View Full Version : Manual Transmission
- how does a dual disc clutch work
- RAM powergrip HD stage 4
- M6 drag guys get in here...
- T5 Clutch adjustment
- What Clutch to get?
- sure could use some help troubleshooting...
- clutch problems....or i think...help fast!!
- For racing which is better short stick or..?
- Clunking, banging?
- adj master cylinder
- McLeod SFI bellhousing installed...pics/info within
- New clutch in, but pedal sits low and grinds
- What's up with getting the clutch master out!!!
- Is the exody triple disc out yet and who has one?
- clutch decision
- Problem with clutch return spring, need help
- Need help deciding on clutch, narrowed it down
- Is this an aftermarket hurst unit? Please help
- customer service on ram clutches?
- Anyone heard of Luk clutches?
- Shifter Boot
- Are Gear Sets Interchangeable
- manual transmission for truck
- Shifters
- wondering whats goin on...
- Running a Jerico?
- What fluid for new tranny?
- Are ram clutches good on LT1's?
- Do you have to replace Slave Cylinder -w- Clutch???
- 2nd gear help
- What are you road course and circle track guys using for a clutch?
- installation of shift light
- Quick Stick or LSS
- Are SPEC stage 1's any good?
- clutch and throwout question.
- Spec 3 shim or no shim?
- Hays Steel Billet Flywheel?
- who else makes shift knobs?
- HELP!!! What shifter to choose
- clutch question
- 2nd blown slave in 2 days
- How hard is it?
- converson
- drivetrain question=@390rwtq
- What else is new... Clutch problems!
- Problems in the Tranny
- whats a good short thrower shifter
- Trans mount question
- what does this sound like
- clutch advice ?
- swap help...
- Well, put in polyurethane trannymount and....
- requesting comments on shifters
- prob with short shifter
- Should the hydrualic line going into slave cylinder move?
- suspicious noise under my right arm
- Good grief, spec stage 3, 3i now the i is f...
- wheres the cheapest place for a 2002+ Z06 clutch?
- Anyone bought a T56 from ESP101?
- Pro 5.0 Question
- bleeding clutch problems... HELP!
- Z06 clutch can hold 490 ft lbs!!??
- Clutch sticking/slipping Need advice.
- Does anyone make/sell the solid slider keys?
- Help me to buy a T5 WC transmission.
- UMI short stick with pictures
- What kind of clutch to get?
- Tailshaft Bushing problem
- Noise engaging 1st gear, only when cold?.?.?.?
- 6 speed reverse problems-HELP
- clutch problems
- downshifted into 2nd at 80mph!!!!!
- Hard shifting, Need Experts within...
- 500rwhp ok on a stock T56 in a truck?
- bleeding question
- How to remove T56?
- thinking about going m6 and junking the a3
- Need some help from the experts
- Clutch Engangement Point?
- Whats the going rate on a used T56?
- Christmas day problem!
- where to get the good rebuild kit for our m6's??
- short stick for hurst billet????
- Converting to manual from automatic
- another shifting problem
- Anyone running SPEC 5?
- SPEC Stage 4
- Ram Clutch Nightmare
- LT1 to LS1 T56 parts conversion
- Flywheel Help!
- T5WC on a LS1?
- 3rd and 4th gear acting weird
- aluminum or iron flywheel????!!!!!
- Pro 5.0 question
- What's Wrong With My Tranny!
- T56 third gear and drill mod question
- Does McLeod make good clutches?
- Help with vibration
- pro 5.0
- LT1 hydraulic upgrade?
- what a mess-this sux
- I'm going to put a Mcleod bellhousing on soon...I'll document it for everyone
- Where can I buy a Jarrods Short Stick?
- Cartek clutch anyone using it ????
- What You Guys Think Of This One...?
- M6 with Spec stage 3
- Ram 910 vs 980
- BAD rearend noise!
- Is the hydraulics upgrade on the Spec Stage 3 necessary ???
- salve problems please help
- Clutch problem
- What clutches are SFI approved?
- Manual gearbox and 1000bhp+++
- New T/A with a squeaky clutch
- Z06 Clutch Kit p/n?
- What kind of Power/Torque can a t5 take?
- Weird noise
- new clutch????
- Will a 168 tooth SBC F/W work with the LT1 T56
- squeeking noise from clutch when letting it out
- grinding often
- High RPM Shifting
- McLeod Slave Cylinder (Yes Slave)
- Exedy multi plate clutch vs. Spec Stage 5
- How many clutches have u changed?
- What's the part # for the LS1 hydrolic line or where to get it???
