View Full Version : Manual Transmission
- clutch life
- Just did Spec 3 clutch and flywheel! I likey!
- Need Help...
- 6-5th downshift
- Toasted Clutch Already...INFO GUYS
- Just installed my spec 3.. have a couple ?'s
- How long is a Spec 3 carbon supposed to last?
- Shifter didn't want to go in reverse
- 3rd shot. rebuild or get another?
- Can you buy a replacement clutch disc?
- Aussie clutch at work..10.4@143mph Vids inside.
- T-56 noob, first question
- Life span of a Spec clutch?
- spec is in and done...
- Best Shifter??
- Sticking in 4th
- t56 Swap pictures
- is anyone else having problems with ram clutches?
- new clutch
- Clutch slipping in 6th!?
- Oil leaking out my rear main seal when I get on it??????????????
- can you install a clutch disc backwards
- LT1 Slave Cylinder
- Mcleod replacement clutch lines?
- Please help Choose A4 or M6
- WTF? My shifter(stick) just came out
- Clutch engagment point?
- TRADE my A4 for your T56, i need T56
- Best Clutch
- There goes ANOTHER pilot bearing
- Stuck in 4th gear!!! Long post?
- What can cause a clutch pedal to .....
- Clutch for FI!!!!
- Cartek..
- 6spd cars w/aluminum d-shaft
- Fluid???????????
- SPEC3 Slipping Already?
- Doing SpecS3 clutch tomorrow...advice please?????
- Umi vs Lou's
- Aluminum or billet steel flywheel?
- Help, Clutch disengagement problems
- tranny
- Flywheel?????????
- M6 questions/comments
- Problems Clutch/Transmission need solutions
- SPEC3 problem
- which clutch is best and do i have to get a new flywheel? please help
- spec 3 chattering.......again?
- clutch exploded!
- Should the PP be balanced with the flywheel?
- Just installed my new clutch/flywheel got a ?
- metal shavings
- spec 3 question
- 650 Rwhp Clutch
- m6 conversation?
- Mcleod Or Ram Or Spec
- Keep Mcleod adjustable master, or go with stock w/ adjustable end?
- ws6 store short stick
- Clutch problem or is it a hydraulics problem?
- C6 Zo6 Clutch set up
- what really destroys a clutch
- ZO6 Clutch
- input shaft?
- B&M vs. Pro 5.0
- trans removal
- Mecleod clutch, how much to turn fly?
- New Viper Spec Tranny, Spec 3, new hydraulics.. cant get into 1st now?
- Spec III installed
- Spec3
- Anybody ever gone back to a rubber tranny mount, after running poly?
- Spec Stage II & Aluminium Flywheel
- Weird Sound PLease HELP!!
- M6 (T56) tranny blanket
- Car Jumped Out Of Gear On Launch
- Trans Fluid.
- Regearing 6th, for 4.10s
- Car starts without pushing in clutch??
- slave just went out
- HELP ASAP In the middle of a spec install!!!!
- Still rattlin'
- pro 5.0 and LSS
- anyone used something besides atf for gear lube?
- Damn Skip Shift
- Need all the help I can get.
- NHTSA Recall # 99V239000 ?!?!?!?
- A4 - M6 Question
- A4 to M6 guys.. how to connect rev lockout sol??
- Best T56 modded trans for sale, where?
- new clutch?
- Spec
- clutch chatter
- At what RPM should you dump the clutch?
- Clutch concerns
- SLP Clutch
- Throw out bearing issues I believe ?????
- Ram powergrip HD & Futral Adjustable Master!
- Drill Mod ???
- Few questions t56
- Clutch issues, gears not engaging **PLEASE TAKE A LOOK**
- Tapping a line
- Centerforce or Spec or Ram?
- 6 speed isolator cup???
- Wierd rattle coming from trans area?
- Sticky Clutch Pedal
- Master Cylinder Replacement
- centerforce
- clutch help
- SPEC to Ram....
- Grease for TO bearing?
- spec level 1
- Spec F Disk issues
- ARP Flywheel torque spec?
- clutch adjustment
- Help with leaky master cylinder
- Flywheels!!!!!!!!!!!!!!!
- Leaking Fluid From T56 question.....
- Clutch
- Exedy owners inside please..
- Question on my slave
- Clutch Master Cylinder
- name of transmission place
- Haven't seen this post before
- Removing and installing tranny/clutch???
- i hate to ask, but which clutch should i get?
- Will my Z06 clutch slip with heads/cam?
- Violent shaking when I start rolling from a stop
- drill mod done, and now...
