PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Clutch Vibration After Install
  2. Where to get hard parts?
  3. What spline is the viper shaft?
  4. T56 trouble going into 5th
  5. Im screwed
  6. weird noise?
  7. WTF!!! - Textralia Exo-Skel Failure
  8. 02 C5 manual - No 2nd gear @ high rpms?
  9. Pilot Bearing Removal (the easy way)
  10. Master cylinder going out?
  11. tick master cylinder ?
  12. t56 slave cylinder fitting
  13. top speed in each gear?
  14. trans crossmember bolts
  15. Fidanza 6.5 twin disk review
  16. Can I use this fluid?
  17. Transmission issues..help- Video inside
  18. What are the signs of a pilot bearing going out?
  19. T56 Tech and Swap questions
  20. Which slave?
  21. Ram twin stock MC
  22. Need help t56 wont fit my ls6!!!
  23. Do F-body bellhousing fits on GTo trans?
  24. what clutch for my setup?
  25. Synchro assembly question
  26. LT-1 T-56 help needed
  27. Want SPEC 3 - Sponsors!!!
  28. Monster level 4 still chattering.15,000 mi.
  29. T56 goes in between 3rd and 5th gear?
  30. Spec 3+ / fidenza FW = vibration at 1st gear
  31. Need help!!!
  32. pulled the tranny today... found this
  33. Please look at this picture of my hydraulic slave line! I need help!
  34. will this work????? anybody done it??
  35. Synchronizers?
  36. should i rebuild or just get new tranny?
  37. Recommended Clutch Kits and questions
  38. Few questions
  39. Monster flywheel pressure plate bolt size??
  40. Transfer case shifts into nuetral all by itself
  41. T56 swap -- must-do's, and interchange
  42. ls3 motor/ls1 clutch,fw help
  43. Multiple T56 Problems
  44. Where can I buy a Built T56?
  45. The correct way to bleed the clutch hydraulics
  46. I need some dimensions on the ls7 slave
  47. Help clutch pedal on floor
  48. Dilemma. . . .Should I stay or should I go?
  49. clutch related or hydrallic
  50. rpms continue or rise
  51. LT1 Clutch suggestions
  52. isolating slave/master issue
  53. went for a road trip yesterday and have a few questions now.
  54. how much Horsepower/Torque can a T5 take?
  55. LS7 clutch need a break in????
  56. Clutch questions?
  57. Please Help With My Clutch Problem!!! :(
  58. Intermittantly not going into gear
  59. 8.1 BBC LS1 trans swap info
  60. Weird 3rd and 5th issue.
  61. boosted 408 t56 upgrades
  62. dumb ? on pilot bushing/bearing
  63. C6 vette...can't downshift from 6th to 5th
  64. 2000 F-body, Press Plate Broke, see pic
  65. t56 slave cylinder
  66. OK just checking only!
  67. Where to buy main cluster?
  68. Searched, found mixed answers - flywheel/PP bolt questions
  69. Transmission/Clutch Squeal! Help!
  70. Keep Blowing Slaves WTF.....Tick Master/Mcleod RST
  71. 61 tooth 5th gear?
  72. Shifting out of 1st?? Help Advice
  73. Disengagement issues with Spec Twin disc
  74. Called 2 Dealerships and nothing! Need Bolt information!
  75. McLeod Twin disc questions
  76. Hard clutch pedal
  77. Clutch Problem
  78. Just disassembled my T56. Questions?
  79. Mcleod twin disc grabs off way too high..spacers on transmission?
  80. stock t56 w/ 150hp no2
  81. will this flywheel work?
  82. borg warner clutch?
  83. shim problem?
  84. clutch issue?
  85. how much can the t56 handle?
  86. Clutch WILL NOT disengage at all!!
  87. Clutch/ tranny compatability question
  88. PROBLEM entering 1st and rev.
  89. Spec stage 2+ vs 3
  90. rattle when i let off clutch.. need some help!!
  91. LT1 T56 vs. LS1 T56 Which is better?
  92. T/A on the ramps...
  93. Spongy pedal issue
  94. Input shaft seal (LT1 tranny)
  95. Monster Stage 3 review.
  96. Just smoked my clutch on the dyno need options
  97. clutch/slave issue
  98. possibly a dumb ?
  99. Clutch Release Bearing Removal
  100. GTO Clutch
  101. How much play??
  102. what T56 goes on the L76
  103. Clutch Problem
  104. Spec 2 v. Luk Pro gold Clutch Kits
  105. Not shifting @ high rpm?? M/C problem??
  106. M29 transmission on an LSX motor?
  107. Quicktime bellhousing help!!!!
  108. LT1 Clutches, let's see them!
  109. strongest T56
  110. new tranny or rebuild
  111. Best overall shifter for my M6
  112. Tremec Magnum + Monster Stage 3
  113. Spec Stage 2 and 3 Driveability
  114. Vette T56 Disassembly
  115. why, does MC go bad?
