clutch
- Clutch chatter
- m6 tranny HELP!! Experts inside!
- Swapping to M6.whats the best street/strip clutch?
- Synchromax or Synchromesh for M6?
- Dynoed yesterday, now M6 won't go in reverse
- Do Z28 M6's come with the torsen differential?
- Looking for GM part # for t-56 inner shifter boot
- Z06 Clutch Parts, Drill Mod Questions!
- LS1 powered Manual Clutch Question
- A3->M6 Swap Parts List...Help
- Need the M6 pros..got questions...doing a swap!
- Borg Warner T56 questions
- Replacing Clutch Which Setup?
- Clutch Pedal Pressure
- Which clutch to buy?
- clutch question
- Need help with Clutch install....**update**
- M6 and rear end oil question
- Mcleod street twin PP vs. LT4 PP
- clutch questions
- synchromesh or not?!?!
- Problem with my clutch or not?
- What is the diameter of the T-56 input shaft?
- B&M Ripper rocks!!
- Question regarding 3rd gear grinding???
- Where to buy Spec Aluminum Flywheel Friction Inserts????
- Great article on T56 transmissions
- M6 Rebuild Needed?
- Stock Flywheel?
- RAM Clutch question
- Major Clutch Problem...
- Clutch, no go
- Mechanics Inside: 1-2 shift thud followed by gear thump and occasional grinding
- Clutch Hydraulic ?'s
- clutch wont disengage PLEASE HELP
- What Gears?? M6, Stock heads, TR224 Cam, Full Bolt Ons, 75-150 TNT..
- Mcleod Twin Disk Questions
- will i hit 5th with 4.10's in the 4th mile(m6)?
- Is my clutch going?
- m6 problem
- upgrading the M6
- Need clutch recommendation
- t-56 won't turn freely.
- T-56 Tranny or Auto?
- Best clutch under $1000???
- Clutch Help
- interest in a m6 swap??
- accidently started in third gear and clutch stuck to floor then big bluff of smoke?
- Tranny grinds when....
- Clutch engagement
- Clutch
- Where do you get the DOT 5 fluid for the Cartek Clutch?
- Clutch Experts Inside Please!!
- Clutch Questions
- lockup clutch going bad?
- blown synchros
- Pulling a T56?
- Pro 5.0 Shifter
- McLeod Twin Disk worth it??
- Had a problem with your T56, Please Read
- T56 Fluid
- Spec stage 3 clutch?
- How the hell do i get my clutch fork on?????
- Dual Disc Clutch Question
- Where can I get just stock a replacement flywheel?
- Excessive play in clutch pedal? Anyone have this?
- Clutches SUCK!!! Need Help
- Help T56 troubles
- mcloud clutches
- Finally replaced 80k clutch (Pics) but have ?'s on new one.
- What's wrong with my clutch?
- NEED HELP FAST WITH CLUTCH ENGAGEMENT
- Question for Spec Clutch owner inside
- Whats the Best Clutch for a 460rwhp daily driver?
- Mcleod dual disc, weight?
- McLeod Master vs. Converted Stock Master???
- Clutch problem
- Bench bleeding clutch MC...
- So who has had problems with their aftermarket clutch...
- STAR clutch?
- How much should a clutch replacement cost?
- anyone use SPEC clutch with stock pressure plate?
- Chattering w/ Ram clutch , why ?? help
- Which flywheel.. billet steel or alluminum?
- McLeod adj Master engagement / adjustment / feel question
- Accidentally ran the clutch master dry,now what?
- T-56 fluid capacity
- need a really good road race clutch
- Strange, Yank, McLeod and Hal on sale!
- RAM 402 PP fit with a Hays SFI Billet Steel LS1 Flywheel?
- RAM Clutch Lifespan?
- T56 1st to 2nd PROBLEM
- i need a clutch alignment tool
- T-56.....Whats the difference.... LT1 and LS1
- Clutch
- Aluminum Fly Wheel?
- I SMELL MY CLUTCH
- Clutch Help Please
- How much can the F-body M6 handle? IN power wise?
- Pro 5.0 issues
- Which Clutch for my '01 SS ????
- Question for M6 guys with stock 3.42's?
- Slave assembly & throwout bearing... Pics???
- simple clutch question....
- Squeaky clutch!!
- ripper
- clutch not covered under extended warranty??
- No pressure on clutch
- need help removing B&M ripper ASAP
- Anyone in New Jersey with a clutch alignment tool they don't need?
- Does this sound like a good clutch set-up to you guys?
- Anybody who has a M6 please help!
- McLeod Master cylinder FIXED!!!!
- T56 Reassembly
- clutch or tranny broken???
- Spec Stage 3 or Ram Clutch
- clutch question
- Pilot bearing replacement? Does clutch have to come out?
- need t-56 help IMMEDIATELY!
- How Bad is the Stock Shifter Compared to the Rippers and Pro 5.0?
- Opinions on rear and clutch
- clutch ?????? INSIDE
- B&M ripper shifter ?????????
- T56 needs rebuilt ....D&D?
- Broken Clutch Return Spring
- Aluminum flexplate- flywheel
- Transmission grinding going into 3rd.....?
- 3rd gear replaced in m6, now it's not shifting smoothly. I have a question.
- Getting T-56 tweaked need help
