PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Motor swap have questions
  2. Does the T56 have internal shift stops?
  3. Installing clutch switch
  4. Spec clutch???
  5. Hard 6th gear engagement....HELP!!
  6. tranny
  7. trans parts questions?
  8. Late shift
  9. Anyone have a broken T56 input shaft?
  10. how much for a master cylinder install
  11. Clutch work needs to be done...
  12. neutral safety/clutch switch problems (want to remove it)
  13. Clutch stuck after Trans replacement
  14. McLeod adj. master- air in line question- not your normal "gotta bleed" thread
  15. ??? about spec5 clutch
  16. Shimming RAM HD
  17. Down shifting question
  18. Centerforce Are They Anygood
  19. question about gears and what happens when it grinds
  20. Part number? and need info
  21. Torque arm bolt
  22. synchro going?
  23. clutch pedal stop
  24. Centerforce Counterweights?
  25. what kind of clutch do i have???
  26. Slave cylinder or clutch problem?
  27. Powder coated my short stick
  28. Need Help
  29. T56 decode
  30. Where to get liberty Trans?
  31. A4 to M6
  32. ls7 clutch?
  33. What Clutch is Everyone Using?
  34. Question for fellow Pro-Shifters
  35. clutch line wont go into trans
  36. dexron VI ok to use?, dexron 3 phased out
  37. best clutch for a street driven 600-700rwhp car?
  38. is my master/slave going out?
  39. ss hurst shifter
  40. Spec stage 3+ won't disengage
  41. For those of you who shimmed your slave cyl's on LS7 clutch swaps...
  42. LS7 clutch torque specs?
  43. Of these 3 which is the best?
  44. Best Tranny out there?
  45. clutch help
  46. brand of atf for t56?
  47. No Fifth or reverse
  48. Textralia clutch users. In here.
  49. HELP!?!?!? I need to fine a hydralic line??
  50. 480whp z06 H/C setup - need DTE brace with "bullet proof" tranny?
  51. Dood im pissed.. anyone have this problem??
  52. AH my transmission went out
  53. Shifter question.
  54. Quite possibly the stupidest question ever
  55. Question
  56. Grinding Noise when i let clutch out!!!
  57. Can't put into gear
  58. Need Help Quick!!! Clutch install
  59. Clutch vibrations go away with break-in?
  60. Driveshaft length with M6 and 9" needed Please
  61. Ws6 Stores Short Stick,What You All Think?
  62. z06 tranny in an f-bod?
  63. Heli-coiling Aluminum flywheel ?!?!?!?
  64. Clutch differences between 97 & 02
  65. can i race with clutch sticking problem
  66. Shimming a Textralia
  67. chatter after spec stage 3 install
  68. Pedal Play
  69. is there a plate between the block/trans?
  70. B&M RIPPER NOISE!!
  71. Which of these clutch sets would you guys pick?
  72. new clutch
  73. Clutch travel after drill Mod
  74. Anyone ever fix the clutch stuck problem?
  75. did i get screwed or am i confused??
  76. Mc Cloud Adj. Master
  77. Clutch woes...Need some help
  78. Another ls7 clutch post (flywheel?)
  79. Good budget clutch?
  80. ls7 clutch and ls2 flywheel
  81. Where to get an input shaft?
  82. Need a clutch
  83. Clutch Pedal Spring....Where to Buy?
  84. grinding with my t-5
  85. what tranny???
  86. Clutch Problem?
  87. Clutch questions...air in Master or possibly flywheel bolts backing off? (Kinda long)
  88. T56 Shifter option !!
  89. Mcleod twin disc/built t56
  90. What are some tips for long clutch life?
  91. please answer this diffecult question!
  92. clutch, flywheel, pressure plate procedure/hours
  93. T56 Rebuild
  94. clutch Replacement
  95. More Pre-Clutch Install Questions
  96. Which clutch
  97. some thing broke on my master..
  98. LS7 Clutch Flywheel Recall
  99. strange noise from under car???
  100. Which harness goes to the Reverse Solenoid
  101. Differences in Slave Cyl
  102. Drill mod
  103. Clutch "break in" question
  104. Hurst Billet Plus shifter question...
  105. Clutch problem
  106. M6 Driving tips
  107. Shift lights?
  108. LS7 Clutch Info
  109. help with spec to shim or not to shim?
