PDA
View Full Version : Manual Transmission
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. LuK clutch on 2002 Trans am
  2. HELP!!! Tremec magnum f with McLeod rst clutch installation
  3. 94 lt t56 question
  4. Clutch pedal firm when car is off but sinks when car is running
  5. Will a tr6060 fit in an ls2?
  6. Nv3500 rebuild kit help please
  7. T56 problems
  8. 2000 Camaro Z28 - Air in clutch and won't get out
  9. T56 magnum rebuild lasted 10 miles
  10. 6.0 LQ9 with TKX
  11. Hydraulic slave cylinder
  12. T56 leaking from strange place
  13. Clutch line keeps popping out
  14. New clutch opinion
  15. Aftermarket release bearing vs stock
  16. Tailhousing swap question
  17. NEED HELP! T56 Reverse acting like neutral
  18. Anyone running Tilton ST-246 clutch?
  19. Reverse in cold start
  20. FBody T56 Mainshaft/Output shaft question.
  21. QT bellhousing problems
  22. t56 5/6/r issues
  23. Hurst Pro Billet Plus Shifter
  24. Clutch MC install
  25. Does this noise sound like clutch disk?
  26. Just my luck 🤬
  27. Clutch engagement
  28. z06 - T56 Transmission Hot Idle Engine
  29. Another T56 fill question
  30. 1996 LT1 T56 to LS1 T56 swap
  31. V6 transmission mount?
  32. Offset dowel pins
  33. Transmission install issues
  34. New Short Throw - Question about the old
  35. Throwout bearing shim how many
  36. Magnum-F owners; shifter choice
  37. Mm6 mn6
  38. 2002 Z28 automatic to manual tr6060 converison
  39. Does this flywheel machined surface look ok ?
  40. F-Body Clutch Options
  41. '01 WS6 T56 Service Schedule
  42. Manual swap shops in florida
  43. Yet another clutch replacement question
  44. T56 1st to 2nd Shift Woes
  45. Vibration only between 2700-3100 rpm with 40%+ throttle
  46. 2014 tr6060 hard lines, cooler recommendations needed.
  47. '96 T5 Hydraulic Clutch Line Replacement
  48. T56 magnum failure need help
  49. CD009 question
  50. Throw out bearing aftermarket
  51. T56 Clutch recommendation
  52. T56 drop out
  53. Cold transmission
  54. T56 clutch quick disconnect e clip
  55. Lt1 t56 to ls1
  56. After hard shift, won't go into 6th or reverse
  57. Quarter Master bellhousing.
  58. Clutch recommendations for the T56 tremec magnum-f
  59. Looking for a recommendation to have my 1999 T56 rebuilt
  60. Isuzu Clutch line
  61. 1500RWHP clutch
  62. T6/Tick MC clutch issue?
  63. Bell housing Alignment
  64. Lose Of Clutch At High RPM
  65. Struggling with high rpm shifts
  66. Transmission swap
  67. tremec magnum t56 f close ration tuet 16362
  68. Clutch interchange question!
  69. Kinking hydraulic resivoir to MC hose?
  70. Measuring slave cylinder gap: shim or no shim
  71. Poor man's Magnum T56?
  72. No wonder that clutch didn't feel so great
  73. Gen5 lt1 tr6060 with ls engine questions
  74. Lt1 gen V tr6060 compatibility.
  75. Tailshaft seal question
  76. Shifting noise
  77. Mcleod Clutch Fitment
  78. Magnum F ratios
  79. T10 transmission
  80. Clutch recommendations
  81. MityVac question, is this normal
  82. HELP! clutch position/cruise control switch out of my car does not match new part
  83. Clutch line isn't going into the slave
  84. 05 CTS V T56 transmission woes
  85. Will 4.8 LS work w/ borg warner T5?
  86. Ford tko600 to gm input shaft swap
  87. manual engine harness to auto car help!
