PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. new clutch..
  2. throwout barring???
  3. Z06 clutch ?
  4. 6-speed transmission corvette C5 - Camaro LS1 the same?
  5. Need Help
  6. SFI T56 Bellhousing
  7. centerforce are strong
  8. T56 Swap into NBS truck?
  9. slp or pro 5.0
  10. Is my 5-6 speed gear messed up?
  11. how can i build my own bullitproof T56?
  12. help
  13. so confused...
  14. Slave & TO Bearing numbers?
  15. 4.10 ET gains
  16. tips on driving manual??
  17. bang... and now wont shift.. what the hell?
  18. M6:Grinding noise when i accelerate?? Help!
  19. New Procedure to bleed the hydraulic system
  20. Where to buy Trans mounts?
  21. transmission yoke
  22. Killin Me!!!!
  23. ?Tremec Transmissions? How accurate is this?
  24. Is the T56 out of cobra same as camaro?
  25. Anyone ever order a New GM slave from Spec?
  26. Good trans shop in Eastern NC?
  27. With MeLoed clutch, pedal all over the place.WTF?
  28. hurst billet plus Q
  29. Whats wrong with my clutch??
  30. tranny grinding when coming to a stop
  31. 1st gear bog down???? HELP???
  32. Are there 2 different McLeod Master cyl.?
  33. Problems with shifting at high RPMs
  34. and my clutch install saga begins...
  35. Is an M6 stronger than an A4?
  36. rear bushing in T-56
  37. 2nd Gear Slip
  38. Line Lock Users Come Inside
  39. lookin for rebuild?
  40. First Drive Since Pro 5.0 Install
  41. wheres a good trany shop in CT?
  42. Stock feel clutch?
  43. Part Number For Gm Mt Synchromesh??
  44. About to order textralia clutch, any reason not to?
  45. Manual guys - what RPM you usually shift at in normal driving
  46. help with problems after tranny swap
  47. spring broke on clutch pedal
  48. Bad Slave Cylinder
  49. New Transmission Fluid
  50. part # for clutch alignment tool.
  51. Help, mushy clutch, how do I re-route line to solve the problem?
  52. can't downshift from 6th to 5th
  53. fidanza shifter?
  54. good clutch for oldschool?
  55. problems with t-56 after a day at the track
  56. Identifying Transmission...
  57. Short throw
  58. LS1 4L60 to T56 SWAP Guide
  59. Well I took the Tranny out and...
  60. Burn out?
  61. Vibration At high speeds.
  62. A4 to M6 pedal question
  63. clutch went down south...... help please!!
  64. second gear help!!
  65. really hard to get into gear
  66. new z06 flywheel with spec ok?
  67. How much power can you throw at a T56?
  68. Shifter Shaking like...
  69. Clunking noise after I shift
  70. Shuddering.....
  71. New owner questions
  72. stock flywheel and spec 2
  73. Trying to handle 600rwhp?
  74. z06 gear box question
  75. Did I just get owned by a Trans Shop???
  76. Where to get my SPEC3 and LS6 slave/MC
  77. phase 2
  78. Brand new SPEC III slipping.....help!
  79. Anyone else afraid of their Pro 5.0 shifter?
  80. Shifter whine
  81. Won't go in gear
  82. Identify This Tube In The T56 Tranny
  83. T56 or ZF 6-Speed?
  84. Master Cylinder Hole
  85. Spec Stage 4 and Flywheel
  86. are these the correct GM part numbers for master and slave?
  87. Pulling the Trans
  88. the plastic white cup under the shifter
  89. changing clutch master cylinder
  90. centerforce
  91. pilot bearing help please
  92. Dropping a T56 in an Auto
  93. Pro 5.0 upgrade
  94. How do you tell if....
  95. Spec 3 friction disk
  96. Any1 made a T56 Drill Mod Write-Up?
  97. clutch upgrade 2001 ta
  98. slave line
  99. anyone wanna trade t56 for my 4l60e? NY,will drive 2 trade
  100. Nos
  101. RAM HD Installed
  102. slipping
  103. the truth about spec?
  104. zo6 clutch
  105. PPLS choice on clutch kits
  106. Stock ADJ master cyl?
  107. T-56 rebuild 700+rwhp??
  108. What RPM do you shift at while racing?
  109. new clutch?
  110. Help with removing transmission
  111. spec install
  112. how to add fluid?
  113. Buying a used spec stage 2
  114. Spec 4 clutch/SLP flywheel install, rubbing pressure plate!
  115. LT1 to LS1 t56 swap
  116. Grinding noise at high speeds
  117. Help:Ran Engine Without Driveshaft, Now oil on floor
  118. T-56 Lost 2nd Gear
  119. new clutch or just bleed the system?
  120. Pilot Bearing Question
  121. 98 z-28 6-speed help please
  122. Questions about McLeod clutch master cylinder
  123. Updated hydraulics from dealer?
  124. luk clutch kit?
