PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 [103] 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Starting problem
  2. Rear main seal leaking oil? Have I ruined my clutch?
  3. Big Problem In 4th!
  4. Gettin an Ls6 Clutch, Which flywheel do i get??!?!?
  5. Need Bellhousing Torque Specs!!!
  6. T-56 leaking after synthetic Mobil 1??
  7. Cartek Clutch? Who has one?
  8. Is aluminum worth the extra cost
  9. For those with SS and WS6...
  10. help t56 problem
  11. Mcleod Master Cyl. Line Question
  12. what the most you are willing to spend on a new clutch
  13. LS6 Clutch (Off road only)??
  14. Clutch setup? Any Opinions
  15. Help with Tranny problems please
  16. Is it Worth buying a short stick for my stock hurst shifter?
  17. SPEC 3 spacer?
  18. My Spec Stage 3 Ceramic Clutch is dead!Have questions??
  19. Help....Clutch install
  20. clutch cleaning question
  21. How do you bleed the clutch Using MityVac
  22. shifter?
  23. Spec clutches
  24. 2nd gear locks me out
  25. Clutch Pedal Slop....Need help!
  26. 500rwhp clutch choice?
  27. which clutch to buy...
  28. 02 SS stock clutch??
  29. So how long do you guys think my stock clutch will hold?
  30. stock 99 z shifter vs Stock hurst?
  31. Problems, noises, and grinds, oh my!
  32. Need a quality clutch-SLP?
  33. drill mod qustions???
  34. Harlan Two Step
  35. New Website is up and my new toll free number
  36. Spec 3 vs. LS7
  37. Short stick on stock shifter?
  38. HOLy crap Bellhousing! help
  39. bad news
  40. Any tips for installing new clutch/pp/flywheel?
  41. Slave quick disconnect..
  42. grinding noise ?M6
  43. T56 value
  44. New to transmissions, gotta few questions..
  45. resurfacing flywheel necessary???
  46. i need a clutch.....help me choose
  47. need help on Reviars for my T56
  48. Clutch help... Pretty easy question...
  49. trade shift kitted A4 for m6
  50. oh no, my clutch is gone
  51. m6 conversion people ecu flash
  52. Shifter ?
  53. part number for slave cylinder
  54. what size is the clutch master?
  55. LT1 and LS1 T56 differences
  56. 4spd. tranny
  57. Big thumbs up to Pete at Textralia for his customer service.
  58. how steetable is a spec 4 clutch
  59. t56 question
  60. need help with mityvac and clutch bleeding
  61. Clutch break in
  62. Solved clutch stuck to floor...mabye
  63. HELP where to get t56 parts HELP
  64. Mcleod twin disk clutch question...
  65. Light or heavy flywheel?
  66. McLeod bellhousing problems
  67. Complications after a4 to m6 swap?
  68. Centerforce guys inside
  69. Viper bellhousing
  70. Ram Adjustable Master Cylinder
  71. Pilot bearing removal/install
  72. HELP!Good pedal pressure but can't shift into any gear from a stop.
  73. Which flywheels will work with an ls7 clutch?
  74. Stock T56 bellhousing
  75. help with lt1 clutch install
  76. T56 vs Viper 6 speed
  77. Test drove m6 somthing weird?
  78. M6 got stuck in 4th, need help ASAP
  79. can anyone get EXEDY replacement discs?
  80. LSS question
  81. 2nd pilot bearing TRASHED on C5! whats happening?!?
  82. car wont go in gear after line lock install..
  83. Flywheel Question
  84. new clutch help!!!
  85. 6 Speed Refill Question
  86. Is my clutch sliping?
  87. clutch help
  88. ratcheting (sp?) type noise....
  89. clutch problems?
  90. P0704...guys that have done the A4->M6 swap
  91. LSS Thread Size
  92. Troubles Pullin out a t56
  93. Issue with drill mod.
  94. Will this Tranny Fit?
  95. Do I need a flywheel?
  96. Difference in steel flywheels?
  97. clutch install
  98. rattle when i push the clutch in??
  99. where do i get the.....
  100. Z06 clutch in a regular Vette?
  101. Air in Line?
  102. SPEC 5 out/new clutch in
  103. Weak petal
  104. What are the signs of a bad trans mount for a m6
  105. Weight of a T56
  106. SES light after skip shift eliminator install
  107. Tranny work
  108. Factory Clutch Life
  109. Clutch makes a ticking sound
  110. Spec Stage 3 Or 3 Plus
  111. Clutch disconnect
  112. Automatic to manual
  113. clutch feel
  114. Whats wrong with the slaves?????
  115. Ring in tranny
  116. reverse lock out?
  117. Clutch Cable
  118. 95 firebird M5 trans.
  119. New Slave?
  120. Clutch question.....
  121. Is there a difference?
  122. Assembling T56: Can't get extension housing on
  123. look what came out
  124. Double cone vs Triple cone design?
  125. How Much Fluid
  126. Easy as Pie
  127. Pilot bushing, is lube required?
  128. Spec 4 guys inside
  129. Questions about Spec II in LT1
  130. sometimes no reverse
  131. What's the latest and greatest daily driver/strip warrior clutch for 600+rwhp?
  132. Alignment key
  133. any tricks to putting tranny fluid in a T56?
