PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. t56 swap help
  2. MGW Shifter - No Limit Stops
  3. How do i get ahold of Textraila ?
  4. any info for monster half stages?
  5. What Flywheel with Spec 3?
  6. what trans for H/C/I car?? mm6 or mn12?
  7. Ram Powergrip HD clutch
  8. Leak/1st gear issues
  9. Another Monster/Tick success
  10. HELP! Clutch hydraulics failed
  11. HELP throwout bearing part # needed
  12. Need input on Monster stg 3
  13. monster clutch in and it feels great and the tick master rocks
  14. 96 ws6-need a new clutch! need some input....
  15. correct autozone slave?
  16. how do you launh your 6speed, help this newbie hook
  17. Bent 3-4 Fork. Upgrading, need advice.
  18. post pro 5.0 install... some newb ?'s
  19. weird noise in 6th gear
  20. 500 mile break in, how important?
  21. what shifter to buy!!
  22. T56 Swap, price?
  23. Removing tail housing in car ...
  24. Did Spec change their PP design?
  25. Looking for a new worked T56 for Nitrous Vette
  26. Clutch chatter ???????
  27. Another question about my clutch swap...hydro question
  28. SFI #'s for Monster Clutch
  29. clutch pedal help???
  30. a4 to m6 question
  31. Help with taking the bell housing off
  32. T56 Interchangable parts? LS1/LT1 fbody, Vette, GTO
  33. LS1 T56 to LT1
  34. Camaro vs. Corvette internal slave
  35. Monster Flywheel question
  36. brakes are stiff (makes it hard to drive)
  37. Clutch Which one i am new to ls1 6 speed
  38. "Wheezing" bearing noise
  39. Short Stick for B&M Ripper?
  40. TKO600 5spd syncro crunch uprated parts?
  41. First time mityvac user here. Hate to start new thread.
  42. Do they make a Dog Box for the LS1 Fbody?
  43. Help: clutch slippage problems during roadracing
  44. t-56 issues (noob)
  45. anyone ever had this happen??
  46. Pilot bearing install question...
  47. noob here please help
  48. T56 Wiring question...
  49. Monster LVL 3 and chromemoly flywheel on!
  50. what is this?
  51. TR-6060 (or t-56 magnum)
  52. what's the purpose of this "hose"
  53. Clutch pedal return spring
  54. double cluthing
  55. 6 speed swap questions (5.0 shifter, and rls)
  56. Is my master Cylinder done?
  57. Do you like your shifter angled towards you?
  58. Master / Slave measurements
  59. My pet monster!
  60. Dot 5 BF can't be mixed with dot 3?
  61. Noise in t56 gto tranny in TA
  62. m6 problems any ideas ?
  63. G.t.o t-56
  64. In middle of LS7 clutch swap, need help
  65. Gmt 56
  66. Small leak from rear of tranny ....
  67. trying to find a tranny builder
  68. does anyone maybe know why 2nd gear not working
  69. clutch bleeding - bad slave ?
  70. Leak from rear of tranny. Need input
  71. Squeak when pulling out
  72. Had it with this Monster Clutch
  73. Shifter to T56 Bushing Question
  74. MN12 t56..what sensor is on the passenger side of the trans?
  75. Flywheel question?
  76. Difficulty level of installing slave cylinder?
  77. 1998 6speeds into a 1996 5 speeds
  78. Questions about my trans/clutch job...new problem possibly
  79. Ticks Master cylinder installed?
  80. Oreilly Slave Cylinder
  81. TickShift trannies?
  82. Shifter off tranny??
  83. gto t56 in f-body, LOL as expected search didnt help.........
  84. what flywheels work with the ls7 clutch?
  85. SPEC LS9/ZR-1 Super Twin Billet Multidisc Clutch and Flywheel Assemblies
  86. Choose my clutch....
  87. please help diagnose tranny noise!! (video inside)
  88. 6spd People come in !!!
  89. '09 cts-v 550hp????
  90. what brake fluid is best for the clutch master
  91. Purpose of adjustable slave?
  92. clutch upgrade time, Please Chime in
  93. Short Shift Stick
  94. which one is the correct pressure plate bolt
  95. Part #Clutch Return Bushing
  96. clutch and pressure plate answer A.S.A.P.
  97. Stock Measurement ???
  98. Help: Clutch pedal Light all of a sudden?
  99. Question about mity vac bleeding from slave bleeder
  100. how much hp to the wheels can a stock t-56 with a good clutch withstand?
  101. Twisted splines on my Viper shaft
  102. After market T-56 rebuilds, MUST READ...
  103. Classic Tube Clutch line, Drop the tranny?
  104. Question on minimum horizontal distance in T56 removal
  105. problem with t-56 gears
  106. What sensor is this???
  107. How strong is a T56? Same T56 as in a Cobra?
  108. noob hearing "new" noise from Pro 5.0 shifter
  109. New Clutch Engages at the top...WTF
  110. drill mod coming up. wish me luck!!!
  111. Clutch noise when pedal is pressed down?
  112. Replace syncoro's in T56
  113. Possible dissengagement issue? Please comment
  114. Torque arm bolt specs
  115. shift knob
  116. Can someone give me a measurement off a T56 please?
  117. Cadillac CTS-V T-56 question
  118. Huge Clutch Issue (FML)
  119. Problem going into 3rd at top of 2nd.
  120. reverse lights
  121. Clutch not fully disengaging...yes ive searched
  122. SBC to LS1 trans?
  123. Do all cars have skip shift/removing from tranny?
  124. Problems after Tick master install
  125. what is this plug harness for?