- LT1 T56 prob
- clutch probs, HELP!
- ls1 tranny yoke
- drill mod necessity
- quick LT-1 clutch fork question
- Clutch Slippage?
- Clutches, which one?
- Length of the LSS?
- Lightened flywheel
- Trans mount
- Transmission noise through shifter:
- aluminum or steel??
- stupid question: would a pro 5.0 shifter from a t56 in a 03-04 cobra, fit an ls1 t56?
- Spec III i question/problem
- Help with new shifter
- Throw out Bearing
- Hard to find 3rd and so on
- Tranny starting to whine.
- how much do i adjust the master cylinder?
- shifter moves when i get on it
- LT1 pedal & crossmember in LS1 car?
- uh oh clutch petal meets stupid friend
- hurst shifter feels loose
- Tranny's not doing so good. Getting worse.
- centerforce or spec? master/slave? any clutch install tips??
- what clutch
- LS6 or Centerforce throwout bearing? (and other clutch ?'s)
- Flywheel / Clutch Balance question.
- SPEC 3 install - shift noise!
- Any one have a Spec Stage 3 Hybrid?
- Anyone have a D&D T56 trans?
- couple of post-install concerns
- a little confused...
- Shift Selector Assembly pics?
- Ram clutch review under hot laps
- T56 in a 2000 Silverado
- clutch install finished, reverse no worky
- Can a Clutch Slip at High Speed
- I need some technical opinions on a clutch problem
- "What Spec number and letter are we up to?"
- clutch feel
- T56 Oil Temp?
- will she make it? spec 3's last leg...
- Spec Clutch & Fidanza Alum Flywheel
- clutches
- Odd RPM problem when in neutral
- clutch or something else
- Tranny Rebuild And Clutch Cost?
- clutch sticking to floor
- Mushy Clutch pedal...what do I need to do?
- Help with Spec clutch install please! Shim or not? for C5 hydraulics?
- Question?
- help! pp bolts won't go in
- Gears too high/thin tires?
- Another SPEC HORRIER Story
- 19K miles T56 Problems....HELP
- Q's about ls1 TO bearing
- Pro 5.0 problems? Or just Problems
- Best deal on a Pro 5.0 and LSS?
- What kind of shifters do you guys have?
- Spec Vs Ram
- slave cylinder
- flywheel resurfacing question
- Two Step Users?????????
- How many miles do you have on your clutch?
- diagram of bolts?
- do i need a new clutch or new hydro cylinder??
- Swap an M12 Z06 T56 tranny into a 99 C5 w/ an M6 t56 tranny?
- Question about 3rd gear....
- Where to buy flywheel bolts, pressure plate bolts, and tranny bolts??
- PP and flywheel bolts
- Flywheel?
- clutch prolblem?
- PRO 5.0 Question
- Any Thoughts?
- What are the T-56 Drive Ratios?
- "T56 King"
- What should I do with the t56?
- Whats the Problem?
- Car wont go into gear. Need your opinion.
- SPEC clutch issues? (kinda long)
- What kind of shifter do I have?
- Spec 3F Installed Today
- Tranny Leak...HELP!
- Clutch break in
- T56 gear puller?
- T56 pooping out
- flywheel questions
- Just bought Ram clutch....Balance?
- Master/slave cylinders...
- Pro 5.0 is it the same as the cobra?
- Lou's Short Stick Installed
- I need a clutch
- Slave Cylinder Problems
- Z06 clutch in - pedal too low
- 1999 T-56 yoke size
- Tranny Mount
- I need your opinion guys...
- Clutch spec 3 or Ram HD
- Hays clutch any good?
- Clutch disk only???
- Clutch Problems.
- Clutch Slipping Help
- Spec SIII w/6 puck disc lasts only 6500 miles.
- are ls1 and lt1 t56 different????
- Clutch Installation help
- Compilation of specific tools needed for T56 rebuild
- clutch decisions
- My Rebuilt Trans is acting weird..HELP PLEASE
- cheapest place for rebuilt T56
- What's the word on the Harlen Drag Cags??
- Just ordered a Ram 3 powergrip clutch kit
- Spec dealers, rebuild question inside, cost?
- How much does the zo6 clutch assembly weigh?
- Clutch going and my Low Trac is acting up
- Car would'nt shift into gear
- Ughh
- Broke the T/A!!!!!!!!
- Is this normal? Pics inside.
- Help my clutch pedal is riding high
- HELP! slave quick connect wont come off
- Spec 3, 02 Slave, drill mod, and Viper Spec installed!
- 2nd gear