  134. Clutch Suggestions ???
  135. Pro 5.0 installation
  136. my spec stage 3 DEFECTIVE?
  137. Where exactly is the clutch bleed valve (already tried "search")
  138. Experts In Here!!!! Help!
  139. Starting M6 w/o Trans
  140. is this the solid bronze pilot bearing (pics inside)
  141. What size nut for the bottom of tranny mount?
  142. Need Help
  143. POST MORE INFO on LS7 clutches
  144. what about an aftermarket flywheel
  145. Replacement to the LSS
  146. strange noise...need advise
  147. Please help me with some diagnosis of my tranny problem...
  148. Just installed a SPEC II problems!!!
  149. OEM clutch questions?
  150. 4 hours of bleeding - no trans engagement (yes I searched)
  151. Help me pick a rebuilt T56.
  152. It wont ENGAGE!
  153. Just installed Mcleod bellhousing
  154. SPEC 3 TOOK A CRAP @500 mi.
  155. Changing Fluid?
  156. Spec stage 4 Sweet clutch
  157. trans help quick!
  158. Upgrade Master Cylinder?? (550+ rwhp)
  159. Best Aftermarket Shifter??
  160. i cant shift
  161. Textralia OZ700 clutch destroyed in my car. Bad clutch or install?
  162. Spec Stage III clutch installation doc
  163. HELP!! Replacing clutch - pilot bearing question
  164. Clutch Problems...
  165. Oil coming out of flywheel bolt holes?
  166. ws6 shift knob?..
  167. Is there anything that can cause a shifter
  168. SPEC Clutch GP
  169. Need Help PLEASE!!
  170. trans input shaft
  171. Installed LS7/LS2 Clutch and Flywheel. My comments and questions.
  172. PILOT BEARING PROBLEM!! (SPEC II install)
  173. Need help picking between two clutches..
  174. need a new slave cylinder
  175. Need Help! Oil in bellhousing???
  176. Spec 3
  177. torque specs on clutch
  178. NEED CLUTCH ASAP....which one??
  179. driveshaft removal
  180. Mcleod pilot bearing install
  181. Trans sticks in gear upon hard accel: 1st, 2d or 3d
  182. SPEC is dead
  183. Striped The Crank Threads!
  184. Joe @ T56 Rebuilds, thumbs up!!!
  185. Difference in master cylinder..
  186. Thanks Ls1Joe
  187. T56Rebuilds.com Feb. Special. You Decide what I will offer!
  188. Clutch bleeding, 2002 Camaro T56
  189. Spec Stage 3+ Just Installed Opinions/Problem?
  190. Bought a clutch from ebay, how to verify what I got?
  191. T56 question plz help!
  192. Harlan 2-Step for Powershifting?
  193. short shift kits...
  194. fidanza flywheel
  195. Mr. Transmission screwed me
  196. Ticking Noise
  197. T56 Vent hose?
  198. Part number of upgraded slave?
  199. Tranny build up questions, t56...
  200. tranny problems?
  201. slave cylinder line
  202. wiring harness swap.
  203. Pro Shifted?
  204. Mcleod Twin Disc Problem
  205. Grind input shaft splines or hone-out throwout bearing retainer????
  206. what is up with reverse?
  207. Scattersheild
  208. what clutch???
  209. LS7 clutch installed today
  210. i smell clutch
  211. 2 problem!
  212. Finally burn't a SPEC 5 clutch
  213. removing t56
  214. Transmition output shaft?
  215. clutch confusion!
  216. Looking for new clutch!
  217. why do u use a ls2 flywheel with the ls7 clutch on ls1's?
  218. 2002 master and slave questions
  219. clutch upgrade
  220. Syncho Cost
  221. Anyone wo has ran a SPEC Clutch Come In!!!
  222. C5 clutch install
  223. Ordered a new Luk clutch and have Q's
  224. Looking for Syncromesh? Go to Autozone!
  225. Is it worth it
  226. t56 clutch replacement
  227. Possible Purchase: 98Z - HELP!
  228. 500rwhp ocasional 200 shot. what clutch
  229. would a bad slave cause this?
  230. grinding noise
  231. slipping clutch???
  232. Umi short shifter handle installed.
  233. reverse trouble
  234. Hurst Billit Plus shifter
  235. leaking hydraulics/clutch questions
  236. Need help with tranny install!!
  237. I need a T56 that can handle 700/700
  238. Awaiting my Textralia!!
  239. What's the difference
  240. 3 days and WHAT THE F@#k!!!!
  241. LS7 clutch swap...worth a sticky?
  242. Flywheel/PP torque???
  243. anyone know about 1999 slave cylinders?
  244. shift knob removal
  245. Adjustable Master
  246. Mcleod Clutch (LT1)
  247. howto for slave cylinder install
  248. GM Flywheel weights
  249. Anybody want an MN12 upgrade?
  250. i wanna do a t56 swap from A4
