View Full Version : Manual Transmission
- Ouch! What IS that noise?
- Rebuilding T56. Have a few questions
- Yet another t-56 hydraulic issue/weird issue need help.
- T56 stuck to bell housing
- Any weight difference in 3,4 and 6 puck clutches?
- master cylinder line and exhaust manifold fix!
- transmission swap ?
- Ls7 clutch
- 2000 4.8 to muncie... what flywheel
- Burnout Fail.. Why??
- LT1 clutch install... help!
- Need stock ls1 slave measurements
- Best Clutch
- Looking for some clarification...
- Help please
- Pilot bearing
- Pedal stuck to the floor
- Monster Stage 1 or Stage 2????
- Attention People Who Have Drilled and Tapped Shift Knobs
- How Can I Remove Chevy NV4500 Shifter Knob?
- Vote: Yes/No/Risky....
- Hydraulic Throwout + Spacer Math
- Tranny or clutch?
- Just ordered my MGW Shifter: Install Update
- New Tick master cyl
- Went back to a stock trans mount.
- Fastest Six Speed List
- My new brilliant Aussie-designed Mantic Clutch kit for my Whipple'd 590rwhp Camaro
- Tranny grinding after clutch install.
- Manual Transmission to hold some Torque
- monster fly wheel
- Which pilot bearing do I need to use?
- slave shiming prob
- Stock clutch took a dump......
- Mantic 9000+ Twin Clutch Review
- short throw shifter
- trouble shifting into 6th gear
- Banging transmission/shifter
- Any Experience With F1 Flywheels?
- Need help!!!
- rear output seal! HELP!
- I will be needing my T56 rebuilt by who RPM or tick performance
- Future Clutch Swap
- Serious Pilot Bearing Problem
- is the only way to check tranny fluid in a T56 2002 from under the car?
- Slow RPM drop
- Tick master instructions for 98-02 fbody.
- Trouble with 3rd and sometimes 5th
- prestone dot 3 to 4 swap?
- Pedal problems
- LS3 Clutch from 2010 Camaro fit in LS1 F body?
- Monster Clutch Twin Discs-Released!
- Weird T56/clutch issue - won't go into gear.
- Sprung or unsprung clutch
- How to remove PITA reverse thrust washer?
- Reuse Pressure Plate Bolts?
- Popped out of 5th, got stuck in 6th...
- Add another person happy with TDP!
- Trans issues look at pics guys.
- Lt1 T56 Throw Out Bearing Help
- Tick master cylinder
- 99 ws6 5.7 a4 to 01 firewawk 5.7 m6 need some help
- Reverse trouble
- T56 GTO VS Magnum lenght. Exacly dimensions
- LT1 t56 trans to bellhousing bolts???
- How is this bleeder operated?
- trans cooler
- Still grinds after Rebuild WTF....
- bleeding help?
- Brass pilot bearing
- T56 grinds into first gear
- ls1 transmission question
- Slave Cylinder Question
- transmission not coming off of engine, 1994 trans am lt1
- T56 clutch will not release with Spec 3 or ls7 clutch
- Quick disconnect? 'S
- Not synchro?
- Need a 5th drive gear ASAP..where to get one??
- Quick help please
- slave to long
- where are the leaks comming from? pics inside
- 3rd gear shift probleme
- Late engaging clutch = new clutch?
- lightest road race clutch for a T56
- Is this an LS or LT T56? Pics inside
- Bleeding clutch, getting fluid buy no pedal.
- RPM transmission rebuild?
- Lt1 clutch won't disengage suddenly
- Shifting woes...
- clutch recommendation
- did ZO6's have the same clutch problems like f-body's
- T-56 yokes
- Trans swap
- t56 identification with pics
- T56 Manual... Is it just me or....
- Trans swap
- shift lever hitting boot frame
- Monster Level 1 Clutch & Flywheel
- PO803 (1-4 Upshift Solenoid) NEED HELP!! THANKS
- LS to Saginaw question
- Illuminated shift knob
- VSS Hi-side wire?
- Monster Clutch Co. After Fathers Day sale!
- SPEC 3+ grabbing near the end of engagement?
- Monster Clutch is hard to fully disengage
- Shifting Question
- Hydraulic line wont go back into slave, need help asap.
- Where did you get your LS7 Clutch?
- New Monster slipping?
- What is a LT1 T56 worth?
- can a T56 take a 1 piece prop ?
- T56 rebuild
- textralia clutch rebuild?
- Monster Stage 2 update!
- LS7 Clutch Pros N' Cons
- My car will not go into gear, any ideas?
- Me and my girl need some help! Clutch/tranny issues
- Shifter moved drastically
- $100 off Monster Clutches @ Lashway!
- 03 Z06 Fidanza Short Shifter Review/Video
- master cylinder question
- Tick Master Hyrdraulic line fitment
- t56 what is this noise *video*
- Which sponsor to get Mcloed RXT twin disc clutch
- Tremont55
- LS2 GTO Clutch decisions
- F body clutch issues..
- Are are clutches/flywheels the same for all T56's?