  126. Car keeps on slipping out of third gear, or not engaging..
  127. Difference in T56?
  128. Ls7 clutch went up in smoke.....suggestions on upgrade?
  129. McLeod Master Cylinder Rebuild??
  130. Where to buy....
  131. Oreilly's Clutch Kit....?
  132. Popping out of first gear
  133. somethings wrong...
  134. weird bleeding experience
  135. Clutch line fitting
  136. how many bolts hold the t56 in place to the motor?
  137. Clutch Pedal Stiff After New Clutch
  138. clutch ?
  139. Need some help, bleeding clutch hydraulics, I searched(long
  140. mcleod RST twin
  141. Still Getting stuck in 4th after rebuild
  142. Aftermarket shifters causing shifting problems, Tranny Damage?
  143. Input shaft!
  144. t56 hydraulic issue
  145. shift lever diameter ??
  146. Best Place to Buy Mcleod Twin Disk
  147. Another Clutch reccomendation
  148. LS7 Clutch
  149. Getting ready to order Monster Stage 3 setup, what to order for the hyrolics?!?!
  150. more problems
  151. Does the LT1 Slave Cylinder have a bleeder?
  152. cags delete
  153. ls7 clutch in 04 gto
  154. reccomend me a clutch
  155. Pro 5.0 Shifter Rebuild?
  156. Advice on new setup
  157. How much for...
  158. Another trans issue!!!!!!!!!!!
  159. Clutch fluid change
  160. Clutch fluid boil point
  161. LPP bleeder install
  162. Convert a4 to m6 reflash
  163. Lifespan of a Spec 3 clutch?
  164. how to bleed lt1 clutch?
  165. Does anyone know the break-in period for a SPEC Stage 3 clutch?
  166. Fourth gear dosent go in???
  167. new slave, new master cyclinder.....still sticky clutch
  168. master cyclinder test
  169. Trans Fluid
  170. Hydraulics Issues?
  171. Monster Clutch
  172. Cannot get clutch pedal to unstick
  173. Monster Clutches help
  174. lq4 + t56 + spacer
  175. Stock Thread For Shift Knob
  176. What should I do?
  177. Which one is better Mcleod RST or Fidanza twin disc?
  178. mityvac question, slave bleeding.
  179. ls7 clutch guys come on in! ls7 an trans rebuild review!
  180. wont go into second sometimes
  181. chromemoly flywheel
  182. Six Speeds Inc.
  183. LS7 clutch question PLEASE LOOK AT THIS PIC
  184. T56 needs a rebuild
  185. clutch pedal spring broke???
  186. How to rebuild a mcleod master?
  187. Specific clutch pedal issue.. (hard pedal/spongey)
  188. noise from under shifter going over bumps in road
  189. All new Hydraulics, clutch and still some grinding?
  190. Manual Transmission Stickied Threads
  191. tolearnce tranny-driveshaft
  192. tips for changing clutch on t56
  193. Clutch Pedal Sticking
  194. Reverse Syncro
  195. Ls1 manual transmission ideas
  196. Need help quick , tranny install?
  197. help with pilot bearing
  198. Bleeding clutch, need fast help!
  199. Clutch pedel loose
  200. When to change tranny fluid?
  201. Which ones are my bell housing bolts?
  202. clutch switch
  203. 02 t56 rebuild ?'s
  204. 6 Speed transmission
  205. Where can I find a LT1 clutch line?
  206. 2004 gto t56 clutch install
  207. Launching on slicks with Spec 3+ Qs
  208. monster Clutch disc install??
  209. Hard to get T56 into reverse??
  210. Clutch pedal too firm?
  211. About to do the adj stock master and...
  212. converting from auto to manual transmission
  213. Should I Replace Mainshaft? *Pics*
  214. 5.3 to ford t5
  215. bad clutch sensor
  216. BMR crossmember not fitting?
  217. Problems w/ clutch hydraulics? LT1 T56 + RAM HD
  218. resurface flywheel or stock replacement?
  219. Who sells Faceplatted gear sets ?
  220. Where can I get a "tick" master?
  221. Shifting to 5th sometimes I grind reverse
  222. new slave cyl????
  223. Spec Dual Clutch
  224. Gear rattle or imput shaft bearing
  225. LS6 Clutch Replacement
  226. New slave cylinder looks different - ok? pics
  227. luk clutch help pics
  228. Do any of you guys get a SQUEAL when feathering your clutch into 1st?
  229. Inspection cover/Cover plate??
  230. Spec Stage 3+ and new 408
  231. Need to bleed your clutch by yourself...?
  232. Clutch pedal stuck to the floor
  233. Kevlar vs. Ceramic clutch material?
  234. clutch problem
  235. Changing clutch (ls7) - what all do I need?
  236. TICK performance master cylinder **installed**
  237. Clutch or possible transmission problem? Please need some input
  238. Transmission swap
  239. T-56 ??s
  240. Horrible clutch screeching when pedal is depressed
  241. TKO600 problem???
  242. spec stage 3+ or ls7
  243. spec stage 3+ or ls7
  244. T56 End Play Tool
  245. Manual Transmission Oil
  246. Do I need a blowpproof bellhousing or will my stock one hold
  247. harlan 2 step question.
  248. sixspeedinc.com??????????????
  249. ls7 breakin mileage
  250. LS7 clutch...