  88. Issues bleeding my t56
  89. Slave cylinder issue
  90. T56 gets stuck in reverse
  91. noisy clutch when first starting
  92. Hurst T Handle Removal
  93. Is this a ls7 clutch?
  94. T56 inspection
  95. tr6060 clearance questions
  96. T5 Movement under load
  97. T56 Output Shaft Sealant
  98. Ruff shifting
  99. t-56 got stuck in 4th
  100. T56 questions
  101. T56 swap
  102. T56 going “through” gear under heavy acceleration
  103. Help identifying a T56
  104. Ls 6.0 to 5spd trans help
  105. Clutch pedal return spring.
  106. Room to work
  107. T56 dust shield with aftermarket oil pan?
  108. Aftermarket LS7 clutches with stock pedal feel
  109. Slave cylinder travel
  110. T56 Clutch sporadic engagement
  111. Also posted this in electrical. Maybe some one will see it here.
  112. Tremec Magnum F constant clunk noise while accelerating
  113. 93-02 F-Body clutch pressure switch replacement
  114. Alternative to Quicktime RM-8027
  115. Help identifying Tremec T56 TUET14000
  116. LS1/ Muncie Issue Need Help
  117. Third(and Last) McLeod RXT vs. T56 Magnum input shaft
  118. C5 Corvette T56 Converted to LS Fbody T56
  119. Reverse Lockout Mod
  120. T56 magnum tq rating
  121. T56 Magnum/ oem ac delco front plate/bellhousing
  122. Help with slipping Mantic & adjusting Tick master
  123. Gear Recommendation
  124. Pilot bushing instead of pilot bearing?
  125. T56 bleed problems
  126. T56 Excessive Shimming?
  127. Hm290 troubles and struggles
  128. Clutch Master Cylnder U bolt
  129. Magnum f install question.
  130. Clutch Options
  131. Tilton ST-246 Clutch
  132. What T56 Synchromesh
  133. T56 won’t shift into 1st, 3rd, or reverse
  134. Input shaft binding once per revolution - LT1 to LS1 T56 Conversion
  135. Input won't spin by hand after main case install?
  136. T56
  137. Summit LS to T56 Bellhousing SUM-7001102
  138. Quick time Bellhousings
  139. Looking for a Clutch Recommendation
  140. Which gears should I replace?
  141. How do these gears and synchros look?
  142. T56 billet 3/4 synchro keys broke
  143. t56 rebuild shop recommendations in georgia/sc
  144. shelby tremec
  145. How do I calculate 1st gear ratio with diff (out of car)?
  146. Another T56 to L96 swap
  147. Options For Moving T56 F Shifter Forward?
  148. DIY- C5 Tick Master Cylinder Install
  149. Viper shifter on fbody t56?
  150. Lm7 manual trans options
  151. Squeaky clutch pedal 02 ws6
  152. Easy way to remove pilot bearing
  153. Identify this clutch?
  154. Clutch slave cylinder line stuck????
  155. Whats going on here, 02 trans am
  156. Some general Tremec information...
  157. New Mamo Motorsports Mantic twin clutch with pics
  158. 2.66 vs 2.95 1st gear for high hp
  159. LM7 Swapping a 1977 Triumph TR7
  160. Anyone have experience with RPM LVL 5,6,7 Trans
  161. Tr6060 to magnum tailhousing 2022
  162. Tick shifter vs MGW?
  163. Pilot bearing
  164. Clutch not disengaging in higher gears
  165. Clutch fluid level 02 Trans Am Ws6
  166. Clutch problem
  167. New Approach To Stick Shift Clutch Tuning
  168. Clutch Change Help
  169. LT1 T56 - Can I pull the clutch fork and t-bolt without dropping trans?
  170. Clutchforece street twin or Dyad
  171. Mating a Corvette ZF6 to an LSx
  172. T56 shifter relocation
  173. Muncie trans on a ls engine
  174. How do these gears and synchros look? T56 rebuild
  175. Mcleod RXT - do I HAVE to balance?
  176. CTS-V T56 Shift linkage parts
  177. Lightweight clutch/FW combo recomendation
  178. Which clutch for lightweight street car on drag radials
  179. another t56 not bolting up
  180. Ls7 clutch noise
  181. S1 sequential shifter
  182. Auto to manual swap
  183. 93 Formula LT1 Trans Mount. Which Part #
  184. be gentle, first time t56 assembly -shift interlock assembly
  185. 4l60e no 4th gear
  186. Which fluid for rebuilt T56?
  187. clutch replacement 99 t56
  188. T56 question.
  189. This bracket??
  190. Starting Issue.
  191. 6.0 with LS7 clutch and flywheel and RAM TO bearing PARTS CHECK plz
  192. Getting the paint off my T56
  193. Clutch Drag ?
  194. Internal slave loose on t56
  195. T56 question
  196. so i stripped my slave cylinder threads, any ideas
  197. Mcleod Rst vs Summit Racing Twin
  198. t56 to 6.0 blazer
  199. Need Help: Potential T56 clutch failure?
  200. T56 Input/counter Shim out of stock?
  201. a normal 6 speed manual temp
  202. T56 Slave Cylinder Help
  203. Lightweight Flywheel
  204. Adding Temperature Sensor to TR6060
  205. TR6060 T/O wont bleed
  206. t56 Gear Position sensor/indicator
  207. Clutch speed bleed question...
  208. Cts-v t-56 + ls1 + ls7 clutch problems
  209. Ls1 + cts-v t56 + ls7 clutch issues disengaging
  210. 2000 WS6 M6 -slipping clutch or MC issue?
  211. Installed MGW shifter over the weekend, good lord.
  212. T56 use with 99-00 6.0 block?
  213. T56...which one is this
  214. Recommend Me A Clutch Please
  215. Clutch pedal position sensor - 1998 PCM to 411 PCM
  216. T56 grinding noise
  217. Slave Cylinder: Luk vs Chevrolet Performance vs Dorman
  218. Overthinking it or transmission issue?
  219. Vss signal
  220. t56 to lm7 questions
  221. Iron or steel flywheel?
  222. New slave/throwout with new clutch - might as well, or not worth it?
  223. Condition of pressure plate/flywheel
  224. Need a twin disk clutch that can shift at 7500
  225. Rev match for 4th gen
  226. Who runs a Mantic clutch?
  227. Ls1 + cts-v t56 + ls7 clutch problems
  228. Centering Transmission
  229. Yet again another clutch problem
  230. T56 from 05 GTO Neutral Safety
  231. Billet steel or aluminum flywheel for DD 550ish RWHP?
  232. LS7 clutch pedal pressure and engagement throw issues
  233. Sudden clutch pedal free play
  234. Need 6-speed shifter - mine is Worn Out
  235. Shimming synchros in t56?
  236. T56 F car transmission conversion parts hunt
  237. T56 shift rail guide bolt thread size
  238. Brand new clutch slipped.
  239. Ls3, '04 gto t56
  240. Monster LT1-S w/ Tick MC pedal feel
  241. Clutch chatter/squealing goes away with clutch bleed.
  242. T56 transmission stuck in gear, shifter moves through all gears
  243. Driveline angle. HELPPPP
  244. T56 output shaft bushing replacement?
  245. Reverse Failure
  246. Intermittent clutch problem
  247. Please help me solve this shifter grinding noise (video included)
  248. Clutch Noise - rotating engine by hand
  249. Any ideas why this damn thing won't seat?
  250. Bleeding Clutch Master Cylinder - Please help!