  110. What clutch do I have?
  111. Anyone spraying on a Ram HD?
  112. New McLeod clutch is sweet!
  113. Dropped socket in bellhousing bleeding clutch
  114. torque spec on bellhousing bolts
  115. B&M Ripper
  116. What should I do?
  117. New Clutch
  118. Clutch sticks to the floor once hot
  119. Time to flush. Recommendations on fluid please.
  120. Explain the problems with t56 trans?
  121. Help, Clutch Install
  122. clutch issues
  123. a bit worried
  124. my 6-speed
  125. Need a new clutch soon.....help!
  126. C5 FRC stock clutch limits
  127. HELP! Bellhousing stuck to motor! How do I remove?
  128. T56
  129. Ebay shifter
  130. Shift boot and console top for A4 to M6 swap
  131. 97 brakes on a 98 ss
  132. SPEC 3 help please...Have a few questions....
  133. This F@#$ing Sucks
  134. Poly tranny mount, won't bolt up
  135. Diagnose this problem
  136. HELP! How do I know if my motor/tranny mounts r shot!?
  137. Clutch and rear end problems... PLEASE HELP!!!
  138. LT1 t56 rattle TO bearing?
  139. Spec Stage 1 clutch + Stock Flywheel?
  140. Push or Pull Clutch?
  141. i wanna change my shifter knob out
  142. Power Bleeder
  143. Who makes a good built t-56?
  144. LS7 clutch limitations
  145. Ls1 stock clutch info
  146. Is a Spec Stage 3 clutch going to tear up my M6?
  147. Shift delay with new clutch
  148. 2000 Camaro messed up after wreck...
  149. clutch fluid flush
  150. trouble to reverse
  151. Cheapest place to buy Slave cylinder
  152. *Update RAM HD installed*
  153. Lowest cruise speed for 6th gear
  154. Balance the ls7 clutch/pp and ls2 flywheel ?
  155. Shift Selector Assembly/Rail Pics
  156. to bearing
  157. Bellhousing Question
  158. Shift Boot Retainer Ring
  159. Clutch chatter when clutch is out and in neutral?
  160. How have you shipped transmission?
  161. vibration at 3000 rpm
  162. LS6 Clutch Reviews
  163. t56rebuilds
  164. Components to a WELL built T56?
  165. Clutch master cylinder same for C5?
  166. slp shift knob removal
  167. Anyone use the SLP short shifter?
  168. How much money does a ......
  169. get good lauch with my m6 is hard
  170. Pre clutch install q's.
  171. Found something interesting while rebuilding
  172. ARP clutch and flywheel bolts..
  173. New Flywheel WS6 OLD FLYWHEEL IS TOTALED!!
  174. How many are running the ls7 clutch right now??
  175. notchy shifting?
  176. Clutch pedal problem?
  177. Should I replace the slave cylinder
  178. shifter choices
  179. Tranny build and shifter choice
  180. flywheel bolts?
  181. clutch diameter
  182. Noise@2800+ rpm ????
  183. Shifter or Springs?
  184. Am I shifting wrong? WOT technique
  185. Squeak while textralia clutch is engaging
  186. 2001 slave cylinder?
  187. Part number for Pilot Bushing??.. not Bearing.
  188. Slave problems
  189. Code P0704 Clutch Switch Circuit
  190. Torque Management ?
  191. Can I get opinions on this...
  192. ALUMINUM FLYWHEEL Is it worth it?
  193. Whats the Diffrences between an alluminum and billet flywheel
  194. Time for a new clutch...is the ls7 the best way to go?
  195. Fluid to run in a m6
  196. Tranny Upgrade and Shifter Choice
  197. heres a good on for you guru's Please Help S.O.S.
  198. LS6 or LS7 clutch
  199. Carbon Fiber Driveshaft
  200. Strange clutch pedal feel after slave swap
  201. Transmission leak, Rear Seal Swap?
  202. Got my engine as a goodie bag, what clutch is this?
  203. SS shifter
  204. Custom Hurst Shifter Handle
  205. hydraulic ????
  206. Jumped out of gear...
  207. Clutch not releasing
  208. Anyone wanna trade M6 for A4 conversion
  209. Not your ordinary bleed question. Oh the noise!
  210. which fluid do you use?
  211. Clutch ?????
  212. Problem after clutch install
  213. Flywheel Dowel Pin
  214. T-56 wants to grind on the down shifts.
  215. sequential manual tranny
  216. Adjusting my master cylinder and the retaining clip FLEW OFF!
  217. Which Gm Clutch For Lt1 Car
  218. were to buy cheap stock clutch?
  219. tough to get in reverse
  220. Urgent...need Help Quick ..
  221. clutch bleeding issues
  222. Clutch problem on daily driver.....need help!
  223. Textralia 1000-mile Checkup... PICS & Concerns
  224. BBC with LS1 t56
  225. help just installed new clutch etc and having shifting problems
  226. Spec Question
  227. T56 trans to bellhousing bolt thread pitch?
  228. Where to buy shims???
  229. Help!!
  230. leaky slave
  231. Textralia install
  232. guideplate/shift selector
  233. t56 flywheel weight?
  234. Problem with M6 after 2 hour trip!
  235. Replacment disk for RAM HD
  236. torque specs
  237. Shifting at wot
  238. Ram PowerGrip HD for those interested
  239. what socket will fit the t56 clutch slave bleed valve?
  240. T56 Rebuild Article in Popular Hot Rodding
  241. RPM's
  242. Problem with spec install! HELP!
  243. Part numbers for 01+ slave and master?
  244. Can i run factory turned flywheel with Spec 5
  245. How important is a new flywheel w/a new clutch kit??
  246. Early Engaging Textralia Clutch... Solutions?!?!
  247. No more black/gunky hydraulic fluid
  248. master cylinder problems
  249. Will drill mod fix my clutch sticking problem
  250. Clutch and bellhousing for 900hp
