View Full Version : Manual Transmission
- Bearing race removal - inner input shaft
- LS7 Clutch with 04 GTO flywheel
- Who uses Lou's Short Stick on their Pro 5.0?
- One piece T56 Countershaft (Z06/SSR) endplay clearance
- What are these connectionstill on a GTO T56 harness?
- 2 clutch slaves bad after rebuilt transmission
- LT1 Pilot Bushing
- LQ9/T56 magnum clutch questions
- Which T-56 Reverse Blocker Ring to Use?
- 04 GTO T56 issues! HELP!
- Keeps Popping out of reverse??!!
- F-body T56 input shaft > GTO T56 possible?
- School me on speed shifting
- Hinson Motorsports or MGW shifter?
- T56 question GTO? Camaro??
- Quicktime bellhousing, spacer plate
- How long should pilot *bushing* last?
- Transmission help for my 5.3 swap.
- Rounded Flywheel Bolt (Easy-out?)
- Play in clutch pedal, when cold
- Everything new out of ideas
- slave travel
- Replacement for LS7 clutch?
- Anyone running an ACT clutch?
- Clutch petal sticking/rough only when engine is running
- T56 Sudenly Hard To Get Every Gear!
- [VR] PPG Sequential Installation and Testing - 474ci Naturally Aspirated C5 Z06
- Luk-04-905
- Help T56 noise! Working Video
- Should I rebuild my transmission?
- Slave Cylinder Issue
- 900 hp turbo drag car clutch help
- Transmission or clutch/master cylinder?
- What color wires to the cags/skip shift solenoid?
- 4th gear issues, very hard to get in or out.
- spec will not help me out
- Necessary clutch movement?
- tr-6060 wont come out of gear
- grinding noise!!!!
- How do you break in an engine with a brand new clutch?
- Mcleod pilot bush
- TR6060 Flywheel and Clutch work with T56?
- Triple synchro blocker question
- GTO Shifter on F-body T56 Question
- Ram flywheel insert
- Help: Issues with shifting after new clutch install
- Remote reservoir hose Q...
- 02 t56 clutch clunk
- What kind do I have???
- T56 tail shaft leaking what sealant
- Need Help Finding A Slave Cyl For T56.
- Another clutch bleeding thread, sorry
- Driveshaft won't fully engage over mainshaft!!
- Pressure plate diaphragm spring
- rebuild kit questions!
- Shifter gets notchy randomly. Any ideas?
- HELP: LS3 + T-56 + LS7 clutch - issues
- GTO t56 price???
- A4 to T56 swap, flywheel balancing question
- T56 input shaft diameter/pilot bearing
- LT1-LS1 Input Shaft and Front Plate - HELP!
- Slave cylinder connector
- Spec 3+ Drag Racing
- Northern Ohio rebuild
- Clutch bleeding issues
- T-56 Decelerating Noise in 5th-6th
- RPS clutch going in this weekend *Pic heavy*
- Flywheel Dimensions ???
- t56 not shiftng into 5th?
- high mileage T-56 shifting weird? ideas-recomendations
- Master Cylinder to Slave Disconnect: Help
- Bye ls7 and hello Lt1-S
- Openings into the Bell Housing
- anyone know the techinical data on fbody? clutch ratio and bore size.
- Trans Tailshaft leak, MWC 9, PST DS
- Is this fixable?
- LS1 Clutch upgrade
- T56 grinds 1-2 locks out of 3rd WOT
- Clutch Slip and Stiff Pedal at High RPM WOT - 2005 CTS-V
- Tremec T56 Magnum won't mate to Ls7 crate engine
- Clutch choice: Best bang for buck
- Stock t-56 shifter
- Please help ID this pressure plate & clutch
- clutch pedal sticks halfway (at engagement point) after tick MC install
- LT1 Spec Stage 3 Questions.
- Gto MN12 T56 exploded view or manual?
- Right clutch choice for me?
- What is the benefit of carbon blocker rings & micropolish internals
- T56 magnum - tick vs D&D
- Quick disconnect o-ring?
- Tick Master Cylinder fitting failure
- level 2 8.5 monster clutch just started slipping
- Clutch for my 70 year old father?
- Build my t56 or drop coin on tr6060????
- Anybody have an SSR Tailshaft housing for sale by chance?
- Another clutch/bleeding issue
- Dowel pin wont stay
- McLeod RST Hot Spots after only 1000 miles
- Tick Master installed Adjustment question
- Can lightweight/aluminum flywheels cause jerky cruising?
- T56 rebuild in Delaware
- Has anyone used the gearbox.org stage 2 t56 rebuild kit????
- Clutch Recommendations for T56
- T56 not wanting to take 3rd gear wot
- Monster 11" ceramic slipping at moderate rpms?
- I need a clutch and got 1k to spend
- Happy with Monster LT1-S
- help id this transmission
- 01 Z06 Torque tube ????? Help please
- Are all Slaves created equal?
- T56 Re-build 3-2 downshift lock out
- What to do, slave cylinder release clip broke
- Another whats it worth thread sorry Built T56
- ram clutch doesn't feel right
- 6th Gear Issue
- Clutch issue (Monster LT1 Twin Disc)
- 6 speed with radial launching??
- Main/imput Shaft t56 need help
- Shift rail confusion
- T56 Reverse Light Switch as an Oil Return
- Rock auto clutch kits
- Can I power wash my T56?
