View Full Version : Manual Transmission
- Switching from Auto to Manual
- Help!!!
- Replacing Flywheel ring gear on Textrailia twin-disc billet flywheel
- Has anyone used the Jegs LS1 flywheel?
- which slave cyl should my setup have?
- t56 fluild pump
- Power tower 5.0 shifter questions??
- C6 T56 shifter for main case location.
- Flywheel for LS7 clutch??? Yes - I searched...
- master cylinder disconnect plastic ring broken....
- MGW Shifter w/ C6 Knob?
- Tick performance master cylinder
- T56 leak
- clutch problems already!!!
- Clutch decision
- [[VIDEO ADDED]]Help me diagnose this squeak please.
- T56 Reverse Hard to engage
- McLeod 500 series w/600hp
- Spec stage 2 thickness??
- ticking noise
- Transmission Tunnel Cutting???
- t56 part numbers?
- Another T-56 Fluid thread...
- Dyno pull, <500mi on clutch?
- Monster Stage 3 installed
- Need opinion about my reverse gear
- F-body – Did your Tick Master Line up?
- New Trans Am Purchase - Clutch Pedal Question
- T56 1st and 2nd gear issues
- trying to decide on a clutch
- Master Cylinder bracket for M6 swap
- what to do to my T56
- Slave cylinder
- Rebuilt T56 grinds 2nd
- Im being told PArts for the GTO T56 are not available?
- Rebuilding a T56 what to upgrade?
- [Solved] Pilot bearing will not fit?
- Master cylinder quick disconnect plastic sleeve.
- Anyone tried the FX Racing Lightweight Chromoly Flywheel?
- Need help picking a clutch!!
- Opinions needed - THANKS USPS!
- Those that have done the A4 to M6 conversion
- 4th gear grinding when downshifting
- Six Speed
- What's the difference?
- High speed in what gear?
- New Clutch in, help me diagnose old one
- Bell housing runout
- OK To DynoTune On New Monster Clutch?
- Trans Mount
- monster stage 3 help
- TR6060 - T56 Magnum hybrid
- TRANS for camaro ls3
- 5-6 Driven Gear Trouble
- t-56 gears engaging roughly
- Tick Master Cylinder killing my slaves??
- best place to buy level 2 T56 rebuild kit w/ bearings?
- alignment tool and pilot bearing?
- Internal Components Campability
- 1998 z28 t56 problem.
- Billet key springs question
- Monster stage 3 can u use a gm fly????????
- GTO to F-body
- Stainless Clutch Line for TR6060?
- helpppp bleeding
- Current discounts of LS1 clutch
- Who all builds T56s?
- Reverse lockout not working (fuses and solenoid are good)
- Running a McLeod RXT? Come in!
- t56 popping out of 3rd gear
- Will hurst nitro stick ii work?
- Swapping to M6 trans
- Clutch Issues please help
- started doing clutch on my car a few issues ???
- Clutch safety shield?
- Need straight answer on where to get Slave cylinder
- 6060 2nd gear miss
- What happened to my T56?! **CARNAGE PICS inside**
- T56 rebuild in progress... ordering parts and have a question
- clutch suggestions
- T56 5-6 Extension countershaft damage?
- Is there a LS2/LS7 clutch option for LT1 cars?
- What clutch is for me?
- LS1 T56 vs 03-04 Cobra T56...countershaft question
- T-56 Experts inside...
- Need a new clutch. Recommendations?
- Brand new Ram slave cylinder leaking
- Reassembly Questions
- Trans issue
- Ls7 clutch recomendation recommendations
- T56 recommended rebuild upgrade parts
- Holinger RD6 Sequential for GTO
- New stock T56 clutch, shifter feels notchy and like shit now.
- Pulled 5/6 gear off by hand. Is it shot?
- Clutch dragging on flywheel and pressure plate
- Bellhousing and Input shaft question
- t56 slip yoke
- Need help figuring out some shifting issues..
- UMI Short Stick Happy Customer
- Input shaft seal
- clutch whine?
- Street drivability and flywheel weight
- T-10 question
- How to identify F-Body vs. GTO Bellhousing?
- 99 camaro ss slp clutch info needed
- Grinding when shifting into 4th
- Where to buy quick release ring?
- PLEASE HELP- clutch / master cylinder issues?
- T56 stuck in gear on my workbench
- Use ls1 hydraulic throwout or Lt1 mechanical throwout?
- help driveshaft stuck wont come down during clutch change
- T56 troubles
- My first tranny removal.
- "So you think you want a 6 speed manual transmission ?" Article from external website
- Clutch installer
- Clutch/tranny problem
- Aluminum Flywheel insert question
- Clutch pedal sticking to floor - 99 Camaro SS with 33000 miles
- Aftermarket gears
- Occasionally "missing" 3rd gear?
- Clutch Install Help
- transmission swap
- t56 input shaft replacement?
- TR6060 VSS gear tooth count /vss pulse output
- McLeod RXT users... what MC you using?