  125. Where to get a trans rebuild in NJ for t56?
  126. Help
  127. Clutch install problems
  128. Why would 5th and 6th go
  129. Ram HD clutch in
  130. bushing part number
  131. Dissegagement problem
  132. Bolt on Daily Driver, Z06 or Textrailia?
  133. Aluminum Flywheel
  134. T56 Rebuild
  135. Sequential replacement?
  136. 1st gear ???s
  137. Do I Need New Clutch?
  138. Changing for an auto to a 6-speed
  139. Textralia clutch is in...WOW!!!
  140. problem with reverse
  141. slave cylinder pictures
  142. how much is too much?
  143. McLeod MC braided line
  144. reverse locked-out
  145. transmission noise
  146. Trans will just NOT go in no matter what.
  147. Slave Cylinder for 2000 SS
  148. Spec Stage 3 clutch NEED HELP !!!???!!!
  149. grinding if not at a stop in 1st????
  150. Quick Question about McLeod Adjustable Master Install
  151. T56 casting numbers
  152. Transmission mount ?
  153. a4 to m6 swap computer question
  154. need part number
  155. Which sponsor is selling the Pro 5.0s w/Lou's short stick?
  156. Double shifting?
  157. A.s.a.p Help A.s.a.p
  158. Grinding going into third
  159. ok-order a new spec 3 and steel flywheel
  160. 1st gear jerks at acceleration
  161. hurst???
  162. what clutch..and what parts??
  163. Tourqe issues ?
  164. M6 transmission giving me hell in reverse
  165. Help....Right Away
  166. clutch question
  167. Should I convert to M6?
  168. Got Myself an Aussie Clutch
  169. what needs balancing?
  170. Clutch is wasted lol
  171. My m6 grinds
  172. Correct Updated GM Clutch Master Cylinder Part Number?
  173. Flywheel
  174. is it possible for a PP to move around?
  175. McLeod M/C adjusted all the way out.......
  176. best place to get a spec clutch?
  177. B&M Ripper Noise
  178. Do I just need the drill mod? Or do I need tranny work too?
  179. Who has UMI short stick??? Opinions wanted!
  180. Z06 3rd gear
  181. T-56 in Southern CA
  182. Fixing mcleod master with rebuild kit...
  183. strange noise
  184. clutch question
  185. Getting tranny in
  186. t-56 flywheel
  187. clutch blowup problems
  188. Help !!
  189. Centerforce installed
  190. help my T56 is stuck in 4th
  191. Z06 clutch install - What do I need?
  192. Clunk?!?!
  193. Question about Noises after Tranny Mount Install
  194. Trouble with Slave Cylinder ( Need Help / Advice )
  195. brock in spec 3
  196. What side of Shifter does short stick go on?
  197. Installing Tranny Mount Tonight..Any Advice?
  198. Turbos and Trans durability
  199. Hurst billet plus install ?
  200. Problem with reverse
  201. Ram Powergrip install
  202. donno if its just the disc?
  203. hey guys SLP or PRo5.0
  204. How does an adjustable MC work?
  205. Pro 5.0 RATTLING
  206. bellhousing...
  207. Spec clutch question-shim
  208. Got my T56 back from D&D today
  209. 98 and 01 6speeds
  210. DID i break my TQ arm?
  211. Spec Stg 3 Clutch - Slipping?
  212. is my trans ok?
  213. Leaking Quick Disconnect- different colors?
  214. Newbie needs some help
  215. power shifting
  216. Which T56 fluid?
  217. Trans Problem
  218. Where to buy Spec clutch?
  219. Spec Stage II Question
  220. Trans Fluid and bad synchros Please help!!
  221. LS1 Aussie Clutch?
  222. Clutch Engagement???????????
  223. Clutch installed over the weekend, NOT fun...
  224. Recently installed Bendix slave cylinder....thoughts. (No pics)
  225. T56 Speedometer question
  226. Just ordered the spec3 clutch... what else???
  227. SPEC'a new shim question
  228. need help with my 2000 c5!
  229. new clutch still slipping
  230. 3-4 Shiftfork actually bent?
  231. T56 problems
  232. pro 5.0
  233. No Clutch Pedal Pressure - LS1 RX7 & Wildwood Master
  234. new to this but need help
  235. Does Spec 2 clutch come with pilot AND throwout bearing?
  236. McLeod Adjustable master Rebuild
  237. Mother ()*&#%(* FREAKIN P#%()#$( PIECE OF @)($*(*$ Stupid Clutch, Stupid Car
  238. Pilot Bearing NIGHTMARE!!!!!!!!!!!!!!!
  239. Replacing clutch on 01 Z28 w/31k miles. Change throwout bearing or not?
  240. pilot bearing seating
  241. Whats the best way to go
  242. Spec ?
  243. ALL McLeod LS1 Hydraulics (Master and Slave)
  244. anyone make a t56 rebuild movie?
  245. In middle of clutch install, need quite a few tq specs, pls help!
  246. 2004gto and 2001 trans am t56
  247. Tranny problem...Time to rebuild!?
  248. Spec stage 3???
  249. spec stage 3 noisey
  250. Where to buy rebuild book for T-56