- T56 Specialists & GURUS NEED HELP! TUET6400 MYSTERY?
- What makes for an easier driving clutch?
- T56 6th gear issue!
- clutch help please.
- Need to find 5th and 6th gears
- Monster LT1-R or Mantic 9000
- Synchro Trouble
- T-56 help
- Has anyone had problems getting the 5/6 cluster gear on?
- New clutch/pp/flywheel, not disengaging
- Syncro keys broke help
- T56 Magnum Stock Shifter
- Choosing a manual transmission oil for T56 and others
- Tr6060 question
- Trans swap help!!! If anyone can help me, the LS1Tech crew can!
- Adjustable Clutch Master Cylinder
- CTSV t56 v f body t56
- T56 Limit
- LSX Block & T56 Magnum
- Lt1 t56 problems
- Quest to find the best clutch for my needs
- Humor the new guy, clutch questions
- Starter to flywheel problem.
- 01 T56 F-body, Reverse cage bearing failure (Twice!)
- Girnding/vibration HELP!
- 3rd and 5th gear grind
- low pedal after monster clutch install
- Shift knob style?
- Transmission problems
- Thinking about dumping LS7 clutch and stock flywheel
- Resurrecting a nearly dead T56 with liquid synchronisers.
- quicktime housing tko 600 clutch confusion
- Clutch/flywheel recomendations, please...
- 4l60e interchangeablity
- ls6/ls7 clutch kit?
- Clutch to flywheel air gap? LS7
- 2000 Camaro clutch pedals
- T56 Problem Need Help!!
- Trying to decipher numbers on T56 3rd gear
- T56 Conversion help.
- Lets hear some recommendations on my next clutch.
- 3rd gear whine at low rpms
- 98 T/A convert manual to auto
- t56 whine
- Monster clutchs? $$$
- Slave cylinder lasted 40 miles? HELP!
- New clutch, noise, shudder, driveline shudder? monster stage 2
- TR6060 SFI bellhousing
- What's the going price on a T-56
- How to test a used t56 out of a vehicle for issues.
- 2 blown new slaves? Help please
- McLeod RXT on standard flywheel?
- Leaking Tiltons
- Someone please enlighten me on proper clutch/slave clearance
- Sequential Tranmission on the street
- Cts-V shifter
- Any sponsors/vendors have a CF driveshaft for C6 in stock?
- T56 aftermarket shifters?
- 2001 Z06 T56 rebuild Help
- 05 l96 6.0 vortec to t56 tran (flywheel and clutch)?
- Transmission and vibration wows
- 6spd grinds at high RPM
- O-Ring Size on the hydraulic line quick connect fitting
- Anyone regret face plating?
- Luk clutch busted on me after 2 weeks of use.
- New Monster slipping @4k rpm
- Is my clutch or trans going out?
- T56 sensor?
- Gearbox video
- t56 noise when off the ground
- How to confirm t56 gear ratio
- CTS-V shifter to F body shifter swap?
- Brand New Slave Cylinder Leaking?
- Pilot Bearing Removal Question
- Time for a new clutch, have a few q's
- Pentosin LOW VISCOSITY DOT 4 in clutch hydraulics?
- Hig torque clutch? Mcload RXT fried
- Difference between Monster LT1-S,SC and R
- My McCleod Throwout Bearing is leaking BAD what other would you use to replace?
- Shim stack up question
- T56 behind LSA
- T56 Magnum disassembly advice
- Gear puller for t-56 rebuild
- McLeod Clutch???
- clutch help on 99 frc vette
- clutch isn't disengaging ... hydraulic issue..
- Clutch School
- t-5 Borg warner on LT-1
- T56 input shaft dimensions or bad shaft needed
- LT1 to LS1 T56 conversion question
- Running a T56 on a ls1 with fewer bellhousing bolts
- wondering what its worth
- need help diagnosing tranny/clutch THANKS IN ADVANCE
- Odd Tick MC, and LS7 Clutch issue
- Hose popped off the slave and pedal got stuck up
- Will a C5 gm slave cylinder work in an F Body T56?
- Importance of details & longevity, 8+ seasons Spec 3+
- Dilemma, push it, or replace it and with what?
- keep my monster 11inch or go rxt???
- Removing mangled pilot bearing suggestions needed
- 2013 C6 TR6060 Vibration in 2nd gear
- Fitting for a cts-v slave cylinder
- Don't Be Let Down By The Gifts You Get This Year. Tell Them To Get You This
- Pilot Bearing and Input shaft trashed
- Clutch goes down 1/2 way, then rock solid?
- Are Ram clutches any good?
- TR6060 rebuild questions
- New clutch install questions
- Best place for t56 rebuilds?
- Bronze shifter cup cause more noise?
- Transmission help
- Removing pilot bearing
- Whining noise with clutch out.
- has anyone used an st1200 with a ls?
- How to bleed LS1 T56 clutch?
- HAWKS Sinister T56 6-Speed Billet Short Throw Shifter
- Black Fri-Cyber Mon at Tick is HUGE: Centerforce, Edelbrock, Holley, K1, Wiseco, MORE
- Monster Clutch Co. Holiday Sale!!!!
- Bad 2nd gear or Synchro???
- MGW & Hinson throw shfter
- Problems going into gear
- Hinson Short Throw Shifter Black Friday Cyber Monday Sale
- T56 Advice
- Can't pass rev test, McLeod RXT, Tick MC
- RPS Lightened Carbon Twin Disc Install / Review