  116. Basic clutch alignment question
  117. Clutch issue at WOT
  118. Vibration when I push in the clutch? (LT1/T-56)
  119. LT1 M6 Mcleod Clutch: Car moves with clutch pedal pressed in.
  120. ranger clutch care writeup
  121. wont go into gear
  122. short shifter
  123. T56 Wont shift into 2 4 or 6th
  124. Broken trans
  125. slave replacement
  126. Slave cylinder bolts
  127. mcleod street twin rebuild lt1
  128. T-56 mounting relative to tunnel
  129. Bought a Ram HD clutch...
  130. should iresurface my Tex flywheel??
  131. need t56 help asap!
  132. MN12 3-4 Synchro Removal
  133. monster stage 2 vs stage 3
  134. Installing new 1-2 synchron... NEED HELP!!!
  135. leaking seal?
  136. how hard can i push my t56??
  137. T56 Questions
  138. Clutch not fully realeasing, help
  139. FLT or Tick for an Fbody T56 rebuild
  140. help removing clutch line
  141. McLeod master question.
  142. Monster level 3 is here!
  143. A4 to M6 swap?
  144. Need Clutch Recommendation for under $500
  145. Monster release their twin clutch yet?
  146. which clutch/ best deal?
  147. Anyway to un-adjust a SAC LS7 pressure plate?
  148. Paging McLeod rep.....
  149. T56 rebuild help
  150. Anyone heard of this?
  151. Tranny knocking noise at idle...is this a problem?
  152. What fluid for the clutch hydraulic reservoir?
  153. Viper T56 behind LS motor
  154. Placement issues...
  155. C.r.s.???
  156. Does anyone know the part number to the T56 front cover?
  157. T-56 serious problems!!!!
  158. Wat after market flywheel n clutch wrks best ..
  159. One of these slaves is not like the other...
  160. how to build my t56
  161. LT1 trans am question
  162. Power loss with LS7 Clutch
  163. Bad speedo Gear? Video Inside
  164. Which T56 is this?
  165. Think i may have bought a Fake Hurst shifter..are t56's the same?
  166. This clutch work for an lt1?
  167. Monster Clutch or Textralia?
  168. T-56 Major Grinding
  169. getting the street twin to fully release LT1
  170. Monster clutch level 3 with lw/fw weight
  171. Best short throw shifter and place to buy
  172. gear noise
  173. AutoZone duralast clutch kit $159.00
  174. Clutch Bleeding Issue, Speedbleeder HELP
  175. T-56 Magnum
  176. mcleod street twin: loose sounding engagement?
  177. trans install problem
  178. Who makes a twin discs clutc setup for Higher HP
  179. indexing hurst shift knob
  180. Another clutch question
  181. T-56 rebuild
  182. Speed Adjustment on T56
  183. RPM transmissions in indiana?
  184. Stock Hurst Shifter Diameter TA 98-02?
  185. t56 servicing question
  186. vibrations at speed with poly trans mount
  187. t56 question
  188. Switching over from auto
  189. Shifting... the best way to shift into 2nd
  190. ES poly urethane tranny mount + stock rubber motor mounts = no no????
  191. Mighty Vac
  192. stock ls1 T56 bellhousing height????
  193. McCleod twin disc ?'s
  194. MGW is very noisy?
  195. Pedal isn't right after manual pedal install.
  196. what clutch to buy? who has the best deal?
  197. 2nd to 3rd grinds, but only when cold
  198. Is anyone rebuilding 5th gen TR6060's
  199. Clutch Break In
  200. Master and slave bleeding
  201. Problems getting into reverse?
  202. hard to get into gear
  203. LS7 clutch
  204. master line O-rings...
  205. will a t56 fit in the trunk of an F-body?
  206. 2010 Camaro Fidanza Twin Plate clutch Q's
  207. grinding in every gear
  208. Is balancing the pressure plate and flywheel necessary?
  209. prothane trans mount problem
  210. Ram PowerGrip HD driveability
  211. t56 help
  212. how to know ls7 clutch
  213. Clutch Barely Disengaging in the Morning
  214. Exedy Hyper Twin. Need some info/parts/dealers
  215. tick master and monster clutch sticky pedal
  216. Hard to get into gear when stopped
  217. Tuet2060?
  218. Reverse lockout on a4 to m6 swap
  219. Flywheel help!
  220. Spline count on TR-6060
  221. I cant get any clutch pedal pressure!!!!!
  222. Arrrgh! Second Gear AGAIN!
  223. Is the maincase trashed?
  224. built t56
  225. slave cylinder question
  226. cleaning the clutch disk
  227. Best/shortest short throw shifter?
  228. slack in hydraulic clutch
  229. Please Help!
  230. monster clutch chatter
  231. having to pump my clutch up after getting on it
  232. broke a mcleoud twin disc....
  233. LS9 clutch on a LS1?
  234. Bad slave??
  235. T56 bellhousing bolts?
  236. difference in standard and "+" spec clutches
  237. Cause for concern?
  238. easiest way to upgrade syncros?
  239. Odd grinding noise when clutch engages??
  240. ls1 driveshaft in lt1
  241. Alternate LS7 pressure plates?
  242. Pretty sure my trans is trying to escape...
  243. SPEC stage 3+ clutch
  244. Boot Retainer Broke - Any aftermarket Fix?
  245. grinding in reverse
  246. Smoothest clutch for 600-650rwhp
  247. Tick turnbuckle/rod adjustment
  248. Hurst Shifter
  249. t56 compatibility
  250. New clutch hard to get in gear