- help with tranny please
- LSS Bolt size
- Help With Tranny
- Z06 clutch on a F-body?
- Noisy clutch...
- Clutch Bleeding
- Build a pressure bleeder for your clutch.
- Z06 Clutch !!
- What clutch.. ( I know.. I know..)
- skip shift
- Toughest Tranny for Trans Am
- SPEC S4F is in and the test drive went well
- Will T56 bolt up to a Big Block??
- Pro Shifted Broke Clutch.
- Where to buy a stock GM steel flywheel?
- Bump stop ?'s with the Pro 5.0
- 99 Black 6-speed Trans Am
- Ram Powergrip and Powergrip HD Special!
- what is your rpm?
- my clutch replacement checklist...
- where to get tranny rebuilt
- Steel Shift fork broke!
- Want cam, but clutch says, "me first!"
- Please Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- spec III noise
- spec 1
- Has anyone ever had problems with a mcleod twin disk before?
- Help! High pitched whine!
- Spec Stage 3 Break in period
- Which clutch should i get????
- Car Back From Speed Inc!!!!!
- Possibly a rear main seal leak and syncro problem
- T-56 conversion???
- Master Cylinder????!!!Slave???!!
- clutch pedal sticking???
- shifter wont move side to side?
- clutchless tranny for street?
- clutch sticking to floor, what to check/change?
- Snap ring part #'s ??
- Need clutch advise, any kevlar discs & heavy PPs?
- slave is out and on my desk, which one is it? update or no?
- 1-------2 Help!
- Know nothing about...please help?
- Double Clutching?
- TTP A-K Stage 3 T56 Transmissions
- Spec stage 3F
- ???????????When do I need to rebuild the T56??????????
- What mods would you do to a stock M6?
- wtf is the deal with my clutch and 5th????
- 01-02 master cylinder with 98-00 slave?
- shifting into 5th at the track (T56)
- Ram Clutches On Special & In Stock @ TSP!
- Weird vibration/shaking from tranny....
- T56 Trans. Fluid
- g-force tranny?
- 2 Issues, hesitation, and a knock.
- Tranny Problem?
- Pro 5.0 springs are too weak
- T56 Tranny Pretty Damn Tough
- bet you never heard this happen before
- HELP! bleed clutch how to
- Clutch Pedal is really soft
- Cheap shifter mod/fix
- Clutch Sticking?????
- looking for part number
- Help with main shaft...I think?
- tranns question
- Speed Inc and Trans Work????
- ZO6 clutch with 99 slave cylinder and drill mod: enough or should I upgrade?
- Prothane tranny mount
- Drill Mod?
- Clutch Sensor???? WHere is it????
- Z06 clutch guys come in
- really NEED HELP.. my car is messed up and dont know why
- Has anyone ever converted a A4 car to M6??
- Quick Clutch Question
- How much work to replace just the SLIDER KEYS?
- Clutch advice?
- transmission mount problems
- NEED ADVICE QUICK! Clutch and trans out!
- clutch gone wacko
- Clutch/ tranny problems
- clunk in rear end of GTO
- mba knob question
- Some Clutch Questions...
- Getting flywheel off....
- Car stuck in gear
- Am I missing any parts for a clutch(+ everything else that's in there) replacement?
- My luck doesnt change, guess which clutch
- M6 Not Going Into Reverse
- New clutch=problems for the rear??
- Should i get a flywheel???
- Stock clutch thickness?
- Crazy grinding sound from clutch/tranny - help please
- stock flywheel or light weight alum one???
- What is a good clutch?
- Drill Mod?
- Where is the cheapest t56 conversion kit?
- LT1 clutch problems
- Something broke. Any ideas?
- Updated Slave??
- Rebuilding Trans
- Double wammy doh!
- Clutch problems
- Convert a 67 camaro 4 speed to a T-56
- Guys with MBA Billet shift knobs come in!
- i need a new pilot bearing is the ls1 bearing the same as the other chevy v8s?
- Shift Knob Questions
- best clutch for my mods?
- 6-speed swap help
- Odd problem with McLeod MC, Inside Please.....
- lt1 ls1 flywheel and clutch difference? What do I need
- Clutch engage/disengage point is 1/2" off floor...what to do?
- bell housing t56
- tranny or clutch problem
- cool link on how to rebuilt a t-56 Son!!!
- tranny
- UMI Short Stick - Recommended
- Launch techniques
- Which Short Stick?
- Power shifting?
- How hard to shift?
- camaro 98-02 manual gearbox
- Reverse light?