- tick master help
- Complete 6 speed change over parts
- t56 re-assembly woes
- -3an to GM quick connect adapter (Comp TOB to stock Master)
- Short Throw Shifters
- Mcleod RST and Fidanza questions shims, balancing?
- Flywheel glaze and hotspots, pressure plate looks new?
- slave cylinder release bearing
- Best clutch for my car. 350hp now, 500hp future
- I think I broke it
- my v6 automatic turned into a baby trans am 5.3 6speed
- T-56 Magnum clutch/flywheel/slave install issue
- tdp diamond stage 2 clutch
- Another T-56 Clutch issue
- Sparton Locker with t56
- Weird problem!
- T56 Rear Seal Leak
- rebuilt t56 still crunching
- Clutch Noise
- Changing out T56 Hurst short-throw shifter - to reduce cabin noise - lots of ideas
- Clutch engaging with pedal to floor
- T56 fill question
- 99 z28 a4 to m6 swap wirring question
- Cross member
- Cya later 2nd gear
- Built t56 or 6060 for 02 TA
- transmission/shifting issues
- Would a 2 step work as no-lift-shift on t56
- T56 conversion experience
- Hydraulic Issue
- Installed my tick master today!
- 79 firebird from auto to t56
- Just pulled my clutch. How does it look?
- vss instrument panel pulse diviser
- clutch question?
- first post..tranny problems :(
- Easy 4l60e to T56 Rev. Lockout Conversion
- Prepare 5.3 for t56 magnum
- Popping out of reverse, tail shaft removed, video inside
- GTO to Camaro Shifter???
- Anyone running the McLeod Mag Force clutch?
- Do you think i still have life left in this clutch
- 95% of clutch issues
- new tranny and rear end break in??
- Opinions / questions on C7 twin disc adapter plate by monster
- Clutch or Slave Cylinder Problem?
- T56 rebuild shops in KC
- Advise on built t56
- trans clunking against body
- Help MONSTER! noise after Monster 3 install? UPDATE: TRACK RESULTS VIDEOS!
- monster lvl 6 vs lt1-sc
- GM LT1 Clutch 'On Car' Balancing Instructions
- mystery flywheel
- spec vs ram vs monster chime in martin@tick
- Installing tick help
- Shimming T56 Release Bearing....Required?
- clutch bleeding
- help ID a part
- Replacing clutch slave – should I replace the clutch?
- Was My Slave Updated?
- Any reason this wouldn't fit a GM TKO600???
- hard to get into any gears help! 00 ls1 t56
- Clutch chattering and losing pressure intermittantly
- nv3500 to 5.3 what flywheel/clutch?
- t56 5/6 countershaft end play spec?
- ID This Transmission - T56 ???
- Flushing clutch fluid
- centerforce dyad twin
- fix for dead pedal
- New t56 mag installed/ clank sound need help
- Tick master cylinder
- new flt t56, tick master, bled, still wont shift
- Quick Disconnect tool
- redline D4
- Odd rattle after TOB replacement
- funky reverse after shifter swap
- T56 Shifter Rattle - Not the shift Cup/Bushing?
- Master cylinder removal.
- WTB quick disconnect fitting for slave cylinder
- So... How hard is a clutch replacement?
- Clutch Recomendations
- 4L60E to T56 wire harness conversion
- Lt1 flywheels question?
- scavenge pump for the T56
- 98-02 t56 in a 96
- 4th gear not going in
- do I need an adjustible master cylinder?
- Nos t56
- Tranny hitting car...
- spec 2+ clutch and trans install
- AHHHH!!! Help, wife put all my blocker rings together.
- Sticking clutch pedal, I know the causes need some diag. help!
- Transmission Shops in Southern California?
- M6 transmission having trouble going into gear? squeeking noise?
- Transmission having trouble going into gear!? squeeking noise?!
- 2nd gear issue
- Has anybody ever retapped the shift rail guide bolts?
- Catastrophic Input Shaft Failure (T56) ****Pics**** What happened?!
- Mcleod RXT question
- How to remove TKO front cover?
- Does a SPEC 3 stage 3 clutch require special slave cylinder or T/o bearing?
- Contacting McLeod
- Vibration at random times
- 5/6 counter gear thrust washer
- Tick Speed Bleeder
- t56 repair near wausau wi
- T56 Magnum twisted input shaft
- Best clutch kit for $900
- TR6060 vs T56 case
- cammed ls1 6 speed guys quick question!
- T56 3rd gear question
- 02 camero ss six speed manual shifting probs
- hydraulic tob AN fitting
- Recommended Clutch Slave for LT1?
- Clutch pedal issue
- T56 yoke
- a4to m6 swap parts HELP.
- Changing Yoke??
- Monster LT1-S installed!!!!
- 5/6 counter gear asm. removal t56
- Mcleod RST and Monster twin disc users come in please
- Upgrading to 30 spline Main Shaft
- faceplate t56?
- Stiff pedal when wot.
- Magnum T56 Shifter