- Looking For A Recommended Tranny Shop - Schaumburg IL Area
- Clutch pedal losing pressure?
- Made my own clutch lines, part numbers inside
- How to get Master Line out of the Slave??
- Clutch chatter/ high RPM shifting issues.
- Clutch problem and its driving me NUTS!!!!!
- T56 Won't Go Into Gears (Pops out of Reverse)
- Shifter/Trans Rise when on gas
- LT1 to LS T-56
- LS1 pressure plate bolts - identification
- HELP!!! slave cylinder problems
- Ordered my tick master cylinder!!!
- T56 vibration then no gears.....
- t-56 2nd gear synchro
- Tranny rebuild.
- Cant get tranny to line up!!
- Remove Transmission and Bellhousing Together?
- slave shim question
- Clutch fluid?
- what fitting for GTO slave cyl.?
- Advice??! Drop transmission WITHOUT removing exhaust?
- Clutch recommendations (Twin disks?)
- t56 1-2 blocker ring and synchro sloppy
- while depressing clutch bleeding?
- Why can't I shift my car fast?????
- Anyone with Tick MC installed, picture inside
- Doing clutch next week, more shims needed?
- Can the drill mod be done without removing the master cyl?
- Flywheel Bolt Torque. Not the usual question...Sort of
- Reverse bleeding master cylinder?
- Is this possible?
- Monster level 2, Tick master- 50 mile review...
- Clutch for my H/C ls2 in 93 rx7
- Is the POWERGRIP HD the clutch for me?
- Aftermarket shifters
- Clutch job
- T56 help please.
- pressure plate issue
- t56 shifter gasket set , any used it .
- Price range for 6 speed conversion
- warmed up grind
- Spec P-trim twin disc Daily Driver?
- Help! Only have about 1-2" of clutch engagement...
- Super T10 popping out of 4th gear
- clutch/stick feels weird no leak
- Clutch finally bled but small issue shifting in 2nd.
- in need of a new clutch, need opinions
- T56 Bearing and Shim Kit - Where to buy single parts?
- Thanks to tick and monster!!!
- T56 issue. help please
- Tight budget. Opinions wanted
- Z06 Fidanza Short Shifter
- ??? something broke hear me out **(UPDATE Broke output shaft w/pics)**
- In need of a t56 rebuild
- Lost 5th and 6th Tore my T56 Down: Opinions Needed
- Clutch is sticking to the floor. Just bought a RAM adjustable Master and have Q's!
- GM T56 Quick Connect Clutch line converted to fit Wilwood Master
- Monster race clutch/Tick master-pedal problem
- Tranzilla magnum
- Adjustable Tick MC Question
- Slave Fittings and Lines
- Monster or Spec? what do you guys think?
- Where to get Clutch Fluid Reservoir cap?
- speed @ 6300rpm
- thanks ws6.store!!
- Reverse Lockout wiring
- can't down shift from 6th to 5th?
- adjustible factory type clutch master cyl.
- stock shifter stick
- C5 Vette Clutch suggestions
- t56 swap parts, best place to find?
- clutch sticking to the floor, or getting very hard????
- GTO offset lever and shifter
- faulty shifter or is my transmission dying on me?
- Can't get the clutch to even begin bleeding
- swapping clutch and tick master this weekend couple of ?'s
- clutch and headers install question
- Looking for Diamond clutch Reviews
- what trans gaskets to change while trans is out? (PICS)
- Pedal drop
- Slave Cylinder ?
- Torn down trans, help me figure out what needs to be replaced
- needing clutch reccomendation for odd setup
- Recommendations? Slave failure? LS7 clutch kits?
- Textralia Clutch Disc
- Wanting a monster stage 2!!
- had engagement issue with centerforce dual friction clutch
- T56 to bellhousing bolts
- 2008 corvette ls3 50km stock clutch is slipping
- I dropped the bleeder screw in the Tranny. How to get it out
- Ram twin disc need dowels?
- how can you tell if a t56 is bad when its out of car! before you buy it
- Clutch decision help
- cant get into gear
- Clutch Headache
- clearance issues?
- Stupid skip shift!!
- Best Organic style clutch ??
- Popps out of gear
- Creeping in gear...
- Help Diagnosing Clutch issues...
- Can syncro assemblys be installed backwards?
- tick adjustable clutch question
- CTSV/ LS1 slave cylinder questions
- *Torque Converter making knocking sound* not sure why
- Clutch disengage issue (weird)
- Got a New Shifter!
- Drill Mod yes or no?
- Good news "I think?"
- New clutch
- t56 recommended fluid/ amount. built from tdp
- problem getting into gear
- Elusive Sachs NFW1050 Flywheel
- Tranny filling
- new synchro problem
- LT1 to LSX tranny questions
- T-56 Rebuild Question
- T56 Sealing Ring on Main Shaft
- 96 Lt1 T56 REBUILD HELP NEEDED!!
- Timken Output Shaft Seal
- LS7 Clutch ?
- Mgw shifter issues still not resolved new transmission
